dreadlocks
5-24-2006
Denver CO
MKIV GTI 3.0L 12V VRT
My C2 VRT Dyno | « » 4:27 PM 4-7-2007 | |
So the results are in, my first day at the dyno.. I got two hours on the thing so I could tune my greddy profec and play with timing. I am extremely pleased with the results.. I was wanting to crank boost up to 19-20psi but the most I could consistently hold was 17psi. Low boost is now tuned to 10psi and High boost is tuned to 17psi.. off is @ 5psi My Air/Fuel was DEAD ON, the power was smooth and consistent and everything held together and performed quite excellent for nearly 20 pulls, the dyno operator commented this was the best running VRT he has ever seen and I was without doubt the most powerful vdub or audi thats been there. Ego Boost from hellzya! I also tried to see what the top speed on my .681 TDI 5th gear was, but unfortunately the dyno shut down at 170mph.. and I still had 1500rpm til redline 8) More info on my car: http://www.cardomain.com/ride/2389842 Video: http://dwarfurl.com/5971e and the meat of the beast:
Modified by dreadlocks at 5:25 PM 4-23-2007
[Ryan] - 3.0L 12v VR6 Turbo
need a vdub
1-16-2005
Phoenix AZ
Corrados
Re: My C2 VRT Dyno (dreadlocks) » | « » 4:31 PM 4-7-2007 | |
Compresion ratio? And this was on 17PSI pump gas?
Need Powdercoating or ceramic coating? Via mail or local for the low!!! phoenixpowderkoating.com The only 12v with vvt FULL E85 corrado N/A 10/17/09 9:26pm and the count down begins.
dreadlocks
5-24-2006
Denver CO
Re: My C2 VRT Dyno (need a vdub) » | « » 4:32 PM 4-7-2007 | |
8.5:1 CR and 93 octane
fastslc
9-14-1999
Mauritius
Re: My C2 VRT Dyno (dreadlocks) » | « » 4:46 PM 4-7-2007 | |
HOT !!!!!!!!!!!!!!!!!
92 SLC - C2 , AWE Short ShifterVisit my Island = http://www.mauritius.com
TBT-Syncro
4-28-2001
Vancouver b.c.
VR MK3 GTI & VRT Syncro MK2 GTI
Re: My C2 VRT Dyno (dreadlocks) » | « » 5:53 PM 4-7-2007 | |
nice numbers.now buy new motor mounts.
Project-GangGreen VRT Syncro GTI Speedhunters feature on my car Some truth & Information about lightweight Batteries
Soupuh
4-28-2005
Canton/OSU Ohio
2001 Jetta GLX VRT
» | « » 6:01 PM 4-7-2007 | |
numbers seem inline with my peak hp at 16 psi versus your slightly larger turbo... nice!
2001 VRT 354whp/422wtq @ 20psi
dreadlocks
5-24-2006
Denver CO
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 6:03 PM 4-7-2007 | |
| Quote, originally posted by TBT-Syncro » | | nice numbers. now buy new motor mounts. |
lol, those are brand new VF Engineering mounts..
TBT-Syncro
4-28-2001
Vancouver b.c.
Re: My C2 VRT Dyno (dreadlocks) » | « » 7:21 PM 4-7-2007 | |
| Quote, originally posted by dreadlocks » | lol, those are brand new VF Engineering mounts.. |
Looks like i'll be going BFI for sure then.
AlexiGTIVR6
7-21-2000
B.C Canada
97 GTIVR6T & 92 GTI8V
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 8:21 PM 4-7-2007 | |
awesome results
-97 GTI vr6 the turbo build, 22psi414whp 434ft/lb, -92 red GTI 8vDaily driver -92 montana GTI. http://www.gcvws.com Aug 2009. We want US cars to take over this year Wear Red Jade
eric@vr6dynos.com
3-15-2004
South FL
98' GTi VR6 SC
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 10:06 PM 4-7-2007 | |
| Quote, originally posted by TBT-Syncro » | Looks like i'll be going BFI for sure then. |
I just got the VFs. You can't beat a fully machined mount with an insert. When you've seen a bolt on vr6 kill a brand new stock mount with an insert while launching, you lose a little respect for them. They don't really vibrate the car much until I put the a/c on, but they made the car 10x better to drive.
www.vr6dynos.com98' GTi 12v VR6 VF SC Stage 3 - Just bought it already SCed 98' GTi 12v VR6 Turbo 400whp - SOLD 03' GTi 24v VR6 - SOLD 97' GTi 12v VR6 - SOLD
dreadlocks
5-24-2006
Denver CO
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 11:16 PM 4-7-2007 | |
you dont put down 400lbs of torque and not expect motor to move a little... compare mine to other VRT dyno videos and you'll see 10x the movement with stock mounts and over 2x the movement with inserts..
obd2vr6
7-6-2006
tdot ont
PURPLE BEAST 97 VR6T 35R
» | « » 12:36 AM 4-8-2007 | |
sick ride bro what turbo are you running
skillton
9-25-2002
Scarberia ON
88 Golf 16v, TTC
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 9:47 PM 4-8-2007 | |
What are you talking about? that's not even bad.
eric@vr6dynos.com
3-15-2004
South FL
98' GTi VR6 SC
Re: My C2 VRT Dyno (skillton) » | « » 10:58 PM 4-8-2007 | |
I'll try to find video of some 400hp pulls on the stock mounts. It looks like the motor is going to rip off the front mount at 20psi. Then it falls on its face when you let off.
TBT-Syncro
4-28-2001
Vancouver b.c.
Re: My C2 VRT Dyno (skillton) » | « » 1:17 AM 4-9-2007 | |
| Quote, originally posted by skillton » | What are you talking about? that's not even bad. |
i've seen lots high horsepower cars on the dyno with way less movement. I guess its in what you want. I prefer my motor to sit in place.
cabzilla
1-3-2000
Honolulu HI
06 s2k, 99 gti vr6, 89 aba cab
Re: My C2 VRT Dyno (TBT-Syncro) » | « » 2:39 AM 4-9-2007 | |
Nice runs. My .58 60-1 comes on just a split second earlier than yours, which I find interesting.
Tomas Sport Tuning | ATP | Schimmel Performance | DTA | Quaife C2 Motorsports
dreadlocks
5-24-2006
Denver CO
Re: My C2 VRT Dyno (cabzilla) » | « » 3:47 AM 4-9-2007 | |
thanks everyone, I'll have a better video up tomorrow with a new angle on the motor and I'll take those 2 down.. They asked me if I wanted them to tune it, I told them it didn't need it.. I expected the AFR to be good from my VAG logs (albeit much lower sample rate).. It was steady 12.5 at WOT, a little leaner than Jeff Atwood told me it would be but the dyno operator said he always sees a fraction lean due to the altitude.. Overall everyone in the shop was stunned by how well fueled this thing was, again confirming my overall pleasure w/Chris & Jeff's products  about the mounts, guys Ive watched them countless times now and if you notice the entire car lunges forward, if you take in the amount the car moves vs the amount the motor moves you'll find the motor is moving much less than you think it is.. hardly at all but yes it does move some.. outside going with solid mounts however I dont think you'll find anything better than VF Engineering
cabzilla
1-3-2000
Honolulu HI
Re: My C2 VRT Dyno (dreadlocks) » | « » 1:01 PM 4-9-2007 | |
| Quote, originally posted by dreadlocks » | hardly at all but yes it does move some.. outside going with solid mounts however I dont think you'll find anything better than VF Engineering |
I turned to VWMS mounts after breaking a VF front mount.
dreadlocks
5-24-2006
Denver CO
» | « » 1:08 PM 4-9-2007 | |
new vieo http://video.google.com/videop...hl=en
rado_speed
10-6-2005
FL
Currently a 91 vrT Corrado, 08 Rabbit 2.5 2 dr daily, and a 79 Trans Am 400 CI and then so
Re: (dreadlocks) » | « » 2:43 PM 4-9-2007 | |
really, who puts music in a dyno video??sweet numbers
| Quote » | | Custom modification is the best modification. |
Matt49265
7-11-2003
St. Paul MN
TR R32/MK3 rat
Re: (rado_speed) » | « » 5:29 PM 4-9-2007 | |
3bar fpr no inline pump? impressive!stock internals? What was the bill after the cryo treat on the tranny, if you don't mind me asking?
| Quote, originally posted by GruvThang » | I think a MKIII driver hit a light pole then got out and A. started throwing a hissy fit cause he broke his VR lip . B. checking for damage under his car. |
tekstepvr6
8-15-2001
PA
1st C2 MKIV VRT
Re: My C2 VRT Dyno (dreadlocks) » | « » 6:05 PM 4-9-2007 | |
Nice numbers especially in the higher altitude.  Looks like its time for a larger turbine housing or some cams to keep the power up until redline.
Sleepers Performance C2 Motorsports
MKIV VRT - Snapping necks of unsuspecting passengers since '05
dreadlocks
5-24-2006
Denver CO
Re: (Matt49265) » | « » 6:24 PM 4-9-2007 | |
| Quote, originally posted by Matt49265 » | | 3bar fpr no inline pump? impressive! stock internals? What was the bill after the cryo treat on the tranny, if you don't mind me asking? |
I have an inline fuel pump, and internals are stock I picked up a freshly built 02A from an abandoned project, took the Diff and Gears out and put them in my 02J housing... I got a killer deal on it, the guy I got it from took a nice loss but I forget how much it cost for the cryotreatment.. He had them in for less than 1k miles before his motor blew and the gears still looked brand spanking new. They are Rocco VR6 gears, I like that 1-3rd are longer and my TDI 5th makes for a great VRT powerband..
Matt49265
7-11-2003
St. Paul MN
TR R32/MK3 rat
Re: (dreadlocks) » | « » 9:11 PM 4-9-2007 | |
| Quote, originally posted by dreadlocks » | I have an inline fuel pump, and internals are stock I picked up a freshly built 02A from an abandoned project, took the Diff and Gears out and put them in my 02J housing... I got a killer deal on it, the guy I got it from took a nice loss but I forget how much it cost for the cryotreatment.. He had them in for less than 1k miles before his motor blew and the gears still looked brand spanking new. They are Rocco VR6 gears, I like that 1-3rd are longer and my TDI 5th makes for a great VRT powerband.. |
where was the work done at as far as the cryo process? Building a vrt here soon, wondering which direction to go w/ the trans. Whether it be APTuning gearset, Quaife or just a cryo treat... the 3rd option seems the most realistic so far
fukndubn96
9-7-2006
monroe ny
VW
» | « » 9:58 PM 4-10-2007 | |
how come u spiked at 17 psi
VW to the fourth PWRI WANNA GO FAST/// PAGPARTS l UNITRONIC l THE RIDE l AR-15 M4 CARBINE
dreadlocks
5-24-2006
Denver CO
Re: (fukndubn96) » | « » 11:56 AM 4-11-2007 | |
I wasent spiking 17psi, I was holding 17psi.. I could get it to spike more but it'd hold less in the higher RPM's.. The exhaust pressure is overcoming the wastegate spring, I only have a 5.5psi spring, I'll put like an 8psi spring in it and I should be able to hold 20+psi all the way to redline.. I thought it was going to take more boost to produce the numbers I did, so I was pleased to say the least.. Next time I expect to reach (actually surpass) my goals with a larger wastegate spring & water/meth injection,.
IN-FLT
3-21-2003
Raleigh NC
VRT Retta
Re: (dreadlocks) » | « » 2:39 PM 4-11-2007 | |
Nice #'s Ryan !!
EuroRennen NCDubs | Hurtin' Egos| Quote, originally posted by KubotaPowered » | | consulting the MKIV forum for anything is like punching yourself in the d!ck, its always painful and never results in anything good |
HYBRO VR6
11-25-2005
the cold
SUMMER 1995 GTI VR6
Re: My C2 VRT Dyno (cabzilla) » | « » 4:15 AM 4-19-2007 | |
broke a vf mount which one? where did u get the vwms mount any pics iam planning the buy vf mount very soon ****.
CARS OWNED:86 JETTA GLI : ,92 GOLF GTI VR6 , 91 GOLF 2L 8V NOW:1995 VR6 =QUAIFE,H&R COIL-OVER,RECAROS,GIAC,HAWK, NEUSPEED SWAYS ,TT2.5,ACT,AUTOTECH STRUTS,DIESELGEEEK
Norwegian-VR6
2-6-2002
Oslo Norway
1996 Golf 2.9 VR6 Turbo , 2001 Volvo 2.4T V70 AWD Estate
» | « » 1:42 PM 4-19-2007 | |
Really nice numbers. Congrats..
96 Golf VR6 2.9 Turbo. C2 63#, 02M w/Peloquin and a 35R 1.06 2001 V70 AWD Estate http://forums.vwvortex.com/zerothread?id=3189710
BigAl03GTI
8-20-2004
Rutland Vermont
03 GTI 1.8T
Re: My C2 VRT Dyno (fastslc) » | « » 1:50 AM 4-20-2007 | |
nice numbers
fastaddiction RaderWerks DubKorps Dunlop
Zupek
5-10-2000
Milwaukee WI
'00 S4 Sedan AWE Stage 3 '98 24v 3.1 Syncro, '88 QSW
Re: My C2 VRT Dyno (BigAl03GTI) » | « » 10:33 AM 4-20-2007 | |
that is really nice, i dynoed 409whp on 104 octane so you are certainly doing well;) keep it and be careful with those "lean" afr's
The Obama Deception Full Video here http://video.google.com/videop...00195How the FINANCIAL system REALLY works http://www.webofdebt.com/artic...s.php How the JUSTICE system REALLY works http://markadamsjdmba.wordpres...ourt/
IwannaGTI
7-12-2001
Bryn Mawr PA
2001 S2000, 92 GTI VRT
Re: My C2 VRT Dyno (fatfreevw) » | « » 1:07 PM 4-20-2007 | |
Is an inline fuel pump required for the #42 injectors and chip? I have the stage 1 kit intercooled with 3" and the injectors, chip and boost controller are sitting in my basement.
| Quote, originally posted by i_baked_cookies » | | Indeed, that car is pretty much the automotive equivalent of having angry sex with Angelina Jolie while duck-hunting with rocket-launchers alongside Satan himself. |
