D.Passat00
2-28-2004
Reseda CA
'00 Passat 2.0T/'07 GTI 2.0T
 So, I have compiled a list of common issues and remedies for the 2.0T« »
So, I’ve compiled a list of common issues and common solutions based on what I’ve seen on the forums. Please research any possible fix before performing it. Personally, I’ve only had a bad pcv, so I’m basing a lot of this based on my understanding of the issue. Please let me know if something needs to be changed or added…I’d like to make this as good a possible.
If your car is stock and you still have warranty, then all the items below should be covered under warranty. If you are not stock, then the failed component may or may not be covered under warranty depending on what caused the failure, though this thread is not a warranty debate thread.
Disclaimer: This is a general guide only. Any problem with the car should be diagnosed by a competent and trained individual. All information provided is for information only and is not designed to replace a service manual or professional help. Use at your own risk.
1. Diverter valve failure
2. PCV failure
3. Broken intake ducting
4. Cam lobe wear
5. High pressure fuel pump failure
6. Air conditioning does not work
7. Tumble flap failure
8. Cold start problems
9. Misfires
10. Low fuel pressure sensor failure
Background:
The stock diverter valve (dv) is prone to failure, whether chipped or stock. The diaphragm is prone to tearing (the orange shown in the pic of the stock dv (in the middle) below-may be a different color depending on the version of dv you have.)
Symptoms:
-A failing diverter valve will generally lose boost.
-The boost can be checked either via a boost gauge, or the vag-com (mb 115). You will see a huge drop in boost when the dv goes bad.
-Pin-hole DV failures usually allow boost to spike, but will then suddenly vent boost.
Tearing in the DV usually only allows 6-7 PSI. Boost will not spike.
-You may see 000665 - Boost Pressure Regulation: Control Range Not Reached
p0299 - 002 - Lower Limit Exceeded - Intermittent
-Alternatively, you can remove the dv, and inspect the diaphragm for tears. It is held onto the compressor housing by three bolts:
Solution:
-You can replace it with the stock dv, vw #06F 145 710 C. This is the latest dv as of this post, however, many people have also seen failures with the “C” dv. VW is also supposedly coming out with a “G” dv, part # 06F-145-710-G, though it is not officially released as of this post.
-You can upgrade to the Forge DV #fmfsitv. Pics of the Forge DV are shown above.
2. Positive Crankcase Ventilation failure
Background:
The positive crankcase ventilation is supposed to let gases get sucked from the crankcase to the intake manifold when under vacuum. The problem is, when the pcv system fails, and allows positive pressure (boost) to go from the intake manifold back into the crankcase.
The latest PCV is the “G” version. To see which version you have, take a small mirror, and stick it under the pcv valve. The last letter identifies the revision (“E” is shown below). The part # is under the round section:
Symptoms:
-Typically you will see a slight drop in boost pressure. When my pcv failed, I saw a 2 psi drop across the board.
-Some oil will be pushed out through the oil filler cap, and onto the valve cover, and may possibly go towards the coil packs. There may also be some oil on the bottom side of the engine cover, where the oil filler cap is.
-There might be a slight decrease in MPG.
-Rear PCV failure usually results in oil accumulation around the DV, and will produce a little blue oil smoke at WOT applications.
Solution:
-There is the Digitalhippie fix which puts a check valve into the line from the crankcase to the intake manifold. For those who want a spare of the hose where the check valve is installed, the part number is 06F 103 221 F. You can read more about it here: http://www.golfmkv.com/forums/...=8952
-You can also upgrade to the latest PCV “G” valve. There have been very few failures reported with this PCV. Please verify the PCV you have before upgrading.
Part numbers for this upgrade:
PCV valve cover assembly: 06F 129 101 G
PCV valve cover gasket: 06F 103 483 E
PCV valve cover to turbo hose: 06F 103 215 A
PCV tube to turbo metal gasket: 06F 145 757 F
-If you did the DH pcv fix, and you have a rear pcv failure, then you will need to change the tube labeled as "Exhaust turbocharged gas outlet" showin in the pic above. the Part #'s are the last two shown above (06F 103 215 A & 06F 145 757 F)
Background:
Some people have reported that part of the intake ducting that connects to the stock engine (the part in front of the accordion section) breaks off and gets lost, or worst, gets stuck and/or shredded by the fan. Due to its location, the loss in power should be minimal.
Symptom:
-You may notice that part of the ducting is missing.
-You may see shreds of the ducting in and around the fan.
-You may see the coolant temps rising possibly due to a part of the intake ducting getting stuck and not allowing the fan to turn. If the coolant gauge goes into the red, then immediately shut the engine off, and check to see if the fan is operating.
Solution:
-If the fan is damaged, then you may need a new fan.
-An aftermarket intake will replace the ducting section, and is a possibly solution.
-You might be able to tape or epoxy the sections together, so that it will make them harder to come apart. You may also remove the top piece alltogether.
4. Cam lobe wear
Background:
Excessive wear of intake camshaft lobe that drives the high pressure fuel pump. The wear limits maximum pump piston lift, causing fuel rail pressure fluctuations. The intake cam drives the fuel pump:
Please see also #5 below.
Symptom:
-Fuel cut-out when driving, esp. under WOT.
-Fuel cut-out symptoms range from soft pulsations of power to long-pulse bucking while in high-gear high-load situations (high gear at WOT, or up a grade). MIL may flash if cut-out is severe. Car will also go into hard-limp (no boost, 4500RPM limit) if severe enough.
-MIL ON
-P0087 Fuel Rail / System Pressure - Too Low
-P1093 Fuel Trim 2, Bank 1 Malfunction
-P2293 Fuel Pressure Regulator 2 Performance
Solution:
Increase surface hardening of camshaft lobe for the high pressure fuel pump. Improved intake camshafts have Part No. 06F109101B. Refer to TSB# 15 07 04
Background:
The high pressure fuel pump sometimes is not able to supply enough fuel, especially at low to mid range RPMs because it is cam driven. Please note that the high pressure fuel pump is different than the in-tank fuel pump. Please see also #4 above.
Symptom:
-You may see the following DTC
004767 - Low-Pressure Fuel Pressure Regulation: Pressure too High
P129F - 001 - Upper Limit Exceeded - MIL ON
Solution:
-If you are chipped, then try to put the car in stock mode to see if the fuel cuts will stop. If it does, then you might want to wait until a fuel pump solution comes out. APR and Autotech are currently working on solutions.
-If you are stock, then it is possible that you have a bad fuel pump. The dealer should replace this under warranty.
Background:
The air conditioners manuf. By Zelex and Valeo tend to fail. They can be identified by the pulley:
Symptom:
- Air conditioning does not cool, air conditioning compressor may seize.
Solution:
- On the 2.0T engine a new Sanden compressor Part No: 1K0820803 index S must be installed. Refer to ETKA for the latest part # for the other engines. This should be covered under warranty.
Background:
The tumble flap motor is prone to failure. This is probably the most common problem I’ve seen when scanning cars with the vag-com. A little background on how the tumble flap works:
Symptoms:
You may see the following DTC’s
-012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded – Intermittent
-012691 - Intake Manifold Runner Control: Open Stop outside of Valid Range
P3193 - 002 - Lower Limit Exceeded - Intermittent
-008196 - Intake Manifold Flap; Bank 1: Stuck Open
P2004 - 008 - Implausible Signal - Intermittent
- 012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 008 - Implausible Signal - MIL ON
Solution: The intake manifold flap motor needs to be replaced.
8. Cold Start Problems
Background/Symptom: Troubles starting car when cold
Solution:
-Some people have reported that it was related to a certain gas, so maybe try a different gas station/company.
-Get the latest software reflash.
-Could also be a bad coil pack.
9. Misfires
Background/Symptom:
-Misfiring either under idle or under boost.
-Scan for DTC’s. See which cylinder is misfiring, and swap coils and or plugs to see if the misfire follows.
-Coil pack misfire (non-fire, lol) symptoms are shorter duration, rather violent, and also result in backfires from unburnt fuel entering the exhaust system. The MIL usually starts flashing. Car may or may not go into limp.
Solution:
-Replace coils and/or plugs
-Could be a bad fuel injector
A special thanks to DirtyDisco. and syntrix for providing some of the info used in this post.
10. Low Fuel Pressure Sensor Failure
Background/Symptom:
You may get the following DTC’s:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent - MIL ON
P129F - 001 - Upper Limit Exceeded – Intermittent
-The first symptom is typically stalling when first starting the car cold.
-Typically, the problem gets worse, and can lead to fuel cutouts at almost any rpm and/or car stalling/running lean/rich
Solution: Replace low fuel pressure sensor (thurst sensor), vw part #06E906051J
Sometimes, the high pressure fuel pump will be replaced at the same time (#1 in pic below)
Modified by D.Passat00 at 9:37 PM 1-28-2008
Modified by D.Passat00 at 9:39 PM 1-28-2008
2000 Passat 2.0t
2.0L Euro-Spec Short Block;JE Pistons and Euro-Spec Rods;PES T-28 Turbo;FMIC;3" TBE;Stoptech BBK
2007 GTI 2.0t with Parktronic
Hex-USB+Can Vag-Com
MKV Vag-Com Guide MKV Fuses 2.0T Issues
VWAUDITEK
12-25-2006
Highboost HI
AudiTT,Audi A4 USP,Audi A4 Titanium Ed. 2.0T
 Re: So, I have compiled a list of common issues and remedies for the 2.0T (D.Passat00) »« »
Excellent!! I think you may ACTUALLY WORK on VAG cars!!
Audi TTFWD,401whp,348tq.REVO,ATP,GT3071R....NO CEL!!!
Corrado 16VT,444whp,350 tq....SDS,GT3076........sold
Audi A4 Ultra sport.........BT coming
Karma,it is everywhere you will be.
DeathMoJo
10-8-2006
Lakeside CA
2004 VW R32
 Re: So, I have compiled a list of common issues and remedies for the 2.0T (VWAUDITEK) »« »
beautiful write up!
This needs a sticky!
Electronics Technician 3rd Class
United States Navy
My Dubs:
04' R32 - DBP, '06 GTI (Sold), '91 GTI VR6( Sold)
milan616
8-5-2006
Burlington MA
2007 GTI w/DSG
Threads like this are why we need a forum sticky like the Mk5 forum.
NEK - Humans are not gentle, friendly creatures wishing for love, who simply defend themselves if they are attacked, but that a powerful measure of desire for aggression has to be reckoned as part of their instinctual nature. (Sigmund Freud)
Quote, originally posted by the awesome »
sometimes i don't wear any underbritches....the kids these days call it going commando, i call it freedom
LeBlanc.
7-14-2003
The US Murder Capital IL
 Re: (milan616) »« »
If you add symptoms (driveability) other than DTCs in some of these, like the Tumble Flap, etc., this thread would be awesome-er-y.
(516): Thank God they found balloon boy, I was afraid that Michael Jackson was ordering take out from heaven.
Chicago's only Radiohead tribute. 11/27 The Alley (Highland Park) - 12/10 Reggie's Rock Club - 12/30 The Abbey Pub
D=Style
7-16-2007
Jakarta ca
Bookmarked.... hehe
D.Passat00
2-28-2004
Reseda CA
 Re: (DirtyDisco.) »« »
Quote, originally posted by DirtyDisco. »
like i said in the first post, i haven't experienced a lot of these problems. also, those that i've talked to with the tumble flap problem haven't really noticed anything different about their cars. but of course, if anyone has something additional to add, then i'd be happy to incorporate it...this is meant simply as a starting point.
2000 Passat 2.0t
Hex-USB+Can Vag-Com
LeBlanc.
7-14-2003
 Re: (D.Passat00) »« »
if severe enough.
Front PCV failure usually results in oil accumulation around the filler cap, etc. as
described.
Modified by DirtyDisco. at 9:20 AM 7-31-2007
syntrix
8-20-2000
Little Rock AR
Loaded Colt Tea Party
Good stuff D!
Here's another pic of the intake piece:
Deviant:Speed | REVO > apropaganda | Swankmonkey Racing
D.Passat00
2-28-2004
Reseda CA
if severe enough.
described.
thanks for the input!
so, for the rear pcv failure, replacing the hose in the back labeled as "exhaust turbo gas outlet" in the pic below with the latest one should fix that problem right?
2000 Passat 2.0t
Hex-USB+Can Vag-Com
LeBlanc.
7-14-2003
 Re: (syntrix) »« »
Quote, originally posted by syntrix »
Good stuff D!
LOL... looks like the one from my MkV GTI... which lodged into the fan, and burnt
out the motor.
D.Passat00
2-28-2004
Reseda CA
 Re: (syntrix) »« »
Good stuff D!
thanks for the pic...do you mind if i use it?
oh, and my piece came off a few days ago too...it was just sitting on top of the intake...luckily i saw it when i did before it had a chance to fall into the fan.
2000 Passat 2.0t
Hex-USB+Can Vag-Com
NoRegrets78
7-6-2006
Dix Hills NY
2008 Honda Element EX 4WD
I love you man!
JIABANO
LeBlanc.
7-14-2003
Quote, originally posted by D.Passat00 »
Yessir.
D.Passat00
2-28-2004
Reseda CA
Yessir.
cool, so the parts needed for the rear hose/tube should be these two correct?:
2000 Passat 2.0t
Hex-USB+Can Vag-Com
LeBlanc.
7-14-2003
them's the ones
teriba
12-4-1999
Calgary AB
2007 VW GTI
You get a big hissing/whooshing sound when your DV fails too!
Stage 2+ 2007 GTI United Grey
Canadian Exposures - Canadian photographer directory, job board & photo sales
Mike Cousins Photography
SPORTLINE GTI 6MT
2-11-2007
Durban KZN
2005 VW Golf 5 GTI
This is brilliant. Thanks DPassat.00
gtidylank
3-14-2007
Seatac WA
06' MKV Gti
I'm confused....
NO Wait... Maybe I'm not... j/k
This thread just idiot proofed the general tuning problems of the 2.0T
I like this better then the "No Drama" Thread
Sincity
5-16-2005
Las Vegas NV
'07 GTI RIP. CURRENTLY '86 190e 2.3, "04.5" C320 sedan, '08 RDX, '09 C63 AMG.
 Re: (SPORTLINE GTI 6MT) »« »
This is awesome. Thanks DPassat
RIP: 07 RS GTI 5-door with APR Stage 2 and other goodies.
Crappy OSIR V1 Fitment: http://forums.vwvortex.com/zerothread?id=3318310
bigred35
3-10-2002
2009 GLI
 Re: (gtidylank) »« »
Very Nice! (Borat voice)
Do your oil changes cost $70 and does your car burn oil like $1 bills at a strip club? You must own a MK5 2.0T!!! Congratulations!
91 16V Jetta
12-6-1999
Portland OR
1991 Jetta VR6, 2007 Dodge Ram 2500 MegaCab, 2006 Porsche 997S Cabriolet
Hopefully VW will look at this too
D.Passat00
2-28-2004
Reseda CA
Quote, originally posted by VWAUDITEK »
i don't actually work for VW, though i do most of the mods on my car myself.
2000 Passat 2.0t
Hex-USB+Can Vag-Com
maitino
7-24-2007
San Juan Capistrano California
2007 Volkswagen GTI 2.0T
Great write up and thank you for the information it will be very helpfull! I checked my PCV valve and it is the "E" version so I do not know if it needs to be replaced? Can one of you guys give me idea of how I pull it off and how you can tell if it is broken? PLEASE HELP! Thank you!
APR 93/100 Octane Software, Neuspeed P-Flo CAI, ATP 3" Downpipe, Magna Flow High Flow Catalytic Converter, Neuspeed Downpipe Back Exhaust System, Forge Twintercooler. Intercooler, Neuspeed Turbo Discharge Kit, Neuspeed Intercooler Pipe, Neuspeed Power Pulley Kit, Schrick Cam, Forge Diverter Valve, Vf Side Motor Mount, Vf Pendelum Motor Mount, NS Boost Gauge,NGK BKR7EIX, Clear Side Markers.
GTIcodez
4-4-2007
Metro DC
06 DSG GTI
great write up, haven't had alot of issues myself, but will be replacing my dv this weekend so I will get you pics of riped one, and next week I am taking it in for the flap so will take some pics of that for you as well
APR STAGE II
13.7 @ 104mph
DSG POW3R!
3.0" ATP Intake Kit VW Audi 2.0TFSI Turbo
vwzig
10-3-2005
fort worth tx
06 GLI
bump cause this is one of the best 2.0t related threads
06 GLI REVO TRADED
05 mini cooper S
JESUS SAVES!!!!!!!!!!!!!!
Conejo GTI
7-29-2007
Virginia beach va
2006 GTI 2.0T 6MT / 2008 Passat 2.0T / 2007 EOS 2.0T sport (hers)
 Re: So, I have compiled a list of common issues and remedies for the 2.0T (vwzig) »« »
JAY PICHARDO Master certified VW sales consultant
Greenbrier Volkswagen, chesapeake VA. VW floorplan/wholesale dealer
sorry IMs don't work
. EMAIL me instead jaypichardo@gmail.com
His: 2006 GTI 2.0T package 2 6MT & 2008 Passat 2.0T Hers: 2007 EOS 2.0T Sport
djorkaeff_andrei
9-16-2006
bucharest
2006 Seat Leon 1P 2.0 TFSI
yesterday i did DH's fix for the PCV and when i removed the hose, i saw that there was pretty much oil in it. where is it coming from? is it the PCV or is it the rear PCV? there is also oil around my Forge Spacer...
I think (and hope) it's the rear PCV that lets oil from the crankcase to the turbo side and that being for a long period of time it got to the intake as well. I would much apreciate some more competent opinion
.. start worrying... lots of sugar
djorkaeff_andrei
9-16-2006
bucharest
update: my PCV is revision D so it has 2 one way valves incorporated, but i have oil accumulation around the DV, if i get the:
"PCV valve cover to turbo hose: 06F 103 215 A
PCV tube to turbo metal gasket: 06F 145 757 F"
i will have 2 rear pcv one way valves, would this cause a problem with something?
djorkaeff_andrei
9-16-2006
bucharest
update: i have the revision D pcv on the car...
A3_yuppie
6-5-2006
Orange County CA
2006 Audi A3 2.0T (DSG) & 2009 Audi A4 2.0T Quattro Sedan (Tip)
This is the single most useful thread in the entire 2.0T forum.
Noob #1: "I want to get a chip. Which is the best?"
Oldtimer: "... use the !@#$%&* search ..."
Noob #2: "OMG you need to replace your DV and PCV stat!"
emo_dubber
5-11-2007
Hamburg NJ
2007 GTI 2.0T FSI
the sad part is i've had about three of these issues.
2007 Tornado Red DSG MK5 GTI. H&R 60-40 Cup Kit. Eurojet Diverter Valve. Revo Technik Stage 2 Software. EuroJet FMIC. New South Boost, Oil Temp and Oil Pressure Gauges. Neuspeed P-Flo Intake and Heat Sheild. 3" GHL Turbo back exhaust and Muffler.2 Pioneer 12" TS W301R Woofers. Alpine Head Unit CDA9886. Alpine PDX 1-400 Amp.
chris@revotechnik
5-17-2007
Buford Ga
too many
 Re: So, I have compiled a list of common issues and remedies for the 2.0T (emo_dubber) »« »
Quote, originally posted by emo_dubber »
Isn't everything sad for you?
sorry just having fun with your username
Chris Cafiero
chris.cafiero@revotechnik.com
(770) 271-4726
http://www.revotechnik.com
2000 jetta 1.8t Gt28rs for sale!
emo_dubber
5-11-2007
Hamburg NJ
2007 GTI 2.0T FSI
 Re: So, I have compiled a list of common issues and remedies for the 2.0T (chris@revotechnik) »« »
LMAO nice one dude.. haha its the music i listen too not the way i am, my europlate says emo-Dubber lol
chris@revotechnik
5-17-2007
Buford Ga
too many
I didn't think you would be offended, like some of the music too.
Chris Cafiero
(770) 271-4726
First  1 2 3 >  Last
» Return to 2.0T FSI Engine Forum
