killerrabbittruck
4-19-2001
Auburn WA
74 Thing, 81 Rabbit Truck, 06 gsxr, 92 4runner, 82 Toy
Killer Rabbit Truck VR6 Build | « » 9:05 PM 11-9-2006 | |
OK, So with all of the VR6 builds going i figured i'd start a post too, maybe i can get some new ideas from you guys and give some ideas to people doing this swap too.Here is what i started with, a good old green diesel that was sitting in a farm in eastern washington since 93:
Modified steering rack w/o linkage:
Front Cross Member and core support swap, I decided on the round headlights:
Coilovers and the 5 lug goods, I went with mk3 coils and they fit the rabbit strut cap, easy bolt on Also some new MK2 tie rods :
MK3 Dash:
How it sits right now:
Let me know what you guys think and if you see something i overlooked:
Killer Rabbit Truck VR6 Build!! http://forums.vwvortex.com/zerothread?id=2921870
Legacy
3-27-2003
Oklahoma City OK
1981 Caddy 1.6L Diesel, 1984 GTI
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 9:13 PM 11-9-2006 | |
you forgot the engine
Miami Blue 81 Caddy Diesel....
patatron
8-10-2003
www.patatron.com
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 9:14 PM 11-9-2006 | |
Are those weitecs in the front? They like to leak more than other brands, and the ones on my VR6 rabbit leaked in a matter of weeks after installed new. Just a heads up!
killerrabbittruck
4-19-2001
Auburn WA
Re: Killer Rabbit Truck VR6 Build (patatron) » | « » 9:18 PM 11-9-2006 | |
i'm about to pickup my lift this weekend and then mock up my mounts.yeah i heard the weitec stories before, but i got em cheap and no one else would sell me the front 2 coils for a mk3, if they go poopie on me i'll probably end up 4 linking the rear and baggin it.
Modified by killerrabbittruck at 6:19 PM 11-9-2006
XJDano
6-4-2006
st. louis mo
1984 VW Rabbitt GTi, 1999XJ, 98 metro, 82 silver wing
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 9:24 PM 11-9-2006 | |
Modified by XJDano at 6:27 PM 11-9-2006
Greme
12-29-1999
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 9:25 PM 11-9-2006 | |
welcome to the poortex, where everyone has deep pockets and short armsThe Jettatron http://forums.vwvortex.com/zerothread?id=2773382 my fleet, past and present http://hometown.aol.com/gremenasty/V-Dubs.html
35i 2000
1-27-2005
cast aluminum oil pans that shear
Re: Killer Rabbit Truck VR6 Build (Greme) » | « » 10:22 PM 11-9-2006 | |
i see 5-bolt rotors in the front.... 5x100 how did you pull it off?
veector
3-1-2006
West Side ONT
94 Jetta TD, 84 GLI Coupe
Re: Killer Rabbit Truck VR6 Build (35i 2000) » | « » 10:48 PM 11-9-2006 | |
Hows the cabby doing George?Caddy looks pretty solid, looking forward to more pics and progress
The Rza - Samurai Showdown (Ghost Dog) http://www.youtube.com/watch?v...lated
rabbot16v
6-24-2006
Buffalo NY
1981 Rabbit 16v
Re: Killer Rabbit Truck VR6 Build (XJDano) » | « » 10:55 PM 11-9-2006 | |
| Quote, originally posted by XJDano » |  |
hahaha, I love that poster I have it hanging in my room Clean looking Caddy good luck with the build
flickr™ http://www.dubsinthebuff.com my slow rabbit
killerrabbittruck
4-19-2001
Auburn WA
Re: Killer Rabbit Truck VR6 Build (35i 2000) » | « » 11:57 PM 11-9-2006 | |
| Quote, originally posted by 35i 2000 » | | i see 5-bolt rotors in the front.... 5x100 how did you pull it off? |
I had a 96 gti vr6 that i used to get all my swap parts, I used stock rabbit control arms modified with mk3 vr ball joints, then moved my ball joint location forwards about 3/8". I used the mk3 gti vr spindles, hubs brakes everything, I used mk3 front coils and bolted them to the rabbit strut bearing/cap. Then i used mk2 non power steering tie rods since they are longer and make it a nice stock clean fit. we'll see how things go when i go to align it, but im' confident it should be all square. Also i'm going to be running ABS and had to modify the rear axle to accept the mk3 vr rear spindles and rear rotors, i had to notch the plate to clear the lower caliper bolt and the wheel speed sensor. Hope this helps
Modified by killerrabbittruck at 8:59 PM 11-9-2006
35i 2000
1-27-2005
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 12:05 AM 11-10-2006 | |
the cab ... its comming allong well... i want to pull of Mark V wheels.. but as everyone knows that mark 1's being 4x100--->are really really tough to convert to 5x112. So what i did was VR6 spindles and the whole bit in the back, and in the front....well lets just say i am comming up with a nifty solution... ie a solution much like killerrrabbittruck, one that looks totally OEM, will have pics up when i get it all the pieces together thanks for the interest
35i 2000
1-27-2005
Re: Killer Rabbit Truck VR6 Build (35i 2000) » | « » 12:06 AM 11-10-2006 | |
those Mark 3 GTI wheels looks real sharp on that car
Dubluva
9-15-2002
East Side GA
1981 Pickup, 1982 Pickup, 1987 GTi, 1988 GLI, 1994 Passat GLX, 2001 A4 Avant Quattro
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 12:14 PM 11-11-2006 | |
You got any closer pics of the ends of your dash? I'm doing mine in my caddy right now, and I wana see what other options there are besides hacking the door cards. Also what HVAC setup are you running? MKI spliced to MKIII controls? or what?Thanks and keep up the good post!
killerrabbittruck
4-19-2001
Auburn WA
Re: Killer Rabbit Truck VR6 Build (Dubluva) » | « » 1:27 PM 11-11-2006 | |
I don't see why you would have to hack the door cards. I had to cut the dash in two pieces take some material out then splice them back together. I used the piece i cut out as a "sleeve" screwed both pieces to the sleeve, then fiberglassed the back of it and used some foam to smooth the contour where i cut it on the top side, i also trimmed offf lots from the edge against the windshield and i hacked out all of the HVAC Stuff, I think i'll put some gauges where the climate control was and carry a towel like it's an aircooled, I don't see myself driving this on rainy days anyways. This is not going to be a daily, more af a fun car. I am going to do a little more trimming and smooth out the vinyl on the dash a little more i can roll my windows though, just barely
frankinstyn
10-11-2004
Tacoma wa
2000 Audi A6 2.8 Quattro Avant, 1980 VW Rabbit Diesel
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 2:31 PM 11-11-2006 | |
I love that original tan dashboard! Would look out of place in my black interior though. Good work you're doing there. That new dash looks like it fits really well.
Does killing time damage eternity?
veector
3-1-2006
West Side ONT
Re: Killer Rabbit Truck VR6 Build (35i 2000) » | « » 3:17 PM 11-11-2006 | |
| Quote, originally posted by 35i 2000 » | the cab ... its comming allong well... i want to pull of Mark V wheels.. but as everyone knows that mark 1's being 4x100--->are really really tough to convert to 5x112. So what i did was VR6 spindles and the whole bit in the back, and in the front....well lets just say i am comming up with a nifty solution... ie a solution much like killerrrabbittruck, one that looks totally OEM, will have pics up when i get it all the pieces together thanks for the interest | waiting for these pics
bullzebub
7-12-2006
ume ac
VW Golf 81
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 4:47 PM 11-11-2006 | |
Hey! you need one of these!  http://www.thinkgeek.com/geektoys/plush/778d/
killerrabbittruck
4-19-2001
Auburn WA
Re: Killer Rabbit Truck VR6 Build (bullzebub) » | « » 7:47 PM 11-11-2006 | |
TOOOlowCOUPE
5-17-2005
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 8:40 PM 11-11-2006 | |
good to finally see some progress out of this thing!.....I'm gunna have to get going on the aba16vt so I can keep up
killerrabbittruck
4-19-2001
Auburn WA
Re: Killer Rabbit Truck VR6 Build (TOOOlowCOUPE) » | « » 2:50 AM 11-12-2006 | |
Speaking of progress I got some pics to show what i got done today. Cover for the stock shifter:
Front mount fabbed up:  Tacked in to check the fit:
I'd say it's a nice fit:
Modified by killerrabbittruck at 11:52 PM 11-11-2006 Modified by killerrabbittruck at 11:52 PM 11-11-2006
Modified by killerrabbittruck at 8:39 PM 3-14-2007
bullzebub
7-12-2006
ume ac
VW Golf 81
» | « » 4:29 AM 11-12-2006 | |
its going to be a monster! Me likes!  have you thought about colors yet?
Bazmcc
1-10-2005
Belfast Ireland
2002 Volkswagen Bora 1.9 TDI, 1991 MK2 1.8 8V, 2 x 1983 Golf MK1
Re: (bullzebub) » | « » 7:15 AM 11-12-2006 | |
You going with a combination of a custom drive shaft along with the stock MK3 one or are you going for a mix of Stock shafts? Baz
| Geschäft | Detailed Image |
Mtvee
4-14-2002
Lancaster PA
2001 225TTQ
Re: (Bazmcc) » | « » 9:33 AM 11-12-2006 | |
What's the string for that you have across the bay?
killerrabbittruck
4-19-2001
Auburn WA
Re: (Mtvee) » | « » 1:20 PM 11-12-2006 | |
As for colors i'm thinking of green or black, not the stock green though, something darker like forest green.I will use the stock passenger MK3 shaft, and i'm going to shorten the drivers side axle, should be easy though it's solid. And as for that top secret string, it's there so i know where the hood will be for clearance issues I'm still debating on what to do with the rear mounts, the stock ones don't seem to be where i want them so i've been thinking about making my own from 1/4" plate and some 2x3 tube stock. I'll post pics when i get them done.
bullzebub
7-12-2006
ume ac
VW Golf 81
Re: (killerrabbittruck) » | « » 1:46 PM 11-12-2006 | |
what about white? it would go with the whole "killer rabbit theme"? plus you could say : "follow the white rabbit" :-D
vdubnut_mike
8-12-2002
Bellevue WA
Minty 1988 GTI 16v and a 1966 Aristocrat Mainliner
Re: (killerrabbittruck) » | « » 2:48 PM 11-12-2006 | |
| Quote, originally posted by killerrabbittruck » | | As for colors i'm thinking of green or black, not the stock green though, something darker like forest green. |
my vote goes for Brittish Racing Green, with a black tinted with silver flake clear coat.
-MikeThe New GTI 16v
Greme
12-29-1999
Re: (killerrabbittruck) » | « » 3:41 PM 11-12-2006 | |
yeah, the rear mounts are a beotch, check out mine. this pic shows the basic idea i used to fab the rears.
Modified by Greme at 12:46 PM 11-12-2006
dubdubberson
5-30-2004
hillsboro or
Re: Killer Rabbit Truck VR6 Build (killerrabbittruck) » | « » 3:44 PM 11-12-2006 | |
| Quote, originally posted by killerrabbittruck » | EDIT: How it's not going to sit once that vr is in it
My Car your spacei wear long sleeve shirts, under short sleeve shirts, under long sleeve shirts WTT mk3 for mk2 http://forums.vwvortex.com/zerothread?id=4073311
killerrabbittruck
4-19-2001
Auburn WA
Re: (vdubnut_mike) » | « » 6:32 PM 11-12-2006 | |
I"m not sure what that color would look like, but if you have a picture, i'd love to see it.As for the rear mounts, i'm trying to find a way to use the stock mk3 mount so i can easily get stiffer ones later on, but looks like a good place to start from there. And i don't get what you are trying to say there? How it's not going to sit?
Twin Weber
8-9-2004
Waverley Nova Scotia
1984 Volkswagen Rabbit GTI
» | « » 6:43 PM 11-12-2006 | |
Nice build the VR6 fits nicley!!!!
1984 RABBIT VR6 Build
ArpyArpad
1-4-2002
northern NJ
81 rabbit, 02 mini cooper s
Re: (killerrabbittruck) » | « » 7:54 PM 11-12-2006 | |
| Quote, originally posted by killerrabbittruck » | And i don't get what you are trying to say there? How it's not going to sit? |
i think he means with the oil pan sitting really low.
killerrabbittruck
4-19-2001
Auburn WA
Re: (ArpyArpad) » | « » 12:27 AM 11-13-2006 | |
OH yeah, the oilpan will be low no doubt, but that's the price you gotta pay man....Here's some progress pics from today, slow progress but the results are worth it i think... Today's Progress:
Modified by killerrabbittruck at 8:41 PM 3-14-2007
Bazmcc
1-10-2005
Belfast Ireland
Re: (killerrabbittruck) » | « » 5:28 AM 11-13-2006 | |
Nice job on the rear mounts. That's more or less what my design looks like. I just need to get around to making them now. This is just a thought but here goes:I know height of the oil pan is always going to be a problem with MK1 VR6 swaps but what are the ways around it? Here's a couple of ideas I've had to possibly help out if I can afford them. 1. Short runner intake and relocated TB for more clearance on top. 2. Suspension spacers and coilovers for both stock height, adjustability and stiffer springs. 3. Oil pan modification....... don't query me on this one, it's just a spark of an idea at the minute. Last but not least: 4. Skid plate. (lowers it further but at least takes the hits). So, any thoughts on these? Cheers Baz
patatron
8-10-2003
www.patatron.com
Re: (Bazmcc) » | « » 6:21 AM 11-13-2006 | |
Looks great! You are gonna be very happy with the results of paying attention to all the small deatails on the mounts!
The Transplanter
1-18-2003
London
VRT Caddy, and some other Dubs!
Re: (killerrabbittruck) » | « » 7:44 AM 11-13-2006 | |
Keep it that OEM colour it looks awesome Everytime I see fabrication work in progress I get withdrawal
Parts for Caddys this way
