need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Megasquirt on a Distributor VR6« »
Not a fancy title but one you can search to.
Got one of the first running almost two weeks ago and I'm finally getting the time to get all the information up. I'll put it up in stages in this first post so be patient. Having problems with my ftp so I won't have screenshots and the .msq until tonight.
I will assume that all those reading will have base MS knowledge. Those who don't feel free to ask some questions.
1992 SLC engine/drivetrain into a 1992 GTI (my old one). Car has been running a stock chipped ECU for a little over a year. All factory sensors have been used, only addition to the engine bay is a single vacuum line for the map signal.
Wiring is straight forward from a cut up Motronic ECU connector to the MS DB37 connector. I will post the pinout below.
[MS to Motronic Pinout Placeholder]
Board built and tuned by me.
MS1 V3
MSnS-E 029t
Board mods/hardware:
VRIN - TSEL
TSEL - VROUT INV
D14 with pullup to IGN (no VB)
Both VR pots fully CCW
Launch Circuit
Tach Circuit (not working yet) w/ 2k pullup
TIP120 for PWM idle valve with 1N4001 flyback diode between output and 12v
Remove Q4, Q20 and R39. replace R39 with a wired link or solder the (E) emittor to the right side of position R39 rather than at the Q4 position.
Innovate LC1 wideband to stock narrowband O2 pigtail.
MSQ: http://www.msruns.com/download.php?id=5661 you will have to register/login until I host it
[Placeholder for configuration screenshots]
The maps are street tuned about as good as they can get and I will NOT post dyno tuned maps as they are customer owned. So, don't ask
The car with this ECU ran 14.0's all day at Waterfest on Sunday despite non-ideal conditions.
Enjoy!!
Modified by need_a_VR6 at 1:47 PM 7-26-2007
-Paul
'95 GTI VR6 - ALL MOTOR 12.833@105.48 - 198+whp
KPTuned : Megasquirt Solutions - Repair - Installation - Tuning
::: The Race Shop : M.J.M.
sdezego
4-23-2004
Hurricane Central FL
'90 G60 -soon to be 20/20 - '62 Harley Panhead
 Re: Megasquirt on a Distributor VR6 (need_a_VR6) »« »
Nice work
Project sc2020
My G60 on MSnS-e | 2020 Timing Belts | 4Cyl Torque Plate Rental | 02M Mounts
VWralley
3-30-2002
Pacific Raceways Wa
'77 Bunny 16v, '82 4dr diesel bunny, '85 Audi 4000q
 Re: Megasquirt on a Distributor VR6 (sdezego) »« »
Thanks man! great info
RalleyTuned-website coming soon!
NFA
FS: 85 Audi 4000
TRAKS Clothing Demon Rally SpitFireEFI.com Scch-Heads
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: Megasquirt on a Distributor VR6 (VWralley) »« »
Thanks I'll get the real msq up later tonight for those that want to download and go
-Paul
fourthchirpin
11-19-2004
EST.8/1/02
mk3gti
interesting....pm sent.
FS: 02A Quaffie & 4.24 Ring/Pinion Final
"RACING IMPROVES THE BREED"
West Indian Crew
darren p.
1-26-2002
All Motor, NY
A2 VR6 - 13.39@101
Good stuff Paul...hurry up on a coil pack one.
I know you haven't done it yet but what, if any difference do you for see between the OBDI coilpack motors and OBDII? Does the distro VR use the same style IAC valve as the coilpack motors?
FS: Volk TE37
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: Megasquirt on a Distributor VR6 (darren p.) »« »
The only difference as far as the setup is concerned is that the OBD2's have the idle valve in the throttle body. I'm pretty sure though it will even work without the uprated transistor I posted above, as the OBD2 idle motor is a much lower current unit.
The OBD1 cars all have the same IAC, either distro or coil.
Working on it though.. hopefully I'll make some nice progress in August without all the races taking up my time.
-Paul
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
Wiring Schedule:
Motronic T68 Pin # ---- MS Pin # --- Function
1,7,10,33,55,56 ---- 8-19 --- Ground
36 ---------------------20-------- IAT+
14----------------------21--------CLT+
41----------------------26--------TPS+
40----------------------22--------TPS
20----------------------23--------O2
67----------------------24--------VR+
68----------------------7----------VR-/VR Shield
22----------------------25--------Tach
27----------------------27--------PWM 12v
23----------------------28--------12v supply
53----------------------30--------PWM Idle (Fidle)
3,24,26-------------32/33-------INJA
2,4,25--------------34/35--------INJB
8-----------------------36---------Ignition Out
6-----------------------37----------Fuel Pump (Relay)
28---------------------37----------Heated O2 (Relay)
X-----------------------29----------Launch
T68/9 needs to be pulled to ground to turn the ECM relay on. There's a 12v ignition hot supply to the ECU that I didn't write down. It needs to control a relay that pulls it on. The stock ECU must have an internal transistor to do this. I'll post up that fix when I do it
Sorry for the sloppy order but it's how I think.
-Paul
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
Tach circuit works with a 4.7k pullup.
The 'funny' issues with the fuel pump relay were solved with an additional relay. T68/9 is grounded through a relay that's switched on with ignition hot on T68/38, the other two pins of the relay (contact and coil ground) are grounded at the MS at pins 14/15.
-Paul
92rado2.8
7-12-2004
New Castle De
1992 MK2, 1992 Corrado
I was just going to do a whole big post but Paul got to it before me.
The vehicle is mine and Paul did a great job with the wiring and getting all the bugs worked out.
I will put up some pics as soon as I can. If anyone has a question about the car feel free to PM me,
http://www.baak2basics.com/
http://www.usrallyteam.com/ <I am a Distributor>
Accurate Machine (302-992-9606) For all of your machine shop needs!
Buy my 1992 MK2 VR!! http://forums.vwvortex.com/zerothread?id=4547052
deviantsoldier
12-14-2006
Kaiserslautern, Germany RLP
2003 VW Jetta 1.8t, 2000 VW GTI VR6
need_a_vr6, can i use your spark advance table on my mk4 coilpack vr6 to start off with? will it be accurate since you have a distributer?
MySunRoofWorks
8-2-2000
somewhere in the desert
93 Corrado
This is great, I have been thinking about doing this for awhile on my coilpack 93 Corrado. Keep it coming!
Membership has it's privileges.
Tire_Marx
3-3-2004
Winnipeg Manitoba
anything else done to the vr, or 14's on stock motor with MS?
1992 GTI VR6 - 262's, GIAC
(The following was said after I DESTROYED my 1.8L 8V)
Quote, originally posted by TwinScrew20v »
You sir...Are my hero
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: (Tire_Marx) »« »
Spark map should work on a coilpack car, even the wheel decoder settings should work. Just have to use three spark outputs instead of just the one.
The motor is a stock 92 SLC motor with a Mk4 headgasket, intake and 2.5" TT exhaust.
-Paul
deviantsoldier
12-14-2006
 Re: (need_a_VR6) »« »
Outstanding. i got my vr6 running yesterday on your spark and fuel maps. thanks need_a_VR6
92rado2.8
7-12-2004
New Castle De
Quote, originally posted by Tire_Marx »
Yeah it is pretty much stock, Along with what Paul mentioned I have a 42 draft design test pipe, no ac or ps, no front sway bar, started to mess around with my intake mani. Thats it. I have a set of schricks waiting to go in but I need HD springs and a couple of other things first.
Just wanted to also say that Paul is a great guy and has helped me out alot over the years, throwing parts my way and some tech support. I would not trust anyone else with wiring up a MS. The inside of my MS looked better than my mother board in my computer
all-starr-me
7-13-2003
Binghamton/Syracuse New York
90 Jetta Coupe VR6, 93 Corrado SLC, 96 Passat TDI.
what's gonna be the advantage of a distributor or coil pack over each other as far as cost, ease of use and spark control? I have parts and harnesses for both and am deciding what way to go in the spring for my coupe.
Fastdubs.org
**** Jake!
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: Megasquirt on a Distributor VR6 (all-starr-me) »« »
Distributor is only one spark output, and the coil is three. Distro would be a bit easier, but in the grand scheme of things they're not that different.
-Paul
surfer1992
11-20-2002
corona ca
1992 VW Corrado 3.0 t
ahh I did somthing wrong... I burned the VB921.....
any advise ?
90 g60 17" Oz's
it gave its life to save mine
New one 92 VR6 rado 3.0vrt
built here
http://www.tuning-technik.com
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: Megasquirt on a Distributor VR6 (surfer1992) »« »
Whats the setup? On this install I didn't use the VB921.
-Paul
nuts4boosting
6-29-2006
Middletown de
1992 3.0 vrt rado
im sent
xbox live sn hanfulopter
IF YOU NEED ANY HEATING, AIR CONDITIONING OR PLUMBING DONE ON YOUR HOME I'M YOUR GUY IM ME
Quote, originally posted by tekstepvr6 »
300 whp on a vrt is like foreplay with a porn star, just a step away from glory.
deepgrooves74
8-2-2006
Pearl River NY
1984 VW Rabbit GTD-SVO , 2004 WRX Wagon
 MegaSquirt... Paul »« »
Hey Paul... I was told to give you a shout from Scott over at USRT concerning help putting together a Megasquirt kit for my car.
Thanks!
cj
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: MegaSquirt... Paul (deepgrooves74) »« »
Shoot me a PM
-Paul
edge-motorsports
10-1-2006
eugene OR
i also run have been running a similar ms setup for a little over a year in my autocross car. it was a grat upgrade from the stock ecu. we went from 192whp to 214whp with just megasquirt.
i don't normally drag race but we took it to the strip at the end of the season and ran 12.2 consistently..it was fun! (its in a mk1 jetta coupe by the way)
i would recomend MS to anyone as a good upgrade for a vr6
ade007
6-12-2007
uk
megasquirted VR6t@27psi + 1958 splitscreen project
i have my coilpack vr6 running on your msq just altered a few settings as mines direct coil pack wired with 3x vb921 cheers
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: (ade007) »« »
Good stuff, glad it worked for you!
-Paul
ade007
6-12-2007
uk
i run 36lb injectors no cat just fitted my techedge linear wideband and been out tuning allday my car has never run as quick im very pleased
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: (ade007) »« »
When you're done make sure you put the msq on msruns!
-Paul
MySunRoofWorks
8-2-2000
93 Corrado
Paul, what MS unit do you recommend to use with a coil pack VR6? Also do you think it's better to buy a pre-built unit or if someone has decent electronics experience, to build one?
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: (MySunRoofWorks) »« »
Either a 3.0 or 3.57 depending if you want to solder a lot or not. The 3.0 isn't bad to assemble just a lot of parts! If you find that sort of thing FUN, do it, you'll learn more just by seeing the hardware and reading the assembly manual then anyone with a prebuilt. I like building them myself but my time is limited and I'm getting prebuilts from DIYAutotune now.
-Paul
MySunRoofWorks
8-2-2000
93 Corrado
Quote, originally posted by need_a_VR6 »
I have plenty of time and solder these days. Thinking about picking one up after the new year. I'm trying to squeeze every last pony out of my NA car before I give up and go FI.
ade007
6-12-2007
uk
i bought mine from phil ringwood extraefi.co.uk pre modifyied to suit my coilpack vr6 and i asked for pauls msq to be pre installed but altered for coilpack all i had to do was turn my required fuel down to from 13.6 to 7.2 to suit 36lb injectors @ 4 bar .. it came with a short lume to wire to stock ecu plug all coulor coded and wires labeled with a pin 4 pin diagram it made it a very easy install for me plug and play if you have an old ecu to break up for the socket
Modified by ade007 at 3:11 AM 12-30-2007
ade007
6-12-2007
uk
ok matey i will put my msq on msruns... i have been very busy i fitted a turbo now i will put that msq on too when ive done some tuning
Dead-Rabbits
1-11-2008
Zeven
VW Golf Mk3 VR6 Turbo 1996
 VR6 Distributor »« »
Can anyone help me at my options for my MS2 V3.57 Firmware 2.687 to start my VR6 Turbo Distributor Engine ???
I have ignition and fuel, but the Engine doesn't start.
need_a_VR6
5-19-1999
Elkton MD
95 GTI VR6
 Re: VR6 Distributor (Dead-Rabbits) »« »
I got your email, just send me your msq and I'll take a look.
-Paul
First  1 2 3 4 5 >  Last
» Return to Carbs, ITBs and SEM Forum
