FuN:TuRBO
9-14-2007
Bay Area, Ca now Albuquerque
MK5 GTI
 ECU Removal for 2.0T FSI how and where? for upgrade« »
as the title states.. i would like to send my ECU to APR as i live to damn far from any dealers and dont have the time. i looked around for a DIY but nothing.. im sure its out there.. can someone point me in the right direction for removing my ECU to send to APR.
thanks!
Quote, originally posted by WetWagen »
Every time someone opens their mouth something completely crazy comes out. Repeating what they heard from somewhere else (which is probably also incorrect). Occasionally some solid facts come out, but it mostly sounds like some crazy and unbelievable tale that was made up in the shower that morning.
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: ECU Removal for 2.0T FSI how and where? for upgrade (FuN:TuRBO) »« »
Quote, originally posted by FuN:TuRBO »
thanks!
0. If your wipers are like the ones on the A3, they move up or down slightly when they park after every time you use them to keep the rubber exercised. Turn them on/off until they park in the lower position.
1. Remove the wipers. Carefully pop the circular covers off of each, and use a 13mm socket to remove the nuts. Use a fine-tip sharpie or a little paint on a toothpick to mark the position of the wiper arm and the threads, so you can put them back in the same position with less effort. Leave each nut on 1 or 2 turns of thread, and wiggle the base of the wiper arm until they pop loose from the splined shafts. This is the biggest PITA of the whole process.
2. With the wipers removed, peel the rubber gasket from the ridge at the base of the black plastic tray. See the corner of the tray where it goes past the hood hinge? You have to push 'in' on that so the tray 'bows' a little to get it past the hinge. On the A3 it's easier to do the left (driver's) side, then you can pivot the tray to get it out....
3. ...BUT - you can't just pull it out. You have to pop the washer jet assembiles first. They just pop out of the tray (up and out, press underneath) without disconnecting the hoses or heater plugs:
...then just lift it out and set it aside:
4. The ECU is behind this 'chastity belt'. The two bolts that hold it on are one-time use, and the heads are ripped off as they are installed. To get to the ECU you will need to use a Dremel to cut slots in the top of both of the bolts and use a large flat screwdriver to loosen them. To put things back to the appearance of being normal, you'll need two new bolts of that type.
Disclaimer: I disclaim all knowledge of anything related to this. It never happened.
Modified by OOOO-A3 at 9:28 PM 3-9-2008
A3 info
Get FireVortex
FuN:TuRBO
9-14-2007
MK5 GTI
Thanks man!
shortydub
10-12-2004
Traverse City MI
2006 gli
 Re: (FuN:TuRBO) »« »
i would guess that this would completely void your engine warranty, correct?
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: (shortydub) »« »
Quote, originally posted by shortydub »
No. Removing your wipers and a plastic panel to take pictures doesn't void any warranty!
If they see that the bolts are missing/modified, they'd ask 'WTF?', but if everything is put back to normal, then nobody would know. Having your ECU flashed 'on the bench' is no different from having it flashed through the diagnostic port; the software will not "completely void your engine warranty" unless they prove cause-and-effect.
If it's a concern, wait until the warranty's up before getting any performance software or parts.
A3 info
Get FireVortex
crew219
10-18-2000
ITH NY
 Re: (OOOO-A3) »« »
Quote, originally posted by OOOO-A3 »
Isn't there also some security glue on the ECU?
Dave
Forge DV Review
APR SII beta logs
REVO 93 logs
APR 93 logs
FuN:TuRBO
9-14-2007
MK5 GTI
 Re: (crew219) »« »
Quote, originally posted by crew219 »
Dave
Security Glue? hah more obstacles
shortydub
10-12-2004
Traverse City MI
2006 gli
yea after the mk4 chip replacement surgery that went on.( i had upsolute) i think they were trying to make a point this time
OOOO-A3
7-19-2004
Newark DE
2006 Audi A3 2.0T
 Re: (crew219) »« »
Dave
ON the ECU, no. Once the two one-time-use bolts are removed, the 'chastity belt' cover comes right off. The ECU slides/snaps into a bracket that has two springy clips. Get the plug off, slide the unit out, that's all.
IN the ECU (e.g. if you were to open the case for some reason)... mmmm, you'd have to talk to someone who does that sort of thing
A3 info
Get FireVortex
MFZERO
3-13-2002
Haverhill MA 495 West
2000 Haro Blammo, 1987 4000csq
 Re: (OOOO-A3) »« »
I hate doing that
Autobahn Performance REVO Dealer | CHEAP OEM PARTS! | nek.cbs.hbc.csd
» Return to 2.0T FSI Engine Forum
