atrujillo1991
5-24-2006
Blue Bell PA/Lima OH
A pretty MKII GTI, an ugly MKIII Jetta, and a loud '72 Squareback
 Ghetto shave (don't move me!) will it gold?« »
So... I got bored one day and decided to find a way to shave my hatch wiper and this is what I did.
Step one: Remove the wiper motor and everything around it.
Step two: Use a jig saw to cut around the wiper blade mounting hole. Make enough cuts so that when hammered, the metal can lay flat.
Step three: Using body hammers and a dolly, hammer the raised section of the mounting hole flat by placing the dolly behinds the raised area. be careful not to dent the hatch. If you DO dent the hatch, tap with a rounded hammer from behind and the dent should pop out.
Step four: use a grinder to smooth any high areas out. It's better for the metal to be low than high.
Step five:Use a piece of sheet metal and hold to shape of the hatch. Run the metal over where you have worked to check for high and low spots. repeat as necessary
Step six: after shaping is complete, take a 3x3 piece of sheet metal and use a 3M adhesive and C clamps to hold it in place behind the wiper hole. Allow to cure for 3 hours. Use the C clamps to keep firm pressure on the plate.
Step seven: After the adhesive is cured, remove the C clamps and lay Bondo over the shaved area. After the Bondo is applied, allow to cure and shape with sand paper.
Step eight: repeat step five to ensure a level surface.
Step Nine: Prime and observe your handy work.
This is what I did in order to shave my hatch and I was just curious to see what people thought. do you think It'll hold?
The cool part is it only took like... two hours. You waste more time waiting for it to dry and you don't have to weld!
Hi, I'm Andrew
The OG. Dirty Euro.
SnubbedMK3
8-27-2004
Huntsville TX
1995 Mulberry VR6
I would have rather welded it.
Zorba2.0
1-27-2005
Kalamazoo MI
'97 Jetta GT 2.0t 034 IC, 02' A4 1.8t daily
 Re: (SnubbedMK3) »« »
INteresting idea... I don't think the adhesive and bondo will hold up that great though. It will still look nice. White is a forgiving color for body work vs. black.
-Adam
034 Stage IC
193 hp/172 tq < Lysholm = OLD NEWS
Dyno Vid
Quote, originally posted by dankvwguy »
i wanna make sure im getting quality wood
atrujillo1991
5-24-2006
 Re: (Zorba2.0) »« »
haha the car is flat black... or in the process of becoming flat blak at least
Hi, I'm Andrew
The OG. Dirty Euro.
root beer
6-22-2004
Pasadena MD
1997 Gti 1994 Jetta
 Re: Ghetto shave (don't move me!) will it gold? (atrujillo1991) »« »
gangster
12.59@107, stock block/management na 12v
Rare JDM SSR's for sale. 5x100>5x114.3
8380
jrbscooch56
5-20-2006
Media pa
99 white sedan
 Re: Ghetto shave (root beer) »« »
That truly is ghetto .
Edit: its ghetto going for a job interview at Walmart.
Exhaust goes *rattle rattle*, windows go *griinndddddd*, speakers go *boom boom boom* front lip goes *scraaaaaappeeee*. Passengers go what the ****?!
xbox live : Unicornasarus
Full Collapse
8-29-2006
West Haven CT
TRUCK.
 Re: Ghetto shave (jrbscooch56) »« »
Prefer welding. i enjoy it.
But whatever you think will work.
SCD
Flickr
dubweiser1
12-23-2001
Hillsboro Oregon
 Re: (Zorba2.0) »« »
Quote, originally posted by Zorba2.0 »
Fusor makes a panel bonding adhesive which is approved by GM, Ford, BMW and such that is made specifically to be topcoated with "bondo". FYI
FS: Mk1 Caddy
djsheijkdfj
8-7-2005
Fairfax VA
2003 Mustang Cobra
 Re: (dubweiser1) »« »
Wait to try for a few hours or take 10 minutes to go wheel out the welder and do it the "right" way........ hm.
I guess for everyone who doesn't have easy access to welder though, it is a good way of doing it.
Quote, originally posted by melanotaenia »
this is not even a comparison. Are we really comparing this Cadillac to a freaking M3????
lehr leistung
3-8-2003
From Green
To Gold
 Re: (djsheijkdfj) »« »
it might gold but it aint gonna hold
*Gone But Not Forgotten*
<Going for the Gold>
soccergk
4-19-2005
Manchester NH
95 Jetta 2.0T, 93 SLC, Futura GTI, B3 Wagon
 Re: (lehr leistung) »« »
Quote, originally posted by lehr leistung »
yea i dont think it will gold either
ReflexTuning.com
NH's REVO Dealer
RT Skid Plates
keysforvw.com Ebay Auction
Criscone25
7-24-2006
Albany NY
98' Jetta
depending on what you used, there is adhesives that will hold just as good as any weld. SEM i believe its called is a 2 stage epoxy, my buddy shaved his door handled by cutting metal and holding it in there w. this stuff...... 4.5 yrs later there still holding, AND the car was in an accidnt an nothing popped out itsall about the cure time!
Quote, originally posted by .sanya. »
my brother in law, that just got out of prison thinks you're cute
http://www.roflwagens.com
nern
3-7-2006
Killadelphia Pa
yet another relfex gti with jetta front end
 Re: (Criscone25) »« »
a couple time closing that hatch or with a little system in the back I give it 2 weeks
http://www.rabbitparts.com
http://www.myspace.com/hardcorenern
bonsaiguitar
9-13-2006
Pelion SC
Tornado Red '97 VW Gti
Looks tight to me. Should hold just fine since its a very small area. For the badge area try just epoxy and hold the bondo.
K04A1
9-1-2004
The Hood Wa
1928 Chevy
um I would have welded a peice in the instead. that just seems like a waste of time to me... for the same amount of work it could have been done correctly.
http://www.1stvwparts.com
http://www.mkippen.com
http://www.snapriot.com
Dirtbag
CrazyGreenVento
8-10-2001
North Jersey
1995 Jetta, 1983 Rabbit GTi, 2006 BMW M5, 2007 Triumph 675
for creativity A+++ nice job
check out my AWD Jetta Coupé Project
http://forums.vwvortex.com/zerothread?id=3545369
"R32DRWBAWDT"
m0d35t8mx
8-15-2005
Dover NH
cars are a waste of time...
crraaaccckk....
INSERT LONG LIST OF PLAYED MOD'S HERE...
http://www.dark-side-customs.com
http://www.myspace.com/leechose
vw's = adult lego's...
Seamus68
4-4-2005
Awesome World PA
#2752 BMP 20th, 97 golf 4-door, 84 Rabbit 16v, 93 cabby 16v
 Re: (m0d35t8mx) »« »
Quote, originally posted by m0d35t8mx »
crraaaccckk....
never mind the Nay sayers....Today you can get adhesive just about as strong as weldin. That area on the car does not see much abuse or pressure. IT should hold out. Nice job...I might consider doing the shaving this way!
Quote, originally posted by LuckySlide16 »
Who ever dressed those women should be shot in the head with an Ed Hardy Pistol. WTF
OrchidEuro
Ink and Essence...custom screen printing, and original designs.
atrujillo1991
5-24-2006
 Re: (Seamus68) »« »
looks good after primer and sanding. I oushed as hard as I could and it didn't move so I'm thinking its going to work. I'll post pictures later.
Hi, I'm Andrew
The OG. Dirty Euro.
FlyBy
5-27-2004
Lakewood OH
Green Grocery Getter
 Re: (atrujillo1991) »« »
really be sure that you used a good primer, one that won't just wash off with some cleaner. I ran into that painting my car, learned the hard way.
HS Tuning --> Performance Upgrades and OEM maintenance parts. If it's not on the site e-mail for pricing!
Six13racer
7-3-2005
scroungeville MD
97 two-door six-pack
 Re: (FlyBy) »« »
im going to be doing some paint work soon, what primer do you suggest using? (newb to the bodywork scene)
Raise your standards, lower your Volkswagen.
Quote, originally posted by neven »
in my country lots of hondas (most are crx) drive with vr lip and they all hate vw very much
dubtometry
4-12-2003
poortland
car
 Re: (Six13racer) »« »
you could have used a hole saw to cut out the wiper base.....but your way worked
i heard a voice crying in the wilderness
FlyBy
5-27-2004
Lakewood OH
I know there's this stuff called U-Pol, it's more expensive I think. You can use etching primer, but that really only works on bare metal. The big key is to really scuff up the paint that is already there if you are going to paint over it. Use the red/maroon 3M Scotchbrite hand pads, the coarse grain is enough to take the shine out of the clear.
Also a big thing, be sure to keep everything super clean, and use a paint prep cleaner by ppg or someone before you lay down any paint.
DaddyOfPayton
2-24-2004
Hilliard/Columbus OH
1995 VW Cabrio 2 Point Slow
 Re: (FlyBy) »« »
All that and you didn't do the emblem recess too?
My name is...Shake-Zula, the mike-rula, the old schoolah, ya wanna trip? I'll bring it to ya. Frylock and I'm on top, Rock you like a cop. Meatwad you up next with your knock-knock, Meatwad make the money, see? Meatwad gets the honeys, G. Drivin' in my car, livin' like a star. Ice on my fingers and my toes and I'm a Taurus.
 Re: (DaddyOfPayton) »« »
Quote, originally posted by DaddyOfPayton »
BB 62.. bitch!
BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
stevevr6
12-13-2002
TORONTO ONTARIO
ONE BAD ASS GOLF
 Re: (Dan J Reed) »« »
x3
Steve- DubFaction
Grita Caralho
Quote, originally posted by Suter »
sell your car and get a girlfriend. Then you'll have someone to tell you what to do all the time.
ILL_VW
10-27-2004
e. northport ny
94 vw golf DD, Supercharger Mustang GT
 Re: (stevevr6) »« »
theres is an adhesive thats is made to replace weldin and it has the same or greater bonding strength that weld does. Its a great way to do body work when u have a few small jobs and dont want to invest in a welder.
FükenDübin : LI, NY
atrujillo1991
5-24-2006
 Re: (ILL_VW) »« »
I would love to invest in a welder but I'm broke and with christmass comming up I don't think it's going to happen any time soon
Hi, I'm Andrew
The OG. Dirty Euro.
haves
11-29-2006
Tempe AZ
1996 Volkswagen Jetta 2.0 5-speed
hehheh, gotta weld it man, especially on a panel that gets slammed shut. harborfrieght.com has small portable welders for like $50 or maybe a little more, which are perfect for projects like this. I've had one for a couple years and it still works fine, just doesn't have some major brand name stamp on it to ad a few hundred bux to the cost!
vwman099
9-26-2002
Owings Mills MD
06 TSX, 66 Bug
 Re: Ghetto shave (haves) »« »
Unless you have the car for 20 years, I think you'll be fine! Enjoy the ghettoness
atrujillo1991
5-24-2006
 Re: Ghetto shave (vwman099) »« »
i will sir i will!
Hi, I'm Andrew
The OG. Dirty Euro.
nfx
7-18-2004
bel air md
mk3 jetta 2.0t project, 01 hyundai elantra daily
 Re: (Seamus68) »« »
Quote, originally posted by Seamus68 »
sean... we'll just weld it. nick can weld it, we'll grab a disc sander from my dad and some bonda from pepboys and we'll even it out, and ill spray it. trust me... it'll work a lot better.
LG6S (and primer) 2.0T
VolkenstieN
11-22-2006
Germantown WI
1998 Panda Golf
i actually went to tech school for auto body work, and metal to metal bonders are being used more and more. some of them (i forget the names) are actually considered to be stronger than welds now. don't quote me on this cuz ii'm not sure if it 100% true or not, but i read, ( or was told by an instructor) that lotus elise's and exige's do not have any welds in the the body structure. they used metal to metal bonders instead.
2007 Dubs in the Valley FUBAR award winner
BALLACLAVA STYLZ 2007
Son of a bitch, the MkIV monkeys got loose again...
kyle, you now you want the Ronal teddy bears, there so cute and cuddly and they swift love out of thier lil bear butts.
mackamitsu
4-14-2008
Terrace Bay ON
1991 jetta diesel
 Re: Ghetto shave (VolkenstieN) »« »
Sikaflex and its line are much stronger then a lot of welds. A lot of bus bodies are held together using this product, and yes a lot fo race cars use non metalic bonding instead of welding to save weight. Epoxies are also better at sealing as they don't heat enough to compromise the galvanising or rust treating process.
Gravity doesn't get you down
The man gets you down
KESET
9-1-2001
Southern NJ
cabby highline
 Re: Ghetto shave (mackamitsu) »« »
you bumped a year and a half old thread for...?
Bübengröpen?
HURRY UP AND BUY!
» Return to Golf III & Jetta III
