maloosheck
10-5-2004
Sterling VA
mk5 Jetta/Golf 4motion conversion findings | « » 12:04 PM 9-21-2007 | |
I would like to start this topic to keep all my findings regarding the Mk5 Jetta/Golf 4motion conversion. I am going to focus on the TDI engine, as this is what I currently drive. It appears it should be way easier to make the conversion in mk5 then in mk4. Here is a comparison of FWD and 4motion rear suspension: This is FWD rear suspension:
 And this is 4M rear suspension:
 It appears the bolts attaching the whole thing to the chassis are in the same location. What is more important I can confirm there is a cavity over rear suspension in my Jetta that should allow Haldex to fit in. In other words: the FWD and 4Motion chassis APPEARS to be the same. Which should make any potential conversion really easy. Here are two pics of the rear side of the drivetrain with the rear drive splitter (or whatever proper name of this thing is). One is from Passat B6 (most likely BMM engine code - Passat B6 shares lots of components with A5 Jetta/Golf), the other one is from mk5 R32. Passat B6 4motion:
 Mk5 R32:
 The BRM engine that is in US Jetta TDI has a similar turbo setup: over the exhaust manifold. Again, this means there should be enough space to fit in the splitter. Here are three pictures of the rear suspension: Passat B6, Mk5 R32 and Mk5 Golf TDI 4motion (available in EU and Mexico AFAIK): Passat B6 4motion:
 Mk5 R32:
 Mk5 Golf TDI 4motion:
 In addition here is the picture of the FWD Mk5 Golf suspension:
 As I mentioned: there is a cavity in the Jetta chassis that should fit in Haldex. One thing that also needs to be changed is fuel tank. I still look for the pictures of fuel tanks in Jetta, Golf and Golf 4motion. I would be grateful for any info regarding 4motion conversion in mk5 Jetta/Golf, especially from the EU forums.
'06 1K2 BRM GQQ 155 255 4M Project I For sale - cheap! I DubHaus GTG Sth=something, Sb=somebody
O2VW1.8T
boosted NC
All wheel drive 1.8T GTi
Re: mk5 Jetta/Golf 4motion conversion findings (maloosheck) » | « » 11:06 PM 9-21-2007 | |
wow that sure does LOOK easy if it will bolt up. The lower trailing arms arm the same. If thats the case everything else will much 100 times easier then a Mk4 AWD swap... I would give it a shot
GT35R with AWD - (1/4 mile 11.76@126mph pump gas)best 1/8th 7.36@102mph http://www.pagparts.com http://www.Eurodyne.ca http://www.forcefedengineering.com http://www.INAengineering.com http://semmotorsports.com B6 A4 1.8T fronttrak Converted to AWD but RWD for now 1988 audi 90q - slow project
O2VW1.8T
boosted NC
Re: mk5 Jetta/Golf 4motion conversion findings (maloosheck) » | « » 11:19 PM 9-21-2007 | |
checked etka and the 4motion trailingarm and the regular FWD arm are the same..
maloosheck
10-5-2004
Sterling VA
» | « » 1:54 PM 9-22-2007 | |
Here is something that I am not sure. This is a picture of the 4motion 6-speed tranny with the detached splitter (anyone knows proper name?):
As you can see there are 4 holes to attach the splitter and there is no diff flange (most likely the whole part is different). I found several pics of the 6-speed trannies that were in the FWD vehicles:
Only the last one does not have the holes for the splitter bolts. My question is: will the FWD tranny with the holes work with splitter, say after making sure that the diff flange from 4motion? Or are there any other differences between 4motion and FWD trannies that will not allow to attach the splitter to the FWD tranny?
jettaboy_gtx
4-12-2003
Hamilton Ontario
1991 Coupe G60, 1990 Corrado R32, 2003 GTI 1.8T
Re: (maloosheck) » | « » 3:18 PM 9-22-2007 | |
the spliter as you call it is transfer case. And im not 100% sure but i think you cant put a transfer cas on a FWD tranny. why wouldnt you just find an AWD tranny and use that instead of trying to put a transfer case on a FWD tranny?
mechanic 1: holy **** look at this! mechanic 2: this aint your mama's jetta no more1990 Jetta GTX 20V - Gone but not forgoten Corrado R32 WIP: http://forums.vwvortex.com/zerothread?id=3187589
maloosheck
10-5-2004
Sterling VA
Re: (jettaboy_gtx) » | « » 11:40 PM 9-22-2007 | |
| Quote, originally posted by jettaboy_gtx » | | why wouldnt you just find an AWD tranny and use that instead of trying to put a transfer case on a FWD tranny? |
how easy is it going to be to find a 6-speed 4motion tranny with TDI engine gear ratio in NA that I can use in mk5 Jetta?
TBT-Syncro
4-28-2001
Vancouver B.C.
1992 MK2 GTI Syncro VRT
Re: (maloosheck) » | « » 2:11 AM 9-23-2007 | |
| Quote, originally posted by maloosheck » | how easy is it going to be to find a 6-speed 4motion tranny with TDI engine gear ratio in NA that I can use in mk5 Jetta? |
You arent going to find with in NA, you need to look overseas.
Modified by TBT-Syncro at 2:58 PM 9-23-2007
Project GangGreen VRT Syncro GTI Speedhunters feature on my syncro Some truth about lightweight Batteries
maloosheck
10-5-2004
Sterling VA
Re: (TBT-Syncro) » | « » 4:17 PM 9-23-2007 | |
| Quote, originally posted by TBT-Syncro » | | Yyou arentt going to find with in NA, you need to look overseas. |
Any idea how to easily bring it here, once I find it?
TBT-Syncro
4-28-2001
Vancouver B.C.
Re: (maloosheck) » | « » 5:59 PM 9-23-2007 | |
Ever imported a large/heavy item before?Its all going to depend on the seller/shipper and what they're willing to do for you at their end. Bringing it through customs once it's here is easy.
boner
5-18-2002
toronto and ottawa
'93 Corrado VR6, '99 A4 Avant, '95 cabby VR...GF's ride soon
Re: (TBT-Syncro) » | « » 1:47 PM 11-6-2007 | |
purely unscientificly, i'd say that the pics look close enough that you can bolt the transfer case on a fwd trans. if i had to guess tho, you'd probably be looking for a different front diff cuz it's got to engage the transfer case. also, what about the axle seal on that side? is the OD of that gonna be the same OD as the part of the transfer case that goes into the box?looks to me at first glance that were you to establish that you CAN infact attach the transfer case to the fwd trans, the rest of the car will more or less fall together, and for relatively cheap too i mean, looks to me all we're talkin about is the transfer case, rear suspension, custom exhaust and probably some misc electrical gizmos to control the haldex (are there any?) the electrical scares me though. i mean, even the wipers on my gti are connected to the brains so that they go to intermittant when you are at a stop light.....
farfrumslow
11-27-2004
brewster ma
83 gti supercharged on 15x9 bbs, 00 gti, 84 gti twin 1.8T, 07 GTI on 20x8 bbs
Re: (boner) » | « » 5:59 PM 11-6-2007 | |
there are also holes for fluid transfer in addition to the four bolt holes
BSD/// http://wentworthmotorsports.com//// 508-896-8660 making dreams reality, one car at a time
maloosheck
10-5-2004
Sterling VA
Re: (farfrumslow) » | « » 2:34 PM 11-10-2007 | |
| Quote, originally posted by farfrumslow » | | there are also holes for fluid transfer in addition to the four bolt holes |
Heard about it. Any pics/other resources to validate this info?
maloosheck
10-5-2004
Sterling VA
Re: (boner) » | « » 2:37 PM 11-10-2007 | |
| Quote, originally posted by boner » | | the electrical scares me though. |
AFAIK it should be the easiest part. Haldex is connected with 5 wires: power, ground, CAN-H, CAN-L and brake switch. The only problem I can see here is that there might be different Haldex programming for Diesel and Gasser.
Modified by maloosheck at 5:50 AM 3-7-2008
tranceporter
11-30-2007
Monroe Twp NJ
2008 BMP GTI
» | « » 3:04 AM 1-29-2008 | |
bump?
http://willlahara.wordpress.com
shortshiften
3-29-2005
raleigh nc
04 s4
» | « » 5:11 PM 1-29-2008 | |
nice......
let me get this straight ... your honda has 1.8 liters when my mountain dew has 2??you know what they say "when in rome".....yes go on..... do..as the romans do here to you Ron Burgendy mopeds are like fat chicks. there fun to ride till your friends find out
Audi4u
6-29-2002
Newark NJ
95 VW GTI, 2001 VW Gti mk4.5T, 2007 VW Rabbit 2.5 Turbo
» | « » 1:40 PM 2-4-2008 | |
This is what I need! Makes my Rabbit even more valuable!
Fastest, Quickest, Most powerful MKV Rabbit in the World Video Channel C2Motorsports Flashloader dealer | Tuning email support@sstune.com 2.5T TECH forum ID=740 Web designer needed please email for details.
shortydub
10-12-2004
Traverse City MI
2006 gli
Re: (Audi4u) » | « » 4:02 PM 2-8-2008 | |
these parts can be easily sourced in america.. ecodeparts will import thus fer shur
mujjuman
7-29-2004
Albany NY
01 Jetta VR6, 06 Jetta 2.5, 03 heated seats
Re: (shortydub) » | « » 12:48 AM 2-10-2008 | |
wow sweet.
mujjuman 2001 Volkswagen Jetta VR6 + 2006 Volkswagen Jetta 2.5
| Quote, originally posted by kraut_pauer79 » | | wow, junkyards look like enchanted forests where you live. |
http://vwvortexsearch.webs.com/ < vwvortex search
wuznmeTT
4-18-2005
newington ct
2005 Audi S4 ,1986 951, 06 Kawi 636, 09 Aprilia RSV1000R
» | « » 11:32 AM 2-10-2008 | |
Wow, I was just talking about this. I'd love to do it. Looks like it may not just be a pipe dream. Thanks for making the info available.
What the Hell's an Aluminum Falcon?
Audi4u
6-29-2002
Newark NJ
Re: (wuznmeTT) » | « » 7:46 AM 2-12-2008 | |
Does anyone have pics of how the mkv r32 exhaust is routed?
Audi4u
6-29-2002
Newark NJ
Re: (Audi4u) » | « » 7:59 AM 2-12-2008 | |
nm
Audi4u
6-29-2002
Newark NJ
» | « » 7:36 AM 3-7-2008 | |
Bump
jetta9103
9-20-2003
Auburn Hills MI
01 Jetta WE, 90 Jetta GLI, RIP 91 Jetta GL ECOdiesel
Re: (jettaboy_gtx) » | « » 7:02 PM 3-9-2008 | |
| Quote, originally posted by jettaboy_gtx » | | the spliter as you call it is transfer case. And im not 100% sure but i think you cant put a transfer cas on a FWD tranny. why wouldnt you just find an AWD tranny and use that instead of trying to put a transfer case on a FWD tranny? |
the "splitter" is NOT a transfer case...it is referred to as an "angle drive" or more commonly a "power transfer unit." it performs the same function as a t-case, but t-cases are usually used in longitudinal setups (and also where the transmission does not house a final drive of some sort), and power transfer units are typically used in transverse setups. btw, cool pics in the OT. and cool topic. im interested in the answer...
MIVE: Michigan VW Enthusiasts Something to remember where I come from:
| Quote » | | Chipped ham? Is that APR or Revo? Either way, that must be one fast pig! |
Issam Abed
All Over
'91 Audi 80 2.0T
Re: (maloosheck) » | « » 9:50 PM 3-9-2008 | |
| Quote, originally posted by maloosheck » | | Any idea how to easily bring it here, once I find it? |
Will cost you about 450-600US in shipping alone.Better to do it in a bulk shipment or have 1 of those specialty people (ecodeparts,etc) import it for you.I guess VW finally got smarter and made both chassis the same.Andre you want to do this?
Issam N. Abed R&D, INA Engineering performance solutions. INA Engineering.Com
Audi4u
6-29-2002
Newark NJ
Re: (Wizard-of-OD) » | « » 8:18 AM 3-21-2008 | |
| Quote, originally posted by Wizard-of-OD » | Will cost you about 450-600US in shipping alone.Better to do it in a bulk shipment or have 1 of those specialty people (ecodeparts,etc) import it for you.I guess VW finally got smarter and made both chassis the same.Andre you want to do this? |
I was thinking of use using a audi tt 225 trans.
trastrim
8-11-2006
west allis wi
05 Subaru WRX STi
» | « » 9:09 PM 3-21-2008 | |
What is the estimated cost and workload associated with the possible swap of a 4motion drivetrain into the MK5 chassis. I'd love to do this one the Rabbit, especially if it's about the same price as a turbo (without labor)
05 Subaru WRX STI, 1987 Volvo 240DL Sedan, 1986 Volvo 240DL WagonOldies: 98 A4 07 Rabbit
Issam Abed
All Over
'91 Audi 80 2.0T
Re: (Audi4u) » | « » 12:30 AM 3-28-2008 | |
| Quote, originally posted by Audi4u » | I was thinking of use using a audi tt 225 trans. |
Same bell housing as the inline-5? Wow VW is getting smarter
abeMKvGLi
7-23-2006
PaLMdAle/Los Angeles CA
2009 Audi A4 2.0TQ, 2006 GLi DSG RIP, 1989 GLi 16v, 1995 GLS VR6, 1991 Jetta Coupe
Re: mk5 Jetta/Golf 4motion conversion findings (maloosheck) » | « » 2:40 PM 4-3-2008 | |
inteerrestttinggg . .......
* 2006 Deep Black GLi DSG (R.I.P.) * 1989 16v GLi 5spd * 1995 Jetta GLS VR6 5spd * 1991 Jetta Coupe 1.8 5spd (stb vento vr!) * 2009 Audi A4 2.0T Quattro Premium Plus Navi AVDUBS ELITE MEMBER
bwzimmerman
6-15-2007
Baltimore MD
2007 Volkswagen Jetta 2.0t
» | « » 5:50 AM 4-13-2008 | |
any more info? What about us 2.0T owners? We got the Audi A4 2.0T Quattro to part from... right?
*SOLD* 2007 VW JETTA 2.0T REVO Stage 2/ HPA DSG Stage 2 2009 Infiniti G37x / Nav / Premium Package / AWD / Obsidian Black
jetta9103
9-20-2003
Auburn Hills MI
Re: (bwzimmerman) » | « » 9:53 AM 4-14-2008 | |
| Quote, originally posted by bwzimmerman » | | any more info? What about us 2.0T owners? We got the Audi A4 2.0T Quattro to part from... right? |
no, not "bolt on," because you are still dealing with completely different drivetrain setups. Audi A4 = longitudinal (w/ a center diff) your 2.0T = transverse (w/ PTU & Haldex)
maloosheck
10-5-2004
Sterling VA
Re: (Wizard-of-OD) » | « » 2:24 PM 5-12-2008 | |
| Quote, originally posted by Wizard-of-OD » | | Will cost you about 450-600US in shipping alone.Better to do it in a bulk shipment or have 1 of those specialty people (ecodeparts,etc) import it for you. |
Do you have any more details on how to ship anything from Europe? I found the transmission I want and I need to find out how to bring it.
djsaint
8-20-2004
Broomfield CO
2008 VW GTI 4dr DSG Candy White
» | « » 10:42 AM 5-13-2008 | |
I am very interested in this thread and hoping I see a DIY come out of it. I purchased a DSG GTI, with hopes that it would be easier to source US parts to do the conversion. Looking forward to someone giving this a shot.Cheers, Chuck
Broomfield, CO 2008 Candy White VW GTI 4dr DSG w/ Autobahn Pkg Lover of music, movies, reading and travel.
maloosheck
10-5-2004
Sterling VA
Re: (djsaint) » | « » 11:19 AM 5-13-2008 | |
| Quote, originally posted by djsaint » | | I am very interested in this thread and hoping I see a DIY come out of it. I purchased a DSG GTI, with hopes that it would be easier to source US parts to do the conversion. Looking forward to someone giving this a shot. |
With DSG gasser all you have to do is to save some money and find the totaled mk5 R32 (one was already in the mk5 classifieds)...
Marshmallow Man
6-16-2004
2.4 liters of z'ness monster
Re: (maloosheck) » | « » 6:55 PM 5-16-2008 | |
whats the orientation of the tiguan 2.0t? after all is said and done probably better just buyin the tiguan
Don't be a whomp, put some butter on it!
EL_3grab
3-25-2006
UAE AJ
07 - GTi
» | « » 6:12 AM 5-17-2008 | |
http://forums.vwvortex.com/zerothread?id=3842257
:Agent 47 Drives a Golf .. :
