PowerDubs
7-22-2001
NNJ
2004 R32 13.14@105.77 AllMotor
 8 months later....« »
Yes my head is finally done!!
It will be shipped back to me hopefully next week. It is across the country so it may take a while..(I am in NJ, it is in WA).
If anyone wants to have one now that the research is done contact-
Steve Hannaford
Progressive Automotive
Tacoma WA 98466
(253) 565-3633
Modified by PowerDubs at 3:04 PM 6-8-2008
Nebby
6-1-2003
SoCal R32
2008 VW R32 / 1991 VW GTI VR6 / 2008 Audi Q7
 Re: 8 months later.... (PowerDubs) »« »
I know nothing about "port and polish" and what it does and what the benefits are... all I know is... that is damn pretty!!!
SoCal .:R32
2008 VW R32 - Well modded and cared for R32 for sale!
1991 VW GTI VR6 - Maintenance and modifications log
newcreation
11-23-2003
HBG PA
2004 All Motor R-C2 TUNED
 Re: 8 months later.... (nebuchadnezzar) »« »
Nice Josh, can't wait for some results
-James
3.2 N/A people COSWORTH will make us a manifold with enough interest check it here
http://forums.vwvortex.com/zer...53413
300BHP CAMMED R
Harepower
1-23-2007
Eagleville TN
2004 TR R32, 2007 Silverado, 1996 quest
That is B E A U T I F U L!
What gains do you expect?
And of course how much for this madness?
R32 ToD 2010 Website
PowerDubs
7-22-2001
NNJ
 Re: 8 months later.... (Harepower) »« »
Quote, originally posted by Harepower »
Rough guesstimate?
http://forums.vwvortex.com/zerothread?id=3545905
No idea what Steve will charge to do more.. call him up tomorrow and ask (before everyone else does and he backs up w/ work )
I know it takes a long time to do one of these heads..but now that he has done this one any that follow should go much easier/quicker. He had to make the jigs and fittings to fit our heads from scratch.
fourthchirpin
11-19-2004
EST.8/1/02
mk3gti
are those the only valves that ferrea makes?(thats if the valves are ferrea valves.) because iam currently interested in flat valves.
also any flow bench numbers?
is this a 3angle? 5angle? bigger valves?....
thanks for pm'ing me.
Modified by fourthchirpin at 12:53 AM 5-10-2008
"RACING IMPROVES THE BREED"
West Indian Crew
"a Fool can make the most simple things complex, It takes a genius to make the most complex things simple."
PowerDubs
7-22-2001
NNJ
 Re: 8 months later.... (fourthchirpin) »« »
Those are the stock valves
.:R
PROJECTS- Intake manifold Higher ratio rocker arms Larger cams Ported head Bigger cats Rear TBD
INFO- Injector Specs
bighauler1
10-19-2005
kinnelon nj
'08 Bunny, '07 denali xl, '05 Peterbilt 335 , '99 IH4700, 69 Camaro
Isn't that lovely!!!
http://forums.vwvortex.com/zerothread?id=2069838 My baby
Looking to build another coupe... stay tuned.....
Issam Abed
All Over
'91 Audi 80 2.0T
 Re: 8 months later.... (bighauler1) »« »
What happened to the other idea Josh?
Any flow #'s?
Issam N. Abed
R&D, INA Engineering performance solutions.
INA Engineering.Com
beachball6
4-21-2003
Nolanville, TX\Philly when i can
2004 TR R32, 1965 beetle (in the back yard), 2001 triumph tt600
Gitty like school girl. have fun doing the install, I imagine that is a world of suck.
TR R32-SM- "be very, very quiet I'm hunting EVOs"
^ Fast in slow out right?
Turn signals are there for a reason use them, they ARE your friend
GTItraveler
4-24-2002
San Francisco CA
2004 R32, 2008 Mazda PRHT, 2002 337 GTI (sold), 1988 16v GTI (sold),1986 8v GTI R.I.P
 Re: (beachball6) »« »
Looking forward to your impressions. A question: does P&P a head require the use of larger more aggressive cams and a different flash or can it work effectively with any cam option (i.e. TT cams)? TIA
UNIbrace - The ultimate rear stress brace
foffa2002@home
7-2-2006
Compton
Nice
Make 5 maf gram logs 1000-7000rpm with the old head
then mount this sucker and make ~5more maf gram logs so that we will get a quick hint of were it flow better and make the good ol 1.25xmaf gram = hp
Modified by foffa2002@home at 5:19 AM 5-10-2008
540Whp Jetta MK4 VR5 11.3@137Mph OEM Ecu
Stage 5
http://forums.vwvortex.com/zerothread?id=2862822
Stage 6
http://forums.vwvortex.com/zerothread?id=3967696
Hurtin' Egos
Patryk R32
4-15-2007
Kearny NJ
2004 DBP R32, 1984 Mercedez-Benz 190D Manual Transmission, 2006 Yamaha R6S
Finally Josh! Looks good.... hope it works out. Did you guys figure out what the MAX lift is on our head?
My new user name is "Patryk@DouglasVW"
If you need to PM me, send me a message to that name, as i do not log onto this user name anymore. Thank you.
13.35@101.66 N.A.
zaxonortesus
3-10-2005
Annapolis MD
2004 BMP R32, 1998 4dr M3, '08 UG GTI
 Re: (Patryk R32) »« »
Wow, that is a thing of beauty! I would def be interested in % increase in flow. Any reasoning behind using stock valves? Were the edges cut at all? Just polished down? This should be a very interesting build, and I can't wait to see some numbers.
-Nick-
Rank: General
Alliance: Legion of Evil
| Induktion Motorsports l TrackDaze | -- Mk4 & 5 Vag-Com cable available in the Annapolis area.
PowerDubs
7-22-2001
NNJ
 Re: (zaxonortesus) »« »
Quote, originally posted by Wizard-of-OD »
Any flow #'s?
Flow #s will be coming in the box w/ the head. I'll try to see if I can get a picture of them sooner. I was told it was comparable to the UK heads #'s.
Quote, originally posted by beachball6 »
Have fun doing the install, I imagine that is a world of suck.
Yea..tearing the engine apart again.. I am torn between installing it ASAP or waiting for CAT to make the larger cams.. but I think I will go ahead and install it since I have it and the cams may take forever to see the light of day or be vaporware.
The best thing about this is I am in the middle of buying a house w/ a 2 car garage and basement workshop so I will be able to work on it a bit at a time at my leisure. No more forced time-frames!!
Quote, originally posted by GTItraveler »
Porting a head will work on anything, even a completely stock car. You are simply making the engine more efficient and breathe easier.
Quote, originally posted by Patryk R32 »
The head will flow more at lifts significantly higher than any cams available presently.
Quote, originally posted by zaxonortesus »
Stock valves were retained for numerous reasons. There was a concern about valve shrouding, to avoid contact issues when going to larger cams with more overlap, cost, and not least of all Steve's opinion is that there is little to nothing to be gained by putting larger valves in this head.
I've had other heads that were done by Steve before and he is highly regarded by many.. all he does all day every day is port heads. I didn't ask many questions, I just asked if he would be interested in doing it and sent it off to him to work his magic.
The time and detail are staggering.. he claims to have over 100 hours in this head. I've tried porting my own cylinder head before (bought all the carbides, a die grinder, variac, etc) and it is NOT easy and very time consuming.
Look at the taper and split he put on the area around and including the valve guides-
.:R
Not4show
6-10-2004
Bay Area CA
96 VW GTI 2.0T Syncro
Looks good,
Why didn't you do swirled tapered valves, besides the outrageous price of them?
Did you get before and after flow #'s?
Looks great man, and I've got the package material, for the side project ready to go for the end of the month, that head gonna be on and waiting?
Were the Intake/Exhaust ports enlarged?
you gonna have the exhast port matched as well?
96 2slow 20vt syncro ,
My Syncro/ABA/AEB Turbo
SOLD AND DELIVERED! 04 R32 slightly less modded than before
Making sure the Ex Doesn't get the R so she can wreck it for a 3rd time
VTEC976
6-25-2004
From Orlando to Denver CO
2004 Deep Blue R32, (NA Build), B5 A4 1.8t Quattro Manual (Stock)
 Re: (Not4show) »« »
Metal work is super difficult, especially in those confined spaces. That looks super nice! I'd love to see dyno numbers, and hear about butt-dyno feel with it installed.
Gabriel
GnG Motorsports
TT CamslCustom Exhaust w/ GnG Motorsports CatslCAIlGIAC CamlFilelAVICF90BTlBBC CH'slGnG Motorsports W8lGnG Motorsports Brake BeautificationlHIDslother stuff
Quote, originally posted by nascent »
A sweet R and a wife who wears kneepads. You are living the life, aren't ya?
beachball6
4-21-2003
Yea, just throw it on it would be a waste to dyno with different cams being that your current setup has produced a lot of solid repeatable numbers.
GTItraveler
4-24-2002
San Francisco CA
Powerdubs: Is 8 months a standard turnaround time for this kind of work? TIA
PowerDubs
7-22-2001
NNJ
 Re: (GTItraveler) »« »
No.. but a 'new' head has research & testing to be done.. I'm sure the rest will go quicker.. call Steve and ask, he is open today.
.:R
XXX008XXX
3-25-2002
New Jersey
 Re: (PowerDubs) »« »
stick with the schrick cams. the head looks good josh. now its time to firgure something out reguarding the intake manifold. i know you have the bong, but i am sure its not going to be enough. if you look at my fuel map, the engine is very restrictive after about 4500 5000 rpm. i will see if i can get you a copy so you know what i am talking about. if you need a hand, give me a call. i am also curious to see this tuning software work. i have an innovative wideband you can borrow that datalogs if you would like to use it.
R32 parts FS:. Check my created topics!!!!
Boost Factory
Lugtronic
Force Fed Engineering
mk2vrooom
10-15-2003
Nashville TN
08 GTI 2.0T
 Re: (XXX008XXX) »« »
why not just stay in NJ with Raceshop? anywho looks good
http://www.dubbedbyrma.com
Pennsylvania College Of Technology
...blowme
someone should take over my mk5 lease so i can get an mk3 again...
DBR007
9-23-2004
Buffalo NY
Deep Blue R32, PG GLI
Very very nice.
j-dub
10-22-2000
AZ
Looks really nice, can't wait to see the results.
1957 T1
R32
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on."
climbingcue
2-2-2001
Morristown NJ
2004 Silver R32 13.25@104.76
Congrats, can't wait to see what kind of power it makes...
Bill
2010 Felt F3
Cam Install's for MKIV R32
Suspension installs for MKIV or MKV IM me
PowerDubs
7-22-2001
NNJ
 Re: 8 months later.... (climbingcue) »« »
I asked Steve some questions in an email that some of you have been PMing me.
Quote, originally posted by Steve Hannaford »
Hi Josh,
I will need to organize the flowtests sheets, and put them into a format so they don't look like gibberish, but will do so soon. As for the other questions:
#1: The standard base price for a 24v Stage 3 is $715.00 Other charges would probably include cleaning, surfacing, miscellaneous parts, so the "out the door" price would be about $800.00. If anyone is interested in having one of these heads done in the immediate future, they should be aware the last couple of months have very chaotic here, and I need to finish up a couple of other large projects before I can promise reasonable turn-around time. I hope to have things back to "normal" in about 1-1/2 to 2 months.
#2: The choice not to touch the combustion chambers was deliberate. Modern chambers, especially 4 valve pentroof ones, are often manufactured to very high standards, as is the case with your head. In chambers that are not well executed, there are often performance gains to be had by un-shrouding the chamber wall area near the valves and blending the transition from the seat to the chamber. The adverse effect of this is increased chamber volume, which in turn drops compression ratio. Now on older engines, it is easy to regain this loss of C.R. by milling the head, but on modern engines with more complicated cam drive systems and closer tolerances, much greater care needs to be taken when removing material from the head. I personally feel that if there is no measurable gain to be had from such modifications, there is no reason to do it. However, not everyone in this business shares this philosophy. Highly polished chambers are often done just for marketing reasons or out of ignorance.
#3: I can only make a "educated" guess here because there are just so many variables. Based on flow numbers, I would say around 15 to 20hp. This could be more if done in conjunction with other modifications such as cams, exhaust, and intake etc... Having not seen any other components of this engine makes it very difficult for me to predict any possible restrictions in the system that would ultimately limit output. Usually, increased head flow enhances most other performance improvements.
I hope this helps,
Steve
.:R
BLU R32
3-29-2006
Belmar NJ
'04 Golf IV R32
Quote, originally posted by PowerDubs »
...Steve's opinion is that there is little to nothing to be gained by putting larger valves in this head.
I'm sure you as well as others here are familiar with the advantage of multi-valving Powa' but for those who aren't as acquainted you can get much less turbulent flow and less restrictive travel of intake and exhaust gases around two valves that cover the same area as one. It is an exponential curve as well. In other words replacing a valve the size of a quarter with two valves the size of dimes, with lift and duration being equal, the two dimes have a much better flow rate even though their area is less than that single quarter-sized valve.
Besides the mid-engine configuration, and the composition of light-weight materials, multi-valving was one of the most advanced as well as expensive traits of supercars that took years to trickle down to lesser road cars.
Good luck with it! It's beautiful. I remember getting my set of heads ported and polished when I put a Pontiac 4.3L racing block in my Regal T-Type many years ago--- what a rush! Peace of mind knowing that everything you've done to enhance the intake and exhaust ends of the beast you have isn't getting "pinched in the middle by a restrictive cylinder head with so much potential beyond stock.
Now put that baby in your ride and give us a sweet review!
Joe McEvoy
_______________________________________________________________________
"...we're drivers here on The .:R Forum- not passengers behind a steering wheel..."
speedbump2
10-28-2004
Cortlandt Manor NY
'04 BMP R32, '08 AWD Pacifica Wagon
Anxious to see how well this will do on your car
--Chuck--
Mutley Slideshow
EIP GTG Slideshow
carma
9-30-1999
San Francisco CA
2004 R32
Wow, great info, thanks for sharing. This would obviously compliment an NA or FI R. If I keep my car NA after all the HPA stuff done this would probably be the ticket. Too bad on the lead time, but looks like quality work, so that evidently takes time.
.:R32
HPA CVP level 2 + VF SC
FlyingFinn@Streetwerke
12-27-2007
Bay Area Ca
2004 R32 T- Red / 65 bug / 66 bug (my daily driver)
Looks awesome dubs I can't wait to hear your final impression when it's all together and running.
I also like how he didn't make any changes with the combustion chambers, very nice for n/a applications. Unlike the head I had done for the VF Stage 4+ car we increased the cc's to give us a lil more room in case we wanted to add a lil more boost
I soooo look forward to getting my head back from P&P
foffa2002@home
7-2-2006
Compton
Btw
A 288-304* duration cam will make you be able to keep the OEM intake runner lenght.
More duration = longer runners can be used for higher rpm pulse tune.
so
8000rpm on a 264* is 360mm from rear bank valve to plenum
But 8000rpm on a 304 is ~420mm from rear bank valve to plenum
So keeping the cam that man with "khram like can of pepsi" regrind scenarion might make you be able to use the best intake out there = OEM
Stage 5
Stage 6
Hurtin' Egos
Super 180s
11-14-2007
Sydney NSW
Excellent... so if he were charging as he should (about $100 per hour), this would be a $10,000 head!!
Vote for a separate 'big 3' forum.
http://forums.vwvortex.com/zerothread?id=4129928
VDubFan32
9-7-2004
Baghdad Iraq
04 Golf R32, 99.5 Jetta TDi, 99.5 Beetle (sold)
 Re: (Super 180s) »« »
This looks both promising and enticing. Right now would be the perfect time for me to send out the head and have this done since I won't be back stateside until Sept, but I don't think the wife is up to removing anything in my car aside from the key.
.:Rick
"Think of me as Yoda. Only instead of being little and green, I wear a suit and am awesome. I'm your bro. I'm Broda!" - B.Stinson
ÜroTuning
ÜroClassifieds
redGTInj
7-6-2003
North Arlington NJ
88 GTI 16v 84 Scirocco 16v project 92 Jetta GL(sold) 84 rabbit GTI(beast II)
 Re: (VDubFan32) »« »
awesome stuff Josh....always pushing the envelope like the old days except now with 8 MORE valves
Not some trend that people care about, dress the part. then tear its heart out........
Lets ask ourselves whos to blame...the ones who destroy? or the ones that let it........
Posts < Knowledge
YoungRepublic
6-29-2005
Oceanside CA
MK4 RSS R32, 2001 S4
Too bad you're not the first! The CC could use a light polish, casting leaves some sharp edges = detonation
Current:
'04 R32 - TR -- VF RSS Turbo, KW V3s, etc
'01 S4 - Bone stock
Past rides: '93 Corrado SLC x 2 ; '03 GTI VR6 24V
First  1 2 3 4 5 6 7 8 >  Last
» Return to Golf IV R32
