b3rt27
6-19-2007
Gatineau Qc
2002, VW Jetta 1.8t
 Tiptronic issue« »
Hi !
I recently started to have that issue: I can't get into Tiptronic mode. I can't even get in "D", it get's in "D" only when I get in "4". Until now I haven't had any problems getting in "R" though. As anyone had this kind of issues, or does anyone know what can be done to fix this. I am hoping this may just be some small adjustments because other than that the car runs perfectly and the tranny seems to shift properly and everything. BTW it's a Jetta 02 1.8T
Thanks guys !
Variety=Spice
2-8-2006
beside the Great Salty Wetspot UT
1999 Audi A8q, 2000 Audi A4q Avant, 1999 Audi A4q, 1982 VW Caddy diesel project
 Re: Tiptronic issue (b3rt27) »« »
pop off the shifter cover and make sure your magnets are still in the right places.
Driving my diesel Caddy is a nice change of pace....it takes the hurry completely out of getting there.
PJA021.8t
4-19-2005
Westerly RI
mkIV Reflex Jetta 1.8t 09A REVO
 Re: Tiptronic issue (Variety=Spice) »« »
Quote, originally posted by Variety=Spice »
Can you elaborate a little on this?
**2010 NE DUSTOFF **
for info, email me at peter@nedustoff.com
///OceanStateDubs
SWIFT MOTOR SPORTS
b3rt27
6-19-2007
Gatineau Qc
2002, VW Jetta 1.8t
 Re: Tiptronic issue (PJA021.8t) »« »
I agree, I would love for someone to elaborate on the subject. I did pop off the shifter cover. Got to the circuit board, but I was unsure of where are supposed to be the magnets, etc. Would be nice to get more info on this !
Variety=Spice
2-8-2006
biggest magnet circled in red...often comes unglued and gets lost. small magnet imbedded in the rubber behind the silver part of the shifter in this view...actually to the left of the shift lever.
http://forums.audiworld.com/a4/msgs/2700013.phtml
Variety=Spice
2-8-2006
also: http://forums.vwvortex.com/zerothread?id=2810322
speakhim
11-18-2007
Norman Ok
1999 Passat Wagon 1.8t
 Tiptronic magnet strip fix »« »
Does replacing these two magnet strips actually make my tiptronic engage and work like it should? Is it just to make the shifter display lights work right? I opened mine up and found one magnet strip and those things that hold them were swinging around my shifter like a hula-hoop, i had no idea what they were for, the pictures in this thread helped a lot. So if i replace these things, where do they go?, both of them, im clueless since I have nothing to go off of. IS this all i need to replace? When I move the shifter over to the "tip" , nothing happens.
Variety=Spice
2-8-2006
 Re: Tiptronic magnet strip fix (speakhim) »« »
The magnets are required to put the tranny into tip mode and to shift gears. When the lever is pushed to the right a switch is activated by the magnet engages the Tip circuitry. There are 2 other switches/sensors that the magnet activates to shift up and down. The sensors are located on the circuit board under the chrome shifter trim. What typically happens is the glue holding the magnet onto the plastic fails and allows the magnet to escape to the nearest metal part. Double check that your magnet is still there.
I can't tell you if that's your only problem, but it's a good place to start.
The long skinny magnet will end up on the far right of the assembly. There are tracks (left to right) in the flexible rubber cover. The multiple plastic chips are just to provide a finished look the shifter assy as the lever moves left and right. IIRC, it was a bit tricky getting the magnet lined up right.
Here's a LITTLE mor info: http://forums.vwvortex.com/zerothread?id=2810322
VWDUDE83
6-29-2003
Bowling Green, KY
-93 Corrado 3.0L VR6T -92 Corrado VR6 04 DBP R32
 Re: Tiptronic magnet strip fix (Variety=Spice) »« »
I get a fault for the Tiptronic switch. im missing the plastic rubber boot on the shifter, does the boot have any magnets in it as well? let me know
93 Corrado 3.0L VR6T....GT35R....
407WHP and 375TQ on pump gas
http://www.youtube.com/watch?v=UTVwDaPRNH4
11.767@124.72mph on pump gas
http://www.youtube.com/watchv=WhhWJP4dWHI
92 Corrado Vr6 14.303 @ 96.22
Variety=Spice
2-8-2006
 Re: Tiptronic magnet strip fix (VWDUDE83) »« »
might help to click on the links above...... esp this one: http://forums.audiworld.com/a4/msgs/2700013.phtml
» Return to Automatic Transmission Forum
