germs dub
5-31-2007
Las Vegas/Barstow/Irwin
2007 GLI
 Fuel pumps and heat problems poll« »
Please reply if you have had any fuel pump and heat related issues on your 2.0T MKV. If you live in an area where the heat during summer is typically above 90, click one....etc, etc. If you're not sure but think you may have an issue, click as such. Reference thread below for details. Thanks
edit: just to be specific, please click only if you are sure it was a fuel related problem (either VAGd or dealer checked it out) thanks
http://forums.vwvortex.com/zerothread?id=3305648
Modified by germs dub at 8:24 PM 7-8-2007
Modified by germs dub at 10:06 PM 7-8-2007
Online Poll » Results
More than once, heat above 90F (77%, 7 votes)
1st time problem, heat above 90F (11%, 1 votes)
1st time problem, heat below 90F (11%, 1 votes)
More than once, heat below 90F (0%, 0 votes)
Not sure, but may have a problem (0%, 0 votes)
(9 total votes)
linedpaper
4-10-2005
Orange CA
2006 gti 2.0T pkg 2
mine has happened more than once. i took it in to the dealer and all they did according to the notes was uninstall/reinstall the fuel pressure regulator. kinda pisses me off because i know that next time i go driving in the heat i'm going to have exactly the same problem.
bgriggs
7-28-2006
Fresno CA
06 GTI 2DR PKG2 CW 6M
It's been over 100F for about two weeks here and my car is running great, not even a misfire (for once).
APR Software & IC ~ KW V3 ~ AWE TBE ~ Peloquin LSD ~ VF Mounts ~ EVOMS Intake ~ Powerslot Rotors & Hawk HPS Pads ~ Neuspeed Discharge & Intercooler Pipes ~ Aluminum Ashtray ~ Euro Switch ~ Aspherical Mirrors ~ Monster Mats ~ OEM LED's ~ Projector Fogs
AutoX - 17x8 Flik FTD | V710 245/45
Street - 17x8 Rial Nogaro | RE-01R 225/45
Street2- 18x8 Karthoum | RE-760 225/40
germs dub
5-31-2007
2007 GLI
I wonder if its just the Vehicles that were built before a certain time. My 07 was built in August. I think my neighbor just drove cross country in his GTI built in Feb, and it didnt look like he had issues.
germs
00 Black VR6 Jetta (first Vdub...traded for a civic )
07 Red GLI
90 Silver G60 Corrado
Barstow/Ft Irwin Dubs click HERE
Twelvizm
4-12-2004
Not approved in the Couve
'06 GLI, '07 Wolfsburg
 Re: (germs dub) »« »
Mine's bogging right now, with a CEL. I have a appt tomorrow to check it out. I'll post a follow up.
SE PDX GTG Meinmedia The Werkstatt <-- Ksport, Eurojet, Kinetic, 034 Motorsports. Free shipping on all Eurojet gear.
Got questions about the joining the Army? I have answers, IM me.
bcze1
2-5-2007
a pink sock is near
some vag
 Re: (Twelvizm) »« »
I've been driving everyday in 90+ heat for the past month, including a 2,200 road trip, and she's running like a champ! 12/06 build date if it matters.
gtimakesmebroke
9-29-2006
Las Vegas NV
2007 GTI
 Re: (bcze1) »« »
mines been at findlay for two weeks now...first it was the sensor they were going to do, then the high pressure fuel pump and now the in tank pump thats SUPPOSED to be there tomorrow, which is why i couldnt have it back...(they wanted it to be there because apparently there are going to be a lot of replacements tomorrow and wanted mine to get one)...i dont know, i didnt buy a brand new car to have these kinds of issues at 10000 miles, plus have crappy AC to boot!!
TEAM FAIL
DUNKIN'DUBSMERCH
Twelvizm
4-12-2004
 Re: (gtimakesmebroke) »« »
I turned out to be a back PCV. It was replaced and things are back to normal.
germs dub
5-31-2007
2007 GLI
 Re: (Twelvizm) »« »
good deal, good luck man.
germs
07 Red GLI
CRB
2-6-2007
2007 Passat 2.0T / 2003 Passat Wagon / (1986 Jetta GL / 1980 Dasher Diesel)
 Re: Fuel pumps and heat problems poll (germs dub) »« »
What are the symptoms?
germs dub
5-31-2007
2007 GLI
 Re: Fuel pumps and heat problems poll (CRB) »« »
check out the thread link in the first post, it should pretty much explain the symptoms.
germs
07 Red GLI
» Return to Golf V & Jetta V
