Yevi
12-6-2005
Wilmette IL
06 Jetta, A4 Avant, 88 GTI {RIP},
DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA 95% complete | « » 7:29 PM 7-12-2006 | |
Well, as i promised many members who sent me instant messages about install.PARTS CHECKLIST -Motherboard- ASROCK -$35.00 ebay -Old Computer Case for modding, and fitment- still looking -AMD Athlon 2400 Processor, from my previous computer -Audio Card- X-FI or Audigy -Flexible keyboard- ebay $6 shipped -Hard Drive Maxtor 200GB- ebay $70 shipped -CD-Rom- Liteon slot load $60.00 -RAM- from old system -GPS- Mouse BU-353 ebay $60.00 shipped -Bluetooth dongle- ebay $20.00 shipped -Wifi Dongle- ebay $20.00 shipped -Power Supply OPUS 150 watt- http://www.mp3car.com $128.00 shipped -Keyhole Rearview camera- pending etc, etc. Wiring Electrical -0/1 Gauge battery Terminal- ebay $7.00 shipped -12 feet 2 gauge power wire- ebay $25.00 shipped -Power Fused Distribution Block- ebay $18.00 shipped -Ground Distribution Terminal- pending -Speaker Wire- 16 gauge (THEY ALL COPPER) $12.00 will add anything else CAR AUDIO -MBqaurt Q series 6.5s- ikeaudio $260.00 shipped -JL 3 Way components $350.00 -4 Channel amplifier- JL 300/4 $350.00 -MONO Subwoower Amplifier Alpine MRP-M350- NEW ebay $70.00 shipped -12 inch to 10 inch Alpine TYPE R swap (12 is too big for my trunk side storage compartment- $179.00 Crutchfield ( i was noob then, but they have world class customer service, they let me an exchange after 6 month, and they have the best service support) -Pre Amplifier Equalizer- pending Construction Materials Way too much Fiberglass Resin 2 Gal: $60.00 Home Depot MDF Boards: -$20.00 Home Depot Bunch of screws, and misc tools Stay Tuned, Yev TOTAL SPENT ON THE CAR SO FAR 4335.89 (including tint, rims, and xenon fogs) Modified by Yevi at 10:12 PM 9-12-2006
Modified by Yevi at 8:55 AM 3-14-2007
Modified by Yevi at 3:46 AM 3-15-2007
B5 CREW ██████ LIVERPOOL F.C.██████ YOU WILL NEVER WALK ALONECEL STATUS: ON
Yevi
12-6-2005
Wilmette IL
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (Yevi) » | « » 7:29 PM 7-12-2006 | |
Screen Bezel Parts used: Lilliput Touch Screen Monitor: $249.99, i got mine on junkbay for $160.00 Metra Din Aftermaket Headunit Dash Mount, ebay $10.00 Bondo Glass bodyfiller, $9.00 Home Depot Labor Since i have done my mount sometime ago, i thank Mega for his pictures 1) dissasemble lilliput monitor, and precut, and fit the face plate with Bezel attach the faceplate with epoxy 2)Mix some Bondo, and apply, Sand
3) fit, and paint violla
that's it for now, waiting for more supplies
-Yev Modified by Yevi at 4:14 AM 7-16-2006
Modified by Yevi at 4:15 AM 7-16-2006
Yevi
12-6-2005
Wilmette IL
» | « » 7:30 PM 7-12-2006 | |
Speakers, first Removing factory, i believe that the factory speakers are decent what is not is the spave of volume 6.5-7 front door woofer has only 4 to 5 inches tops of cavity depth, there is no way it should be that shallow, same things go for a midrange, and even front door treble So We will star by Removing Front door panel, 1) there are for exterior screw 3 on the boot, and the 4th is on the side where a treble speaker is 2) there is also 2 larger Torx screws behild the window control, to get there just pop it
3) use a door clip removal tool, and detach the door panel
4) Omce bottom detached, pull up gently, and violla
5) Treble is a bugger,i lot of pulling involved, and 1 screw 6) Drilling out the speakers i use 1/8, and another larger drill bit, that was truly a pain the butt Make Sure your Windows are UP not to damage the glass
Front door is ready  Now similar tactics with the rear door, although it only holds on 1 screw, and 2 big screws, it little tougher to diconnect, unlike in the front door that has a harness component connections rather than indiviadual wiring
Now waiting for speaker to arrive Modified by Yevi at 3:47 PM 7-18-2006
Modified by Yevi at 3:48 PM 7-18-2006
Modified by Yevi at 4:44 AM 9-27-2006
Yevi
12-6-2005
Wilmette IL
Re: (Yevi) » | « » 7:31 PM 7-12-2006 | |
SUBWOOFER FIBERGLASS BOX TOOLS YOU WILL NEED 1) 1 Can of ACETONE if you want to reuse your brush/roller, more than once 2) Fiberglass Roller, you can get one online or in westmarine stores 3) 2 pakcets if fiberglass mat 2 sq. yards 4) 1 Gallon of Resin 5) 1 sq yard of fleece 6) staple gun 7) cheap brush 8) Gloves 9) Jig Saw, and Sander 10) mixing jug 11)carpeting 12)spray adhesive 13) optional dynamat or equivalent 14)masking tape 15)foil wrap 16)MDF may something else i missed 1) I have removed side of the trunk carpeting with the compartment, i haven't gotten a change of document that, but it's simple remove some clips, and you will have to remove rear seats as well to get that piece out, there is a thread in FAQ of how to remove rear seats
2)Mask tape the cavity 3)To be safe i also use foil, just in case 4)I suggest to mix Resin about 4-8 oz at the time, pot life in the hot day could be less than 12 minutes, in the same time you will have first layer to work with fast 5)personally i like to work with mat, some people don't like it, but it depends on application, cuase we are laying it mostly flat mat would be a nice solution, precit mat in about 3x3 squares, or other comfortable shapes, and dip in resin, and apply, just like Papier Masche, only with the tough stuff
6) Violla first layer is done, lets repeat until you have at least 3 layes, the box might look unpenetrable, but if you want to keep your box longer, more layers doesn't hurt 7)once we have fit it inside the cavity, i precut and piece of MDF  8)we will need to bond the faceplate with the fiberglass togerther, and to accomplish that i use fleece 9)after fleece has been reinforced with more glass, and covered with Dynamat, I sprayed some adhesive, and tightened carpeting over the box 10) finished product Modified by Yevi at 10:47 PM 7-26-2006
Modified by Yevi at 4:46 AM 9-27-2006
FUZE
4-12-2004
San Jose CA
2006 GLI
» | « » 11:37 AM 7-17-2006 | |
Looks good so far, keep us updated
I'm the guy that started the Cinna-Berry craze
the.ronin
2-22-2006
Orange County CA
MKV 2.5L
» | « » 11:45 AM 7-17-2006 | |
Thanks ... I'm going to be following this thread closely.
███ 2.5L Driver | CI MX Surfer | D40 Shooter | Live Gamer
Dreamstate
1-1-2002
Kitchener Ontario
» | « » 4:19 PM 7-17-2006 | |
Looking forward to the outcome
The Colour of Money - 23.88 @ 56mph Methes Energies: the biodiesel company
00VR6Tong
9-20-2004
Pleasanton CA
2006 GTI, Candy White, Pkg. 2, 6sp man
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (Yevi) » | « » 4:41 PM 7-17-2006 | |
soo you are going to only listen to music off the HDD? what about XM or even FM? i know i get tired of my mp3 collection quick. i guess my real question is, is there anyway to include a radio of any kind into your setup? you also could get like the sprint broadband card and stream music... wow so many possibilities. im really interested in how this turns out..
user name unknown
9-2-2001
The Poopy Glove
1010011010
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (00VR6Tong) » | « » 4:49 PM 7-17-2006 | |
| Quote, originally posted by 00VR6Tong » | | soo you are going to only listen to music off the HDD? what about XM or even FM? i know i get tired of my mp3 collection quick. i guess my real question is, is there anyway to include a radio of any kind into your setup? you also could get like the sprint broadband card and stream music... wow so many possibilities. im really interested in how this turns out.. |
You can get an AM/FM tuner for your computer.
Projekt-GIB.com H2Oi 2008 - THE OFFICIAL MK5 MOTEL THE OFFICIAL MK5 GTG Thread
Yevi
12-6-2005
Wilmette IL
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (00VR6Tong) » | « » 5:26 PM 7-17-2006 | |
you can have xm/sitius for computer via usb, or custom too with 200 gigs i don't think i would need all of the above, sorry but that's just me here is how do it, the funniest thing that XM receivers are free after rebates http://mp3car.com/vbulletin/showthread.php?t=41001 same concept for sirirus, on sirius receivers are $80.00 or if you don't want to mess around http://cgi.ebay.com/XM-PCR-Sat...wItem XM PCR although discountinued because people were recording music for free INTERNET, you don't need sprint broadband you just need phone with USB adapter for it, there is a loophole with sprint about unlimited data plan, so you can use your cell phone as a internet data plan provider, but bluetooth phone is the way to go. i tried with friends it woriked fabulous, i use my phone as a modem, my contract expired, but i am not renewing cause i am going to school in Canada in spring Yev Yev
Modified by Yevi at 12:29 AM 7-18-2006
Yevi
12-6-2005
Wilmette IL
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (Yevi) » | « » 8:54 AM 7-18-2006 | |
got my processor today, will start puting computer together, in the eveningBummer Pentium M processor even though say 478 pin would not fit into the mATX 478 pin motherboard cuase 1 of the pins ****ed, and mismatched. New Solution AMD Atlhon XP mobile + asus motherboard $100.00 extra towards expense, computer put to together postponed
Modified by Yevi at 7:55 PM 7-19-2006
OGSN0
10-4-2004
SOLO2.COM
MK4 Golf
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (Yevi) » | « » 9:58 AM 7-18-2006 | |
::high five::
2007 San Diego SCCA G-Stock Regional Champion 2007 Gymkhana USA Stock Class Champion What am I driving in my local Street-Tire, Stock-Class? Link It's about damn time VW separated the GLI in the line-up. It only took 24 years...
Yevi
12-6-2005
Wilmette IL
Re: DIY, COMPUTER, and AUDIO Intallation on MK5 JETTA, and similar GTI (OGSN0) » | « » 3:48 PM 7-26-2006 | |
subwoofer box update
Little Joe
4-4-2004
The Old Pueblo AZ
1984 GTI 2.0 8V
» | « » 4:56 AM 7-30-2006 | |
well this sure looks familiar, lolbest of luck to you
"I have no special talent. I am only passionately curious" Albert EinsteinMy Dirty Rabbit - currently disabled THE ORIGINAL mkV PC Squares for Life
AirmanPika
4-10-2006
Alexandria VA
2009 Dodge Challenger R/T (Sorry)
» | « » 6:18 AM 7-30-2006 | |
How did VW handle the Crossovers in your Jetta? In my GTI they were triangular boxes next to the woofer but I don't see anything like that in yours due to the doors being shorter I guess.
¯\(º_o)/¯ I'm just the messenger.
GTIHun
4-17-2005
Portland OR
2006 Audi A3 2.0T 6mt, open sky, nav
Re: (AirmanPika) » | « » 6:54 AM 7-30-2006 | |
Looks good
Modified by GTIHun at 4:01 AM 7-30-2006
I created a monster.............
Yevi
12-6-2005
Wilmette IL
Re: (AirmanPika) » | « » 10:26 AM 7-30-2006 | |
i have 05.5 model, it came with an amp under the seat, i guess that's how my distribution went rhough factory amp, funny thing is that all 2 speakers are different impedance trweeter i believe is 2 or 8, mid range is 4 ohm, i don't remember anymore, too much workhere is the reaser
Yevi
12-6-2005
Wilmette IL
Re: (Yevi) » | « » 10:27 AM 7-30-2006 | |
LuciferRex
7-4-2006
Middletown OH
2006 VW GTI Package 2
» | « » 10:53 AM 7-30-2006 | |
wow
Yevi
12-6-2005
Wilmette IL
Re: (LuciferRex) » | « » 10:55 AM 8-4-2006 | |
well now i need some suggestions there is no matchng color material to fabricate the speaker, and the doorso i will have to add another color since my car is reflex silver i am thinking of uphostering a lower door panel matching silver, with blue stripes going in interior, and exterior what do you guys think
blackvento36
3-17-2003
Easton pa
06' GLI 6MT Deep Black
Re: (Yevi) » | « » 5:40 AM 8-10-2006 | |
| Quote, originally posted by Yevi » | | OOh you have balls. I wouldn't have went that far, but **** it man, go all outEdit: If I were you, I would go with a 5.1 channel sound card, if you have an open PCI slot. I'm not sure what kindof on board audio your motherboard has, but I'm guessing it's 2-channel. If you use that you will have no control over the F-R fade in your system, other then your (4ch) amps gains. I also would forget about a preamp EQ, the PC will handle that well.
Modified by blackvento36 at 5:47 AM 8-10-2006
The BEST MKV carputer Posting in the MKV forum is like smacking yourself in the face.
Yevi
12-6-2005
Wilmette IL
» | « » 11:01 PM 8-10-2006 | |
yeah, i went with creative audigy 2 5.1-7.1 surroundso it's much better than any aftermarket headunits Yev
Yevi
12-6-2005
Wilmette IL
» | « » 11:08 PM 8-10-2006 | |
right now i am working on the amp rack, which would be suspended off the trunk ceiling, if you look up there there is a series of clock type hangin holesYev
Tourenwagen
12-28-2002
NJ USA
CC
» | « » 11:30 PM 8-10-2006 | |
subscribing to this thread
**Coolwater**
VWNDAHS
6-20-2002
MkV R32, MkV GTI, some JDM cars
Re: (Yevi) » | « » 11:30 PM 8-10-2006 | |
so why not just install a mac mini with xp on it into the glove box? you prefer to build ur own windoze machine?
Jpics
4-25-2006
va beach va
2006 GTI 2.0T pk2
Re: (VWNDAHS) » | « » 11:40 PM 8-10-2006 | |
Jay P. Checkered Flag Volkswagen sales Virginia beach, VA (757) 660-0034 Taking orders for the MKV .:R32 for only $500 over invoice
FUZE
4-12-2004
San Jose CA
2006 GLI
» | « » 11:43 PM 8-10-2006 | |
Wow Yevi, looks good man! I just ordered my Xenarc and it should arrive next week...
Yevi
12-6-2005
Wilmette IL
Re: (VWNDAHS) » | « » 7:19 PM 8-11-2006 | |
| Quote, originally posted by VWNDAHS » | | so why not just install a mac mini with xp on it into the glove box? you prefer to build ur own windoze machine? |
well windoze is a fracture of the cost it's only cost under $150.00 plus you have better audiocard, dual screen videocard allows to have 2 displays. even though you can get xp, slim hard drives aren't good is harsh automotive environments, and last you can't boot from flash drive, which allows my windozaa to wake up from hibernation with in 5 seconds, and boot with in 10-15 Yev
majinjoel1
2-12-2006
Orange Park FL
2007 Camp. White GLI Pk.2 and 2006 Jetta 2.5
Car Speakers » | « » 9:17 PM 8-11-2006 | |
Does the 6 1/2" speaker in the front have a spacer? I am looking around for a new set of speakers but I am having a hard time finding ones that fit. There is only like 1" of space for the front door speakers. Atleast that is was Crutchfield said.
Yevi
12-6-2005
Wilmette IL
Re: Car Speakers (majinjoel1) » | « » 10:10 PM 8-11-2006 | |
what do you mean by spacer, there is about .25 inch in between the speaker, and the door panel and really little space in between the window, and the magnet the large woofer diamteter is roughly 7 inches, and magnet is 3.5, operates at 2 ohmYev
Sincity
5-16-2005
Las Vegas NV
'07 GTI RIP. CURRENTLY '86 190e 2.3, '08 RDX, '09 C63 AMG.
Re: Car Speakers (Yevi) » | « » 12:18 AM 8-12-2006 | |
Dude...that is hardcore
RIP: 07 RS GTI 5-door with APR Stage 2 and other goodies. Crappy OSIR V1 Fitment: http://forums.vwvortex.com/zerothread?id=3318310
TypeR #126
5-10-2006
Concord CA
2006 GTI
Re: Car Speakers (majinjoel1) » | « » 12:14 PM 8-12-2006 | |
The stock 7" has an integral spacer built into it. You'd need to frabricate your own for a replacement, or go wo with the Rainbows that come with one. Total clearance is about 2-2.25". Crutchfield was probably refering to the clearance from the door skin itself to the window track, which is about an inch.
majinjoel1
2-12-2006
Orange Park FL
Car Speakers » | « » 10:27 AM 8-13-2006 | |
Is there anyway that you can take a picture of the factory speakers so that I can see the size od the magnets and the speakers? This would be really helpfull to me
majinjoel1
2-12-2006
Orange Park FL
Re: Car Speakers » | « » 11:41 AM 8-13-2006 | |
I want to install these speakers in my doors for the 6 1/2 / 6 3/4 driver but I am not sure if I have enough deph to put them in the hole.http://www.sonicelectronix.com/item_5154.html
Yevi
12-6-2005
Wilmette IL
Re: Car Speakers (majinjoel1) » | « » 1:26 PM 8-13-2006 | |
well i don't think you will be able to fit those, because of the coaxial components , generally you just need at lest .5 inch, i suggest you advice crutchfield service representative, they have all those numbers in their databases, look what fits, i am sure you will be able to fit a component set in factory cavity, but not coax, besides it will sound like crap since tweeters are directional, and in this case you will have to grow ears on your bum bum Yev
