ssaffioti
4-8-2006
06 Jetta GLI, Pkg 2, 6MT, Silver/Anthracite - 00 Ford F-150, 4.2L, 5MT
PCV Valve 'E' vs. 'F' | « » 11:54 PM 12-3-2007 | |
A lot of members have been swapping the PCV in the front, and the tube in the rear. According to the chart, the 'F' valve can be used with the old pipe.... Are owners with the C & D versions just as well off going with the 'F' valve?Also, with 'G' being discontinued, the latest revision logically would be the 'F'.
matt225
11-23-2007
fl
Re: PCV Valve 'E' vs. 'F' (ssaffioti) » | « » 12:51 AM 12-4-2007 | |
I'm getting a new one at the dealer tommorrow so I'm interested to see which revision they'll give me.
ssaffioti
4-8-2006
» | « » 10:42 AM 12-4-2007 | |
Matt, please reply back with your results! Anyone else know about how these two valves compare?
crew219
10-18-2000
ITH NY
Re: (ssaffioti) » | « » 10:54 AM 12-4-2007 | |
| Quote, originally posted by ssaffioti » | | Matt, please reply back with your results! Anyone else know about how these two valves compare? |
IMO it is better simply just to replace the back check valve pipe with the new version and get the EJ PCV setup for the front. Dave
Forge DV Review APR SII beta logs REVO 93 logs APR 93 logs
- Jeremy -
2-22-2006
Stuttgart Germany
'08 DBP R32 #2791
» | « » 11:42 AM 12-4-2007 | |
My car was odd, actually...My G rev PCV was blown, so I replaced it with F and ordered a new breather tube to match. When I took off the old breather tube, I found that it was already the new style with a check vavle inside and the part number matched the new one that I had just ordered... I checked it for leaks and found that it was actually holding air better than the new one I had so I just put it back on the car. Looks like I wasted $50 but at least I have a spare laying around, I guess... - Jeremy -
rbradleymedmd
2-23-2007
Columbia SC
B6 Passat Tip
Re: PCV Valve 'E' vs. 'F' (ssaffioti) » | « » 11:43 AM 12-4-2007 | |
I have the F revision after my C PCV failed. At the same time I replaced the F, I added the EJ PCV fix and since then...no problems.
| Quote, originally posted by Joel@Eurojet » | | Dazzle them with brilliance, don't baffle them with Bull****. |
ssaffioti
4-8-2006
Re: (- Jeremy -) » | « » 11:50 AM 12-4-2007 | |
So Jeremy, you have a combination of parts on your car... The 'F' valve originally came with the steel pipe which had no check valve in it at all. That should mean that you have three check valves instead of two. That may not be a bad idea!
mwwVW
3-30-2003
Rocky Point NY
Re: (ssaffioti) » | « » 3:03 PM 12-4-2007 | |
what pipe are you guys talking about? the one on the back of the engine or the one that connects the pcv valve to the intake manifold?
2007 bmw 335i 12.788 @ 111.89 on 2.082 60' i still <3 kmj
ssaffioti
4-8-2006
» | « » 3:42 PM 12-4-2007 | |
The "pipe" we are talking about is the one running from the back of the valve cover down to the turbo.Food for thought: Since 'F' comes after 'E', I would assume that the improvements made on the single valve in 'E' would also be found in the corresponding valve in 'F'.
Modified by ssaffioti at 12:44 PM 12-4-2007
shue333
2-18-2007
felton DE
1988 FOX GL wagon / 2006 GTI
Re: (ssaffioti) » | « » 4:06 PM 12-4-2007 | |
| Quote, originally posted by ssaffioti » | | The "pipe" we are talking about is the one running from the back of the valve cover down to the turbo. Food for thought: Since 'F' comes after 'E', I would assume that the improvements made on the single valve in 'E' would also be found in the corresponding valve in 'F'. Modified by ssaffioti at 12:44 PM 12-4-2007 |
i went round and round with my dealership and vwoa about this. they told me that if my car was equipped with the "E" valve, then "F" would be the replacement. supposedly it's from the audi side and does not require changing the rear tube. the check valves inside the pcv are also supposedly "beefier". they weren't going to put the "G" valve on and nothing i could say or do would change their minds. my "F" valve has been good to me so far. my original (E) went when i was stock right after the oy update and my new valve (F) has seen stage 1 and stage 2.1 and is still holding strong. i'm over 5k with stage 2 now and i drive it like i stole it all the time.
818tech
11-15-2007
Northridge CA
`89 8v Jetta,`89 16V GTI,`87 16V Scirocco,`04 1.8T GTI,`07 2.0FSI GTI
Re: PCV Valve 'E' vs. 'F' (ssaffioti) » | « » 4:06 PM 12-4-2007 | |
This is all confusing! I`m a tech at a dealer and I blew my "G" PCV valve on my 07 GTI, when I went to the parts dept, they gave me a "E" valve. I told them to double check to see if that was the correct part #.He said it was. I was in doubt so I called the VW factory tech line. He told me that the E valve was ok because the G valve was discontinued and it was superceeded back to the E. I said "why are the letters going backwords. He said the the E valves are from another company than the G valves so they went back to E.  Damn Germans make **** so confusing! He also said the F valve is not the correct valve. Just wanted to share the info.
mwwVW
3-30-2003
Rocky Point NY
Re: (ssaffioti) » | « » 4:07 PM 12-4-2007 | |
that one looks like a PITA to replace...is it?
ssaffioti
4-8-2006
Re: PCV Valve 'E' vs. 'F' (818tech) » | « » 4:18 PM 12-4-2007 | |
818tech -- They are correct. 'F' would not be the correct valve for you, because your car originally came with 'E' along with the updated pipe with checkvalve. If your car didn't have the 'updated pipe with checkvalve' already installed, then the correct part, as I understand it, would be 'F'.Is the metal pipe hard to change?? That probably depends on your mechanical skill and what tools you have.
Modified by ssaffioti at 1:20 PM 12-4-2007
shue333
2-18-2007
felton DE
Re: PCV Valve 'E' vs. 'F' (818tech) » | « » 4:39 PM 12-4-2007 | |
| Quote, originally posted by 818tech » | This is all confusing! I`m a tech at a dealer and I blew my "G" PCV valve on my 07 GTI, when I went to the parts dept, they gave me a "E" valve. I told them to double check to see if that was the correct part #.He said it was. I was in doubt so I called the VW factory tech line. He told me that the E valve was ok because the G valve was discontinued and it was superceeded back to the E. I said "why are the letters going backwords. He said the the E valves are from another company than the G valves so they went back to E.  Damn Germans make **** so confusing! He also said the F valve is not the correct valve. Just wanted to share the info. |
lol, i love it. i got so frustrated when my "E" valve went, because they were on backorder, that i ordered a "G" valve from fixx tuning and offered it to the service guy. i said "I paid for it, you put it in and cover it". he wouldn't do it and pulled the printout from vwoa, which stated that the "F" was the one he HAD to use to replace my "E". he even told me the "G" valve with the updated breather wouldn't work at all on my '06, which by now we all know is a crock. regardless, my "F" works great, and if the "E" breather hose has a check valve in it, and the "F" has 2 check valves, and i plan on doing the DH fix, then i'll have 4 mofo-ing check valves. and if that doesn't hold up, then i'm completely f-ed also, i think by now with all of the problems it's safe to say that no matter which PCV valve you have, or which brand new one they'll give you, it sucks balls and will break again. Modified by shue333 at 1:42 PM 12-4-2007
Modified by shue333 at 1:47 PM 12-4-2007
mwwVW
3-30-2003
Rocky Point NY
Re: PCV Valve 'E' vs. 'F' (shue333) » | « » 4:44 PM 12-4-2007 | |
| Quote, originally posted by shue333 » | and if that doesn't hold up, then i'm completely f-ed Modified by shue333 at 1:42 PM 12-4-2007
you could always just vent to atmosphere
matt225
11-23-2007
fl
» | « » 4:46 PM 12-4-2007 | |
I just went to the dealer to get a new PCV, and they are saying mine is fine. The tech tried to tell me that it was normal to blow oil out of the cap, and if my PCV went bad I wouldn't be able to drive the car, and without a CEL there is nothing wrong with it. I am pissed.So if i beat on the car for a while in 93 mode will it make it throw a cel?
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
» | « » 4:53 PM 12-4-2007 | |
where on the valve does it say what kind it is? can someone post a pic of the pipe running from the back of the valve cover down to the turbo Modified by NEW2B at 4:55 PM 12-4-2007
Modified by NEW2B at 4:57 PM 12-4-2007
2009 GTI - APR 93 STAGE I - intake 2006 PASSAT-AUTO - 14.3 @96MPH-260HP APR 93 STAGE II - APR TBE - INTAKE - NS PULLEY - NS GAUGE EJ PCV FIX - 18" ACE DIMENSION-TOYO PROXES4 DRIVEGEAR SPRINGS - 35% TINT.
shue333
2-18-2007
felton DE
Re: (matt225) » | « » 4:53 PM 12-4-2007 | |
| Quote, originally posted by matt225 » | | I just went to the dealer to get a new PCV, and they are saying mine is fine. The tech tried to tell me that it was normal to blow oil out of the cap, and if my PCV went bad I wouldn't be able to drive the car, and without a CEL there is nothing wrong with it. I am pissed. So if i beat on the car for a while in 93 mode will it make it throw a cel? |
probably not. get the eurojet fix, or do the DH fix. on mine, the actual pcv housing broke causing a vacuum leak and a high pitched squeal at all vacuum conditions (idle, or moving while off the gas) and popped a CEL. extremely irratic idle also. if you're blowing oil, one of the checkvalves inside your PCV valve is going bad, and won't throw a CEL. and obviously you know how the dealership is if there isn't a CEL
shue333
2-18-2007
felton DE
Re: (NEW2B) » | « » 5:09 PM 12-4-2007 | |
| Quote, originally posted by NEW2B » | where on the valve does it say what kind it is? can someone post a pic of the pipe running from the back of the valve cover down to the turbo Modified by NEW2B at 4:55 PM 12-4-2007 Modified by NEW2B at 4:57 PM 12-4-2007
the number is on the bottom of he valve under the round saucer. i'll put up pics if someone can tell me how. i'm puter stoopid
ssaffioti
4-8-2006
Re: PCV Valve 'E' vs. 'F' (818tech) » | « » 5:13 PM 12-4-2007 | |
818tech (or others) -- Should we replace the orange gasket when changing the PCV? Is the orange gasket sold with the 'E' PCV (by ECStuning as a kit, for example) also compatible with the 'F'?P/N for orange gasket being sold with Valve 'E': 06F 103 483E
shue333
2-18-2007
felton DE
Re: PCV Valve 'E' vs. 'F' (ssaffioti) » | « » 7:03 PM 12-4-2007 | |
| Quote, originally posted by ssaffioti » | | 818tech (or others) -- Should we replace the orange gasket when changing the PCV? Is the orange gasket sold with the 'E' PCV (by ECStuning as a kit, for example) also compatible with the 'F'? P/N for orange gasket being sold with Valve 'E': 06F 103 483E |
not sure about "E" or "F", but "G" gets the same gasket that you listed above.
shue333
2-18-2007
felton DE
Re: (NEW2B) » | « » 7:27 PM 12-4-2007 | |
okay, dude, bear with me, first time picture post!! the breather tube is connected by the short rubber tubing circled in pic
and the part number is circled on the PCV valve (bottom side)
Modified by shue333 at 4:29 PM 12-4-2007
Modified by shue333 at 4:31 PM 12-4-2007
shue333
2-18-2007
felton DE
Re: (shue333) » | « » 7:34 PM 12-4-2007 | |
another interesting point: i blew into valve and a little bit of air passed through both the pcv valve and breather tube valve!! so they're not air tight!
818tech
11-15-2007
Northridge CA
Re: PCV Valve 'E' vs. 'F' (ssaffioti) » | « » 8:50 PM 12-4-2007 | |
You usually dont have to change the gasket as long as there is nothing wrong with it but it cant hurt. It is slightly expensive from the stealership. The gasket is the same for all valves.
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
Re: (shue333) » | « » 5:11 AM 12-5-2007 | |
ok so i f......up. last night when you said the number is on the bottom of the valve under the round saucer, i thought i had to pull off the round cover. and as carefull as i was i still managed to damage it trying to take it off. i broke a little peace from the tab that locks it in place. i dont think its leaking but now im really pissed off. can i replace just the cover or will i need a new one? has anyone removed this cover?[IMG] [/IMG] Modified by NEW2B at 5:13 AM 12-5-2007
Modified by NEW2B at 10:48 AM 12-5-2007
818tech
11-15-2007
Northridge CA
Re: (NEW2B) » | « » 4:16 PM 12-5-2007 | |
The valve is not made to be dissasembled. As long as it isnt leaking I wouldnt worry about it, But you are gonna have to buy a complete one if you want it back to perfect.
shue333
2-18-2007
felton DE
Re: (NEW2B) » | « » 5:17 PM 12-5-2007 | |
| Quote, originally posted by NEW2B » | ok so i f......up. last night when you said the number is on the bottom of the valve under the round saucer, i thought i had to pull off the round cover. and as carefull as i was i still managed to damage it trying to take it off. i broke a little peace from the tab that locks it in place. i dont think its leaking but now im really pissed off. can i replace just the cover or will i need a new one? has anyone removed this cover?[IMG] [/IMG] Modified by NEW2B at 5:13 AM 12-5-2007
OH NOOOOOO!!!! dude that sucks. when i said bottom of the valve, i meant the whole valve assembly. sorry i didn't clarify. and i posted the pics a little late. listen - you will know if it's f-ed up. you're idle will whack out, etc. when it starts happening, it's cool to still drive the car. let it throw a CEL and just take it into the dealer and let them replace it
i bet you were cussing me NOTE: i was checking out your PCV valve and it looks identical to my "G" valve. i'll go out and see if my "F" (which is in the car now) looks any different. i know my "E" has some subtle difference. Modified by shue333 at 2:20 PM 12-5-2007
Modified by shue333 at 2:29 PM 12-5-2007
rbradleymedmd
2-23-2007
Columbia SC
B6 Passat Tip
Re: (shue333) » | « » 6:40 PM 12-5-2007 | |
Shue333,Is there anyway New2B could epoxy the piece that broke off back on and then add a little silicone around the cracks? Just curious. TIA
shue333
2-18-2007
felton DE
Re: (rbradleymedmd) » | « » 8:18 PM 12-5-2007 | |
| Quote, originally posted by rbradleymedmd » | | Shue333, Is there anyway New2B could epoxy the piece that broke off back on and then add a little silicone around the cracks? Just curious. TIA |
probably so. the only problem with that is he can forget about it being covered under warranty once they see it's been messed with. with that little piece broken off, he can just give the service advisor the dumb look. "something's broken?!?!?!? "
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
Re: (shue333) » | « » 4:36 AM 12-6-2007 | |
hey, no problem it was my fault for rushing, i should have been more patient. luckily it does not leak, in the future im going to change it anyway. is there any way i can find out what pcv i have without taking it off, and if i have the other valve in the back?this part just confuses me : NOTE: i was checking out your PCV valve and it looks identical to my "G" valve. i'll go out and see if my "F" (which is in the car now) looks any different. i know my "E" has some subtle difference. Modified by NEW2B at 4:38 AM 12-6-2007 Modified by NEW2B at 4:39 AM 12-6-2007
Modified by NEW2B at 5:15 AM 12-6-2007
rbradleymedmd
2-23-2007
Columbia SC
B6 Passat Tip
Re: (NEW2B) » | « » 11:50 AM 12-6-2007 | |
| Quote, originally posted by NEW2B » | hey, no problem it was my fault for rushing, i should have been more patient. luckily it does not leak, in the future im going to change it anyway. is there any way i can find out what pcv i have without taking it off, and if i have the other valve in the back?
Maybe try a small cosmetic mirror to see under the housing? I can't remember if there is enough room (I believe their is) and read the part number off like that. New2B, all the housings look identical, but not all are made for every car. I would definitely recommend getting the correct part number before order one that may/may not be compatible with your car. The service manager can look up what the latest revised PCV for your car if he/she has the VIN. PS...Glad to see you're not losing boost/vacuum. Sorry, I haven't been able to help you more. I just went with what my dealer told me was the latest revision for my car and added the EJ Fix...no problems since.
shue333
2-18-2007
felton DE
Re: (NEW2B) » | « » 1:57 PM 12-6-2007 | |
| Quote, originally posted by NEW2B » | hey, no problem it was my fault for rushing, i should have been more patient. luckily it does not leak, in the future im going to change it anyway. is there any way i can find out what pcv i have without taking it off, and if i have the other valve in the back?this part just confuses me : NOTE: i was checking out your PCV valve and it looks identical to my "G" valve. i'll go out and see if my "F" (which is in the car now) looks any different. i know my "E" has some subtle difference. Modified by NEW2B at 4:38 AM 12-6-2007 Modified by NEW2B at 4:39 AM 12-6-2007
yes, i can be confusing!! i used to have an "E" valve until it broke the dealership replaced it with an "F" valve. while waiting for the dealer to get the "F" valve, i purchased the "G" valve from fixx tuning. so i've had them all. so i remember what the "E" looked like, i can't remeber what the "F" looks like and i have the "G" sitting right in front of me. the "E" and "G" looked different, and yours looks like the one in front of me ("G"). The "F" is in my car with 3" of snow on it, so i'll check tomorrow what it looks like. lol, how's that for confusing? (Or try a small cosmetic mirror ) Modified by shue333 at 11:03 AM 12-6-2007
Modified by shue333 at 11:04 AM 12-6-2007
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
Re: (shue333) » | « » 2:39 PM 12-6-2007 | |
thanks. does any know where i can get a new pcv, i checked with fixx tuning and they dont seem to have any.
Modified by NEW2B at 2:59 PM 12-6-2007
rbradleymedmd
2-23-2007
Columbia SC
B6 Passat Tip
Re: (NEW2B) » | « » 3:40 PM 12-6-2007 | |
1stvwparts.com always has good prices. also, check with Bud@CheckeredFlag here on the forums.
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
» | « » 5:59 PM 12-6-2007 | |
i called Bud@CheckeredFlag and he lookded up the pcv i need by vin#. believe it or not he said the 2006 sedan gets the F and the wagon gets the E. hows that for confusing? why is the wagon different? now just so i can understand this onece and for all. ecs tunning only sells the E and they claim it MUST BE used in conjunction with updated breather pipe (ES#7511). does that pipe have a valve in it? why does the F pcv not need this breather pipe? can someone clarify a little more so i can understand this.Modified by NEW2B at 6:01 PM 12-6-2007 Modified by NEW2B at 6:05 PM 12-6-2007
Modified by NEW2B at 6:06 PM 12-6-2007
