angryrican66
4-16-2006
Harrison NY
2007 A3 3.2Q Open Sky,Bose,Technology,Cold Weather, Nav,Roof Rails Ibis White
need a DIY for front suspension for A3 | « » 10:41 AM 6-8-2008 | |
as the title says, there was one from Swank Monkey or something like that floating around , Help A Rican out
/Euro S-Line Spings&Shocks/Haldex GenII/http://i98.photobucket.com/alb...8.jpg http://i98.photobucket.com/alb...s.jpg http://i98.photobucket.com/alb...9.jpg
jerseyrat325
9-30-2007
Tysons Corner VA
2008 A3 2.0T
» | « » 11:30 AM 6-8-2008 | |
http://www.swankmonkey.com/vw/...nsion/You had your finger right on it.
2008 A3 2.0T 2002 Civic 237 WHP/187 lb-ft @12 psi
angryrican66
4-16-2006
Harrison NY
Re: (jerseyrat325) » | « » 11:56 AM 6-8-2008 | |
thanks!!
Modified by angryrican66 at 7:57 PM 6-8-2008
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
» | « » 7:46 PM 6-8-2008 | |
here's another:http://forums.audiworld.com/a3/msgs/83063.phtml
for sale: HID kit - H7 3000k, s-line shocks
angryrican66
4-16-2006
Harrison NY
Re: (krazyboi) » | « » 7:57 PM 6-8-2008 | |
Thanks, we need to sticky the Swank Monkey one, I was quoted $400 plus another $125 for alignment, I spent $150 in tools and did it in 3 1/2 hours, plus the satisfaction of doing it myself
WISVW
8-24-2003
De Pere WI
2010 Jetta TDI, 2008 Passat Lux
Re: (angryrican66) » | « » 10:50 PM 6-8-2008 | |
| Quote, originally posted by angryrican66 » | Thanks, we need to sticky the Swank Monkey one, I was quoted $400 plus another $125 for alignment, I spent $150 in tools and did it in 3 1/2 hours, plus the satisfaction of doing it myself |
Kind of wish I would have done that 3 suspension changes ago At least I did my own rears this last time.
A3_yuppie
6-5-2006
Orange County CA
2006 Audi A3 2.0T (DSG) & 2009 Audi A4 2.0T Quattro Sedan (Tip)
Re: (WISVW) » | « » 1:10 AM 6-9-2008 | |
My mechanic friend charged me $200 to install my S-Line springs; I had to help with the fronts though, they were a PITA. My alignment set me back another $80 two weeks later.
Noob #1: "I want to get a chip. Which is the best?"Oldtimer: "... use the !@#$%&* search ..." Noob #2: "OMG you need to replace your DV and PCV stat!"
angryquattrorican66
3-10-2007
Kaohsiung Taiwan
2006 A3 2.0 Black
» | « » 12:22 PM 6-9-2008 | |
hey cuz did you take out the drive shaft?
S3 front, anything I can get for cheap Hola! I'm angryrican's cheap Cousin
OCaudi
11-16-2006
Orange County ca
2007 AUDI A3
Re: » | « » 12:27 PM 6-9-2008 | |
What are the tools needed to change the front? Where is the best place to buy them?
Silver 2007 A3 2.0T MT S-line Package - Tech package - Bluetooth package - Cold weather package - Navigation plus package - Bose System with 6 CD Changer - Open SKY
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
Re: Re: (OCaudi) » | « » 12:28 PM 6-9-2008 | |
| Quote, originally posted by OCaudi » | | What are the tools needed to change the front? Where is the best place to buy them? |
Not positive, but I think these are needed...and best place to buy. http://autodax.com/catalog/pdetail.php?prdid=44 you'll also need them if you ever plan on changing your rear rotors
angryquattrorican66
3-10-2007
Kaohsiung Taiwan
2006 A3 2.0 Black
» | « » 12:29 PM 6-9-2008 | |
you can use a T65 torx bit also
terje_77
12-18-2005
NORCAL CA
2009 Audi TT 2.0T S-Line
Re: (angryrican66) » | « » 7:38 PM 6-9-2008 | |
Strong work dude.
APR | H&R | Milltek
OCaudi
11-16-2006
Orange County ca
2007 AUDI A3
Re: Re: (krazyboi) » | « » 8:09 PM 6-9-2008 | |
Thats it? just torx bits and a jack? There has to be some special suspesion tools to make it less of a PITA.
angryrican66
4-16-2006
Harrison NY
Re: Re: (OCaudi) » | « » 8:23 PM 6-9-2008 | |
| Quote, originally posted by OCaudi » | Thats it? just torx bits and a jack? There has to be some special suspesion tools to make it less of a PITA. | no, you need a 27mm 6point for the axle bolt, a 14mm triple square bit for the pinch bolt , and the lower hub spreader tool to expand the hub so it will release the lower part of the front strut, check out swank monkey link above, with all these it is an easy swap, without you may lose a finger or 2
angryquattrorican66
3-10-2007
Kaohsiung Taiwan
2006 A3 2.0 Black
» | « » 8:25 PM 6-9-2008 | |
trust me you dont need to buy tripple square .. T65 torx will do fine.also a 3/8 inch extension will work fine as a spreader tool
angryrican66
4-16-2006
Harrison NY
Re: (angryquattrorican66) » | « » 8:30 PM 6-9-2008 | |
| Quote, originally posted by angryquattrorican66 » | | trust me you dont need to buy tripple square .. T65 torx will do fine. also a 3/8 inch extension will work fine as a spreader tool |
yowzaa
7-30-2007
los angeles ca
2007 A3 DSG Premium Open Sky ...Brilliant Black Smoked n Squinted
Re: Re: (angryrican66) » | « » 8:37 PM 6-9-2008 | |
What about spring compressors? Needed or no?
APR Stg 1 | Bilstein PSS9s | Dice iPod | Tint | Dogbone insert | Eurojet VTA | A3 Monster Mats |
angryrican66
4-16-2006
Harrison NY
Re: Re: (yowzaa) » | « » 8:48 PM 6-9-2008 | |
| Quote, originally posted by yowzaa » | | What about spring compressors? Needed or no? | to remove the stocks yes, to install the euro S-lines NO
kuroaudi
6-4-2008
Re: Re: (angryrican66) » | « » 3:07 AM 6-15-2008 | |
Hello everyone! This is my first post. I've had my 2007 A3 2.0T sline for a year now. I just started putting mods on it. I've ordered a set of euro springs and planned to pair them with the stock s-line shocks. Martyn at vagparts had told me this was possible. But when I took it to my mechanic he told me that the springs are too short. There was play between the spring and the spring holders/dome, and he told me that it would definitely make noise when I turn or go over bumps. He ended up putting my stock springs back on. Now, can someone tell me if this can be done and how to do it? I'm in SoCal. Does anyone have this done in a local shop? I'd like to bring my car there. Thanks in advance!!
terje_77
12-18-2005
NORCAL CA
Re: Re: (kuroaudi) » | « » 3:18 AM 6-15-2008 | |
| Quote, originally posted by kuroaudi » | | Hello everyone! This is my first post. I've had my 2007 A3 2.0T sline for a year now. I just started putting mods on it. I've ordered a set of euro springs and planned to pair them with the stock s-line shocks. Martyn at vagparts had told me this was possible. But when I took it to my mechanic he told me that the springs are too short. There was play between the spring and the spring holders/dome, and he told me that it would definitely make noise when I turn or go over bumps. He ended up putting my stock springs back on. Now, can someone tell me if this can be done and how to do it? I'm in SoCal. Does anyone have this done in a local shop? I'd like to bring my car there. Thanks in advance!! |
Sounds weird. The euro springs should definitely work if you got the right part #. Search this forum and you'll find a group buy that a bunch of us did for these springs. Many of the sets were installed with stock shocks.
APR | H&R | Milltek
kuroaudi
6-4-2008
Re: Re: (terje_77) » | « » 3:46 AM 6-15-2008 | |
Thanks for the reply. I'm pretty sure I got the right springs. Martyn said he sold the same set to the group buy. My mechanic didn't use the new nuts and bolts and didn't cut the bumpstop. Was that the reason it didn't fit?
1sika3#2
11-5-2007
Tempe AZ
2006 Audi A3 2.0T
Re: Re: (kuroaudi) » | « » 2:42 PM 6-15-2008 | |
hmm I paid $200 for coilover install and balancing up atDTM Autowerks in Milford, NH the desk man is pretty reputable across the Vortex, owns the "Ron Burgundy" MK4 GTI, great guys, if anyone ever needs a coilover install in the New England area.
Metrodubbin'- verb (Me-tro-dub-bin)- state of VW/Audi crazyness over Denver's most exclusive club Metrodubs.com 2006 Audi A3 2.0T - APR Stage 2+ - AWE 2.5" Catback Exhaust - ATP 3" Downpipe - AEM Cold Air Intake - H&R Coilovers - Nitto Invo 225/45/17 Tires - O.Z 17" Canova Black Diamond Wheels-
