edisonr
10-24-2003
DIY: 2.5L Oil Change with Pictures | « » 2:01 PM 4-22-2006 | |
This oil change DIY is just for reference, there is more information around, but I felt that there were not enough pictures of the critical steps (if you can say that).This is not a guide and I am not resposible for any damage to your car caused by following this DIY. I did my wife's 2005 2.5L Jetta first oil change at 5K miles and this is what I did: 1. Raise the front of the car by either using ramps or a jack stands.
2. I used Mobil-1 0W-40 since it complies with VW standards.
3. You need to remove the lower cover, a standard torx bit would do.
4. Here is a picture of the rear drain plug and the oil filter housing
5. Remove the oil cap on the top of the engine. Drain the oil by removing the drain plug, be careful since it can be hot. To make this easier, run the engine before hand, since hot oil will flow easier.
6. This is the drain plug, notice the washer is part of it and can not be replaced. The dealer told me the drain plug can be reused and should be replaced every third oil change. Screw back after the oil has been drained out of the engine.
7. To make my life easier, I bought a 74/76mm oil filter cup. It works like a charm
8. Drain the old oil by pushing in the little nob on the filter housing (you have to remove the small cap to see it) 9. Remove the filter housing using the filter cup
10. Replace the o-ring inside the filter housing, the new oil filter should come with it.
11. Insert the new filter cartridge.
12. Screw back the filter housing to 25Nm tq. 13. Pour new oil (6.2qts) 14. Check oil level 15. Start engine and check for leaks. 16. Have a Let me know if the pictures are too big and need to be resized.
Modified by edisonr at 5:31 PM 4-25-2006
2008 Chevy Avalanche ... Mine 2006.5 Jetta TDI DSG ... Hers 2007 Mazda Miata Touring ... Ours 1995 Golf Sport ... NASA GTS1 Kermit Racing
Dan Halen
5-16-2002
Dougal County
06 GLI, 08 Rabbit
» | « » 2:06 PM 4-22-2006 | |
FAQ'd- thanks for taking the time to write this up.
D-E-F-I-N-I-T-E-L-Y. No "A". Anywhere. Definitely.2006 GLI .:. 2008 Rabbit S MkV Forum New User Information :: MkV FAQ & DIY Guide
acrossthepond
11-27-2005
London
2006 MK.V Golf GTI. DSG
Re: DIY: 2.5L Oil Change with Pictures (edisonr) » | « » 3:32 PM 4-22-2006 | |
Thanks for the write up / photos .. useful aid.
BrianGriffin
9-15-2005
STL MO
06 GTI MkV 6MT
Re: DIY: 2.5L Oil Change with Pictures (edisonr) » | « » 4:00 PM 4-22-2006 | |
| Quote, originally posted by edisonr » |
Gotta love Juan Pablo on the Mobil! Great DIY - Keep up the good work!
| Quote, originally posted by rpmk4 » | | i would hyabusa all over her face |
Yevi
12-6-2005
Wilmette IL
06 Jetta, A4 Avant, 88 GTI {RIP},
Re: DIY: 2.5L Oil Change with Pictures (BrianGriffin) » | « » 1:48 PM 4-24-2006 | |
Grear DIY, out of cusriosity how much would you spend for oil, and filter rather than take it to the service-Yev
B5 CREW ██████ LIVERPOOL F.C.██████ YOU WILL NEVER WALK ALONECEL STATUS: ON
digitalhippie
4-21-2004
Stamford CT
2006 GTI 2.0T, 2001 Jetta GLS 2.0L (sold), 1993 Golf GL 2.0L (sold)
Re: DIY: 2.5L Oil Change with Pictures (Yevi) » | « » 2:35 PM 4-24-2006 | |
| Quote, originally posted by Yevi » | | Grear DIY, out of cusriosity how much would you spend for oil, and filter rather than take it to the service |
Filter is about $10-11 (www.germanautoparts.com) Oil, for Mobil1 0w-40, about $30-35 depending on where you get it (Autozone, walmart, whatever) Dealer will charge between $70-90 for the same service. Plus... on my GTI... did my first oil change 2 weeks ago, put Mobil1 0w-40 in... and I'm getting better gas mileage than I was on the factory oil Good DIY, intersting that the filter housing is different than the GTI's... but I do believe the filter element is the same! Also, for anyone who wants to put a magnetic drain plug in... the drain bolt is 14x1.5mm
Modified by digitalhippie at 2:38 PM 4-24-2006
VAG-COM Scans/Mods available (HEX+CAN) 2006 GTI 2.0T, United Grey, 6MT PKG2+iPod and then some 2001 Jetta GLS 2.0L (AEG), Tornado Red - 143+k miles (sold) 1993 Golf GL 2.0L (ABA, OBD-I), Teal/Green - 158+k miles (sold) http://www.myspace.com/digitalhippie
Shrek2005
11-2-2004
Ivyland PA
2006 Jetta VE 5 speed
Re: (BRM10984) » | « » 7:18 PM 4-24-2006 | |
Thanks, this is great. I'm going to reach 5K miles soon and bought Motul 0W-40 oil. I am wondering if it is a stupid idea to get the tool in the attached picture because it is $79.50. Obviously you should drain the filter housing prior to removal but I am concerned about getting oil all over the place without using this drain tool but I really don't want to spend the money.
digitalhippie
4-21-2004
Stamford CT
Re: (Shrek2005) » | « » 7:20 PM 4-24-2006 | |
The tool is a TOTAL waste.Use a screwdriver to push the center piece of the drain valve up-and-over... you can catch it on the lip of the housing and the oil will drain straight out. Once done, just push it up again, and let it snap back into place. No big mess, not worth $70-90 for that tool.
Shrek2005
11-2-2004
Ivyland PA
Re: (digitalhippie) » | « » 7:18 PM 4-25-2006 | |
| Quote, originally posted by digitalhippie » | | The tool is a TOTAL waste. Use a screwdriver to push the center piece of the drain valve up-and-over... you can catch it on the lip of the housing and the oil will drain straight out. Once done, just push it up again, and let it snap back into place. No big mess, not worth $70-90 for that tool. |
Yeah but does the oil run down the screwdriver and drip all over your hand?
digitalhippie
4-21-2004
Stamford CT
Re: (Shrek2005) » | « » 12:52 AM 4-26-2006 | |
| Quote, originally posted by Shrek2005 » | Yeah but does the oil run down the screwdriver and drip all over your hand? |
Nope. You don't leave the screwdriver there while draining, just a quick push to open the valve... then another push to close it... as I already said, no real mess. That tool is a waste of $80.
Shrek2005
11-2-2004
Ivyland PA
Re: (digitalhippie) » | « » 7:56 PM 4-27-2006 | |
digitalhippie
4-21-2004
Stamford CT
Re: (Shrek2005) » | « » 8:21 PM 4-27-2006 | |
Is there an echo in here? I already answered your question
lateral_g
3-17-2003
Saugus Ca
2006 Mk5 GTI
» | « » 12:18 PM 5-6-2006 | |
The 2.0T is it at 5 quarts?
Anand@4induktion.com
8-25-2001
Annapolis MD
2008 Golf 20v
Re: (lateral_g) » | « » 12:38 PM 5-6-2006 | |
| Quote, originally posted by lateral_g » | | The 2.0T is it at 5 quarts? |
Yup, 5qts brings it to the upper 1/3rd of the "OK" area
Anand '08 Golf 20v - GIAC | H&R | Koni | H-Sport Induktion Motorsports - 410-684-3900 - For all your Audi/VW/BMW/MINI/Porsche aftermarket and service needs! Follow us on: Twitter | Facebook Folding@Home to Find a Cure!
camjr
11-19-2005
Lewisville TX
Bone Stock 1991 Mk II Jetta, 2006 MkV 2.5 Spice Red Jetta
Re: DIY: 2.5L Oil Change with Pictures (digitalhippie) » | « » 3:22 PM 5-6-2006 | |
| Quote, originally posted by digitalhippie » | Filter is about $10-11 (www.germanautoparts.com) Oil, for Mobil1 0w-40, about $30-35 depending on where you get it (Autozone, walmart, whatever) Dealer will charge between $70-90 for the same service.
My dealer charged $59.95. for the service with Castrol Syntec 5w-40, plus a wash, top off washer fluid. Worth it! Modified by camjr at 12:23 PM 5-6-2006
mujjuman
7-29-2004
Albany NY
01 Jetta VR6, 06 Jetta 2.5, 03 heated seats
Re: DIY: 2.5L Oil Change with Pictures (camjr) » | « » 4:56 AM 8-8-2006 | |
| Quote, originally posted by camjr » | My dealer charged $59.95. for the service with Castrol Syntec 5w-40, plus a wash, top off washer fluid. Worth it! Modified by camjr at 12:23 PM 5-6-2006
x2 personally
mujjuman 2001 Volkswagen Jetta VR6 + 2006 Volkswagen Jetta 2.5
| Quote, originally posted by kraut_pauer79 » | | wow, junkyards look like enchanted forests where you live. |
http://vwvortexsearch.webs.com/ < vwvortex search
dwilkinsjr
3-29-2006
Re: DIY: 2.5L Oil Change with Pictures (edisonr) » | « » 5:55 AM 8-8-2006 | |
| Quote, originally posted by edisonr » | | 6. This is the drain plug, notice the washer is part of it and can not be replaced. The dealer told me the drain plug can be reused and should be replaced every third oil change. |
Is this really necessary to change the complete drain plug? It does not look any different than a MKIV plug and what we did when I worked for VW as a tech was to take a pair of dykes, cut the original washer off and put a replacement washer on. The dealer should have replacement washers to do this. Replacing the whole plug seems a bit excessive to me.
gotta_jet
2-10-2002
Hanford/Fresno CA
2008 Batmobile, Cannondale Capo, CAAD9
Re: DIY: 2.5L Oil Change with Pictures (camjr) » | « » 6:15 AM 8-8-2006 | |
ehh...we've all heard too many horror stories to allow anyone but ourselves do something as seemingly simple as change the oil
Fents, crubs, and burshes."...if the cops get in the way, we're gonna roll right over them."
TDI-4-RD
5-12-2006
Hamilton NY
2006 Jetta TDI (North Sea Green)
Re: DIY: 2.5L Oil Change with Pictures (gotta_jet) » | « » 10:18 AM 8-8-2006 | |
| Quote, originally posted by gotta_jet » | ehh...we've all heard too many horror stories to allow anyone but ourselves do something as seemingly simple as change the oil  |
Plus letting the dealer wash your car is dangerous! Don't get Thread or Brian started....
Euro LED taillights, amber mode, aspherical mirrors, Isotta steering wheel cover, various VAG-COM mods; DieselGeek Skidplate; Hella Dynabeams. Fifteen is my limit on schnitzengruben . . .
dudleyrabbit
7-29-2006
Oakville ON
2007 RABBIT 2.5
Re: DIY: 2.5L Oil Change with Pictures (edisonr) » | « » 10:28 AM 8-8-2006 | |
I read on another thread that the oil filter cap threads are reversed ie. to remove the cap have to be twisted in CW rotation. Is that true or the guy who said it was just trying to screw anybody up? Does the filter unscrew CCW or CW?
electricme
8-8-2005
Hershey PA
My Cars-06 SHADOW BLUE GLI...
Re: (Anand@4induktion.com) » | « » 10:37 AM 8-8-2006 | |
| Quote, originally posted by Anand@4induktion.com » | Yup, 5qts brings it to the upper 1/3rd of the "OK" area  |
The manual says 5.8 quarts? That what I put in the car and it is right where is is supposed to be! The 1.8t's were 5 quarts!
To alcohol! The cause of - and solution to - all of life's problems! CePAvw... WE ROLL DEEPER flickr
electricme
8-8-2005
Hershey PA
Re: DIY: 2.5L Oil Change with Pictures (dudleyrabbit) » | « » 10:40 AM 8-8-2006 | |
They are NOT reverse threads... the picture on the housing is decieving... I tryed it reverse and almost broke the nut part of the housing off!
VW-fani
11-24-2005
Tampere Finland
OUT- 2005 Golf V 2.0TDI 4MOTION IN- 2007 Passat 2.0TDI 170HP
Re: DIY: 2.5L Oil Change with Pictures (camjr) » | « » 10:40 AM 8-8-2006 | |
I guess its worth it but comparing Syntec 5W-40 to 1 0W-40 is like comparing bananas to apples!!! They are completely different kind of lubricants and Syntec is only a semi-synthetic lubricant (correct me if I have it wrong). You should compare Mobil 1 0W-40 price to Castrol's fully synthetic 0W-30's price in order to compare similar kind of products.
electricme
8-8-2005
Hershey PA
Re: DIY: 2.5L Oil Change with Pictures (dwilkinsjr) » | « » 10:40 AM 8-8-2006 | |
| Quote, originally posted by dwilkinsjr » | | Is this really necessary to change the complete drain plug? It does not look any different than a MKIV plug and what we did when I worked for VW as a tech was to take a pair of dykes, cut the original washer off and put a replacement washer on. The dealer should have replacement washers to do this. Replacing the whole plug seems a bit excessive to me. |
I use the Dikes and 0.99 washer form the dealer... no need to replace the plug!
SeaBiskit
1-1-2003
Poughkeepsie NY
ming blue b6 A4qm sport/ 00 S4
Re: DIY: 2.5L Oil Change with Pictures (electricme) » | « » 2:01 PM 8-8-2006 | |
| Quote, originally posted by electricme » | I use the Dikes and 0.99 washer form the dealer... no need to replace the plug! |
And you're supposed to replace the washer EVERY oil change. It's a crush washer. N-013-849-3!!!!!!
Yanks in 09 baby!!
glock005
5-28-2006
2006 Jetta 2.5L VP
» | « » 1:08 AM 8-17-2006 | |
Is it neccessary to drain the filter housing before removing it?? Since it's upside down, I figured if just unscrewing and removing it slowly would be just as effective w/o first draining it (thus making it simplier).
freezermink
12-17-2002
'06 LY3D OETTINGER GTI 2.0T
Re: (glock005) » | « » 1:26 AM 8-17-2006 | |
| Quote, originally posted by glock005 » | | Is it neccessary to drain the filter housing before removing it?? Since it's upside down, I figured if just unscrewing and removing it slowly would be just as effective w/o first draining it (thus making it simplier). |
you can see that the filter itself sits much higher than the housing is tall once it is removed, so there is a bunch of overflow. also the angle that it sits at will make things really messy. its just simpler and cleaner to drain it all first.
loonbyn
8-27-2006
fremont ca
2006 jetta gli
Re: DIY: 2.5L Oil Change with Pictures (SeaBiskit) » | « » 11:53 PM 8-27-2006 | |
I take it you bought the washer from the dealer? I took my 2006 GLI into the dealership yesterday for it's 5000 maintainence service and found out all they were going to do for $90 was to change my oil and top off any fluids. $90? I said 'forget it' and took it to a Jiffy Lube place (oh please don't flame me for saying that). As it turns out, the Jiffy Lube place said they couldn't change the oil in my car because they didn't have the right tool to remove that cap!
papaTDI
1-9-2004
Here Now
2007 VW Touareg 4xMOTION Twin-Turbo V10 TDI PD, 2004 Golf GLS TDI PD
Re: (Shrek2005) » | « » 11:57 PM 8-27-2006 | |
| Quote, originally posted by Shrek2005 » | | I'm going to reach 5K miles soon and bought Motul 0W-40 oil. |
how much a qt. for dah MOTUL ?
Im paralyzed * Just listening to you * Now I am receptive * I know you sleep * So sound every night * And you are deceptive * It always feels good to be right * And if it helps you sleep at night * Ill tell you what you want to hear * And act like I care - Helmet
edisonr
10-24-2003
Re: DIY: 2.5L Oil Change with Pictures (dwilkinsjr) » | « » 9:41 AM 8-28-2006 | |
I guess that's an idea. I said that before because the washer is part of the drain plug and it cannot be removed. You could also add an extra removable crush washer.
loonbyn
8-27-2006
fremont ca
2006 jetta gli
Re: DIY: 2.5L Oil Change with Pictures (loonbyn) » | « » 5:55 PM 9-2-2006 | |
gee, i just found out the oil cap tool for a 2006 gli is quite different than the one pictured above for the jetta. and of course this was after i bought the tool, the filter, and the oil. drianed it out, popped that thingie on the end of the cap to drain the oil out of the filter 1st, THEN found out it's a different cap than the above. there's also an arrow etched on the cap which seems to indicate it's a reverse thread. i am now going to see if i can find the removel tool on the internet. i guess i'll just fill er up with the new oil, and when i get the tool repeat the whole process so i can get the new filter in! now to figure out if i really need to replace that drain plug every time
loonbyn
8-27-2006
fremont ca
2006 jetta gli
Re: DIY: 2.5L Oil Change with Pictures (loonbyn) » | « » 3:21 PM 9-3-2006 | |
now that project should go quicker the next time around. the oil cap takes a 36 mm socket, and it's NOT reverse threaded. i wonder why they etched that clockwise arrow on it? anyone know why VW changed the orientation of the drain plug from slanting downward like on the 2.5 to to the parallel-to-the-ground orientation that the 2006 GLI has?
joeoregon
4-10-2006
Eugene or
2008 Rabbit
Re: DIY: 2.5L Oil Change with Pictures (SeaBiskit) » | « » 10:26 PM 9-14-2006 | |
| Quote, originally posted by SeaBiskit » | | And you're supposed to replace the washer EVERY oil change. It's a crush washer. N-013-849-3!!!!!! |
Correct! you are supposed to replace at EVERY! oil change. Although the part number n-013-849-3 is for the Aluminum washer for Aluminum oil pans. Steel or Hybrid pans such as the one pictured above require a Copper drain plug washer Part number N-013-849-2 Just FYI!
Mattj63
8-15-2006
2007 VW GTI, 1999 A4 Quattro
Re: DIY: 2.5L Oil Change with Pictures (joeoregon) » | « » 3:31 PM 9-15-2006 | |
On my '96 Jetta 2.0 I re-used the copper washer 2 or 3 times before changing. As long as you don't go Hulk and crush it too much you're probably OK. All it has to do is not leak. I don't like the idea of putting 2 washers on. That doubles the number of surfaces it can leak on. QUESTION: This DIY is for 2.5L engine. It seems the 2.0T is the same/similar. Am I correct? I have a 2007 GTI now.
benjaminlin
10-19-2006
Re: DIY: 2.5L Oil Change with Pictures (edisonr) » | « » 10:20 AM 11-30-2006 | |
Dose anyone know the spec of oil filter housing wrench and drain plug wrench? I wanna buy the right torque wrench and use it when I change oil in my Rabbit 2007. Thx~
Modified by benjaminlin at 6:36 PM 11-30-2006
