SoCalDubber
7-21-2004
Calabasas CA
03.5 Turbo S Beetle, 06 Passat 2.0T, Mk2 Jetta on 17inch RSs
Complete Idiots Guide To Basic Modding For 1.8T | « » 5:23 AM 10-4-2006 | |
I don't know if this would be considered a FAQ, but as a response to many people needing guidance, I thought I'd put together a basic overview of modding which will get the 1.8T to a well-rounded machine... Performance, looks, handling, etc. I will go in an order which I have determined would be the most logical in terms of level of improvement (ie starting with the basics and getting more specific)...Step 1.1 Programming (aka chipping, reflash) - Most common companies: APR, GIAC, Neuspeed, and REVO - Each of these offer comparable gains in horse-power and torque - GIAC seems to be the "strongest" while Neuspeed is the closest to stock driveability while offering modest performance gains - APR is switchable through the cruise-control functions while REVO and GIAC offer an external switching device (SPS for REVO, Flashloader for GIAC) for an additional charge. Neuspeed is switchable via laptop and an OBD2 connection. - All programming options offer the ability to switch the car back to stock (stock program for an additional cost) with a "dealer lock-out" mode available on APR. - Any modification to the car's ECU will void a warranty. Period. However, as stated above, each program offers a way to "hide" your programming. That being said, there is no way for your chip to be 100% undetectable. Even the "stock program" on the programming is merely an attempt to copy the OEM programming but still is not fool-proof. - Most programming will offer approx. 25-30 hp and approx. 50 ft-lbs of torque gained. - As with any performace upgrade, increasing the engine's performance has risks. However, there has been very little to no direct evidence of any damage caused by aftermarket programming. - Cost for APR, GIAC, and REVO are typically around $499 (installed... never pay for installation...) with Neuspeed being slightly cheaper... There are typically deals to be found at larger show with programming vendors. Step 1.2 Aftermarket Diverter Valve - This is a matter of debate, but most reccomend and upgraded diverter valve (aka recirculate blow-off valve) with aftermarket programming. Typically the increase in boost created by the chip will, in time, cause the OEM DV (diverter valve) to fail. So, in order to get your car performing at its' potential, a stronger DV is reccomended. - Most Common Companies: Forge Motorsport, VF-Engineering, and Samco Sport. - All operate in the same manner and are typically priced between $100-$150. - It is a simple DIY install. Cost is $0. Anyone with minor know-how can install this valve in 15-20 minutes.
Step 2 Exhaust (In this case, Turbo-back) - A turboback exhaust is an exhaust that includes both downpipe, and cat-back... Basically all piping from the turbo back.... - Most Common Companies: GHL Motorsports, APR, and Milltek - For the purposes of this write-up, all prices are based on a 2.5" down pipe mated to a 3" catback. I had this exact set-up on my car and found it to offer the best of both worlds (2.5" and 3" turboback).. People have found that with a larger than 2.5" downpipe, the car loses some low-end power, but with a 2.5" catback, the car doesn't get as much high-end power as it would with a 3". - The turbo-back exhaust replaces the stock piping, which is terribly restrictive. It allows the air leaving your turbo to flow more freely, which, simply put, increases hp. - The exhausts all run about $1000 +/- a couple hundred dollars. - Installation is usually fairly easy and shouldn't cost more than $100 to get your local exhaust shop to install.
Now that you've completed step one at two, your car is performing great and you've spent about $1,800. Your car is putting just shy of 200hp to the wheels and you're now considerably faster/quicker than a stock 1.8T Now, let's address some handling issues Step 3 Rear Sway Bar (RSB) - A rear sway bar (reffered to as RSB), without getting to technical, stiffens the rear of the car to reduce body-roll, which, in-turn, reduces unsteer (a common problem with our cars). - Most Common Companies: <A HREF="http://www.neuspeed.com/products/product_details.asp?app=45|J4&type=2<ype=ns_euro&p_id=240" TARGET="_blank">Neuspeed</A> - The Neuspeed 28mm RSB is basically the "industry standard" - The 28mm RSB will dramatically increase the handling capabilites of the car and will make the car feel more planted in a curve. - Will the RSB really make that big of a difference in the handling/feel? Yes. - The bar is 5-way adjustable so you can fit it to your needs. - Expect to pay about $250 for this bar (shipped). - This is also a fairly easy install. If you have access to a lift, this job is pretty straight forward, otherwise, I'd suggest leaving it to someone with the right equiptment. I wouldn't expect to pay anymore than $50 to have a professional put it on. (See if any local VW owners would like to help you with the install... someone usually has the know-how and ability to do it for very cheap). Step 4 Suspension (Coil-overs, Cup-Kit, Springs) - Coilovers are an all-inclusive suspension set-up. They include the spring (or coil) over the shock body and typically offer adjustability in both ride height and stiffness. - A cup-kit is a spring and shock combination. - Most Common Companies: KW Suspension, Koni, H&R, <A HREF="http://www.neuspeed.com/products/product_details.asp?app=31|G4&type=2<ype=ns_euro&p_id=540" TARGET="_blank">Neuspeed</A>, and many others readily available upon searching. - A coilover set will cost you, typically, around $1,200 (with options going MUCH higher and as low as approx. $700). - A set of Neuspeed springs (for example: Neuspeed Race) will cost about $250. - A set of shocks (ex: Koni Yellow, adjustable) will cost about $500 - Let's start at the basics. Replacing just springs (and not shocks) is typically a bad idea. While you might get the ride-height you are looking for, a lower-ride will inevitably wear out the stock shocks and you will end up with VERY bouncy, uncomfortable ride quality. It is better to just wait til you've saved enough to either do the cup-kit (spring and shock) or save more for a coilover set... or else you'll end up doing installation more than once. - Different springs have different "drop" amounts, and are sometimes classified as "Sport" and "race". The "sport" drop is not as low as the "race". Look to the different manufacturers for drop amounts. - If a set of aftermarket springs are mated to aftermarket shocks (ex: Neuspeed Sport springs and Koni Yellow adjustable shocks), it will allow for an adjustment of ride stiffness. - Coilovers allow for everything a cup-kit does, along with the added ability to adjust height (which is typically the most popular reason one would choose a coilover setup). - Different coilovers offer different lowering capabilities and ride-quality at different settings, but as a rule, the lower you are, the worse your ride quality is going to be... - For more information on each brand and type of suspension set-up, please search. There are countless reviews of each different set-up and each has its trade-offs. - Installation is typically approx. $200 (again, something you can have a fellow enthusiast do for not much more than a 6-pack and a few bucks to make it worth their time...) - An allignment is HIGHLY reccomended after the installation, especially for coilovers. - Click here for a picture of a 20th on Neuspeed Race Springs (and Koni Shocks) - Click here for a picture of a GLI on Neuspeed Sport Springs - Click here for a picture of a GLI on KW Variant 3 Coilovers (not quite all the way down) This is the end of the "basic modding" tutorial. At this point, there is approx. $3k invested in to your car, it is looking great, and performing even better. You have a great mix of show and go and anything past what we've discussed will acheive not as much results per dollar spent. This is merely an opinion-based write-up. Take my views for what they're worth and I hope you're able to use this information to get you through " basic-modding". I recieved absolutely no outside influnce in writing this and all companies mentioned were done so without their prior knowledge. As a basic rule of modding, there are three things. Fast, Good, and Cheap... Pick two, because you'll never get all three Many people responded to this thread asking for it to address a TIP (Turbo Inlet Pipe) and FMIC (Front Mount Intercooler). In response to the calls for TIP, FMIC to be added: I'll consider adding "The Next Step For Dummies" type of post based on the input that I've been getting. However, I have very little personal experience so I don't know how comfortable I feel putting my name to a post which is basically regurgitating things I've heard in the past... TIPs help to allow more airflow to the turbo, and FMICs help to allow the air leaving the turbo to stay colder (theory behind this is colder air=more dense air, which basically means that more air is getting in to the engine, which, in turn, makes more HP). I have found, through the limited experience I've had with the two, that both can be quite beneficial but cross that "basic modding" threshold which most people usually don't want to cross. Again, I did not have either of the products on my car nor do I have the enough personal experience nor research to give my informed decision on the matter. On the CAI (cold air intake) or short-ram intake: I 100% refuse to address the "issue". To me, it is no where near beneficial (enough) to the 1.8T to justify spending the money on and if I had not worked out a sponsorship with AEM, I probably wouldn't have spent my own hard-earned money on it (actually, I lie... I wooshing... Miss it a lot )". If one is hell-bent on the "woosh", realize that a CAI gives a more noticable sound, but the convenience of not having to ever worry about hydrolocking (sucking water through the CAI in to your engine while driving through a puddle... happens every winter), would make me spend my money on a "short-ram" intake (one which utilizes ambient engine-compartment air) vs a CAI (which takes fresh, colder air through the air-vents in your bumper). I don't think the supposed performance difference between a CAI and short-ram in take justifies the added risk (even if it is very rare) of ruining your entire motor.
Modified by SoCalDubber at 5:59 PM 10-4-2006
F*ck the politics. Let's Party! Wuste 2010 -- June 4-6, 2010Pure Euro . We Haters Be Friends With Wuste2010 on Facebook... it'll make you look cool!
BHB
Global Moderator
10-26-2004
Santa Monica, CA
07 A6, 08 GTI
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 5:27 AM 10-4-2006 | |
Need a simple paddle holster for a full frame handgun? : FS: Galco Yaqui Paddle Holster for Full Frame Beretta 92, Glock or Sig - $50 obo.
UntouchableGTI
4-30-2006
All over the Place
02 VW GTI 1.8T Blue..... 97 Golf 2.Slow
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 7:02 AM 10-4-2006 | |
good job now lets keep bumpin this up for the noobs so we dont get this question a million times a day as we do now
I Pagparts USRT FTW
| Quote, originally posted by speeding-g60 » | here is what i tell one of my friends who just runs his dick-sucker all the time.-"when you talk, you teach. and when you listen, you learn. now **** and learn something!"
CBHVR6
7-3-2006
York PA
00 Jetta 2.8T- SOLD, 98 Jeep Cherokee Mighty 4.0
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 7:05 AM 10-4-2006 | |
Nice Writeup
foundubbedriver
1-10-2006
chicago, az
Re: Complete Idiots Guide To Basic Modding For 1.8T » | « » 7:09 AM 10-4-2006 | |
lmfao, this is good...
Daisy 1o.6.o6 Exklüsiv Motorsports | Quote, originally posted by Curtis » | | i want sex. |
CapeGLS
8-2-2002
Here CT
01 Golf GLS 1.8T, 02 Jetta GLS WGN
Re: Complete Idiots Guide To Basic Modding For 1.8T (CBHVR6) » | « » 7:10 AM 10-4-2006 | |
Great....
FlickR WRD WM FL Dunlop
Infamous1.8TWB
2-20-2006
Pittsfield Ma
2001 VW 1.8T, 2007 Rabbit
Re: Complete Idiots Guide To Basic Modding For 1.8T (UntouchableGTI) » | « » 7:15 AM 10-4-2006 | |
Verdict Motor SportsHow do I get the Jeep Avitar?
rs4-380
12-12-2000
Maine
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 8:33 AM 10-4-2006 | |
| Quote, originally posted by SoCalDubber » | As a basic rule of modding, there are three things. Fast, Good, and Cheap... Pick two, because you'll never get all three |
good work, but it should be reliable, not "good". it's kind of hard to qualify good.
Dave - The Blog 09 S5 00 A6 Avant 87 EJ25 Powered Vanagon Syncro 80 Rabbit 034EFI 16v
starr18t
11-26-2005
Charlotte NC
2001 VW Jetta 1.8T
» | « » 8:51 AM 10-4-2006 | |
well i seem to be on track. I guess the RSB is next on the list. Great write up
So many mods they made me shorten my sig Chapter 11 Go broke or drive trying
VeeeDubn
3-31-2005
Louisville Ky
2008 Rabbit
» | « » 9:14 AM 10-4-2006 | |
nice job.
2008 Rabbit "KENTUCKY: Five million people, Fifteen last names."
core5
4-28-2006
Marietta Georgia
04 Jetta 20V
Re: (TurboGolfKid) » | « » 9:22 AM 10-4-2006 | |
Great write-up. Nothing really new, but at least it is concise and in one thread. I think it might be worth adding something about intake. I know it doesn't do a whole lot for the 1.8T, but replacing the TIP and possibly the airbox will help some at higher RPMs.
VCDS (VAG-COM) Registered User: Hex-USB+CAN Interface VAG-Tools (exhaust/dyno database/tuning guides).:James
midnightbluegli
4-4-2004
miami fl
03 Civic SI-T
even though i have a vr6
Dub Cartel
CLICK HERE FOR BEST PRICES ON TIRES
Ben1.8T
2-21-2006
Malvern PA
oh four & a half
Re: (midnightbluegli) » | « » 9:31 AM 10-4-2006 | |
I love that the letters C, A, and I are nowhere in there!but I must say, stubby antenna should be on before you leave the dealer...
███ ............................................................................................................MyScrapple
rpmk2000
6-27-2005
Somerville ma
2001 VW GTI 1.8T
» | « » 9:32 AM 10-4-2006 | |
nice write up
00boraslow
5-22-2004
Lower Burrell PA
2008 4-dr Candy White GTI
Re: (rpmk2000) » | « » 9:58 AM 10-4-2006 | |
| Quote, originally posted by rpmk2000 » | | nice write up |
x2
2008 GTI - Candy White - 4-dr - Autobahn Package - 6-spd - 35% Tint - Euroswitch - GTI Monster Mats - ESE Color Matched Side Markers - New South Boost Gauge - Front Votex Lip, R32 Rear Valence w/ Eurojet R32 Exhaust, & Color Matched Side Skirts
EFYH
6-27-2003
Vancouver BC
02.5 GTI 1.8T
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 10:00 AM 10-4-2006 | |
Nice write-up! But I'll have to point out the somewhat glaring omission of the turbo inlet pipe in your list of basic mods for the 1.8T. Bang for the buck, it's tough to fault the Forge Motorsports TIP.
My photos @ Flickr | Blitzkrieg Autowerks
redline_gli
9-14-2006
Taunton MA
g-l-i
» | « » 10:06 AM 10-4-2006 | |
Beautiful write-up!
ItDiesToday
10-10-2005
Cape Town S.Africa
Mk4 Whore
Re: Complete Idiots Guide To Basic Modding For 1.8T (EFYH) » | « » 10:08 AM 10-4-2006 | |
| Quote, originally posted by EFYH » | | Nice write-up! But I'll have to point out the somewhat glaring omission of the turbo inlet pipe in your list of basic mods for the 1.8T. Bang for the buck, it's tough to fault the Forge Motorsports TIP. |
x2
EÜRÖStiehl lodator in'08
| Quote, originally posted by lodator » | | No, in reality, he was trying to get in to your pants...simple but effective pick up line...obviously did not work though.. *re-thinking pick up lines* |
The mk4 forum ultimate chillers club...for people who chill mad hard
tchristemac
2-4-2005
Das Geschaft NY
BAGGED MK4 Jetta 1.8T, LAND ROVER DISCOVERY HSE, 07' PASSAT AVANT 3.6 30V 4 motion
Re: Complete Idiots Guide To Basic Modding For 1.8T (xitdiestodayx) » | « » 10:12 AM 10-4-2006 | |
Great write up..... and this sld be locked UP TOP.....moderators keep this thing up top please?????
REVO forge FORGELINE WHEELS DAS JETTA
redfred18T
5-28-2004
chicopee, ma
07 335i
» | « » 10:35 AM 10-4-2006 | |
Either throw this in the faq secton or make it a sticky in this forum, it should help those pesky newbs
AIM: redfred18t| Quote, originally posted by shylo » | | Trying to sell your car with pics of it on a trailer is like trying to ask a girl out while shes getting boned by another dude. |
Spa_driver
7-30-2005
anytime
03 1.8T Wolfsburg Jetta/07 Forester X 5-speed
Re: (starr18t) » | « » 10:43 AM 10-4-2006 | |
Whenever I drive thru beautiful Calabasas I always think "These people must have a lot of time on their hands!". Good write up
GIAC X+-by Jeff Moss
jettaIIIspeed
4-25-2005
Re: (Spa_driver) » | « » 10:48 AM 10-4-2006 | |
awsome write up hopefully this will stop all the pointless post that go up .... good thinkin on this one
gre9del
7-17-2006
Fresno CA
2003 Jetta 1.8t / 2007 Passat 2.0t
» | « » 11:16 AM 10-4-2006 | |
Good job man! Everyone reply to this. If it's bumped long enough, it'll stick!
---StÖrmTrpr---- I Don't Ride In Single File To Hide My Numbers Cencalvw.com Represent
tvarmy04
10-29-2004
RIVERSIDE CA
01' vw [g]etta glx vr6
» | « » 11:23 AM 10-4-2006 | |
wow! awesome write up!! i for one asked all those famous turbo questions at one point. I VOTE THIS BECOME A STICKY !!
jettaIIIspeed
4-25-2005
Re: (tvarmy04) » | « » 11:25 AM 10-4-2006 | |
who votes this to stick say eye!!!
2003 gtivr6
6-30-2003
Pittsburgh Pa
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 11:25 AM 10-4-2006 | |
Great write up!
jettaIIIspeed
4-25-2005
Re: Complete Idiots Guide To Basic Modding For 1.8T (2003 gtivr6) » | « » 11:34 AM 10-4-2006 | |
now someone should take the time up to write one about the vr6 and it will be set i would but that looked like it took a lot of time and i cant sit here and do all of that but yea some one should def get on that
12PSI
1-2-2006
Raleigh NC
2002 GTI 20V - 07 Audi A3 s-line
Re: Complete Idiots Guide To Basic Modding For 1.8T (bhb399mm) » | « » 11:48 AM 10-4-2006 | |
GREAT WRITE UP! now if we can only get people to read this BEFORE posting
oj1480
6-6-2006
Brklyn Queens ny
new beetle 98, audi a4 98, jeeta 05
» | « » 11:51 AM 10-4-2006 | |
GOOD
----/========\ ' ---------''/==========\ (]/_ _____ _\[)-----(]/_ ________ _\[) ''/(OO)--[H]--(OO)\'--------(O8o)==\X/==(o8O) '|------||||||||------|------|\=============/| [__|--------------|__]--.-'[__|===========|__]
ARMYVDUBVR6
4-22-2006
Miami _ Tacoma FL _ WA
12v VRT 6spd
Re: Complete Idiots Guide To Basic Modding For 1.8T (12PSI) » | « » 11:53 AM 10-4-2006 | |
| Quote, originally posted by 12PSI » | GREAT WRITE UP! now if we can only get people to read this BEFORE posting |
haha hell yeah!
CTSTurbo!!| Quote, originally posted by DubberFromAnotherMother » | We have a beautiful bromance. |
| Quote, originally posted by Mr. Glidden » | | Josh, will you be my vortex body guard? |
Iraq and Afghanistan Veterans of America (IAVA)
bootymac
4-18-2005
Vancouver BC
00 GTI 1.8T
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 12:02 PM 10-4-2006 | |
What, no TIP?
project satin
jdahlstrom
8-11-2005
MA
Re: Complete Idiots Guide To Basic Modding For 1.8T (SoCalDubber) » | « » 12:06 PM 10-4-2006 | |
| Quote, originally posted by SoCalDubber » | Step 3 Rear Sway Bar (RSB) - The bar is 5-way adjustable so you can fit it to your needs. |
I know it says 5-way adjustable on the Neuspeed website, but how do they figure that since there's only three different settings? Are they saying 5 since you can adjust the endlink length, or did they actually change the bar so there's now 5 different firmness settings? Great write-up by the way!
I lost you two months ago! We broke up! Are you mental? Get the net!
SoCalDubber
7-21-2004
Calabasas CA
Re: Complete Idiots Guide To Basic Modding For 1.8T (bootymac) » | « » 12:12 PM 10-4-2006 | |
| Quote, originally posted by bootymac » | What, no TIP? |
I think the TIP would be a great next step, but that seems to start to get past "basic". I was trying to take care of the stuff that is very common-place and "needed". I could also have included a 4-bar upgrade, but I would conisder these the "next step" in modding... All of these things can be done without ever having to think twice (and are very easily installable)....
jduarte
9-5-2006
Chico CA
03 GTI 1.8T RIP '92 GTI VR6 Monty
» | « » 12:21 PM 10-4-2006 | |
Damn y0! I'm going to take this opportunity to thank you from all the newbs. I've been searching and reading everything I can click my mouse on for the past two weeks and it's like you put it all in one spot.
| Quote, originally posted by Warrior Legend » | | You know nothing about 2005 Easton Warrior football. You need to get a fire under your ass or else you'll probably just get in your pick-up truck with your girlfriend and have no part in special forces. WARRIOR FOOTBALL RULES!!! |
jettaIIIspeed
4-25-2005
Re: (jduarte) » | « » 12:29 PM 10-4-2006 | |
| Quote, originally posted by jduarte » | | Damn y0! I'm going to take this opportunity to thank you from all the newbs. I've been searching and reading everything I can click my mouse on for the past two weeks and it's like you put it all in one spot. |
there is one count it
