voxwagen88
12-8-2001
North Vancouver BC
1988 Fox GL Wagon
New Dyno Numbers | « » 4:34 PM 6-3-2006 | |
I was able to make it to the Dyno Day hosted by RPI at Kinetic Motorsport.Here's the resullts of the 4th gear pulls. 88.3 WHP @ 5300 RPM 103 FtLb @ 3700 RPM A/F 14.3/14.4 all the way through. Regan
Modified by voxwagen88 at 1:35 PM 6-3-2006
1988 Fox GL Wagon 3A - Eurospec Head - G-Grind Cam - Large Throttle Body Full tt Exhaust - 2P 5 Speed - GTE Oil Pan -Neuspeed Lowering Springs Sway Bars -Rear Strut Tower Bar - 10.1 Brakes - H4s BX
88vwFox
11-22-2005
Melbourne FL
1981 VW rabbit 2 door auto, 1981 VW rabbit 4 door 5 speed, 1988 vw fox wagon +1658 posts
» | « » 5:55 PM 6-3-2006 | |
thats not bad at all. i wonder what a 100% stock fox puts down?
93 VW Fox 2 door = RIP (totaled 06-03-08) 88 VW Fox wagon 2 door = IT RUNS! now for sale. Build thread---> http://forums.vwvortex.com/zerothread?id=4432862 81 VW Rabbit 2 door = 1.8l 8v swap, 3 speed auto 81 VW Rabbit 4 door = Parts car FREE!
voxwagen88
12-8-2001
North Vancouver BC
1988 Fox GL Wagon
Re: (88vwFox) » | « » 7:19 PM 6-3-2006 | |
| Quote, originally posted by 88vwFox » | | I wonder what a 100% stock fox puts down? |
Flipping through VWSport Tuning, I came across this.
The Caption reads "The stock Fox exhaust system strangles the engine above 5000 RPM. An aftermarket sport exhaust will yield a 7-hp peak gain and a 14-hp gain at 5500 RPM."
slvfox
2-15-2005
Milwaukee WI
'88, VW, Fox
Re: (mdwelsh) » | « » 9:08 PM 6-3-2006 | |
| Quote, originally posted by mdwelsh » | Unless I am mistaken, the Bentley states 81HP stock. |
True, but isn't that at the flywheel.
'88 VW Fox, 62k miles, little rust, Bought 4 $700
Longitudinal
11-12-2004
Columbus OH
1977 Audi Fox 2D - 87, 88 QSW - 1990 VW Fox 2-door
Re: New Dyno Numbers (voxwagen88) » | « » 11:08 PM 6-3-2006 | |
Regan,Nice. I'd love to wave the wand over your fuel system. I am sure I could find a few ponies you didn't know about.
No time for Stalin!"And in two years he made the cover of Time The albino priest with the psychic mind..." Richard Wurmbrand Centennial
voxwagen88
12-8-2001
North Vancouver BC
1988 Fox GL Wagon
Re: New Dyno Numbers (Longitudinal) » | « » 12:44 AM 6-4-2006 | |
I wish you had been here to do that. I would have loved to pull 90 WHP and matched the MKII GTi's crank rated 90HP. You are one of very few I would let wave a wand under my hood.She seems healthy though. A bit rich? At this level I do not find myself saying"I need more fuel!"
VWestlife
9-29-2004
central NJ
Re: (voxwagen88) » | « » 2:54 AM 6-4-2006 | |
| Quote, originally posted by voxwagen88 » | Flipping through VWSport Tuning, I came across this.
The Caption reads "The stock Fox exhaust system strangles the engine above 5000 RPM. An aftermarket sport exhaust will yield a 7-hp peak gain and a 14-hp gain at 5500 RPM." |
Notice how there is only a 1-2 HP gain below 4000 RPM -- really not that much to be noticeable or useful, in the range where most people do 95% of their daily driving. This suggests that unless you constantly drive your Fox as if it had a VTEC under the hood, a more useful mod to start with would be better gearing (such as from a 9Q gearbox), since it lets you make more effective use of the engine's entire rev range, not just the extreme top end.And remember, a Fox is quite a bit lighter than a GTI, therefore it doesn't need an equivalent amount of power to deliver equivalent performance. (For example, the 1976 Rabbit, with 1.6L and 73 HP, matched the acceleration of the 1986 GTI, with 1.8L and 102 HP. Why? Lighter weight, and better gearing!)
_____________GCF - It's Wimblebot approved!
BustedFoxWaGeN
7-8-2005
Gates NC
92 turbo diesel Jetta, 73 duster 340, 96 harlequin bbm SC, 07 rabbit
Re: (VWestlife) » | « » 10:37 PM 6-4-2006 | |
| Quote » | | This suggests that unless you constantly drive your Fox as if it had a VTEC under the hood, |
drive all my cars like that.. especially my diesel just to keep up with traffic
Modified by BustedFoxWaGeN at 7:55 PM 6-4-2006
DirectConnectionTuning HID KITS $139.99 shipped 1 YEAR WARRANTY THROUGH ME!! WÄGENWERKS "i'd rather be judged by 12 people, than carried out by 6"
voxwagen88
12-8-2001
North Vancouver BC
1988 Fox GL Wagon
Re: (VWestlife) » | « » 12:39 AM 6-5-2006 | |
By way of meaningless comparison, here is my previous dyno numbers. TT exhaust, synthetic oil, and a K&N filter were the only performance mods at this point. By way of explainawaytion The numbers are from a different dyno. With the PSA 5 speed. The big numbers were a second gear pull. The lower numbers generated by run 002 are from a third gear pull and are helpful in guessing what the (lower) 4th gear numbers might have been. I found I tended to drive the car very hard when it was stock. I felt I had to to keep up. My wife however tended to shift much lower. Working with the torque band rather than the horse power band. She got much better gas mileage. With the TT exhaust it was much more willing to stretch to 5K rpm. Now I still like to drive it hard from time to time. But because it is fun, not just to get the car out of its own way. Modified by voxwagen88 at 9:45 PM 6-4-2006
Modified by voxwagen88 at 11:24 AM 6-28-2009
snowfox
4-4-2002
Livermore CA
1989 Fox Wagon, 89 Jetta Wolfsburg, 99 Passat GLX - the baby hauler
Re: New Dyno Numbers (voxwagen88) » | « » 1:10 PM 6-5-2006 | |
| Quote, originally posted by voxwagen88 » | She seems healthy though. A bit rich? At this level I do not find myself saying"I need more fuel!" |
I wouldn't call it 'rich' unless you were getting down to like 12:1 A/F. Isn't stoichiometric 14.1:1? If that's the right number, 14.3/14.4 would actually be lean... Or is it 14.7:1? Can't remember off-hand. If stoichio is 14.7, then your 14.3 should be just about rich enough to get you near max power. Maybe you might even want to get down to 13.9... BTW, I thought most folks did their pulls on the Dyno in 3rd. Why did you do it in 4th?
Modified by snowfox at 10:13 AM 6-5-2006
| Quote, originally posted by kerensky » | It's a direct swap. Just be sure to get the 5 speed linkage, as the two are different. And replace the bushings in the new linkage while you've got it apart. And a new clutch/CV joints/bearings/brake rotors/engine swap/paint job/interior refresh, because, you know, while you're in there you might as well.  |
chryco63
8-7-2005
Fenwick ON
'88 Fox Wagon GL, '88 Fox Wagon GL
» | « » 1:40 PM 6-5-2006 | |
Stoichiometric is 14.7:1.
Glen Robins (2) '88 Fox Wagon GL's
snowfox
4-4-2002
Livermore CA
Re: (chryco63) » | « » 2:39 PM 6-5-2006 | |
| Quote, originally posted by chryco63 » | | Stoichiometric is 14.7:1. |
A-ha! I thought my first guess of 14.1 sounded a little off...
voxwagen88
12-8-2001
North Vancouver BC
1988 Fox GL Wagon
Re: New Dyno Numbers (snowfox) » | « » 1:32 AM 6-6-2006 | |
| Quote, originally posted by snowfox » | | BTW, I thought most folks did their pulls on the Dyno in 3rd. Why did you do it in 4th? |
My understanding is that you want to make the measurement in the gear closest to 1:1 in order to limit the torque multiplying effects of the lower gear. Second or third gear pulls tend to produce smoother curves and more flatttering numbers so they are popular. It probably doesn't matter that much which gear the pull is done in as long as you are comparing it to one done is a similar gear. And of course these were done in different gears with a different set of gears so it quickly becomes apples and oranges with lots of room to speculate. I'm mostly pleased the numbers are bigger. At least that would suggest it is going in the right direction. Power on the lean side. Regan
snowfox
4-4-2002
Livermore CA
Re: New Dyno Numbers (voxwagen88) » | « » 10:35 AM 6-6-2006 | |
| Quote, originally posted by voxwagen88 » | My understanding is that you want to make the measurement in the gear closest to 1:1 in order to limit the torque multiplying effects of the lower gear. Second or third gear pulls tend to produce smoother curves and more flatttering numbers so they are popular. |
Aaaaahhhh... I've never actually messed with getting on a Dyno, so the gear selection thing is nothing I've ever had to deal with. Doing it at or as near as possible to 1:1 gearing makes good sense though. Thanks.
Fox-N-It
7-23-2003
RVA
83 Coupe GT 91 Golf GTI
» | « » 10:11 PM 6-6-2006 | |
With your AF staying pretty constant in the low mid 14's i'd say your O2 and such are doing their job.From all the tuning stuff i've read a 13.5 to 13.9 AF is the place to be on a NA motor. Adjust the CIS-E a bit and im sure you'd see over 90whp.
Knox Motorsports Richmond VA, VAG-COM and Dyno Jet chassis dyno service available Email: tuned AT knoxmotorsports.us for details.  http://www.knoxmotorsports.us
