QBalance156
4-9-2003
Ann Arbor MI
1996 VW GTI VR6
 Ignition Switch DIY w/ Pics« »
I'm sure a lot of you have already changed your ignition switches by now, but for those who haven't, here's a DIY on how to do it without pulling out the steering wheel and the pressed collar. Thanks VW for making access to the switch such a pain in the arse!!! There's another thread out there on this technique, but I thought I'd post my own version with some advice from my recent experience.
Reason to Replace?
When ignition switches start to go, there are a ton of different symptoms. In my case, my switch would not recognize when I pulled my key out of the ignition. It would keep playing "la cucaracha" and the radio would stay on even after i pulled my key out. Thanks to the advice from fellow vortexers, I realized that I only needed to replace the switch and not the ignition lock cylinder. phew...
Where to Buy?
I bought mine for $8 with free shipping from http://www.mjmautohaus.com. It came in about 2 days! I'm not sure if this is OEM, but it will probably last me long enough.
Tools Needed
10mm wrench for the battery terminal
(2) 13mm wrenches for the joint
Phillips screwdriver
**Small phillips screwdriver** This is very important!!! It needs to be a phillips with a very thin and long shaft (try an eyeglass repair kit)
Procedure
1) Make sure that you have your radio codes for your stock stereo or that you write down all of your preset stations and sound settings.
2) Remove the negative battery terminal since you'll be working in the airbag area.
3) Remove the upper and lower steering column covers (two screws)
4) Remove the lower foot panels (3 total)
5) Remove the knee panel (remove the 5 screws at the bottom and pull straight down
6) Unplug all (8?) wire connectors to the steering column
7) Use vise grips to unscrew the bronze screw since the screw head is smooth
8) Stick your head into the footwell and check out that U-joint. First mark off the position of the shaft relative to the U-joint. This will ensure that everything is aligned when you re-assemble. I used whiteout to mark it in two spots. Then use the a 13mm wrench on the nut and another 13mm wrench on the bolt. You need to remove the bolt COMPLETELY in order to pull the column out.
9) Okay! Use the steering wheel to pull out the column! Watch out for little spring that will drop when you pull the column out of the U-joint
10) So this is the trickiest part. To remove the ignition switch you need that small phillips screwdriver. Based on previous posts, I didn't know how difficult this was going to be. Apparently, the only thing that will work is a screw driver from like an eyeglass/jewelers kit. None of my "small" screwdrivers fit!! I started to panic because this is my only car and I had no means to drive myself to the store to get the proper tool. I tried bending a screwdriver, and that didn't work. I DID have a jewelers flathead screwdriver. Desparate times call for desperate measures. I used the flathead and the vice grips to make myself a nice ghetto tool to get the screw out.
11) Just swap out the switches. My old switch had a crack in the housing which might have been causing my problems. Old is on the left, new is on the right
12) Just like the Bentley manual always says, installation is the reverse of removal. Some tips:
When installing the column back to the U-joint, don't forget to put that spring back in. When you put the bolt back in, take note that the steering column has a notch in it for this bolt, so you might need to slide the column either out or in to get it to line up.
13) Once everything is reinstalled, connect the negative battery terminal , and be prepared for the alarm to set off. Stick the key into the ignition and switch it to accessory 2 mode to let the engine recalibrate for about 1 minute. Fire her up and let her idle for 5 minutes to let the ECU stabilize.
Ta DA. That's it!! You're done!
Da_Mount
1-19-2003
Lil American Ghetto
06 Passat & 96 Getta GL
 Re: Ignition Switch DIY w/ Pics (QBalance156) »« »
ctuagent117
10-3-2005
Atl GA
1997 vw jetta gls
nice DIY, you can never have too many.
Find out who /Really/ controls America.
http://video.google.com/videop...dex=1
rayray086
9-24-2006
West Sydney NSW
95 VW Golf GL
 Re: (ctuagent117) »« »
Quote, originally posted by ctuagent117 »
x2. Going to do mine when the new one gets here. I've already bookmarked at least three DIY's for this
VWWatercooled.org.au
Dubs Down-under.
`rayray086
fbmorcrack
8-4-2005
732 NJ,910 NC
so much rice i put chinese restaurants out of business
 Re: (rayray086) »« »
if i have a chip will the flash be lost when the ecu recalibrate's?
ecaps ym
3/6 USMC-AFGHAN '09-'10
gtiodea
7-17-2005
Madison WI
96 GTI 2.0, 85 Cabriolet
Good DIY nice pictures
The power of the four gerbils A.K.A. the 2.o
http://www.cabby-info.com/index.html
Dutchsider
4-26-2006
Population increase PA
1995 Jetta GLX
 Re: (gtiodea) »« »
new ignition switch ordered from MJM earlier today. This will be happening soon
Josh - PM me about MK3 OEM European fenders, bumpers and hatches
Book
Quote, originally posted by whiteriot »
People are modding their cars with cheaper and cheaper ****, this to me is the European equivalent of "rice".
FS: Volks
MJM Autohaus
10-20-2003
T E X A S
 Re: (Dutchsider) »« »
Quote, originally posted by Dutchsider »
We appreciate the order.
|M|J|M| |A|U|T|O|H|A|U|S| B+G|Forge|NEUSPEED|KONI|Autotech & more!
Your best online source for discounts on OEM and MAINTENANCE parts, too!
Our Vortex feedback is HERE and HERE | ------> AIM & YIM : mjmautohaus
wagsGTI
9-16-2006
B.F.E. OH
1996 GTI VR6
nice DIY
http://www.bigohio.net
http://www.swov.org
http://www.dubdojo.com
BB 62.. bitch!
BBQmotorsports - BUBENGROPEN - LOWERED CARS SAVE GAS! my DIY page -
VertigoGTI
4-1-2001
Cincinnati Ohio
2004 Finneus G35
+1
I like this method more than the one that was posted a few weeks ago.
Does anyone know the size and thread pitch of the bronze smooth screw? I'm just gonna get a flathead of phillips to replace it.
Modified by VertigoGTI at 2:39 PM 9-20-2007
Your 'Sentra chirps 3rd gear' jokes/references are original and witty... in opposite land.
Vortex Transaction History
mr sarcastic
11-2-2006
gonic nh
 Re: (VertigoGTI) »« »
take a dremel with a cutting wheel to cut a line into the head. that way you can use a flat head screwdriver on it.
CSD
FS: 01 JETTA 1.8T AUTO
VertigoGTI
4-1-2001
Cincinnati Ohio
2004 Finneus G35
 Re: (mr sarcastic) »« »
Switch came in today. I'll be doing the install this weekend with one of the 16 DIYs that are on the boards. I'll just use this one
sun98gtiVR6
1-7-2007
Milwaukee WI
'98 GTIvr6, 160,xxx miles, with original chains
Quote, originally posted by VertigoGTI »
Quote, originally posted by Ceramic God Product »
Your question was answered the third post down, but you probably didn't notice as you were too busy focusing your attention on how best to whine like a bitch.
Quote, originally posted by djsheijkdfj »
Math. It's hard to believe
Dutchsider
4-26-2006
1995 Jetta GLX
 Re: (sun98gtiVR6) »« »
just did mine today.
turns out I didn't need too oh well,
that steering knuckle realignment is a bitch
Book
FS: Volks
VertigoGTI
4-1-2001
Cincinnati Ohio
2004 Finneus G35
Oh well, at least you weren't in a situation where you HAD to do it. It really sucks on a 103° day and you can't start your car until the interior cools down.
ReflexJettaVR6
7-6-2004
North Kingstown RI
03 Jetta (The "other" GLI), 04 Passat GLX wagon
Did mine the other day following this DIY... finding the right small screwdriver is a huge PITA... and putting the steering column back into the U-joint is an absolute nightmare
Other than that, it's pretty simple. No more finding my ignition's "G-spot"
OSD
03 Jetta GLI - No CEL since 3/16/09
FL 2.0L
7-31-2002
'96 Jetta GLS 241K '02 Cabrio GLX 66K
It definitely helps to have a hand getting that u-joint aligned. My 10 yr old was able to help, so if you have one, or a semi-intelligent pet, the job will go easier.
fear vw 2.0
4-26-2007
Catlett va
1997 Vw GL Golf
I just replaced my switch with this diy thinks man its about time vwvortex was useful you saved me. 250$
GTI are only letters
Toiletcar
8-3-2007
Coatesville PA.
95 Jetta GLX 08 Rabbit 2.5
nice diy
buy my mkIII. i need coils for my rabbit
http://forums.vwvortex.com/zerothread?id=3806268
QBalance156
4-9-2003
Ann Arbor MI
1996 VW GTI VR6
 Re: Ignition Switch DIY w/ Pics (Toiletcar) »« »
I'm glad that my DIY helped people out. I guess one thing that I should add is that it's somewhat easy to put the shaft back into the U-joint if you position yourself the following way:
-lie on you back in the footwell w/ your arse on the door scuff plate.
-with your left hand, control the steering wheel
-with your right hand, line up the U-joint and make sure the spline goes in straight.
In my opinion, the hardest part about this repair is dealing with that one screw.
AmberTrevorfix
9-28-2007
Watsonville Ca
1999 VW Jetta
I just wanted to say thank you so much for posting this DIY!!! I have very little knowledge of car repair but with your guide I fixed it in 1 hour!
andyztoy
1-21-2006
Whitby Ont
1992 jetta aaz 1996 Gti-Sold 1993 Jetta-Sold 04 636 Ninja 03 EX-500 Ninja-Sold
 Re: Ignition Switch DIY w/ Pics (AmberTrevorfix) »« »
sweet diy i don't need a new switch but i am sure i will one day... so keep the pictures hosted for a long long time
Gti - My toy
mk2 td build
04 636
For amazing quality Powdercoating for a fair price contact,
Bright Side Powdercoating ryan@brightsidecoatings.com 905 449 7910
...OMGHI2U...
7-24-2007
North LA CA
gRabbit
you don't have to pull off the knee panel, but great write up
sarah
Dubbers for the cure | Rat Stylz
grabbit
vw_love
1-13-2006
trek.
 Re: (...OMGHI2U...) »« »
Quote, originally posted by ...OMGHI2U... »
says the person driving a MK5
Quote, originally posted by hurt »
Dance puppetboy if you do a good job
Then they'll want you again, give it all that you got
But laugh, clownboy, laugh 'cause it's always so pleasing
Rub a dub dub
9-7-2003
on the other side of the zipper line
Widebody DC10 and C1 Local Driver Tug #612
 Re: (vw_love) »« »
autobOOb.
QBalance156
4-9-2003
Ann Arbor MI
1996 VW GTI VR6
The reason why I pulled off the knee panel is because it's really hard to pull out the connectors in such a tight space. The connectors on my car were pretty much sandwiched between the steering column and knee panel.
You don't NEED to remove the panel, but it does make things easier to access.
...OMGHI2U...
7-24-2007
North LA CA
gRabbit
 Re: (QBalance156) »« »
hmm I didn't have any issues with space on mine, or my friend's that I did. If I ever do one again I'll try your way and see if it's easier.
sarah
grabbit
BlueMk3VR6
8-6-2001
Jacksonville FL
98 GTI VR6 blown, 06 Touareg V6
excellent DIY...did mine few months ago the same way.
Arnie - 98 GTI VR6 blown
BlueMk3VR6
VertigoGTI
4-1-2001
Cincinnati Ohio
2004 Finneus G35
 Re: (BlueMk3VR6) »« »
How exactly does the back right lower foot panel go back on? I cannot get it to line up to anything.
Anyone have a picture of the assembled footwells?
EDIT: N/M, I got it. I just needed to step away from it for a few minutes..
Modified by VertigoGTI at 6:33 PM 10-9-2007
kujo763
8-3-2007
saint francis mn
1998, vw jetta
Ta DA. That's it!! You're done! [/QUOTE]13) Once everything is reinstalled, connect the negative battery terminal , and be prepared for the alarm to set off. Stick the key into the ignition and switch it to accessory 2 mode to let the engine recalibrate for about 1 minute. Fire her up and let her idle for 5 minutes to let the ECU stabilize.
i followed this to a tee, but now my jetta will not idle any suggestions? what have i done wrong by the way the diy was super helpful, thank for the post!!!
VertigoGTI
4-1-2001
Cincinnati Ohio
2004 Finneus G35
 Re: Ignition Switch DIY w/ Pics (kujo763) »« »
Anytime I disconnect my battery, the idle gets weird for a day. Even if I do the 'key in the on position for a minute' thing, it's still weird. Just drive it the best you can.
Modified by VertigoGTI at 3:35 PM 10-11-2007
GoodFella07
10-10-2007
 Re: Ignition Switch DIY w/ Pics (VertigoGTI) »« »
Awesome DIY
scruffy923
12-21-2006
MA
'91 Jetta 8v
Quote, originally posted by kujo763 »
Ta DA. That's it!! You're done! 13) Once everything is reinstalled, connect the negative battery terminal , and be prepared for the alarm to set off. Stick the key into the ignition and switch it to accessory 2 mode to let the engine recalibrate for about 1 minute. Fire her up and let her idle for 5 minutes to let the ECU stabilize.
Take your throttle body of and clean it with some tb cleaner that **** is probably gross if you never done so, that happened to me last year everytime I got my car back from the transmission shop til one day I decided to clean the throttle body and its been fine ever since.
And good DIY
Modified by scruffy923 at 6:25 PM 10-16-2007
QBalance156
4-9-2003
Ann Arbor MI
1996 VW GTI VR6
I'm surprised with how many people have had to do their ignition switches since the time I've posted this DIY. Man, VW designed a pretty lame ignition switch... I'm sure the stealership makes a killing off of this repair.
I'm planning on doing my timing chains sometime soon...I'll also make a DIY for that
First  1 2 3 4 5 >  Last
» Return to Golf III & Jetta III
