WolfsburgerMitFries
7-4-2005
Lexington KY
Maintaing Eos top seals/weatherstrip with Krytox | « » 10:13 AM 9-12-2006 | |
Volkswagen sells a weatherstrip lubricant under part number G 052 172.A1 for maintaining the weatherstrip roof seals in the Eos and that part number is given in the Eos owners manual. Another member priced it at the VW dealer for $95 in a 30ML volume. It is a liquid form of DuPont Krytox, the DuPont equivalent part number is GPL 105 and it is sold in a minimum package of 0.5KG/1.1lb for $145 from Krytox Vendors. The 0.5kg bottle is about 8X the volume from the VW dealer. The Chemical Abstracts Index (CAS) name for Krytox fluorinated oils is oxirane trifluoro (trifluoromethyl)-homopolymer, and the CAS Registry Number is 60164-51-4. Thanks to Speedster356 in Greece for the picture.
 According to the MSDS sheet, its 100% Krytox
 Dupont has just put out an interesting pdf that deals with Krytox as a long term solution for squeaks and rattles in automotive applications. http://www2.dupont.com/Lubrica...1.pdf
There has been an update newsletter from DuPont dealing with the 100 series Krytox oils, specifically comparing the performance and durability of the auto industry standard GPL105 to thinner viscosity GPL104 and GPL103 versions. http://www2.dupont.com/Lubrica...2.pdf Volkswagen offers 3 versions of Krytox. The second part number is a 100ML aerosol spray version under part number G 052 172.A2 and after examining the MSDS sheets, it was possible to determine that there is no silicone present in the product, but of the 100ML volume, it is mostly propellants. You only get 5-7% Krytox by weight, but Krytox is very dense so you would end up with less than 5-7 ML if you calculated the content by volume. This part number appears to be a poor value.
 Volkswagen also lists part number G 060 172.A3 which is a paste (grease) version in a tube. The DuPont Equivalent to this is GPL 205 and it is a 2 ounce/56.7 gram quantity. This version of Krytox is also well known by owners of Corvettes, as well as the Cadillac Allante with a removable hardtop. Krytox is the only product which can silence the squeaking problems in the weatherstrip as the chassis flexes against the removable hardtop in the Allante. I purchased Krytox GPL 205 for $29 plus shipping from Darrel Kinkaid at THT Group Inc. His E-mail is dkinkaid@thtgroup.com or 650-595-1112, extension 1. Unfortunately the price has now gone up over 30% to $38 for the 2 ounce tube. Its frustrating to see such rapid price increases, and a good incentive to look to other vendors. Here's another affordable alternative. You can get GM part number 3634770 for $32.49 at GM parts Direct. Its worth reading their product description. After reviewing the MSDS sheet from GM, I was able to determine that this is the liquid Krytox GPL 105 which is an exact match to the VW part number G 052 172 A1 in the Eos owners manual at 1/3 of the price. The quantity listed on the label is 29ML. It has been mentioned that the liquid may be more difficult to apply precisely, and may be prone to unintentional spreading over time. So you may prefer the thicker GPL-205 grease instead of this. http://www.gmpartsdirect.com/
 You can clearly see that the label lists the contents as "Oxirane" and the CAS registry number of 60164-51-4 (see top paragraph of this post for information on determining a chemical match). The liquid in the bottle is about the consistency of maple syrup. You can see it cost a little more at my GM dealer, and they had to order it anyway, so I just recommend ordering from the gmpartsdirect.com website.
 There is a permeable applicator pad fixed to the top of the bottle to control flow which would remind you of a bingo marker. This pad and its white plastic mounting ring are easily removed from the translucent bottle for direct access to the liquid inside.
 My contact at the GM dealer also got me the MSDS sheet which confirmed the GM 3634770 weatherstrip dressing is 100.0000% Krytox. Notice the CAS registry number I explained in the first paragraph.
 To precisely apply the liquid Krytox GPL 105 oil, you might want to repackage into a squeeze bottle oil dispenser with a needle to reach into tight spots. There's many different styles available. When you are selecting a Luer needle, get the biggest possible. I recommend 14 gauge 1.5 inch length, 16 gauge is O.K., but don't go smaller (higher number i.e. 18, 20 gauge) than that. http://jensenglobal.com/
 Again here's the Krytox FAQ directly from DuPont to quickly make you aware of the chemical properties. Krytox is really an aerospace lubricant, use as a dressing/protectant is a secondary application. http://www.dupont.com/lubricants/en/faqs.html Here's an old interesting discussion from the Plymouth Prowler board in 2002 when some individual was selling GPL 205 for $20.70/2oz tube. The e-mail/group buy is no good anymore, but there is a highly in-depth technical discussion that's worth reading. Its a little alarming to me how quickly the price of Krytox has been increasing over such a short period of time. http://www.prowleronline.com/u....html If you read step 21 (scroll down) of this link, you can see a good idea of how to apply krytox paste to weatherstrip with a thin protective glove. http://www.corvettemagazine.co...p.asp
 Here's my tube of Krytox GPL205. Its working well on my non-Eos vehicles. Remember Krytox is primarily a lubricant so it can be used anywhere you would apply regular oils or greases. It is far superior to petroleum based lubricants in that it is very resistant to washoff from nautrally occuring solvents, and has a much slower evaporation rate, guards against corrosion better, is a better lubricant and is much cleaner. Your door and trunk hinges would be better protected with Krytox compared with, for example, white lithium grease.
 Most auto manufacturers offer Krytox in some form or another to deal with squeaks and rattles. Here's an example from Saab, at least they don't try relabel it.
Modified by WolfsburgerMitFries at 5:57 PM 7-11-2007
You have our gratitude. http://members.tripod.com/~JB5353/kfm/kfm.html
nette
8-22-2006
Huntington Beach CA
2007 Eos Thunder Blue
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 11:56 AM 9-17-2006 | |
Thank You for your research and detailed information. I have had my EOS 3 weeks. It's gotten its first two "baths" at the dealer. Once when I had the LoJack installed and the upholstery treated and once when a window wouldn't stay closed after the roof was closed. I need to purchased something soon for the seals.
Maybe we are all a little paranoid?? My husband has driven a 2001 Corvette, with the removable top, for five years. He takes it to the local car wash and has never used any sealant on the weatherstripping. No Leaks, looks great !! Are the EOS seals made of a different type of material?
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Maintaing Eos top seals/weatherstrip with Krytox (nette) » | « » 1:31 PM 9-17-2006 | |
I guess the reason we have the top seal and weatherstrip issue under the microscope is because one owner noticed white spots appearing on his seals after a couple of rainstorms. So far it appears to be an isolated (or at least limited) problem. I'm thinking that particular Eos might be downwind of an industrial town or manufacturing facility, and the white spotting on the rubber is a result of the car being subject to excessive environmental fallout/pollutants. In any case, Krytox does not oxidize, its does not contain any volatile compounds that evaporate, and its very resistant to wash off from water or naturally occurring organic solvents. So treating your seals with Krytox would appear to create a rather robust environmental barrier. I'm still waiting on my order so I can post some original pictures.To answer your question, the rubber seals have a coating applied to them in order to address a wind noise problem that delayed the release of the Eos by several months. So I would never try to aggressively scrub the seals or wash the car with any type of high pressure spray hose. Also, things like silicone tend to soften rubber and break down rubber (make it spongy) over a long time, and might cause this coating to de-laminate from the weatherstrip/seals. I believe the Eos owners manual specifically recommends against products containing silicone. If anybody has an Eos owners manual and a good digital camera, It might not be a bad idea to post pictures of care/maintenance procedures and warnings about the top seals in this thread.
Modified by WolfsburgerMitFries at 10:43 AM 9-17-2006
bjorngra
7-22-2006
Netherlands
2007 VW EOS 2.0TFSI - SILVER ESSENCE - LEATHER - BI XENON - 18" CHICAGO
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 2:47 PM 9-17-2006 | |
On my Eos are a several white spots visible. I can't get them off. I don't know how to remove it? I wil take a picture and post it. I wil look in the owners manual, if there is something to do about it. When I make the spot wet it's away, but when the water is dryed up you will see it. I thinks it's the coating that becomes white when it comes in contact with water. I have just send the pictures to my dealer. When I got an answer I wil post it.
Modified by bjorngra at 11:21 AM 9-18-2006
Modified by bjorngra at 12:56 PM 9-18-2006
http://static.flickr.com/80/24...o.jpg http://static.flickr.com/94/24...o.jpg http://static.flickr.com/81/23...o.jpg http://static.flickr.com/98/24...o.jpg
bjorngra
7-22-2006
Netherlands
Re: Maintaing Eos top seals/weatherstrip with Krytox (bjorngra) » | « » 3:56 PM 9-18-2006 | |
See the picture I've made today. This is the 1st time he gets wet by rain.
Domdog31
8-30-2006
Bloomfield NJ
2007 Volkswagen Eos 2.0T Silver Essence / Titan Black
Re: Maintaing Eos top seals/weatherstrip with Krytox (bjorngra) » | « » 7:36 PM 9-19-2006 | |
great pics..i get the same white spots almost a fiber like thread that can be seen why the car is dry...lets find out and ge this taken care of
Silver Essence / Black Interior / Auto DSG
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Maintaing Eos top seals/weatherstrip with Krytox (Domdog31) » | « » 8:30 PM 9-19-2006 | |
Okay, back to my theory about excessive environmental fallout / pollution as a source for spotting on the rubber. Domdog31, you're in New Jersey which, lets face it, is heavily industrial and filthy so the potential for you to be on the receiving end of sulfur / acidic fallout is very high. I don't know about bjorngra in the Netherlands, any factories by you? Where's the prevailing winds coming from?
bjorngra
7-22-2006
Netherlands
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 3:05 PM 9-22-2006 | |
I think it's not the pollution because I saw it after I washed the car with clear water. Before the were only a few very little spots. At the moment the dealer is investigate it. But I think that everyone should use original VW products. Perhaps is Krytox bad for the special coating on the seals? And erases the coating.The strange thing is that it's not the whole seal thats get white. I wil post the reaction of my dealer. The other Dutch member EVGUNST said: The grainy texture can be solved by putting on a special VW-gel produced specially for the eos. But I don't know if he tried it? And of it's working.
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Maintaing Eos top seals/weatherstrip with Krytox (bjorngra) » | « » 7:46 PM 9-23-2006 | |
| Quote, originally posted by bjorngra » | But I think that everyone should use original VW products. Perhaps is Krytox bad for the special coating on the seals? And erases the coating.
I fully appreciate a desire to maintain the Eos exactly per the manufacturers instructions (and recommend that approach)...there's nothing funnier than some of the posts you read where somebody thinks they know more than the auto manufacturer, but I'll explain the motivation behind my research which eventually became the top post in this thread. My objective was to find out exactly what Volkswagen was selling for $95 as weatherstrip dressing, and find a less expensive source for the exact same substance, and that's what I've done. You can pay $95 for Krytox in a Volkswagen labeled container at the Volkswagen dealer, or you can pay $29 for Krytox in a DuPont labeled container from a 3rd party vendor...either way its the same stuff. If you read the Krytox FAQ on the DuPont website (see top post), DuPont goes on at great lengths to explain how Krytox is chemically inert, non-reactive, and does not oxidize or break down. That would indicate there is no solvent characteristic to Krytox, so it would not attack the weatherstrip or the coating. Remember the principal application of Krytox is a lubricant. If you read the section about compatibility with seals it reads exactly.... "Is Krytox® compatible with various seal materials? Krytox® is compatible with all seal materials. It is chemically inert." Here's a translated discussion from a German board dealing with the new Beetle Cabriolet over a year ago. Apparently Krytox is also recommended by Volkswagen in that application as well. The discussion was about obtaining Krytox outside of Volkswagen. Apparently the Germans weren't interested in Volkswagens grotesquely overinflated price either. This was my source for the 3 different Volkswagen part numbers. http://translate.google.com/tr...lr%3D
Modified by WolfsburgerMitFries at 5:36 PM 9-23-2006
bjorngra
7-22-2006
Netherlands
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 3:05 AM 9-24-2006 | |
You're right. I'm sorry I did not read everything. So Krytox is the same as the stuff that VW is selling in theire own tube. Hmm.. I think VW is selling all accesoires with tripple prices. Thanks for your short explanation. Did somebody already used Krytox, and did it work to remove the white spots on the Eos?
JML
6-19-2000
Hamburg
Re: Maintaing Eos top seals/weatherstrip with Krytox » | « » 7:38 AM 9-24-2006 | |
Adding in while my Eos is still a few months from production at least, I looked at the three Eos parked near my house after a few rainy weeks and I haven't seen similar white spots on the roof seals. However, I checked the inside of the inner door seals of my Audi A4 (2004 model) and I found some stains similar to the roof stains shown in the pictures posted above. I also found such stains on the wiondow seals of some cars (usually older cars with the softer window seals) parked in my street). To me, they look like the snow stains you get on leather shoes or the decoloring of some chocolate bars (usually the ones that went from hot to cold environment). This *could* (uniformed layman talking here) indicate that the stains might be excess "stuff" (for lack of better word) that the seal "sweats" out under certain conditions. Could those experiencing the stains please think about whether their cars were exposed to rapidly changing temperatures or other conditions that might have caused the seals to first slightly expand (not normal operational squeeze) and then contract. Just an uninformed thought.
Modified by JML at 4:40 AM 9-24-2006
Hotmoose
8-31-2006
Quebec QC
Re: Got it!! (Speedster356) » | « » 11:59 AM 10-3-2006 | |
I bought a 8 onces tube of Krytox (GPL 205) for 125$ canadian. I've used it on my EOS. I'm waiting some rain to see the result. I had only few white spots on the seals. I suspect that it might be wax. When the dealer prepare the car, they probalby wax it...anyway, they waxed mine for sure. These white sopts probably come from the wax....food for thought anyway. Once I got the result I will post a comment.
bjorngra
7-22-2006
Netherlands
Re: Got it!! (Hotmoose) » | « » 1:00 PM 10-3-2006 | |
Ok, when you brought it on didn't it disappear? I have also white spots, but it looks like they not getting more. My dealer is investigating it with the VW Import. 2WKs ago
Modified by bjorngra at 10:05 AM 10-3-2006
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Got it!! (bjorngra) » | « » 1:00 PM 10-12-2006 | |
The top post has now been updated. I bought the GM weatherstrip dressing and traced the Chemical Abstracts Index number of 60164-51-4 to determine an exact match for Krytox GPL105/GM 3634770/VW G052 172 A1. The liquid is silghtly easier to spread compared to the paste GPL-205 but they both will work just fine. It has been mentioned that the liquid may be more prone to unintentional spreading/leaching out compared to the paste GPL-205. I knew the counterman at the GM dealer and paid a discounted price of $34.36 plus tax, but it is still cheaper at gmpartsdirect.com
Modified by WolfsburgerMitFries at 11:37 AM 10-12-2006
Hotmoose
8-31-2006
Quebec QC
Re: Got it!! (WolfsburgerMitFries) » | « » 1:37 PM 10-12-2006 | |
Just an update on my part. I use Krytox GPL 205 and that work just fine. Little white spot disapeared , and I find that GPL 205 is easier to apply because its a grease, so no leak. I got also a liquid lubricant from PBR and used it on my other car, but the liquid tend to leak all over the place.Bottom line, use whatever its best for you. For me I continue to use GPL 205 with a little paint brush
PanEuropean
Moderator Emeritus
11-3-2001
Victoria, BC / Zurich, Switzerland
2004 W12
Re: Got it!! (Hotmoose) » | « » 2:45 AM 10-20-2006 | |
Archival Note: related discussion - Unwanted sounds from the roof (Squeak and Rattle Repair Kit)
bjorngra
7-22-2006
Netherlands
Re: Got it!! (PanEuropean) » | « » 10:18 AM 10-21-2006 | |
Yesterday I got the VW Lubricant from my dealer. Just made a picture of it. I got it for FREE. It's guarantee they said.I brought it on today. It's very simple. Just spray all the rubber seals. I half opend the roof to spray the sides of the seals that are not visible from the outside. De white spots are gone. I'l hope for a long time. The lubricant spray is almost empty. 100ml I ask or I can get another one 'for free?".
just4fun
10-29-2006
Red Deer AB
2007 Eos 2.0T DSG Sport, 2006 Honda Ridgeline, 2000 Honda Odyssey, 2006 Jetta 2.5 5spd
Re: Got it!! (Hotmoose) » | « » 6:44 PM 10-29-2006 | |
Haven't got my EOS yet, so I can't comment on whether or not I have white spots yet.The idea it may be caused by wax, or other protectant, sounds plausible. The white spots do look a bit like wax residue in the photo. Have the cars with the spotting problem been through an automatic car wash that has a wax or clearcoat protectant cycle?? If wax is the culprit, the krytox grease may prevent the wax from adhering, and solve the problem. hmmm??
2007 EOS 2.0T, DSG, Sport Leather, Candy White on Beige. Build Date: Dec 12 2006
vweosdriver
10-30-2006
Spanish Fort AL
2010 Ford Fusion Hybrid
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 10:18 AM 10-30-2006 | |
I have enjoyed reading the many posts on this subject. I have a seal lubricant/protector from BMW called Gummi-Pflege part # 82 14 9 407 015. Would someone please cross reference it to see if it is the same as the Krytox? It has no CAS number on it. It is in a 75ml tube with a foam applicator. Also on the tube is D-80788 Munchen and Tel. +89/3 1170 08. TIA
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Maintaing Eos top seals/weatherstrip with Krytox (vweosdriver) » | « » 12:15 PM 10-30-2006 | |
The best way to see what your BMW part number contains would be to get a MSDS sheet from your BMW dealers parts counter.It is a good idea to to still keep an eye out for alternative sources for Krytox, we may stumble on a cheaper source yet. I'm sure both BMW and Volvo have Krytox in some form, because they both offer convertibles, and now they both have RHT convertibles. I'll see what I can learn next time I'm at the BMW dealer...who also happens to be the VW dealer. (minor edit - Michael)
Modified by PanEuropean at 4:19 PM 11-14-2006
vweosdriver
10-30-2006
Spanish Fort AL
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 4:11 PM 10-30-2006 | |
Although the product is no longer available from BMW, the dealer did get me a MSDS. It contains n-paraffins and silicon. One nice thing about it is that a few minutes after applying it the rubber absorbs it. Thanks for your reply and the work you've done researching the Krytox products. I'll probably buy the GM product. My Eos arrived at the port today so I should have it in a couple of weeks.
IchLiebeVWs
10-10-2006
Tacoma WA
2007 VW Eos
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 9:06 PM 10-30-2006 | |
I would like to thank you for all the input into the lubricant. My car started showing those white strips on the weatherstripping and when I took my car to the dealership to get the windows tinted I asked them for the lubricant and the service guy wanted to argue with me that he did not want to order the lubricant for me until he knew that it was the right product. I had to explain to him that I have been viewing the information on Vortex since the beginning of the EOS site and that the threads stated what the product was and that the information was available in the owners manual. I liked being an informed consumer. Thank you, thank you, thank you!
just4fun
10-29-2006
Red Deer AB
Re: Maintaing Eos top seals/weatherstrip with Krytox (vweosdriver) » | « » 9:19 PM 10-30-2006 | |
I did a little research on Krytox on the Dupont website and offer the following info for INFORMATION only. Krytox is an inert liquid lubricant composed of flourine, carbon and oxygen. According to Dupont, "Krytox lubricants for seals and gasket material do not cause cracking or swelling and are compatible with all plastic and synthetic rubber." To create Krytox grease Dupont adds PTFE (a form of Teflon) to thicken the product. As far as I can tell the specific product used is Zylon PTFE. PTFE is composed of flourine and carbon. Making it a very similar product to Krytox. I could not find anywhere on Dupont's site where it confirms PTFE compatibility with plastic and synthetic rubber. With being such a similar product, one would assume it would be compatible. Only bringing this up because the VW OEM product is the liquid Krytox, which would be 100% Krytox, without the added PTFE. The thicker the grease, the higher the PTFE content. Not suggesting anyone change from the grease product if they are happy with it, but wanted to put the info out there to assist in the decision making process. It's possible VW markets the liquid form due to the absence of PTFE??
Bef
11-20-2005
Shaker Heights OH
2007 VW EOS, Island Gray 2.0T
Re: Maintaing Eos top seals/weatherstrip with Krytox (just4fun) » | « » 5:07 PM 10-31-2006 | |
PTFE is Teflon. It is incredibly inert and is safe to use on plastics and rubbers. It is widely used in automotive and aerospace applications as a gasket & seal lubricant. It also has the lowest coefficient of sliding friction known. (yahoo for being a chemist!)
2007 EOS 2.0T DSG, Island Gray on Titan Black
Bef
11-20-2005
Shaker Heights OH
Re: Maintaing Eos top seals/weatherstrip with Krytox (Bef) » | « » 5:20 PM 10-31-2006 | |
Also, I ordered the Krytox grease from Darrel Kinkaid at THT Group Inc (mentioned in original post)... There was a 2-tube minimum at $29 per tube (2 oz), plus shipping. Nice guy, for sure.
just4fun
10-29-2006
Red Deer AB
Re: Maintaing Eos top seals/weatherstrip with Krytox (Bef) » | « » 7:58 PM 10-31-2006 | |
Thanks for confirming compatibility Bef
jhlong
11-1-2006
Venice CA
2007 VW EOS Silver Sports/Black Leather/18"/PDC
» | « » 1:58 PM 11-2-2006 | |
I went to the THT Group webpage, but I couldn't find the lubricant (although being a new owner, I'll admit I don't know exactly what I'm looking for). Can someone please tell me the name of the product as it is listed on their webpage?
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: (jhlong) » | « » 2:59 PM 11-2-2006 | |
I don't believe its on the webpage, it was a non-stock part number when I ordered, with a 2-3 week lead time. Just call / email part number GPL 205 per the top post to Darrel Kinkaid. Someone mentioned there is a 2 tube minimum, perhaps someone else wants to split an order with you? Instant message jhlong if interested.
Modified by WolfsburgerMitFries at 12:40 PM 11-8-2006
Bef
11-20-2005
Shaker Heights OH
Re: (WolfsburgerMitFries) » | « » 3:55 PM 11-2-2006 | |
^^^ What he said. I called Darrell and he was very helpful.
theothereos
10-9-2006
Durham NC
2007 EOS - Thunder Blue, 2.0T - Sport
Re: (WolfsburgerMitFries) » | « » 12:23 PM 11-8-2006 | |
Product is not on the website, but you can contact Darrel via e-mail (dkinkaid@thtgroup.com) or phone +1 650 595 1112GPL 205 prices are as follows: 2 ounce tube: $29.00 each 8 ounce tube: $88.40 each 0.8Kg Cartridge: $244.25 Each Various containers per Kilogram: $290.00 each I purchased the 8 oz tube and white spots are gone.
Timokreon
11-13-2006
Davenport Iowa
2007 VW Eos 2.0T Thunder Blue/Moonrock Gray
Re: Maintaing Eos top seals/weatherstrip with Krytox (WolfsburgerMitFries) » | « » 10:57 AM 12-1-2006 | |
A question for all my wonderful VW owners. Yesterday my area had it's 1st snow storm of the year. On my way home from work I started hearing a kind of clanking noise from the roof, sounding like it was coming from the back area of the roof, perhaps over the rear seats or towards the rear window.I have applied the krytox on as many seals as I have found, so I am curious about 2 things. 1) How often are people putting krytox on their seals? 2) I'm thinking of just taking this into the dealer when I take it in to replace the MFD and tell them about it. Perhaps they will use the rattle kit that has been spoken about on a different thread, or?? Any suggestions or comments would be helpful
PanEuropean
Moderator Emeritus
11-3-2001
2004 W12
Re: Maintaing Eos top seals/weatherstrip with Krytox (Timokreon) » | « » 5:31 PM 12-1-2006 | |
| Quote, originally posted by Timokreon » | | Yesterday my area had it's 1st snow storm of the year. |
Tim: That's an understatement if there ever was one. That 'first snowstorm' you referred to was such a doozer that it even made CNN news here in Europe - see this link: Storm causes death, trouble across mid-U.S.. The clanking noise you heard was probably the roof collapsing from the weight of all the snow on it. Be sure to melt all the snow and perhaps wait a few days before you take it in to the dealership to get a new roof installed, to ensure that VW doesn't put 2 and 2 together... Michael
mark_d_drake
8-16-2006
San Mateo CA
"MY VW EOS" EOS 3.2. Thunder Blue/Moonrock, Sport, Tech, RNS-510, Dynaudio, iPOD and Bluetooth!
Re: Maintaing Eos top seals/weatherstrip with Krytox (PanEuropean) » | « » 5:51 PM 12-1-2006 | |
Interesting question.. What is the snowload for an EOS roof
$7.26.. That's what we'll be paying a gallon in CA to balance the budget
Timokreon
11-13-2006
Davenport Iowa
Need Help » | « » 4:36 PM 12-3-2006 | |
Hello everyone! I need some help with the seals and krytox. I am curious how often people are putting krytox on their seals? Also, how much do you put on your seals? Just a little tiny bit, or???? I have also gotten some on my paint My own fault and am curious what people recommend to get it off your painted surfaces? My problem seems to be that if I don't put the krytox after almost EVERY carwash, then I end up hearing all kinds of rattles etc.. coming from the roof and trunk area. Very annoying So any and all help would be appreciated. Perhaps I should just let the dealer wash the car and let them apply the krytox after washing?
WolfsburgerMitFries
7-4-2005
Lexington KY
Re: Need Help (Timokreon) » | « » 5:14 PM 12-3-2006 | |
Tim, up on the top post, my most recent update is a link to a Dupont pdf dealing with durability (see first link at top). They seem to think an application can last 4 years pretty easily. Krytox does not evaporate quickly like petroleum based oils and greases can, nor does it wash off easily. I would think 2 applications a year would be more than enough, even for daily drivers in harsh environments. On my cars, the GPL-205 paste I've applied stays on the weatherstrip so long, that the only problem I've had is occasionally forgetting about it and ending up with a handful of Krytox when I rest my hand on the weatherstrip inadvertantly. I have not used the GPL105 oil as a weatherstrip dressing, but I have used it for door hinge and throttle cable lubricant, and I also used it in my brake caliper slide pins to replace sil-glyde that I had been using before, its only been 1 week since I repaired my brakes, so I won't be able to check durability for a while, but the brakes do seem to grab a little faster now...but that might be new parts too, we'll see. As far as getting it off paint, my real world experience is that its a non-issue. It just wipes off with an old cotton cloth. Krytox is inert and has no solvent sharacteristic, so it won't damage paint either.
Modified by WolfsburgerMitFries at 12:35 AM 12-4-2006
