LUME
Subdriven Member
2-5-2003
Pottstown PA
 Jetta IV AEG does not start - P0322 "engine speed sensor" suspected« »
Ok, my girlfriends car wouldn't start, so I started diagnosing the old fashioned way. Fuel pump ran, exhaust smelled like gas. So no problem with the fuel delivery. Checked for spark, no dice. So I did a bonehead move and ordered a DIS coil (this is a Jetta IV with the AEG engine) from germanautoparts.com, but that didn't solve the problem.
So I went out and bought a scan tool, which revealed code P0322, which somehow relates to the engine speed sensor. Now, I noticed in the [crappy] bentley manual that I borrowed from a friend that the engine speed (crank) sensor is only mentioned in the fuel injection section, but no matter. I checked (what I believe to be) the engine speed sensor as per the manual and saw infinate resistance accross all three wires (one of the combinations, between terminals 2 and 3, should read between 480 and 1000 ohms). So, my first question.... Is this picture accurately showing the "engine speed sensor" connector?
And if so, I believe the connection cable routes to this sensor, which is sort of located to the lower right of the oil filter (as vied from in front of the car looking at the engine):
And final question, is that if this indeed IS the engine speed sensor, and it is indeed preventing the car from starting (as the manual/scantool suggests it would), does anybody have the VW part number so that I may avoid a whole bunch of headaches at the VW dealer?
I would appreciate any help.... My girlfriend is growing tired of a 1+ hour commute in my somewhat uncomfortable impreza, and I'm getting sick of driving my dodge ram to work....
Once again, just to clarify.... 1999 Jetta IV, auto, 2.0 AEG.
Thanks a bunch.
Modified by LUME at 1:20 AM 10-6-2006
randallhb
9-17-2002
Managua Nicaragua
2001 VW Jetta GL (AEG), 2003 VW Jetta GL (BEJ)
 Re: Jetta IV AEG does not start - P0322 "engine speed sensor" suspected (LUME) »« »
Is this the same as "crankshaft position sensor" and "impulse sender", if so the part number is 06A 906 433C for AEG engines.
BTW the engine will not run, or stop running if this sensor goes bad.
Modified by randallhb at 8:19 PM 10-5-2006
OEM HIDs | 4motion front GLI rear & skirts | GLI Recaros | GLI tail lamps | GLI black grille | GLI exhaust | OEM FIS Cluster | OEM Dash Kit | Turbo S Door Pins | R32 Pedals | Upsolute Chip | K&N Filter | W8 Console | Rieger Iluminated Shift Knob | TT Short Shifter | Sunglass Holder | Molded Mats | Euro Split Mirrors | Aero Wipers | Long Beaches | Smoked Sidemarkers |
LUME
Subdriven Member
2-5-2003
Pottstown PA
 Re: Jetta IV AEG does not start - P0322 "engine speed sensor" suspected (randallhb) »« »
It definitely is a crank position sensor of some kind, so I guess this is it... Thanks for the input!
--Roy
LUME
Subdriven Member
2-5-2003
Pottstown PA
Part number is correct, and car now starts! Thanks!
mhamill
10-1-2006
Miller Pl NY
98 Jetta / 00 Passat Wagon / 05 Touareg / 09 Jetta TDI
Hi - I have a problem where my car stalls when it gets to operating temperature, then wont start till it cools ALL the way down. Was this part of your symptom. I have replaced all I can think of except the RPM sensor - (crank sensor).
I have replaced the following:
Coil, rotor, cap, wires, plugs, IAF sonsor, both coolant temp sensors, air filter. I just looked a the codes and the P0322 was one of many along with a P725 (speed sensor) and a P1580 (idle speed contrl).
I had been disconnecting the temp sensors so there were a few of those in there as well.
I actually have the crank sensor and will slap it in tomorrow regardless. I am just nervous as this car has stranded me (1 hr at a time while it cools) too many time and I am about done.
Did this crank sensor fix yor problem? anything you can think of
Thanks,
Mike
97VWJett
5-16-2003
Bellevue WA
Mk3 Jetta/Mk4 GTI
 Re: (LUME) »« »
Quote, originally posted by LUME »
... and car now starts! Thanks!
Shop Owner/Manager @ IPM Auto Service
16325 Cleveland St
Redmond, WA 98052
425.883.6311
10% off to VWVortex users* | We service AC (R12 and R134)
97VWJett
5-16-2003
Bellevue WA
Mk3 Jetta/Mk4 GTI
 Re: Jetta IV AEG does not start - P0322 "engine speed sensor" suspected (mhamill) »« »
P0322 http://forums.vwvortex.com/zerothread?id=1550552
P0725 engine speed sensor. ECU can't read RPMS
P1580 Just clean the throttle body and you'll be set.
please use this link from now on: http://forums.vwvortex.com/zerosearch
search terms: P0322, P0725, P1580, search archives and topic titles
16325 Cleveland St
Redmond, WA 98052
425.883.6311
Mussen
7-1-2006
Brick NJ
92 cabriolet
I have a CEL with Code P0322. I also have Warm Starting issue. Some times the car wont start after a drive. If i let is sit for a few minutes it Tends to Restart. As of now the issue is still intermittent. The price of the sensor on Worldimpex is $52.00. any one think i maybe able to take it out and just clean it? If not does any one know some where cheaper to get one? I know 52$ is not much, but Im a pretty broke college student. To bad there arent any VW Salvage yards around here....
Mussen
7-1-2006
Brick NJ
92 cabriolet
 Re: Jetta IV AEG does not start - P0322 "engine speed sensor" suspected (Mussen) »« »
any one?
Mussen
7-1-2006
Brick NJ
92 cabriolet
Quote, originally posted by Mussen »
Screw it.....I guess my credit card takes another hit....
» Return to 2.0 Liter Engine Forum
