envisionmore
11-7-2005
WPB FL
03 GLI 24v Stg.III VRT
FS - 2003 24v 2.9L STGIII VR6 Turbo | « » 4:17 PM 2-11-2007 | |
 - - - ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- - - - 2003 GLI - 24v 2.9L VRT STG III ------------------------ STG I installed by EIP in Maryland @ 1,200 mi STG III Engine professionally built @ 39,900 mi Current Mileage: 51,089mi (as of December 23rd, 2008)Engine ------------ 6 Speed manual transmission Engine Bored and Stroked to 2.9L Turbonetics "Ceramic Ball-Bearing" t04b turbocharger (brand new w/ engine build) JE Forged Turbo Pistons (Low Compression) Eurospec 4340 Forged Lightweight Connecting Rods 60 lbs/hr. (630cc/min) Hi-Impedance Large Injectors Short Ram K&N Intake High Volume, High Efficiency Front Mount Intercooler Turbosmart Manual Boost Controller Stainless Steel Dump Tube Custom Fabricated Test Pipe (removed Catalytic Converter) *High Volume Catalytic Converter is boxed and available *Post cat 02 sensor mod installed EIP Stage III Engine Management (utilizing 60lb injectors) EIP 2.5in full SS dual tip exhaust EIP 2.5in down pipe EIP Ultra high grade stainless steel exhaust manifold EIP High Strength / Low Vibration Motor Mount EIP Strut Caps Fully coated mandrel bent piping set Classic Greddy TYPE "S" Blow Off-Valve New OEM Oil Pump & Water Pump Stage II Bosch Upgraded Fuel Pump Suspension & Wheels ------------------------------------ 19in Axis Mod se7en rims (w/ brand new center-caps 4/3/08) Front Tires: Nexen N3000 - low pro. (good tread as of 12/23/08) Rear Tires: Hankook Ventus k104 Sport - low pro. (good tread as of 12/23/08) Eibach Pro Springs (1.5in drop) Eibach Pro Dampeners Brembo drilled & slotted rotors Hawk Performance Ceramic brake pads Audio ------------ JBL 1500-Watt Amplifier Dual 12in Pioneer Premier subs in closed box Rockford Fosgate 1-Farad Capacitor Kenwood Excelon 817dvd w/ 5.1 surround sound & remote control Alpine single-DIN center channel 5.1 surround sound speaker Pyramid 160-Watt Amp (dedicated for alpine center speaker) iPOD to Kenwood DVD touch screen interface device Monsoon Speakers & Amplifier Security ------------ Viper Alarm System Two-way pager/transponder with half-mile range Glass breakage alarm module Shock sensor alarm module Remote window roll-up/down module Remote start & turbo-timer module (Needs Install - Plugs into Viper System) Interior ------------ Center Steering Column VDO Boost gauge (dash color matched) OEM Snap-in Brushed Aluminum Dash Kit (only center console) GLI Sport Bucket Seats (dual tone - textured cloth) Front/Rear Heavyweight Monster Mats OBDII Engine Code Scanner Exterior ------------ Custom Eurogear Carbon/Kevlar Bowser Hood (Black & Red tight weave) *Hood sides painted tornado red to line up with grill *Update 8/6/08 Put Stock Hood/Grill Back on *Update 12/22/08 Carbon-Bowser Hood - SOLD Kamali Badge-less grill Clear Side Markers Tinting by EIP Shaved Trunk VW Emblem De-badged all trunk lettering Solid Trunk fitted with dynamat extreme (sheets and foam filler) 2005 red/clear OEM tail lights Molded Rear Bumper / Quarter Panel Molded Front and Rear valiances Dubtechnik Side Skirts (brand new & unpainted sitting in garage / included) Custom Front Bumper (cut/molded to show intercooler) My youtube page..... http://youtube.com/profile_vid...e&p=r - - - ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- SOLD ----- 5/28/2009 ----- - - -
Modified by envisionmore at 3:15 PM 5-28-2009
FS : 03' 24v 2.9L Stg.III VR6 Turbo The Elite 24v VR6 Club: Member #316 Myspace YouTube
Sid-Rage
6-15-2004
WPB FL
89 Helios (x2)
» | « » 5:54 PM 2-11-2007 | |
this car is the nasty. 350z, g35, wrx, srt4... all love the look of this car's tail lights...
MK2 Helios Jetta. Coils - Recaros WTB : MK2 VR6 Jetta (+Coupe)
IDdubber
10-17-2006
Roanoke VA
'01 Wolfie, '08 GTI
Re: (Sid-Rage) » | « » 6:56 PM 2-11-2007 | |
If I had the cash I'd have no problem offering $21k-$25k for your car. clean, simple, power out the you know what....easily a $20k+ car.more pics anywhere?
VW Database Need pictures? Want to hear what a particular exhaust sounds like? Looking for pictures to help you decide what suspension to run? Thanks to "TheMunky"| Quote, originally posted by Richard Hammond » | | "Yeh, itsa rainin', ehhh I'm goin' north, and I'm lookin' for a whuuur!" |
envisionmore
11-7-2005
WPB FL
» | « » 7:40 PM 2-11-2007 | |
^ If your wondering why it says eiptuning.com ... It is because I bought this car from Greg Schute up in Maryland. It was built by EIP and was originally used on their website.
Modified by envisionmore at 11:00 PM 10-5-2008
envisionmore
11-7-2005
WPB FL
» | « » 7:44 PM 2-11-2007 | |
Modified by envisionmore at 6:50 AM 2-18-2007
envisionmore
11-7-2005
WPB FL
» | « » 7:47 PM 2-11-2007 | |
Modified by envisionmore at 7:55 PM 2-11-2007
envisionmore
11-7-2005
WPB FL
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 7:53 PM 2-11-2007 | |
Modified by envisionmore at 10:54 PM 4-17-2008
envisionmore
11-7-2005
WPB FL
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 7:56 PM 2-11-2007 | |
ricecopvwdave
1-7-2005
Miami Fl
05 GLI, 1989 Chevrolet Camaro (The weekend toy)
» | « » 8:56 PM 2-11-2007 | |
Being the person who built the engine (Those are my camera phone pics) I can tell you this car fricken rips.Ive drove dozens of BT 1.8T's and some turbo VR6's and this one has the nastiest powerband. Slipping the clutch with no gas is flawless, burying the gas is not required in everyday driving, but when someone's mouth gets a little too big...... Jon, send more pix of girlfriend.
bryan burnick
9-16-2005
birmingham, atlanta
2003 JB 20th
Re: (ricecopvwdave) » | « » 9:23 PM 2-11-2007 | |
nice car
WTB: mk1/2 project car for the winter. Shoot me a pm if you are in the South East
mnVWmk4
10-15-2005
Mankato MN
MK2, 944 Race Car, Jeep mk4-kinda
Re: (bryan burnick) » | « » 11:33 PM 2-11-2007 | |
| Quote, originally posted by IDdubber » | | If I had the cash I'd have no problem offering $21k-$25k for your car. clean, simple, power out the you know what....easily a $20k+ car. more pics anywhere? |
lol well that sounds like u like to through away your money... paying what he is asking ... sounds ok
Jetta APR STAGE III Trashed -Smashed-Taken apart MK3 Golf...........Sold --------------- MK2 the new project Porsche 944 Race Car
| Quote, originally posted by megafr0 » | | megafr0: How do you make a noose? I'm having trouble with the knots. |
ricecopvwdave
1-7-2005
Miami Fl
» | « » 12:30 PM 2-12-2007 | |
He didnt actually post a asking price....
srosey
1-2-2007
Ashtabula Oh
1988 VW Fox
» | « » 8:05 PM 2-12-2007 | |
How much are you asking is the KBB price? Is that firm? Iam in Ohio kind of fardamn it . Whats the price with the girl inlcuded HAHA just kidding but nice car man
envisionmore
11-7-2005
WPB FL
Re: (srosey) » | « » 11:44 PM 2-12-2007 | |
I haven't put an asking price just yet because I'm debating whether or not to keep it.... I do have a lot of bills piling up so I just wanted to see if people are interested. I might sell it if someone makes me a decent offer. Anyone who wants to test drive lemme know, this car will leave a lasting impression. I live in West Palm Beach, FL.
Sid-Rage
6-15-2004
WPB FL
89 Helios (x2)
» | « » 12:17 AM 2-13-2007 | |
hey jon, were you also thinkin of a trade of some sort? i remember you saying you'd trade your car for something but i couldn't remember..
envisionmore
11-7-2005
WPB FL
Re: (Sid-Rage) » | « » 4:48 AM 2-13-2007 | |
trade & cash is possible too...
envisionmore
11-7-2005
WPB FL
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 4:54 AM 2-13-2007 | |
http://www.youtube.com/watch?v=LJvVjM9Sv1E ^^ video of my exhaust in neutral ^^ tomorrow ill upload an engine view... its nearly 5am.. I'm going to sleep g'night.
envisionmore
11-7-2005
WPB FL
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 4:59 AM 2-13-2007 | |
 side profile
envisionmore
11-7-2005
WPB FL
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 2:12 PM 2-13-2007 | |
http://youtube.com/watch?v=P3EQ3SdnXVM ^^^ video of engine in neutral ^^^
ricecopvwdave
1-7-2005
Miami Fl
Re: (envisionmore) » | « » 8:07 PM 2-13-2007 | |
| Quote, originally posted by envisionmore » | | I haven't put an asking price just yet because I'm debating whether or not to keep it.... I do have a lot of bills piling up so I just wanted to see if people are interested. I might sell it if someone makes me a decent offer. Anyone who wants to test drive lemme know, this car will leave a lasting impression. I live in West Palm Beach, FL. |
Remember when I took you and danny for a ride when I finished the car?"It feels just as fast as I remember" "No, its faster.....that was only half throttle."
envisionmore
11-7-2005
WPB FL
Re: (ricecopvwdave) » | « » 11:52 PM 2-13-2007 | |
...and still at 10psi! Still breaking in the engine easy.. I'm going to wait another 500-1000 miles to turn up the boost I little more. Thanks again buddy, you really did a great job....
envisionmore
11-7-2005
WPB FL
» | « » 12:45 PM 2-14-2007 | |
This dyno is is just after EIP install as Stage I @10psi.. :::: SEE NEXT PAGE FOR POST ENGINE BUILD DYNO ::::
Modified by envisionmore at 4:34 PM 2-23-2009
Matt@EuroJerks
4-21-2006
Northeast states and waterways
» | « » 12:48 PM 2-14-2007 | |
very nice ride!!
There are two theories to arguing with women. Neither of them work.
vdubz2004
12-12-2005
Bedford PA
2004.5 Platinum Gray Jetta GLI
Re: (Matt@EuroJerks) » | « » 3:54 PM 2-14-2007 | |
how much??
Now: 2004 Volkswagen Jetta GLI: P-Grey, Carbonio cai, Apr 3in turbo back, Apr Stage 3 turbo kit, H&R coil overs, apr intake manifold Had: 2004 Volkswagen Jetta GLI: T-red, AEM cai, GHL Turbo Back, K04-001, Apr TIP, forge 007P, weitec 2.25 cup kit
ricecopvwdave
1-7-2005
Miami Fl
Re: (envisionmore) » | « » 10:46 PM 2-14-2007 | |
| Quote, originally posted by envisionmore » | ...and still at 10psi! Still breaking in the engine easy.. I'm going to wait another 500-1000 miles to turn up the boost I little more. Thanks again buddy, you really did a great job.... |
Remember what I told you. If you want to turn up the boost to add alcohol injection.
VR6 24v
12-21-2006
Corpus Christi TX
2003 Jetta GLI VR6 24v
Re: (ricecopvwdave) » | « » 7:03 AM 2-15-2007 | |
Drool ... Umm, I'll trade you my stock 03 GLI VR6 24v............. first born..........my whinny azz dog that's been pissing me off lately............ooh, and an original hubcap from my old 69 Dodge Coronet 440 project car. Bump for a sweet a** car......wish I could afford another car.
2003 /Galatic Blue / Jetta GLI / VR6 24v The Elite 24v VR6 Club: Member 140
5speedsteve
12-13-2004
nj home but currently in Florida
mk2 calypso...e46 AWD...DUCATI 748
» | « » 12:21 PM 2-18-2007 | |
this is seriously sick and should not last long
Calypso FTW!kingmotorcar click it ...
Sid-Rage
6-15-2004
WPB FL
89 Helios (x2)
» | « » 12:16 AM 2-19-2007 | |
bumperz.I WANT MY DAMN MK2!!!
RTCustomz
12-19-2004
Olney Md
VR jetta coupe
Re: (Sid-Rage) » | « » 12:34 AM 2-19-2007 | |
i have a mk2 jetta coupe vr6 i could trade ya and add cash.. lmk if ur interested
My jetta coupe vr6 project: http://forums.vwvortex.com/zerothread?id=1969109
Sid-Rage
6-15-2004
WPB FL
89 Helios (x2)
» | « » 2:18 AM 2-21-2007 | |
bada bing.. bada bump..he's open to stocky trades.. hit him up.. he might suprise you
jchipperg
9-24-2006
NE Pa
2007, Volkswagen GTI
» | « » 7:53 PM 3-1-2007 | |
sick ride . . . u willing to take a 2003 1.8T and some cash? email me shibbyy77@yahoo.com
Signel
3-4-2007
Gainesville FL
07 Jeep JK looking for GTI still
Re: Feeler : 24v 2.9L Stage3 VRT (envisionmore) » | « » 5:53 AM 3-4-2007 | |
Okinawa Bump. That car is sic and I am interrested if you are gonna sell it. I'm sure there is a long line of interest. Nice job on it. email me if you have a price.
Enjoy your freedom, thank a vet.
Sid-Rage
6-15-2004
WPB FL
89 Helios (x2)
» | « » 1:23 AM 3-6-2007 | |
bada bing.. bada bump..was just driving this sick machine of a car.. as soon as that wastegate starts roaring... it's nasssssssssssssssssty...
5speedsteve
12-13-2004
Re: (Sid-Rage) » | « » 1:50 PM 3-6-2007 | |
sflgtg bump
BlackJettaT
4-24-2005
Ft. Lauderdale FL
2007 VW GTI V 2.0T, 2003 VW Jetta IV WE 1.8T (Sold), 2001 Audi A4 B5 1.8T (Sold)
» | « » 3:32 PM 3-6-2007 | |
Yo dude I will give u an 01 A4 1.8t im in Coral Springs! Yo Danny whats up its Rob
Modified by BlackJettaT at 11:45 PM 3-7-2007
2007 VW GTI V 2.0T (United Grey) Revo'D
