aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
 Passenger door closing improperly.« »
I've just started noticing that ocassionally my passenger door (right hand door) shuts with the window on the outside of the seals rather than tucking up inside. I haven't done any testing yet to see when and why this occurs. All I can speculate is that the auto roll down function that is supposed to occur when the door opens to clear the seals is not rolling down all the way. Thus when I close the door the window can't slide under the seal but instead mates with the outside. It is an obvious malfunction due to the fact that it leaves a crevice into the car a few millimeters wide along the entire trailing edge of the window.
Before someone points out that this may be the cause of the window rolling down in excess of 4 inches at random, I would like to say that on my car the passenger window rolls down sometimes when I put the top up so I believe it to be a separate problem even if it may have the same outcome. However, this issue may explain why after going out to eat with a friend we returned to my car to see the passenger window rolled halfway down. I assure you the car was off with windows rolled up and car locked when we went inside. Perhaps the car realizes there is an issue with the door not closing properly and it takes a similar action.
Whatever the case may be I am taking my car in this afternoon if possible to explain the issue to my dealer and ask what VW intends to do about this. At the vary least I expect to hear that they will resolve this issue under warranty. My guess is that it will involve a fix for the ecu which rolls the window down more when you open and close the doors thereby clearing the seals fully before rolling back up.
*** UPDATE ***
Went by the dealership, big surprise they know nothing of the problem. I'm going to set up an appointment with a service tech this week I suppose.
*** UPDATE ***
I've done some testing and here are the results. After nearly 20 cycles of openning and closing the right and left hand doors I've come to the following conclusions. The LHD and the RHD do not operate the same when openinng the door. The LHD rolls down the window about 1/4 of an inch and thus clears the seals when openning and closing. The RHD rolls down less and thus catches the seal during every openning and closing. Usually the door closes just fine anyway but ocasionally the glass does not make it into the groove in the seal and that activates the pinch protection. The window then rolls down excessively. Finally, on very rare ocassions the window doesn't make it into the seal and doesn't immediately activate the pinch protection thus it closes on the outside of the door. Although I did not wait to see what the car did in this situation I will assume that later the car realizes the error and rolls down the window even when technically off and locked.
Modified by aflaedge at 12:04 PM 9-23-2006
Modified by aflaedge at 12:06 PM 9-23-2006
VERY Old and Busted: Ruby Mica 95 Subaru Legacy Brighton with crowbared locks, busted glass, and a ripped out stereo.
New and Busted: Thunder Blue 07 VW EOS Luxury with dynaudio, beige interior, and a leaky roof.
New Hotness: Thunder Blue 08 VW EOS Lux with dynaudio, moonrock grey interior, and better seals!
Pelican18TQA4
12-13-2000
Burbs of Philly PA
'09 Jetta TDI l '09 Jetta TDI DSG l '02 Golf GL TDI l Audi R10
 Re: Passenger door closing improperly. (aflaedge) »« »
Oh gees, I'm having visions of the New Beetle convertible when it was first released!! They too had this same problem, took two model years to come up with a fix.
2009 Jetta TDI
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
cb391
3-12-2006
Saw two Eos' today that had the pinch problem on the sonroof seal. One was on the passenger side and one on the driver's.
"After The Fact" Archival Note from Michael:
Long after this discussion started (it is mid February 2007 as I add this note), the solution has been found and well documented. To save anyone who comes along in the future from having to read through all 5 pages of this discussion, here is where you can find the solution -
For pinched roof seals, see this post: How to solve (or prevent) Eos Roof leaks
NOTE: Lubrication of the roof seals is the first step that must be taken before any other investigation or troubleshooting is attempted!
For side windows that do not properly engage the roof seals, see this post: Phantom operation of Eos front windows
Michael
Modified by PanEuropean at 11:09 PM 2-26-2007
Andy
2007 Eos 2.0T Sport, Eismeer/Cornsilk, DSG, DynAudio D.O.B 8-1-2006
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
*** UPDATE ***
I've started dialogue with VW service reps to see if this sort of thing is being discussed in the VW service tech circles. If anyone else has spoken to their service dept about this issue please keep us all posted. I am eager to find a solution. It was also mentioned in another thread that a similar problem had occured on several of the newest Golfs in Europe. Any insight into that as well as any solutions that came from it would be greatly appreciated.
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
*** UPDATE ***
It happened again. This time in the rain I'm going to the dealership today. I'll post what I can when I can. If anybody has had any experience with warranty claims and VW I would appreciate the advice. As of right now my tactic is going to be cool and collected however I anticipate a shift towards yelling and finger pointing.
*** UPDATE ***
I've spoken with VW's Customer Care Center and they have openned a Case file on it associated with my car. If anyone else is currently having this problem I suggest contacting your dealership and calling 1-800-822-8987. I don't know if you can ask for a specific call handler, but Mrs. Smith understands the issue. Besides the case file she sent off an email to the service manager at my dealership to expedite service. Furthermore, she will be contacting me today during or after the appointment to keep VWOA informed.
Modified by aflaedge at 6:09 AM 9-29-2006
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
*** UPDATE***
Well I took it in to the dealership and I think we are working towards an acceptable solution. I'm not sure if they really knew what was coming down the line since at first I got a bit of the runaround as they shifted me from one person to the next. So to each sales person, service rep, service mechanic, and anyone else who asked me why I was there or what they could do to help I explained the following set of events.
I told them about how on my own as well as through this community we had discovered a glitch that is both safety and security critical. I explained that through our own individual efforts no one had come to a solution but we were pretty sure what was causing it. I further recounted my own experience thus far and how my sales rep never got back in touch with me or how several attempts to contact/visit the service center were ignored. I was particularly clear on that point because in fact one service tech admitted to losing the original note he had taken when I had called them earlier in the week about the problem.
So the end result of a 2 and a half hour visit on friday was that VW was aware of this problem and that there may possibly be a fix which takes about two hours to do. So I will be taking my car in Monday morning and if they know whats good for them they will give me a loaner for the day. What I found particularly interesting was that after the dealership got off the phone with the VW Techline, I was told that VW had been waiting for me to come in because they had been following the VWvortex site. I guess I won't be asking around here anymore for advice on warranty questionable aftermarket mods.
For those of you who are holding back on getting this fixed. Don't wait, don't let them give you the run around. If they know what's best for them they will get it done now, because I won't settle for anything less than full warranty coverage for the replacement of my now mildew infested carpet, water damaged front seat, and anything else that comes up in the full inspection of my car.
Lemon Law ticker (1/3)
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
The service trip monday went fairly well. I came by at 8:00 and stayed till 10:30. It would have taken less time but I was using their computer for some of my search and rescue responsiblities. They did not get a chance to address my other issues with the potential water damage caused from the whole incident but it is in their system and I will be monitoring the performance of the passenger seat and the smell of the carpet over the next week or so.
The procedure was explained to me quickly but I think I have a fairly good grasp of what occured. Essentially, they repositioned the glass window and adjusted the angle at which it rolled up at. Furthermore I noticed the passenger window now rolls down farther than before on the initial unlocking of the car.
Unfortunately, I experienced the same problem again today. I haven't tested the full gambit of situations which previously caused the issue, but here is what I have observed. I took the top down and up once and there was no issue. My passenger exited the vehicle and closed the door, (harder than I would have liked). The window preceeded to roll down to the infamous 4 inches. I then rolled the window up and as soon as it mated with the seal it rolled down again. Finally, I got it to stay up on the second try. Later today I'll give it a few tests, I'll be curious to see if the force of closing the door is the key factor. Perhaps the frameless nature of the window is allowing it to bounce and loose contact with the sensors in the seal.
Anyway I left a message with the dealership along the lines of they will be getting my car for as long as it takes once they work out the details with VW and I will get a loaner. No more taking time off work.
Lemon Law ticker (1.5/3) I'm hoping today was just a fluke.
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
Last night i openned and closed the door roughly 100 times and was unable to duplicate the roll down error. I'm not sure how my coworker was able to yesterday. There was about a 20 degree difference in outside air temp between noon and 8pm so I'll try testing it out again today to see if temperature was a factor.
I did however discover something a little peculuar. I'm not sure if this can be reproduced by the rest of you guys because it may have something to do with the fix that VW inacted on my car. When closing the door gently and slowly I've been able to repeatedly keep the window from rolling up that last 1/4 inch that it is supposed to roll up. If you remember correctly the window under normal operation rolls down a 1/4 inch when you first pull the handle to open the door. When you close the door it rolls back up that 1/4 inch to make sure the window is inside the top seal. An easy way to see this is to watch the two horizontal lines on the corner of the window appear and disappear during the whole operation. Unless this has always been the case, my guess is that whatever change VW made to my car it created a overload situation where the window would normally roll down those 4 inches but instead now stays stationary. I have to lock the car, unlock the car, open the door and close the door ocassionally more than once to get it to reset. I suppose going down a 1/4 of an inch and not rolling back up is better than going down 4 inches but it still leaves a crack into the car. I hope I can reproduce this for the VW tech next week. That's right, the regional tech guy should be at my dealership next week to work on the car all day. I'll let you guys know how it goes
P.S. Not many people have been posting about this problem anymore. Have you all found solutions? Can I get a head count of how many people have actually had this problem?
ialonso
8-26-2006
2.0T Eos
mine did it again yesterday. The ackward thing about mine is that we have never seen it do it, we come back to the car to find the lowered window. Yesterday the window went down wiithout the door being used all day. WEIRD !
2007 Eos 2.0T
liquid stereo
2-26-2003
Saint Paul MN
2007 Eos, 1969 Karmann Ghia
Keep posting the updates! I'm interested to see how the situation is resolved.
Also, keep your patience and good luck
Direct your eye right inward, and you'll find a thousand regions in your
mind Yet undiscovered. Travel them, and be Expert in home-cosmography.
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
 Re: (ialonso) »« »
when it went down without the door even being used had you atleast put the top up recently?
ialonso
8-26-2006
2.0T Eos
Not in that entire day, and at least 75 miles.
2007 Eos 2.0T
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
 Re: (aflaedge) »« »
***Update***
It's late and i don't feel like going into my usual amount of detail but basically I took the car in last tuesday and they kept it for a few days with the VW Regional tech. Apparently they made some changes to the doors (make note of this) and washed my car. Then they called me up and I picked up the car after work on Thursday. I must say that I was pretty impressed with how clean my car was and how awesome the tires looked. However, they did a piss poor job on my doors. I will congratulate them on their ability to correct the original problem on the passenger door. This whole weekend I had people getting in and out of my car pretty regularly as I drove all over Virginia and not once did the passenger window roll down. Unfortunately they also decided to work on the driver side door which NEVER had a problem and I NEVER stated had a problem. Low and behold they added it to the work docket on this last visit and now my driver side door has been going down about once a day. I guess this technically doesn't count towards my lemon law tally cause they did fix the initial problem. Anyway they're getting another call tomorrow along the lines of "UN-FARK THIS" Seriously, I never said to fix the driver door and I don't appreciate their desire to premptively tinker with things without full disclosure prior to services rendered.
P.S. I don't know why the LH window is now screwed up. My initial observation is that it rolls down more than it used to and now rolls up slightly less than before but why it might be catching on the seals is a mystery. Perhaps tomorrow I'll have a better idea.
Modified by aflaedge at 10:21 PM 10-16-2006
timetrip
10-20-2006
Apopka FL
 Re: (aflaedge) »« »
My EOS used to have a problem with the driver side window. It would come down very often when I would close the door. I took it to the dealer and they fixed it. They explained when the door is shut, you should only see the bottom line of the pairs of lines that are on the window. When I initally brought the car in, both lines were disappearing under the seal on BOTH doors... oops!
I don't think that this is your specific problem, but I thought you might want to check the lines anyway, as I hadn't read about them on this forum yet.
EDIT: just wanted to bring up another point. If your window rolls down upon close because of the pinch protection, if you try to close it again within 5 seconds, it will not use pinch protection. This would probably explain why you could get it to stay closed on successive attempts. I always had to be real quick on my keys when leaving the car before the fixed it
Modified by timetrip at 9:34 PM 10-20-2006
andrewLI
9-20-2006
Baldwin NY
2007 VW EOS 2T
 LEAKS« »
The car has been leaking since the day I got it. Drivers side at the A-pillar. Same problem - never fixed.
I have owned the car approximately 60 days. The car has been in to VW more than three times for this problem. I have been without the car for a total of 24 days now and counting. It is back for the fourth time.
A word of caution. Take a good look at the seals if you consider this car. Many are dry and chaulky. Brought it to a different dealer this time too.
We are nearing the end with this company. They promise it will be fixed this time. Yeah right. I also have to wait for the VW "Engineer" to come to town each time. They won't let the regular union service tech. touch the car. What good faith they have in these gentlemen.
The worst and obviously most disappointing car purchase ever. All the excitement is gone.
Do your homework.
gilesrulz
11-2-2006
Hollywood FL
09 Tiguan 4Motion SEL Alpine/Charcoal
 Re: LEAKS (andrewLI) »« »
I'm not sure what your exact problems have been, but we got a bunch of rain here this weekend, and I noticed a few drops of water on the driver's A pillar on my car. After some scrutiny, it was coming from outside the car, rolling down the roof and seal when the door was opened, and traveling via the joint in the A pillar to the low spot, about in the middle of the pillar, before falling on my knee. At least in my car, though at first glance it seemed to be coming from the pillar, it actually wasn't.
I don't mean to discount your troubles, I've had more than my share of poor customer service from VW with this car as well, but it's something to look at anyway.
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
3 times for the same problem? Lemon law it. Get your money back and buy something else.
I had a problem that I went in to the dealership for about 2 or three times and I was without my car for about 6 days total but it's been problem free for weeks now that a VW engineer took a crack at it.
I guess the point is that you can stick with it and still have an amazing car or you can back out under federal and state lemon laws. Your call.
Modified by aflaedge at 9:55 PM 11-15-2006
PanEuropean
Moderator Emeritus
11-3-2001
Victoria, BC / Zurich, Switzerland
2004 W12
 Re: LEAKS (aflaedge) »« »
Archival Note: I've merged (appended) this new post of Andrew's onto the end of an existing post that Chris started about the same subject, so as to keep all the related information together.
Michael
wy
11-3-2006
Honolulu HI
2007 EOS 2.0T DSG Eismeer/Beige
Aflaedge,
I have the same problem you had. The driver's side is fine (rolls down 1/4 in so the window clears the roof seal when I close the door).
The passenger side, however, rolls down 1/8 in or less, and hits the roof seal. When the passenger door is open and I can lightly push down the window by hand, and it rolls down an additional 1/8 in (total 1/4 in), so it can clear the roof seal when I close the door. I think the auto roll down feature is not rolling the window down enough - but I don't know why.
Do you know what's causing this?
And any suggestions for my dealer in Honolulu to fix the problem. Would prefer not to have to re-invent the wheel and allow them to do trial and error fix attempts.
WY
PanEuropean
Moderator Emeritus
11-3-2001
2004 W12
 Re: LEAKS (wy) »« »
Quote, originally posted by wy »
Best suggestion I can offer is that your VW tech calls the Eos technical support team at VW of America headquarters in Auburn Hills, Michigan. I am 110% sure that the tech support team has encountered this issue before, and will be able to provide exact guidance to resolve it.
Michael
davidg
8-1-2006
wigan lancashire england
 Re: LEAKS (PanEuropean) »« »
Well still happening to us ,, 3 days in the shop ,,, put some special grease on the rubber
They want to fit a new seal now as you all know who have this prob it is so clear that the window is not level , drops ok at the back edge just the front ,,, same side door [drivers for us ]
aflaedge
6-27-2006
Richmond Va
2008 VW EOS LUX
 Re: LEAKS (davidg) »« »
Tell those guys to call their revolutionary rivals in the USofA for the solution prescribed by the VWoA Techline. One two hour fix is all you need and it won't cost you a dollar... er 0.52778804 pounds.
PanEuropean
Moderator Emeritus
11-3-2001
2004 W12
David:
While I was looking at an Eos in Switzerland earlier today, I noticed two campaign stickers in the trunk of the car. In Europe, 'campaigns' are more or less the same as what Technical Bulletins (TBs) are in the North American market - they are notes sent out advising the dealership service staff about actions that can be taken to improve the quality of the product.
You might want to note the 4 character numbers written on the stickers below, and inquire at your dealership if these campaigns apply to your vehicle, and if so, if they have been carried out. Note that it is normal that changes are embodied into the new car build process at the same time that campaigns are issued, so, if the campaign was issued the same week that the factory was building Eos serial number 9999, then the campaign likely would not apply to any Eos with a serial number of 10,000 or higher. So, if your dealer says "that campaign does not apply to your car", you can reasonably assume that he or she is telling you the truth. The dealers are reimbursed by VW for carrying out the campaign work, which means that they are generally quite happy to do it.
Michael
Campaign Stickers - European Market Only
davidg
8-1-2006
Hi Michael
Thanks for the numbers ,,, will mention when we go again soon !!
Here is a pic ,not good need daylight ,, back edge of the door just opened good 1/2" gap.
Front edge door open is touching the rubber
The other window opens 3/8" equal all the way across
Will get some better pics as soon i can
David
PanEuropean
Moderator Emeritus
11-3-2001
2004 W12
David, thanks for the pics. Even though they are not the greatest quality pics, they illustrate exactly what the problem is, namely that the window is not adjusted evenly from front to back.
My guess (guess!) is that should be a pretty easy problem to fix... I don't think the mechanics of an Eos window are much different than the mechanics of any other VW window, despite the fancy roof.
Let us know what the outcome is once you get an outcome.
Thanks again,
Michael
passat06boi
2-1-2006
Glastonbury CT
2009 VW Eos 2.0T
So VW bought back my B6...and I got a 2007 EOS...
They bought that back because it was a Lemon..33 days...multiple fixes for same problems...
AND NOW... I love my new car...not a problem..
Then...day 5...the CD player get's all scratchy...then fixes itself...
Then...3 days ago...Window Gremlins...
My passenger side door, when not shut hard enough, the window goes up to meet the seal but is outside the seal...and it activates the pinch protection....ARGHH
Can we VAG-COM off the pinch protection?? If we do, will that disable the windows coming down the 1/8 inch when we unlock and open the doors??
'09 Eos 2.0T - Euro LED Tails AMBER CLUB, Euro Switch, Roof Module...
'08 Audi A5 3.2; '08 Range Rover HSE; '04 BMW X5 3.0i; '05 Land Rover LR3; '03 BMW 325xi; '07 EOS 2.0T; '06 Passat 2.0T
owr084
11-14-2004
Fairfax Station VA
2005 VW Passat GLS TDI, 2007 VW EOS 2.0T w/Sport Pkg, 2002 Mazda MPV ES
 Re: (passat06boi) »« »
I noticed you named your Passat "Damien." So, have you decided on a name for the Eos yet? wn the 1/8 inch when we unlock and open the doors??
Quote, originally posted by passat06boi »
Modified by owr084 at 7:58 PM 11-21-2006
passat06boi
2-1-2006
Glastonbury CT
2009 VW Eos 2.0T
I was thinking GIZMO..
The nice Gremlin from the film "Gremlins"
Cute as a button..but still has a problem or two... (he overeats)...
wy
11-3-2006
Honolulu HI
davidg,
Thanks for the photos - they illustrate my car's problem exactly. Only the passenger door window is faulty - the rear part of the window rolls down sufficiently when opening the door, however the front part of the same window does not roll down enough. It appears as though the window is rolling down in a "tilted" fashion, with more roll down towards the rear edge of the window while not pulling down the front part of the window enough. I can still close the passenger door, but it hits the rubber seal each time - and I think it will cause the rubber seal to fall out of place or become damaged prematurely.
Based on the appearance and close similarity of the problem, this must be a common problem for a certain number of vin #s.
I have an appt for the dealer to work on it this Tuesday. Will let you know how it goes.
davidg
8-1-2006
 Re: LEAKS (wy) »« »
Hope this is a better pic,,, with the rubber trapped
Dealer still wants to change the seal ,, will book it in next week ,,,,, HOW will a new seal fix this ,,, as you say wy ,,, NEEDS THE WINDOW LEVELING
Modified by davidg at 8:51 AM 11-25-2006
Modified by davidg at 11:05 AM 11-25-2006
just4fun
10-29-2006
Red Deer AB
2007 Eos 2.0T DSG Sport, 2006 Honda Ridgeline, 2000 Honda Odyssey, 2006 Jetta 2.5 5spd
davidg and wy,
Check out the 'pinch protection, window gremlins" thread on this forum. There is a post there from davidpg that identifies a dealership in Montreal, Quebec, Canada that has figured out the window adjustments required to fix the problem.
I'm sure your local dealership(s) could contact Montreal and discuss the fix with their techs.
Kevin
2007 EOS 2.0T, DSG, Sport Leather, Candy White on Beige.
Build Date: Dec 12 2006
davidg
8-1-2006
 Re: LEAKS (just4fun) »« »
Hi Kevin
I have printed out some pages from here and given to them , told them about this great forum ,,, but they dont know of any uk problems
Have to say the dealer has been great , it is "vw uk" that they have contacted that dont want to know
Dave
wy
11-3-2006
Honolulu HI
just4fun,
Thanks. I looked at that thread and it appears they had a window alignment problem (x-y axis), too. Will ask my dealer to contact VWoA tech and if they don't know, then to call the Quebec dealer.
just4fun
10-29-2006
Red Deer AB
 Re: LEAKS (wy) »« »
Good luck with getting it resolved, let us know how it works out.
Kevin
PanEuropean
Moderator Emeritus
11-3-2001
2004 W12
Just a note to say thanks to everyone, and especially to David, Kevin, and Wy, for contributing all of the excellent factual information to this post. It is just fantastic to have the pictures, because they make it clear exactly what the problem is.
I am pretty sure that if we continue to gather information like this, we will be able to confer "informally" (translation = off the record) with our forum friends at VW, and get some pretty good advice as to what is causing the problem and how to fix the problem correctly on the very first attempt.
Thanks again to everyone who has contributed,
Michael
First  1 2 3 4 5 >  Last
» Return to Eos
