Vhat Does Dis Do? | « » 2:09 PM 5-25-2006 | |
 Part of ambient temp sender unit for A/C system? Seems to rattle when I shake it..
BB 62.. bitch! BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 2:10 PM 5-25-2006 | |
Its an ambient temp sensor, but not for the MFA. IIRC it adjusts either the air/fuel mixture or the fans, i asked a while back, but i forgot what the guy told me
Phil | GTiKid at gmail.comFour Season Tuning | 714.997.5842
Re: Vhat Does Dis Do? (ThatGuy) » | « » 2:12 PM 5-25-2006 | |
Yea, I don't have an MFA...And its not part of the FI system... that sensor is in the intake.. Anyone else?
zugigwagen
1-21-2005
Duluth MN
1997 4door golf VR6
I always thought it was for the MFA, wonder what it is now
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (zugigwagen) » | « » 2:13 PM 5-25-2006 | |
MFA is front passenger lower grille
Brass Knuckle Therapy
4-10-2006
Some Cemetery.
Racoon with Steelies
I always thought it was just an underhood temp sensor..
I'm clever with the censors / I get by with what I got Swearing on the Internet / Makes all the girlies hot But now I know what's up / These mods they got it planned The next time I get clever again / Sure as **** I'm getting banned
Re: Vhat Does Dis Do? (Brass Knuckle Therapy) » | « » 2:15 PM 5-25-2006 | |
I pulled it out and tested it with an ohm meter... it just says "OL" (open)...
Lawn Ninja
11-24-2003
It's a time/space distortion sensor. If you reverse the polarity you can actually travel backward in time.
4-10-2006
Some Cemetery.
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 2:16 PM 5-25-2006 | |
chase the leads to it?
yuk
2-1-2004
Purple And Plaid
Re: Vhat Does Dis Do? (Lawn Ninja) » | « » 2:16 PM 5-25-2006 | |
| Quote, originally posted by Lawn Ninja » | | It's a time/space distortion sensor. If you reverse the polarity you can actually travel backward in time. |
You are ok with me today.
DCI-VW -East | Volkstech -"free chubb" | Mediocre Bmx
Re: Vhat Does Dis Do? (Lawn Ninja) » | « » 2:17 PM 5-25-2006 | |
Ya know I tried that, but I ended back up in the same place..
jhayesvw
10-2-2001
Tucson AZ
1996 Golf 4 door VRT
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 2:19 PM 5-25-2006 | |
it is the Ambient temp sensor. the ECU uses it to make corrections. it is NOT for the MFA.
MY CAR vwvortex is like the Hotel California, you can check out any time you like, but you can never leave. Tucson Forced Induction "The welfare of humanity is always the alibi of tyrants." - Albert Camus
Re: Vhat Does Dis Do? (jhayesvw) » | « » 2:20 PM 5-25-2006 | |
| Quote, originally posted by jhayesvw » | it is the Ambient temp sensor. the ECU uses it to make corrections. it is NOT for the MFA. |
Why don't I see it in the Bentley or any aftermarket manuals?
EDM_v-dub
3-15-2003
Hellview
» | « » 2:24 PM 5-25-2006 | |
it definitely looks like a sender of some kind, thats all i know.
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 2:26 PM 5-25-2006 | |
| Quote, originally posted by Dan J Reed » | Why don't I see it in the Bentley or any aftermarket manuals? | same reason you cant buy a passenger half shaft with that rubber donut on it
Re: Vhat Does Dis Do? (ThatGuy) » | « » 3:07 PM 5-25-2006 | |
Well... I do think its part of the cooling fan ckt...Manual says "near horn" some two wire switch... Unless they mean down on the A/C dryer unit.. jhayes - I am 99% sure its *not* an ECU input... that sensor (intake air temp) is on the side of the intake...
FrameSparks
11-10-2005
Under Ya Bed
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 3:23 PM 5-25-2006 | |
Just marking my spot for when you figure it out. I need all the room I can get.
Bite My Style
Ghetto-8v
6-3-2001
Seacoast
96 Golf + Cabrio
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 3:31 PM 5-25-2006 | |
jhayes is right
Petey Pablo Völkschnell
LedJetta
2-19-2003
Felgen Mans Tee Pee
12 Cylinders 24 Valves
Re: Vhat Does Dis Do? (ThatGuy) » | « » 3:34 PM 5-25-2006 | |
| Quote, originally posted by ThatGuy » | same reason you cant buy a passenger half shaft with that rubber donut on it |
what reason is that again?
8380 Laboratories GAWWW! E30M World Champ!
bikerbill2021
10-7-2004
Upstate NY
Turbo Mark 3, e30, CB500T
Re: » | « » 3:37 PM 5-25-2006 | |
i always thought that had something to do with the alarm, shows how much i know
:.Tyler.:DoWn 2 EaRtH! So Sophisticated, I'm such a zero...
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (LedJetta) » | « » 3:44 PM 5-25-2006 | |
| Quote, originally posted by LedJetta » | what reason is that again? | VW doesnt have it listed in their ETKA so i cant order it
Ddubb9965
5-5-2005
Ocean City/Salisbury MD
'97 GTI 8v
Re: Vhat Does Dis Do? (ThatGuy) » | « » 3:47 PM 5-25-2006 | |
rubber donut...pfft you think it's rubber, rubber coated 5lb hunk of metal...i hate that thing
DiJ aim=DiJ9965 http://www.myspace.com/dj_white
| Quote, originally posted by BoostedEG6 » | | only way you might beat it is if you lost some of that extra baggage you got laying around under your ****ing chin. I hate people like you. |
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (Ddubb9965) » | « » 3:49 PM 5-25-2006 | |
your talking about the one on the half shaft and not the one that bolts to the subframe? but onto dan's problem.you could pull the part number off it and see what ETKA says it is, likely it will say "ambient temp sensor" but it might be worth it...
LG6R
10-20-2003
roadtrip mk3
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 4:33 PM 5-25-2006 | |
| Quote, originally posted by Dan J Reed » | | Ya know I tried that, but I ended back up in the same place.. |
May'09 Roadtrip: 14,500 miles in 37 days http://forums.vwvortex.com/zerothread?id=4537823 Nov'09 Roadtrip: 5,500 miles in 12 days http://forums.vwvortex.com/zerothread?id=4651695| Quote, originally posted by Vayastyle » | | i love this thread, so many people with little knowledge and lots of advice |
| Quote, originally posted by nater » | | I see cars on here all day that SUCK. |
Re: Vhat Does Dis Do? (ThatGuy) » | « » 4:59 PM 5-25-2006 | |
| Quote, originally posted by ThatGuy » | | you could pull the part number off it and see what ETKA says it is, likely it will say "ambient temp sensor" but it might be worth it... |
Aint got a copy, I know its a no-no to ask for one (here and on other sites...)
Thug life
4-26-2006
juhio nk
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 5:20 PM 5-25-2006 | |
http://www.myspace.com/paduber Neuspeed Gti Eric, you are by far the whitest kid I've ever met...
Franco...
6-18-2004
out of the gay
and in da Valley...CT
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 5:25 PM 5-25-2006 | |
| Quote, originally posted by Dan J Reed » | | Aint got a copy, I know its a no-no to ask for one (here and on other sites...) |
you have an IM
autocratica 1 thirty pack at a time
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 6:30 PM 5-25-2006 | |
WE HAVE A WINNER. Good Afternoon, Dan,
The component in the picture is F38, ambient temperature switch. Reference wiring diagram 33/3, current track 40. I suppose you'll want to know what it does and why....? If you study the wiring diagram, you'll see that F38 is in series with several components that can switch off the A/C compressor. OK, that explains what it does; now why does it do it? When the temperature under the hood gets down to whatever value is stamped on the body, F38 opens and keeps the A/C compressor off. This is because the compressor manufacturer (Sanyo?) feels that cold compressor oil does not provide adequate lubrication. After a while, the compressor picks up some engine heat, and so does F38, and the compressor can come back on. You just might ask, "what is the point of running the A/C on a cold day?" Don't forget that passing air over the A/C evaporator dehumidifies it as well. Hot, dry air makes the defroster work GREAT! And when the cabin is full of wet boots etc., it makes the interior much more comfortable. I just ran outside and checked F38 on my wife's '98 Jetta TDI and the temperature is not marked on it. Running the part number (1H0 959 625) through the parts system yields a switch-on/switch-off temperature range of 10-1.7°C (50-35°F). In summary: F38 keeps the A/C compressor off when cold to protect it. So there you have it; no additional charge for the lesson. Arthur LeBrun Bentley Publishers
ThatGuy
1-28-2004
So Cal
MK2 MK3 MK5 (GTi's)
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 6:34 PM 5-25-2006 | |
Must be a slow day over at bentley
KIEZERJOSE
2-15-2003
Queens NY
Re: Vhat Does Dis Do? (Thug life) » | « » 7:28 PM 5-25-2006 | |
| Quote, originally posted by Thug life » | |
hahahaha thats funny
I'll set you up like kiezer and walk straight at the end
FourSeasonTuning
gti_r_done
10-7-2004
findlay ohio
99.5 A4 Avant
Re: Vhat Does Dis Do? (KIEZERJOSE) » | « » 7:33 PM 5-25-2006 | |
i always thought dan was the one with all the answers
flickr
Re: Vhat Does Dis Do? (gti_r_done) » | « » 7:37 PM 5-25-2006 | |
| Quote, originally posted by gti_r_done » | i always thought dan was the one with all the answers |
No, sometimes there are things that stump me... I was pretty sure it was that A/C sensor. Just had no way to prove it... I can rest at night now... knowing... what the hell that little do-dad is, and I know that if the A/C ever takes a dump to jump it.
cgeromi
4-30-2006
Bloomsburg Pennsylvania
1998 GTI Vr6
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 6:11 AM 12-27-2007 | |
| Quote, originally posted by Dan J Reed » | | WE HAVE A WINNER. Good Afternoon, Dan,
The component in the picture is F38, ambient temperature switch. Reference wiring diagram 33/3, current track 40. I suppose you'll want to know what it does and why....? If you study the wiring diagram, you'll see that F38 is in series with several components that can switch off the A/C compressor. OK, that explains what it does; now why does it do it? When the temperature under the hood gets down to whatever value is stamped on the body, F38 opens and keeps the A/C compressor off. This is because the compressor manufacturer (Sanyo?) feels that cold compressor oil does not provide adequate lubrication. After a while, the compressor picks up some engine heat, and so does F38, and the compressor can come back on. You just might ask, "what is the point of running the A/C on a cold day?" Don't forget that passing air over the A/C evaporator dehumidifies it as well. Hot, dry air makes the defroster work GREAT! And when the cabin is full of wet boots etc., it makes the interior much more comfortable. I just ran outside and checked F38 on my wife's '98 Jetta TDI and the temperature is not marked on it. Running the part number (1H0 959 625) through the parts system yields a switch-on/switch-off temperature range of 10-1.7°C (50-35°F). In summary: F38 keeps the A/C compressor off when cold to protect it. So there you have it; no additional charge for the lesson. Arthur LeBrun Bentley Publishers |
Thank you and Arthur LeBrun for the great info! Is it possible to buy a different sensor with different ranges? Kind sucks if it's to cold out and you have all that moisture from snow in your car, that you can't get some nice dry air in the cabin until the compressor gets up to its minimum range temp... Modified by cgeromi at 3:16 AM 12-27-2007
Modified by cgeromi at 1:01 AM 12-28-2007
1998 MK3 GTI VR6 169,000 Miles and counting...with Working Cruise & Factory ClutchMy Ride: http://s4.photobucket.com/albu...w.flv
Euro99G3
4-25-2005
Penns Woods
99 Golf Silver ARRoW Rip... 2001 XJ
Re: Vhat Does Dis Do? (Dan J Reed) » | « » 9:03 AM 12-27-2007 | |
You might be a pimp if
WTB some LG9R...miss her
