My Profile | Active Users | Help | Search | Google Search
wchp
4-1-1999
Springfield MA
06 A3 2.0t DSG Sport
 Rear Sway Bar Discussion« »
I don't want to get in a debate about the "Best" bar but rather solicit feedback.
From what I can tell there are currently three readily available rear bars for this car. Autotech, H&R and Neuspeed. I called Dick Shine and SRS is working on a bar for the GTI but will be awhile before they have one available.
I had always like the Shine Racing Bars, Street Springs and custom dampers as they were the most drivable on the street. They never extracted the last 5% from the car for the track, but were more livable for daily driving by maintaining suspension travel and maintaining caster and camber so tires wore like factory spec suspension.
The Neuspeed calls theirs "Racing" and appears to have two setting points. The H&R and Autotech both seem to currently have three points.
All three now appear to be using the factory pickup points.
I did note the threads about the H&R mounts snapping.
So the question is, if I want poise and neutrality in 90% of my daily driving, and the stock Sport Suspension is missing the mark. Which bar would folks suggest and at what setting.
Would love to hear about throttle steer and ESP influence in the equation as well.
06 A3 2.0t DSG Sport pkg
angryrican66
4-16-2006
Harrison NY
2007 A3 3.2Q Open Sky,Bose,Technology,Cold Weather, Nav,Roof Rails Ibis White
 Re: Rear Sway Bar Discussion (wchp) »« »
Just to put it out there, Eibach does offer a front and rear kit, its on there website and a few online retailers, do a google search, should come up
/Euro S-Line Spings&Shocks/Haldex GenII/
http://i98.photobucket.com/alb...8.jpg
http://i98.photobucket.com/alb...s.jpg
http://i98.photobucket.com/alb...9.jpg
wchp
4-1-1999
Springfield MA
Here I am adding to my own post already.
Just got off the phone with the folks at AutoTech and here is their opine:
The NeuSpeed is a more aggressive rate bar at it's max setting.
N=Neuspeed, H=H&R, AT=Autotech
So from a rotational torsion standpoint (Lets call this anti roll rate factor)
H and AT in hole one is slightly less that the factory "Sport bar"
H and AT in hole 2 is about = to Factory Sport bar
H and AT in hole 2 and N in hole 1 is sort-of 1 step up from the Sport Bar
N in Hole 3 is sort-of 2 steps up from the Sport Bar (most aggressive)
N and AT are lighter than H thus less unsprung weight (good no matter how you look at it.
Inquired about the AT mounts cracking and he said that this had been addressed. That the bushings were manufactured out of spec (two large) causing this issue. It has been addressed and the new bushings will be in stock by the end of the week.
Please note that I have used the terms "slightly", "about" and "sort-of" to describe these differences. Without any factual measurements I am deliberately using vague and ambiguous terms open to subjective interpretation.
Would like some input and thoughts
Avant agedS4
10-1-2006
2007 A3 2.0T (6M) S-Line
Just installed my Neuspeed RSB this past weekend - I initially went with the firmest setting and can say it's done wonders keeping the car neutral through the curves. It's been wet here and haven't had any issues with the tail kicking out. Huge fan and great bang for the buck mod.
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
Let's think of this another way.
AT = $210
HR = $195
N = $235
If you're a bargain hunter, get HR. If you're a aggressive driver, get N. From what other people have said, AT should be avoided.
2008 Audi A3 3.2Q -- Misano Red, MSW Type 11 wheels, Milltek Exhaust
Rest in Peace -- 2006 Audi A3 2.0T DSG
Golgo-13
8-20-2003
Noob question, but what does the sway bar do? Educate, don't hate.
BalloFruit
9-25-2006
Severn MD
2008 Misano A3 3.2Q
 Re: Rear Sway Bar Discussion (Golgo-13) »« »
Quote, originally posted by Golgo-13 »
Check out the 2nd to last post in this thread. Good synopsis.
http://forums.vwvortex.com/zerothread?id=2908416
Jeffaz
8-8-2005
Scottsdale AZ
im really happy with my H&R sway bar..............no problems and great handling
2006 Audi A3 Lava Grey/Lt. Grey, Sport, DSG, Bose, Open Sky, Xenons, Revo, H&R RSB, Awe Boost Gauge, Aluminum Pedals, OEM S4 18x8 wheels
wchp
4-1-1999
Springfield MA
Think of it as a spring that connects the two rear wheels. As you corner the car rolls to the outside of the turn. This lifts the inside rear wheel. Since the bar is attached to the wheels axis point is twists the bar down. The bar then transmits the downward rotational force to the other wheel forcing it down as well, reducing the amount of roll. Since the car is theoritically flatter there is more even traction on the front wheels, reducing under-steer. I am oversimplifying this quite a bit, but that is the general idea.
wchp
4-1-1999
Springfield MA
 Re: Rear Sway Bar Discussion (Jeffaz) »« »
Quote, originally posted by Jeffaz »
Which of the three holes are you using on the H&R bar?
I have always viewed swaybars as band-aids for to soft of springs and an under-damped suspension. I really only want to turn up the factory sport bar 1 notch.
artargyle
8-14-2006
Argyle TX
2006 audi a3
 bushings.... »« »
Might want to consider the bushings as well:
-Nuespeeds must be lubed (X 2 months or so to really quiet down) & they even then tend to squeek on rough roads.
-H&R has composite bushings, no lube required & generally are very silent. Mine never made a peep even on difficult road surfaces.
-I had the experience of driving both set-ups & the sometimes creaking Nuespeed was very distracting ,making a $30K car sound like a taxi.
-I wish H Sport (Hoskins) made a sway for the Audi.
Mud_Shui_Ah
4-25-2001
San Gabriel CA
 Re: bushings.... (artargyle) »« »
So H&R wins on the noise? oh well. i was thinking about Nuespeed but if it's noisy and require me lubing it, no thanks.
Watch my cat being a Ninja http://youtube.com/watch?v=RF7LDMs9SGU
wchp
4-1-1999
Springfield MA
Well I called Pure Motor Sports and was speaking with Michael there.
They sell bot the AutoTech and H&R bars. The Autotech and Nuespeed bars are both hollow 25mm bars. The H&R 22mm. Michael stated that the Autotech was stiffer than the H&R but both were a dramatic improvement over the Factory Sport bar. He also brought up that there is a European Spring for the MK5 GTI that is stiffer and about only drops you 3/4". This is important to me to maintain wheel travel. I might seek out those springs but will probably be more inclined to wait for Dick Shine to deliver a Set of MK5/8P "Street Springs".
So all in, I decided to pick up the H&R bar. It is heavier, but I could stand to loose 10lbs anyway. It is not really added unsprung weight since the bar is attached primarily to the car. At the end of the day, I like the fact that H&R supplies no maintenance bushings. These bars all use the factory pick up points and none of the silly add on brackets.
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
oops, double-post
Modified by OOOO-A3 at 9:34 PM 11-16-2006
A3 info
Get FireVortex
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
Quote, originally posted by wchp »
Not really.
Springs affect the wheels individually, in all situations. Reducing body roll with springs is a side effect of increasing the force required to move the suspension *at all*. Swaybars have no effect on straight-line ride feel since as long as both wheels move together (e.g. over expansion joints in pavement) the bar has no torsion. Swaybars come into effect *only* with a *differential* movement between left and right wheels (one extending/one compressing), and target body roll specifically.
There's a place for both, but one is not neccessarily a band-aid, or replacement, for the other.
A3 info
Get FireVortex
MisterJJ
7-27-2005
Ramona CA
67' Bug, 69' Baja Bug, 78' Scirocco, 86' GTI, 95' Jetta, 06' A3
 Re: Rear Sway Bar Discussion (OOOO-A3) »« »
Quote, originally posted by OOOO-A3 »
As long as the wheels "move together", right? What about hitting a pothole, or going over a seam between lanes, or rythmic dips on one side of the lane only, or the cobblestones like they have in the entranceway to my neighborhood? What about the feel of the back seat passenger in all these situations? That's what I haven't heard anyone address yet.
Personally, I really do want to get a RSB, but I already have to put up with a wife and kid who ask "Why is your car so loud and bumpy?"
Free, Cheap, or Easy
buddahvw
5-4-2004
Las Vegas NV
2005 Audi A6 3.2 quattro
 Re: Rear Sway Bar Discussion (MisterJJ) »« »
NUESPEED RBS on order! shipped today, should be here by tuesday
will post my review - " from a noobie-ass laymen's perspective"
05' A6 sedan; 3.2 tip quattro, Artic White, Black Int, Caractre Rear, H&R springs
Q U A T T R O ||=||
Queers4Gears Blog
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
Quote, originally posted by MisterJJ »
Right but... generally speaking the more torsion is applied to the bar, the more force it exerts back in the opposite direction (basic restorative force....). In practice, small deflections (cobblestones, expansion joints) will have small/negligible consequences, and large deflections (body roll around a corner) will have larger consequences (body roll being countered). If you hit a pothole significant enough that a swaybar would have a noticeable effect, you have bigger problems, like a flat or a bent rim, or a realignment.
A3 info
Get FireVortex
wchp
4-1-1999
Springfield MA
So I ended up doing the H&R rear bar. Bottom line was the no maintainence bushings. I was not able to find any posts on which of the two holes (settings) folks are using. I opted for the outermost holes (more roll/less stiff) to start untill I figure out how the car rotates with the new bar. Easy enough to move the links in if I want to bring it up another notch.
Thank you all for your thoughts and feedback.
RyanA3
5-11-2005
Philaburbia PA
Audi A3 2.0TFSI
exactly. I got mine from ecs. I love it.
everyone NEEDS a rsb.
My media-room
The Volvo C30 Thread
wchp
4-1-1999
Springfield MA
 Re: Rear Sway Bar Discussion (RyanA3) »« »
Quote, originally posted by RyanA3 »
Which set of holes did you use for the endlinks on the H&Rs?
shady12v
10-14-2004
valencia ca
06 Audi A3 & 04 Audi A4 Ultrasport
I got H&R from ECS as well. Right now i have it paired with stock base suspension. Stock base suspension was UNBEARABLY bad IMO. I hated it! I added the H&R on the outermost holes (softest).
The difference and improvement was significant. The car feels better in every way IMO. So good infact, that I have lagged for months on installing my H&R coilovers that have been sitting in my garage. Man i really need to install those. Once I install the coilovers I am gonna move the bar to the stiffest setting...Id like to see how it feels.
Current:
2006 Audi A3 2.0T 6MT Brilliant Red
2004 Audi A4 1.8T CVT Ultrasport Brilliant Black
SOLD:
1996 Audi A4 Quattro 2.8M Brilliant Black - MODIFIED
RyanA3
5-11-2005
Philaburbia PA
Audi A3 2.0TFSI
 Re: (shady12v) »« »
Quote, originally posted by shady12v »
I had base suspension. I went with the aggressive setting. go for it. you will not regret it. my gf wants the bar for her A3, it's not too stiff.
My media-room
kharma
1-2-2004
Mass
 Re: (RyanA3) »« »
I'm holding out for Shine
2000 Audi A4 Avant 1.8TQMS
crew219
10-18-2000
ITH NY
 Re: (kharma) »« »
Quote, originally posted by kharma »
Shine is overrated IMO. Why would you wait for someone who has never made a swaybar in the traditional sense?
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
crew219
10-18-2000
ITH NY
The no-maintenance bushings cause the bar to rust pretty badly after one winter.
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
wchp
4-1-1999
Springfield MA
 Re: Rear Sway Bar Discussion (crew217) »« »
Quote, originally posted by crew217 »
Dave
To Late... I put it on yesterday morning. I did in fact give the whole bar a light scuffing with synthetic sandpaper and then sprayed the whole thing with rustoleum gloss black appliance enamel (with the exception of where the bushing ride. There I applied a very thin coat of brake shoe grease (the sticking stuff you put on the slides that never comes off). I used the outer (softer setting) holes.
After I had the OE sport bar in my hands it occurred to me that I could have tried drilling holes about 1.5 inches back from the factory location. That would have theoretically stiffened it up a bit ! ?
So easy to take on and off, may just give it a try in the spring when there is an AautoX to try it at. I really want to find somewhere I can play with stability control both on and off to see how the H&R bar changes the balance and rotation characteristics of the car. Would hate to be surprised in a corner on the street or on a hwy ramp !
crew219
10-18-2000
ITH NY
Eh the stock bar is so weak and flimsy that I don't think you would have seen a huge difference.
I had the H&R a long time ago . . . . then I moved up to the Neuspeed. No regrets, although one of the tack-welded nuts on the subframe did shear off and caused the bar to loosen up. A new bolt fixed that problem.
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
kharma
1-2-2004
Mass
 Re: (crew217) »« »
Dave
They're right down the street... I've been more than pleased by his solutions for other platforms... I have my reasons
wchp
4-1-1999
Springfield MA
 Re: (crew217) »« »
Dave
Dick Shine is not over or under rated. He has a design and tuning philosophy that some subscribe to. I to happen to be one of them. His solutions don't work in all situations and for all drivers and some just don't agree, but that is why we live in the country we do, the freedom to choose. By the same token Microsoft, Mac and Unix platforms all have their strengths and weaknesses. No one platform is the perfect fit for all users or tasks. We choose the solutions that work best for the situation we are preparing to tackle.
I happen to like SRS product because it does most things very well most of the time. There are tracks and events that I would wholeheartedly disagree with Dick's no or low front sway bar, but I run into those less often and prefer SRS's solution on the street. The new platforms are for the most part 4 wheel independent now. SRS had a very valid reason for the bar systems they developed for the torsion beams. They worked well and were very predictable, reliable and maint free. I am curious how he will address things with the beam gone. I wont loose site of the fact that you are only as good as what you deliver, not what you have done! (That's called history)
SRS is not overrated in my mind... I really like his stuff and that is my opinion of which I am entitled. I will get on a soap box and tell my fellow forum members the strengths I see in his products in my applications (and it's weaknesses) but I don't want to disparage any manufacturers products or philosophy. I might suggest that rather than saying SRS is "over rated", commentary on what other options exist and why others like them would be more productive and informative.
I loved your APR and REVO logs and your posts were ultimately why I chose APR. I would love to see a comparison between the H&R and Neuspeed bars with Skid-pad and slalom tests but that will have to wait for European Car. Your Vogtland review was very helpful and informative as well, and actually help contribute to my choosing to stay with my OE sport springs and a set of Koni's for what I want the car to do.
In the tone of the day though... I am thankful and value your input and participation in this group.
Modified by wchp at 9:55 AM 11-23-2006
crew219
10-18-2000
ITH NY
 Re: (wchp) »« »
Yep, I know what Dick has done for the forum. I actually subscribe to some of his tuning philosophy (parallel control arms, moderate to no lowering, higher spring rates & etc). Then you get certain parts of his philosophy that is completely off-the-wall (i.e. redline will kill your tranny) and several bad dealings I've read about on other forums with them not standing behind their product / install. I used to run a Shine SRS RSB on my B5. Didn't like it much. Went neuspeed 28mm and it was signficantly better. My point being with the RSB is that manufacturing IRS-style swaybars are much different than his former torsion-beam design (piece of pipe + welded fittings). Just look at a few of the issues autotech has had with their MKV design.
Thanks. If you didn't see, I was probably the first person on the forum to get the H&R sway.
http://forums.fourtitude.com/zerothread?id=2190448
Ran it for about a year until I switched this fall to the Neuspeed RSB.
The neuspeed is much better. The softest setting is stiffer than the H&R and definitely helps the car come around easily. From the experience of others, the stiffest setting is too harsh to be used on the street but is fantastic on the track. I have yet to try it out.
Stock is 20.5mm hollow, H&R is 22mm solid, Neuspeed is 25mm hollow but uses thicker wall tubing than Autotech.
However, the area where the Neuspeed shines is in the bushing. The stock bushing width is 3cm whereas the Neuspeed is 4.5cms. The poly bushing is also harder than the H&R bushing or stock rubber. The greater contact area + stiffer bushing = more response and greater effect translated to the wheels. As shown, I have the earlier Neuspeed bar with the aftermarket brackets. The new Neuspeed bars reuse the stock bracket and include a modified poly bushing.
In the end, the extra cost of switching to Neuspeed from H&R was worth it to me.
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
angryrican66
4-16-2006
Harrison NY
 Re: (Avant agedS4) »« »
Quote, originally posted by Avant agedS4 »
x2 I had my Neuspeed bar installed this week and spent Friday driving 70+ miles of fast winding rolling roads and have been blown away, should have been my first mod was initially worried about the Racing name and the large diameter
definitely does not effect ride comfort but does improve handling dramatically , I do have it in the stiffest setting:thumbup:
Mud_Shui_Ah
4-25-2001
San Gabriel CA
 Re: (angryrican66) »« »
So how did you guys keep the noise down? so lub it when install? then when do you have to relub?
angryrican66
4-16-2006
Harrison NY
 Re: (Mud_Shui_Ah) »« »
Quote, originally posted by Mud_Shui_Ah »
no noise yet, had to retorque bolts after first drive, I'll keep you posted
wchp
4-1-1999
Springfield MA
On a previous car I had taken the tip of a dremel tool and scored a v shaped grove (1/4 inch deep and wide) around the inside middle of the bushing. I then fitted the bushing to the car with the OE clamp sans the bar. Drilled a 1/8 diameter hole through the clamp and bushing which came out in the middle of the grove. I then tapped the clamp and threaded in a grease fitting nipple. Then when I wanted to lube the bushing I just put a grease gun on the fitting a pumped until it came out the edges. The grove kind of acted as a reservoir and I didn't have to remove the clamp and bushing to add more grease.
» Return to A3 & S3 (8P)
Forum Jump
