BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
NEUSPEED Rear Sway Bar DIY | « » 11:12 PM 11-3-2006 | |
I had a little present waiting for me when I got home. It kinda irked me that DHL left the box (with NEUSPEED written across the box) right outside my door all day and not delivering it to the apartment rental office like FedEx and UPS does. It's a good thing I live in a decent neighborhood, otherwise that box would've gone missing... Anyway, let's get on with the DIY.
First of all, take the amount of time you plan on committing to this change and multiply it by two. NEUSPEED claims 1.5 hrs of install time... It's closer to 3 hrs. (unless you're really good with tools and you've done this before). Let's see what you get in the box. Btw, this tutorial should apply to all the sway bars on the market with minor modifications to the steps.
You get the sway bar, 2 polyurethane bushings, 1 package of grease, and three sheets of paper. Throw the paper away -- they're useless. Now, you'll need an M10 and an M6 12-point sockets, a hammer, and a 16 mm wrench. A ratchet or another wrench to turn the sockets would also be helpful. Now jack up the car and place it on jack stands, roll up on ramps, or if you're lucky enough, raise your car on a full lift. Here's where the stock bar is connected to the end links.
Set up your wrenches in some sort of pattern like this using the M6 socket.
Now turn! Remember, lefty loosey, righty, tighty. Remove the bolts on the end links first. Now turn your attention to the brackets.
Unscrew the 2 bolts on each of the brackets using the M10 sockets. Once you've removed all four bolts, the sway bar will fall out of place. Now for the fun part -- wrastle that bastard around the suspension and the exhaust to remove it. I personally had to remove a wheel to get some clearance.
Now remove the original brackets from the stock sway bar (this is where the hammer comes in). New sway bar vs. stock bar with OEM brackets.
Next place the new sway bar in place and connect up the end links -- DO NOT TIGHTEN. Just place the bar in the desired location and put the bolts on loosely.
Now lube up the insides of the bushings and attach them to the inside of the stop washer on the sway bar.
Then put on the brackets over the bushings and replace the screws.
In the end, tighten all bolts. Make sure they're nice and tight. Double/Triple check the entire installation. And finally, Enjoy! (Thanks to a3lad for loaning me the 12-point bolts)
Modified by BalloFruit at 11:11 AM 11-21-2006
2008 Audi A3 3.2Q -- Misano Red, MSW Type 11 wheels, Milltek ExhaustRest in Peace -- 2006 Audi A3 2.0T DSG
yam
7-18-2005
Santa Jose CA
A3 3.2Q DSG S-Line
» | « » 11:42 PM 11-3-2006 | |
Did I just see a crescent wrench?
A32Have
6-4-2006
Irvine CA
06 A3 2.0T, DSG, APR Stg2 w/ TBE, Neuspeed RSB, EVOMS, etc...
Re: (yam) » | « » 12:18 AM 11-4-2006 | |
I would actually use a torque wrench instead of the "nice and tight" method. I torqued mine to spec and they became loose after a month of driving. The sounds the rear made were horrible and it sounded and felt like a big hammer hitting the control arms. I ended up adding 3 more ft/lbs and haven't had any loose bolts for almost 2 months now
Exhaust Vid 0-60 Video I-TrayAudi Meets: Ortega
a3lad
8-6-2005
arlington va
'06 A3 2.0T DSG
Re: (yam) » | « » 10:39 AM 11-4-2006 | |
| Quote, originally posted by yam » | | Did I just see a crescent wrench? |
it was either that or one of these..
crew219
10-18-2000
ITH NY
» | « » 11:03 AM 11-4-2006 | |
Wow . . . I see neuspeed decided to start cheapening out and removed the aftermarket brackets from their kit. I guess it increases their profit margin though  Dave
Forge DV Review APR SII beta logs REVO 93 logs APR 93 logs
dhltal
5-25-2006
Sacramento CA
2006 Audi A3 2.0T
» | « » 11:40 AM 11-4-2006 | |
Great write up!
2006 Audi A3 2.0T Arctic White DSG Premium Open Sky Bi-Xenon NAV+(Retrofit) Neuspeed Flash, Genuine S3 Mirrors, Euro Blindspot Mirrors, AWE Metal Downpipe, Forge Diverter Valve
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
» | « » 3:21 PM 11-5-2006 | |
If the old NEUSPEED brackets were anything like the AutoTech brackets that a3lad had, then I'm happy to stick with the OEM ones. They are definitely stronger and more durable than the aftermarket ones. And yes -- that is a crescent wrench. I didn't have all the correct tools, so I improvised... The difference is uncanny. I love how the rear end feels so locked down. There's less body roll when I power through turns. Definitely $235 well spent.
azoceanblue
8-12-2006
Sun City AZ
Re: (BalloFruit) » | « » 6:54 PM 11-5-2006 | |
Where did you purchase your rsb?TY, great write up
.:|Scott's 2006 A3 2.0T|Ocean Blue|DSG|Open Sky|:.Euro Plate|Mats|Tails.:|:.KW V2 Coilovers.:|:.Neuspeed RSB.:|:.APR S1.:|:.BSH-TM.:|:.Bridgestone RE760 Sport 225/45/17 94W|:..:| http://www.volkwerks.com |:. .:|Red T Member|:.
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
Re: (azoceanblue) » | « » 9:44 AM 11-6-2006 | |
MJM Autohaus. Forum sponsor. Not bad service, the RSB shipped the same day I ordered.
shagwAg3n
9-9-2006
atl ga
06 audi a3 2.0t
» | « » 1:31 PM 11-6-2006 | |
$235? wonder if that has anything to do w/the fact that it didn't come w/the aftermarket brackets bc on neuspeeds site the bar is listed at around $330?
a3lad
8-6-2005
arlington va
'06 A3 2.0T DSG
» | « » 2:35 PM 11-6-2006 | |
http://froogle.google.com/froo...ab=wf
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
Re: (Shazam!) » | « » 2:49 PM 11-6-2006 | |
| Quote, originally posted by Shazam! » | | $235? wonder if that has anything to do w/the fact that it didn't come w/the aftermarket brackets bc on neuspeeds site the bar is listed at around $330? |
I can't imagine that that's the reason -- $95 for brackets? It's more likely that the NEUSPEED MSRP is inflated. Anyway, it looked like the rubber bushings for the RSB were designed for use with the OEM brackets.
Modified by BalloFruit at 2:51 PM 11-6-2006
A32Have
6-4-2006
Irvine CA
» | « » 6:02 PM 11-6-2006 | |
I bought my RSB from mjm a few months back. It did come with the neuspeed brackets. Neuspeed must have decided to cheap out or possibly found the stock ones to be betteR?
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
Re: (A32Have) » | « » 6:30 PM 11-6-2006 | |
Got a pic of that bracket? The OEM ones are pretty damn sturdy looking.
crew219
10-18-2000
ITH NY
Re: (A32Have) » | « » 6:43 PM 11-6-2006 | |
| Quote, originally posted by A32Have » | | I bought my RSB from mjm a few months back. It did come with the neuspeed brackets. Neuspeed must have decided to cheap out or possibly found the stock ones to be betteR? |
Def cheaped out. Part of the reason why I went with neuspeed was because my stock brackets rusted after one winter. I'm sure there's no functional difference with the two diff brackets, given that they're now using a bushing designed for the stock bracket. Dave
shagwAg3n
9-9-2006
atl ga
06 audi a3 2.0t
» | « » 11:12 AM 11-7-2006 | |
^^^at least i don't have to worry about the rusting part...
placenta
6-2-2003
SF CA
2009 VW GTI
» | « » 12:29 PM 12-6-2006 | |
hmm.. $200 shipped would be even better.
2009 VW GTI (APR, S3 IC, Hawk HPS) 2009 Nissan Xterra FS: ARC Mini 500.1
justdanorm
12-14-2005
Cape Coral. FL/Hannover, DE
2006, Audi A3 2.0T FSI
Re: (a3lad) » | « » 12:42 PM 12-6-2006 | |
OH SNAP!
On: '06 A3 2.0T FSI | Lava Grey Pearl Effect | Grey | 18% | DSG | Conv | OpenSky | 19" Oxigin's | Nitto's | APR Stage II Software | Forge | Höen | H&R Springs | ECS Smoked | Nav+ & Bluetooth Retro Fit | Debadged | AWE Vent Gauge | Neuspeed | APR 3.0" TBE | SiriusComing: Custom Quad-Tips
angryrican66
4-16-2006
Harrison NY
2007 A3 3.2Q Open Sky,Bose,Technology,Cold Weather, Nav,Roof Rails Ibis White
Re: (placenta) » | « » 4:33 PM 12-6-2006 | |
$235 MJM Autohaus, $239 NA Motor Sports either way worth every penny, BTW both include shipping
/Euro S-Line Spings&Shocks/Haldex GenII/http://i98.photobucket.com/alb...8.jpg http://i98.photobucket.com/alb...s.jpg http://i98.photobucket.com/alb...9.jpg
tpliquid
5-1-2006
Panoche ca
» | « » 4:45 PM 12-6-2006 | |
so tempting
this is my eyes when im sober -_- this is my eyes when im high -_-
a3lad
8-6-2005
arlington va
'06 A3 2.0T DSG
» | « » 4:46 PM 12-6-2006 | |
i got mine for fitty bucks (plus the credit i got for my broken bar)
A32Have
6-4-2006
Irvine CA
Re: (a3lad) » | « » 5:44 PM 12-6-2006 | |
And if you live near one of Neuspeeds warehouses, you can get it next day! I think one of neuspeeds wharehouses is in Camarillo, CA
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
Re: (A32Have) » | « » 6:02 PM 12-6-2006 | |
| Quote, originally posted by A32Have » | | I think one of neuspeeds wharehouses is in Camarillo, CA |
Really?!? I used to live in Camarillo!
juan@mjm
Forum Sponsor
3-30-2005
Alamo City TX
1995 GTI VR6
Re: (a3lad) » | « » 7:57 PM 12-9-2006 | |
I'm pretty sure that our price of $234.95 with free shipping is the best out there. If not, please let us know, as we want to take care of you guys the best way possible.Oh, and to BalloFruit: thanks for the order and thanks for letting us know DHL did this (with leaving it on the front). I'm calling our rep on Monday and picking a major beef with them. That is unacceptable!
MJM AUTOHAUS ::: Your Discount Parts and Accessories Warehouse!Warehouse Distributor for NEUSPEED|KONI|Sparco|MOMO|Hawk|ARP ~~~The Home of FREE SWAY BARS with Purchase of Coilovers~~~ ..::: AIM: JUANatMJM - Quaife'd 6-speed MK3 VR6 Kinetic T3/T4 :::..
FlyingTurtle
3-26-2006
Deep In
Assortie of VWs
» | « » 10:33 PM 12-10-2006 | |
i like my Neuspeed as well. At the stiffest setting of course
| Quote, originally posted by s-rocc » | | this is the a2 forum...we don't have 40 photo diys for changing shift knobs. |
Hobbs_R32
1-5-2005
CA/NY
R32, 01 jetta
Re: (coppertone) » | « » 10:20 PM 12-30-2006 | |
| Quote, originally posted by coppertone » | Just letting you know that http://www.parts4vw.com has their selling for $200.00 plus at the most $25.00 for shipping. If you can beat that you have a sale. |
i don't see the nuesped ones on their site just the h&r ones for $220 plus freight after my experience with the links on my h&r bar on my mark4 i'll pass. my cousin's gti have the nuesped bar on it and it rocks
MK4 R32 - GIAC:H&R:BBSMK5 R32 - bone stock but not for long WTB - a3 2.0t or mk5 2.0t
coppertone
5-27-2006
Millville ext 24 off rt 55 New Jersey
1995.5 German Golf, 2010 Subaru Leagacy GT Limited turbo, 04 Titan Le, 09 Honda odyssey van.
Re: (Hobbs_R32) » | « » 11:26 PM 12-30-2006 | |
I'm so sorry, you were correct about that.
Turning my Subaru into the car that it should have been.
WISVW
8-24-2003
De Pere WI
2010 Jetta TDI, 2008 Passat Lux
Re: (BalloFruit) » | « » 6:30 PM 8-23-2008 | |
This really is a great mod. Thanks for the how to do!!This really took alot of the extra bounce out that I had with the FSD's. FYI: Spend the money and get the 12 point sockets. I tried to use the hex sockets that Neuspeed said were ok, and promptly stripped the bolts!!! I was able to get a vise grips on the other end of the tie rod bolt to remove the nut. Also the 16mm wrench did not fit my 06, but a 5/8" did The 2.0t must be easier than the 3.2, because I did it in under 1 hour even with the isues I had. Very happy with the ride improvement.
5309
12-10-2002
FL
Re: (WISVW) » | « » 6:51 PM 8-24-2008 | |
got mine from mjm aboot 1.5-2 years ago no problems with it at all. Minus a lil noise. Just Lube it often
duglas
10-5-2005
Chesapeake VA
2001.5 Audi S4 Avant Stage 2+ 6 Speed
» | « » 8:53 PM 8-24-2008 | |
I'm pretty sure that our price of $234.95 with free shipping is the best out there. If not, please let us know, as we want to take care of you guys the best way possible. Oh, and to BalloFruit: thanks for the order and thanks for letting us know DHL did this (with leaving it on the front). I'm calling our rep on Monday and picking a major beef with them. That is unacceptable! HOLLY CRAP your website sucks... My address is CRESCENT, not Street, or Road, or Circle... 841 Juniper Crescent.. your website will not accept that for an address.. Then I tried my home address and my Paypal address and the address I set up my account on your site has to be the same.. This is way to much work, just take the money from Paypal and send it to my confirmed address.. How hard can you make it!!!!!!
