Issam Abed
All Over
'91 Audi 80 2.0T
 ***1.8T Intake Manifold Test Results***« »
For those who dont want to go over to Elite dubs,the test was conducted by vortexers so the infomation should be shared here.definitely a huge to axelkiller & silvercar.Also congrats to DonR (cadmasterflex ) for the 007 manifold.
The Short Take:
The Long Take:
Quote, originally posted by Dizzy »
First off I'd like to give a HUGE thanks to Mike @www.tyrolsport.com, Phill @www.bshftw.com, and Scott @www.usrallyteam.com. These three businesses gave sizable contributions to conduct this test with nothing to gain or lose by "sponsoring" this test. That alone speaks volumes about their support and interest in the advancement of the 1.8t community. Also, everyone that gave a contribution, no matter how small or large, we thank you as well. Lastly, the manifold contributors are owed the biggest thanks. Without your help and the use of your hardware, this test wouldn't have happened.
Now on to the data. The only real way to rank the manifolds with regards to flow would be total flow through all four runners. This is the easiest way without getting into standard deviation and outliers in individual runner flow. This does NOT correlate into which will make the most power on a given setup. Intake manifold flow is dynamic and undergoes turbulence, heat change, as well as sudden transitions, like during a WOT lift to shift. All testing is done at 28 in of water to ensure accuracy in comparisons, but flow in vacuum is entirely different than positive intake manifold pressure. All of this must be noted when trying to compare the different manifolds. The most interesting thing to me is the variance in individual runner flow.There weren't any huge surprises in regards to results of total flow, but there were some interesting notes from individual runner flow. Stock style manifolds starve the first runner. Notice the similarities in runner flow between the stock OEM big port manifold and VariantStg3's affectionately labeled "Homebrew" manifold, which uses OEM big port runners and flange. It seems as if most all the manufacturers could spend some time focusing on equal distribution. ABD and RMR seem to have the best distribution, the biggest plenums. Obviously the larger the amount of flow, the harder it is to have a manifold that evenly distributes this. For example, the Dahlback manifold, which uses the Lehman style of dual plenums for even distribution, isn't that even.A variance of 3-4 cfm isn't huge, but it is a variance. That said, a variance of 8-10 cfm isn't going to affect much in the real world anyways since this is under vacuum, and adding boost will more than likely even these out somewhat.
Another thing to pay attention to is the throttle size. All of the small port manifolds used stock throttle bodies, except the 007 small port which uses a 12v VR6 throttle. The big ports are even more varied with APR's RS4 and 007 using the R32 throttle, RMR accepting a variety of throttles, Homebrew's manifold accepting a 3" DBC throttle, and Hypertune not even having a throttle plate. We added a comparison graph between the 007 small and big port manifolds and nother between the OEM small and big port manifolds as well.
Comments from the flowbench operator that did the testing:
RMR big port Retail price $699.95
The operators spoke highly of this manifold. They thought it had plenty of plenum to get the job done, with very nice runner design and injector placement. He also noted the distribution- a variance of only 7 cfm from highest to lowest runners. (which is only 3 or 4%) They also commented on how short the runners were, and how that would shift the torque curve up in the revs signifigantly.
Homebrew Cost is up to end user lol
Said that it looked like it could be a good alternative to spending big money for an aftermarket manifold with a little revision. They seemed to think that the angle of the throttle plate and the 'flat' entry was killing the first runner. "Once air is moving so fast, its just not gonna turn like that, you know?" They also liked the radiused runner entrys in the floor of the plenum and that the OE injector bosses had been ground down a bit to increase the cross sectional area.
Dahlback Retail price is $999.00
They really didnt have anything good to say about it other than the fittings were nice and that it looked well made. They said that the Lehman style, while it may help distribution over stock, kills flow. And that this plenum design didnt do anything that a well thought out plenum and throttle angle couldnt do; basically saying that it was a trade-off that didnt have to be made.
ABD Retail price is $499.00
They said it was a big piece of crap. They remarked on how sloppy the lower flange was with regard to port alignment. (which i confirmed by comparing to an APR and my 007). They also complained about the casting slag. They didnt like that it used OE injector bosses. They basically said that while it performed moderately well, that it just wasnt a nice part.
APR Retail price is $899, $1299 with the throttle body
They really liked the build quality this one, and remarked on the quality of the casting. They did however say that the throttle angle needed to be changed in order to get it on par with regard to distribution and that the injector bosses again should not be protruding into the port entry, because it was what killed the flow.
Hypertune Retail price is $1399
When i pulled this out of the box, Dan smiled real big and said "Bling, bling." Again, they thought the machine work on this was phenomonal. and that the injector mounting was great. But they absolutely hated the plenum. They said it was far too thin for a big boost, big power or sprayed car. Dave said one good pop back through the intake would blow it to pieces, and then remarked on a flaw in the weld on the inside of the plenum.
007 Small Port Retail price is $699.00
This was the first of the aftermarket manifolds that they saw. Their initial reaction was to the throttle angle and plenum design in regard to how it should distribute air much better than the stock small port he held in his other hand. But he said that the most signifigant improvement to flow would certainly come from the injector bosses being nixed out of the runner unlike stock design.
007 Large Port Retail price is $699.00
This was the overall winner in their eyes. Like the small port, they liked the runner shape and injector placement. However they did say that they thought the distribution could be a little better if the entry angle and the backside of the throttle plate was revisited to compensate for such a massive throttle. They concluded by saying that if they were to build a VW, they would use this intake based on the performance vs. dollar value it has. (said they would use the 800 price diff between it and the hypertune to buy spray lol)
OE Small Port Comes free with your car.
Hated the throttle angle. Again, they commented on air not wanting to make that kind of turn, and said they (VW) set themselves up for failure from the get-go by pointing the throttle at the roof of the intake over cyl 2. And again, they hated on the injector bosses.
OE Big Port Retail price is $319.00
they basically said all of the same things they did about the OE small port.
Before anyone comments on their comments... Please bear in mind that they had absolutely nothing to gain or lose by doing this testing or providing the opinions they did. It should also be noteworthy that these guys build absolutely ridiculous engines for some fairly high profile race teams, and have years of building and racing experience. So please think about the commentary and its value before any remarks are made about it.
Unfortunately, due to some manifolds needing to be returned as soon as possible and a lack of planning (DOH), we don't have pictures of all the manifolds. Most of you know what most of them look like and we do have pictures of some of them. silvercar has some that I'm having trouble getting access to and they'll be posted later along with his measurements of the different manifolds (runner, port, plenum, throttle, etc). We just wanted to get the data out as you've all waited long enough.
007 Big Port, APR, and Hypertune (top to bottom)
Hypertune plenum
APR plenum
007 Big Port plenum
RMR plenum
007 Big Port port
APR, 007 Big Port, and Hypertune ports (top to bottom)
Homebrew manifold
Dahlback manifold
ABD manifold
ABD ports
ABD plenum
Check back later this evening for more pics and measurements. Thanks again to everyone who made this possible. And lets try to get as many back to back dynos with different intakes to see how all this adds up. :thumbsup:
The original thread that made this all possible.
Issam N. Abed
R&D, INA Engineering performance solutions.
INA Engineering.Com
zemun2
9-2-2004
Belgrade/Zemun SRB
'04 Audi A4 APR Serbia Powered
Great work.
DBR=Vaporware
'04 B6A4 APR Serbia Tuned
Issam Abed
All Over
'91 Audi 80 2.0T
 Re: (zemun2) »« »
Quote, originally posted by zemun2 »
DBR=Vaporware
I am actually going to dyno test it against another manifold from the list.It did perform better than stock
Issam N. Abed
INA Engineering.Com
zemun2
9-2-2004
Belgrade/Zemun SRB
 Re: (Wizard-of-OD) »« »
Quote, originally posted by Wizard-of-OD »
Their longitudinal version is $1900.
Probably yields same results
O2VW1.8T
boosted NC
All wheel drive 1.8T GTi
nice results, good job for doing this work....
GT35R with AWD - (1/4 mile 11.76@126mph pump gas)best 1/8th 7.36@102mph
http://www.pagparts.com http://www.Eurodyne.ca http://www.forcefedengineering.com http://www.INAengineering.com http://semmotorsports.com
B6 A4 1.8T fronttrak Converted to AWD but RWD for now
1988 audi 90q - slow project
screwball
12-10-2001
Fifty Trim
 Re: (O2VW1.8T) »« »
yeah, is this stickied yet?
FS: Used Full Set of ECS Lightweight Underdrive Pulleys
SnowGTI2003
1-7-2004
Guelph Ontario
2009 CR-V 4WD EX-L, 2005 W210 E55 AMG, 2003 GTI 1.8T APR
 Re: (O2VW1.8T) »« »
Interesting results there! Thanks for all the work!
ROZAP
spoolin turbo s
Gate City Virginia
2002 new beetle turbo s
 Re: (screwball) »« »
Quote, originally posted by screwball »
if not it should be
good work guys .........thanks for the effort and work you guys put into this much appreciated
"Son if you got lag you ain't driving right"
-Carroll Shelby
VariantStg3
9-24-2004
Da Swamp FL
2008 R32, 1983 Rabbit GTI
 Re: (spoolin turbo s) »« »
What's 24 cfm between friends? lol...
Thanks for putting on the test guys. With this information we can definitely state that adding a bigger Plenum will increase the overall flow of the factory runners (+ 40ish) and it will continue to have the same traits of the factory manifold.
11.006 @ 135.74 mph 1.731 60ft - 1983 GTI with mods
508.84Whp and 420 Ftlbs | GT3076R-15 |1825cc
18T_BT
9-15-2005
Pittsburgh PA
1.8T "BT" (project) 97 4runner (daily-whenever)
 Re: (VariantStg3) »« »
homebrew FTW now help figure out which way to angle the TB to make it easier on cyl 1
TUNED BY EURODYNE.ca Where Luck Isn't a Factor
155VERT83
8-1-2000
Alexandria Va
07 B6 3.6L Variant //96 B4 Passat GLS 1.8t (For Sale!) // RIP 02 & 03 W8 Variants
 Re: ***1.8T Intake Manifold Test Results*** (Wizard-of-OD) »« »
Great info!
fs: B4 Passat 1.8T
From BlownM3 - "This whole pissing match could have been avoided if the OP did a freaking search!!"
VW remains the "Peoples car"... but the "Peoples" need to bring more money (das loot?).
johnny5gti
11-16-2002
San Jose Ca
nice work! congrats to donR
johnny :: 2010 vw jetta tdi :: 90 vw golf vr6
http://www.lubrify.com
amsoil :: elf :: eneos :: liquimoly :: mahle :: mann
mobil 1 :: motuo.l :: pentosin :: redline :: swepco :: torco
WCM - H.O.D. - streetwerke
VariantStg3
9-24-2004
Da Swamp FL
 Re: (18T_BT) »« »
Quote, originally posted by 18T_BT »
Working on it as we speak. I am gonna incorporate as many learnings as possible and hopefully level the runners. I was also thinking about shortening the runners as well, but that take math. So I will need help...lol.
silvercar
8-23-2004
Dalton GA
337 with a (now more) swole up turbo
 Re: (johnny5gti) »« »
I sure would like to hear what the people who designed these intakes think of these results.
Don R designed the 007 i believe, monster 007 did the fab work.
I believe brett@apr designed the APR unit.
any of you fellas care to chime in on areas you feel are victory or defeat?
Whiskey Tango Foxtrot
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
 Re: (silvercar) »« »
Quote, originally posted by silvercar »
Correction: Don R collaborated with Jimmy @ monster-turbo in designing the 007 and http://www.monster-turbo.com did the fab work.
Elitedubs |Unitronic - DonR@unitronic.ca | QED Power | Pagparts
UniSettings for USB OBD Cable
Issam Abed
All Over
'91 Audi 80 2.0T
When I contacted Keith @ the beginning of this project,he informed me that APR had done there own testing on the manifold and that it gave a 36bhp gain.I wonder if Sam(18bora) would be willing to bolt on one of the other manifolds and hit up a dyno.
The results would be interesting to see.
Issam N. Abed
INA Engineering.Com
FrankiEBoneZ
6-4-2002
Da hood NEW YORK
GTI 337
One thing about the ABD, it is the most consistent across the board so cylinders wont be rich/lean. Either way a few CFM wont matter, but something to take into consideration.
Wish Momentum Tuning's intake manifold was tested.
707WHP/468trq 2.0/20v GTI.... GONE BUT NOT FORGOTTEN!! RIP September 2008
Current Car 2003 Mustang Cobra Terminator, Sonic Blue, Kenne Bell Blown, 615WHP 535TRQ, 10 second daily driven
L.I. Street Racing
solowb5
1-16-2007
cincity ohio
a4 b5
so the 007 manifolds are now 700 instead of the 900 i was quoted?
Parts Pictures for anyone that ask for a picture of an item I am selling:
http://s139.photobucket.com/al...talog/
Issam Abed
All Over
'91 Audi 80 2.0T
 Re: (solowb5) »« »
Quote, originally posted by solowb5 »
This is transverse,not longitudinal.
Issam N. Abed
INA Engineering.Com
axlekiller
10-16-2006
the track
1.8t GTI tuned by axlekiller
W000T.
Sulman's pal
igotaprestent4u
11-2-2002
2002 GTi 20v, 1995 Passat VR6, 1988 Scirocco 16v, 1978 Rabbit L
Looks like RMR would get my $$$
02 GTI 1.8t
07 Subaru WRX
08 Suzuki GSX-R 750
Issam Abed
All Over
'91 Audi 80 2.0T
 Re: ***1.8T Intake Manifold Test Results*** (igotaprestent4u) »« »
Quote, originally posted by igotaprestent4u »
You deducted this from the results?
Issam N. Abed
INA Engineering.Com
SHUMopper
1-1-2002
Long Island
2007 A4 2.0T 2008 Touareg2 V6
awesome testing diz.
really some thourough work here.
The RMR manifold has always caught my interest, and with its price point and results shown i see it definetly in my future.
Question though, with a smaller sized turbo such as mine (T3 Super 60). what gains persay should i expect to see with such an addition? Just torque high up in the RPM range? More sustained power?
Also, does the monster 007 big port come available with a passenger side TB?
Thanks
Steve
|:|SHUMOPPER|:|TYROLSPORT|:|
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
 Re: ***1.8T Intake Manifold Test Results*** (SHUMopper) »« »
Quote, originally posted by SHUMopper »
Thanks
Steve
Steve, I'm not sure if the RMR is available in a small port but it is modular.
I'm not sure what kind of gains you'd see with the RMR.
Modified by Boostin20v at 8:45 AM 2-27-2007
axlekiller
10-16-2006
the track
RMR is available in small port version for the same price.
Sulman's pal
SHUMopper
1-1-2002
Long Island
 Re: ***1.8T Intake Manifold Test Results*** (axlekiller) »« »
RMR can use stock 1.8t TB correct?
Wolk's Wagon
9-27-2000
Houston Tx
 Re: ***1.8T Intake Manifold Test Results*** (Don R) »« »
Nice data guys,
Congrats to Don R on a manifold well done.
'01 225TT Coupe with 400whp
'08 R32
skydaman
12-16-2005
No VA
I see where your going with that... not a bad choice and it comes with a fuel rail and TB adapter or you could build it youself here: http://stores.ebay.com/Ross-Machine-Racing.
Would like to see a USRT tested for comparison.
Modified by skydaman at 11:14 PM 2-26-2007
DSD
Losers can always explain why...as winners never explain how.
bmxp
8-9-2003
Sammamish wa
K04-022 2002 GTI 1.8t, 06 Suzuki GSXR 600
good to know... I have an ABD intake manifold that I got for a trade... So looks like it actually does something at least... haha I might be able to dyno test it sooner or later...
Hooptie|K04-02x info thread
i220gorb
3-30-2006
Odessa
88 mk2
it's the best topic
04VDubGLI
5-19-2005
City of Champs, Pa
Lagoon Blue MK4
 Re: ***1.8T Intake Manifold Test Results*** (bmxp) »« »
What he said. I'm going to try and dyno test my ABD. However, I plan to clean it up a little first. I noted the casting slop. I'm thinking about getting it extruded and honed. If that were to happen it may even be close to the 007 SP.
This test is awesome though... I wonder how the RMR SP would perform. Why did VW hate us and give us SP intake manis...
My Girlfriend: "People get so pissy on vortex. I think thats why you are mad all the time."
BUY MY STUFF!: 20GB Xbox 360 (20GB), OEM 19mm Rods
turbotuner20V
3-15-2004
Overland Park Kansas
 Re: ***1.8T Intake Manifold Test Results*** (04VDubGLI) »« »
Quote, originally posted by 04VDubGLI »
because we also got small port heads
Awesome data compliation and presentation
Cool to see that the AEB/custom plenum method was a pretty decent alternative to dropping alot of cash
2009 Corvette 6spd, Z51, NPP
2002 Audi A4 3.0 Quattro
1990 BMW 325i - turbo track rat
1996 Mazda Miata
[Sold] GTI 1.8t - GT3076r T3/.63 - 462whp/374wtq (100oct.)
John@20Squared
Forum Sponsor
12-5-2005
Philadelphia PA
'08 Rabbit, '02 Jetta 1.8T, '96 GTI, '89 Coupe
 Re: ***1.8T Intake Manifold Test Results*** (turbotuner20V) »« »
great collection of data!
to those who helped make it possible.
20squared, Inc.
John@20squared.com
(610) 757-4649 | AIM: John at20squared
Check out the 20squared BLOG! | Follow us on Twitter
Don R
10-3-2002
Manifesting Within
2000 Golf AWD 1.8T
Reason why ABD has made satisfactory results is do to its short, wide and stuby runner design. I'd like to point out that it's overall performance would not be as expected.
Trq in the mid-range would suffer and fuel atomization would be less than opitmal as a result from low port velocity and turbulent flow.
SloJTI
10-28-2005
fields of corn
BT JTI
x2...especially since mine is ordered
» Return to 1.8T Engine Forum
