Chemhalo
5-24-2004
Bartlesville OK
'04 Jetta GLI 1.8T, '04 Audi A4 1.8T
1.8T 02m Clutch DIY | « » 2:47 PM 7-12-2008 | |
I felt this should go in the 3/2/G forum because most everyone has an 02m here. Just trying to give back.Original DIY instructions by SAVwKO with my photos added. My comments are in italics. Anything overly important has been bolded. I really had no idea what I was doing most of the time and it took me far longer than someone who is more experienced. This DIY is geared towards those who are a little reluctant about doing a clutch install themselves. But remember, you wrench at your own risk. You could cause some serious damage by screwing this up. Tools List: T25 and T30 Torx 13mm deep socket 16mm deep socket 18mm deep socket 10mm triple square 12mm triple square 1/2” deep socket (to carry the triple square bolts) Stock lug wrench (dual use as a small torque bar) Larger torque bar 9mm socket High temp grease 2 floor jacks 2-4 jack stands Range of socket extenders (I used a 4, 8, and 12”) Flat head screwdriver 17mm allen wrench You're gonna need another set of hands for sure. Lemme try and play this out in my mind, as I've done quite a few clutch installs but on the O2J IN the car. The O2M is like 30lbs heavier than the 5spd and thus, I chose to replace the clutch when I tore the engine out. First thing before the first thing is to remove the front bumper for more working room. First thing to do would be the axles. Take off your driver side wheel. Have someone step on the brakes, and you'll need one of those triple square bits (I purchased a three pack from O’Reilly). 6 bolts per axle on the tranny. Once those are out zip tie em up out of the way. I also had to remove some plastic liners under the oil pan and around the driver’s side. I also recommend using several plastic zip bags to keep like parts together and to make sure you don’t lose anything.
Before continuing on, remove the Airbox. Next, start removing visual parts up top. Disconnect the shifter cables from the weight, and then take out the 3 13mm bolts holding the shifter cable bracket to the tranny case. The third bolt you will need a deep socket for. Also, remove the transmission ground wire.
Unbolt the hard power steering line from it's brackets which are also on the tranny. Pull the clip out of the clutch slave line and remove it form it's hole. If you have something to plug the line with, have it ready. Otherwise, have a small bucket below as fluid leaks out. Zip tie up and out of the way.
Unclip the final drive sensor in the back of the tranny (I didnt get a pic of it, but its not hard to find), the starter harness, the reverse gear sensor close by. Get a jack next with some wood blocks and support the oil pan. Start unbolting all the bolts all the way around the tranny. Take the 2 starter bolts completely out (you'll have to move that wiring harness bundle out of the way). Starter can be removed.
Then you have 2 bolts up top (the transmission ground and the hard to reach shift cable bracket bolt), 2 on the bottom, one in the front, and one in the back. Should be a total of 8 bolts (including starter) that hold the tranny to the block. Get em all cracked so they can be turned easily. There are at least 4 different shapes/sizes of bolts so it may be worth your while to label which bolt came out of where to make it easier later. At this point I would also recommend removing the driver’s side axle. It may not be required but the damn thing kept getting in the way. Have someone step on the brakes and use a 17mm allen wrench (purchased at Sears) with a large torque bar (make sure they brake hard… it took a lot of torque to get that bolt out and I ended up shearing off that little screw that goes through the rotor. I also disconnected one of the bolts for the stock front sway bar. In addition I removed 3 bolts underneath holding the rotor assembly in. There may be other ways to do this. I was told this particular method may necessitate a realignment! Once all that is done the axle can be taken out.
Take dogbone off, and undo driver side mount. get another jack under the tranny and undo all the bolts holding it to the block.
Start lowering the engine b/c you'll need an angle to get the tranny straight off the block without bending the input shaft. You kinda have to have someone on their back and pushing UP and over on the back of the tranny to get it off the flywheel and past the K-frame. This is the hardest thing I have ever had to do while working on my car. It was incredibly frustrating and requires lots of patience. I had to play with lowering and raising the engine with jack to find an angle where I could get it out. Extra hands, jacks are needed to keep the transmission supported so it isn’t just hanging there. The two places I ran into trouble were the passenger side axle flange hitting the flywheel, and getting the tranny over the K-frame. Once off, remove old pressure plate clutch (6mm hex) and flywheel (12mm triple square). Bolt on new flywheel, I believe 45ftlbs for the torque specs but double check with bentley OR 1.8T forums. I just tighten the pressure plate bolts till they're tight tight. I don’t have torque specs for the pressure plate bolts, but I just did those two hands tight whereas I did the flywheel bolts torque bar tight. I think it is recommended that you replace your flywheel and pressure plate bolts with new ones but I only replaced the flywheel bolts. I didn’t use a flywheel locking tool, but look into one so you don’t have to rig something like I did to keep the flywheel from turning. The clutch alignment tool should just be called a clutch holding tool. Do not blindly rely on it. Use your eyes to make sure the clutch is as centered as possible. Also, make sure you double check which side of the clutch is the gearbox side.
If your clutch disintegrated like mine you will have a lot of bits of clutch to clean out. Use a shop vac if possible. The clutch fibers are like fiberglass insulation and really irritate the skin. Don’t forget to install a new slave cylinder as well. This comes out with three 9mm bolts.
Getting the tranny back on is a little tougher, but reverse the process. The instructions that came with my clutch recommended lightly greasing the input shaft of the transmission with some high temp grease. I used brake caliper grease for this. I had a friend who just he-man’d the tranny in from underneath. Went in a lot faster than taking it out. Once you are ALL done, you'll have to bleed your clutch line. Once it's driveable, take it VERY easy for the first 450 miles or so. No neutral drops, no hard pulls, seriously try to get the best gas mileage out of your tank of gas. After 500 miles, everything should be kosher and let er rip. I reset my trip odometer so I could count down to it ------------------------------------------------------------------------ Please PM me to add corrections or additional info but I may not be the best resource for answering technical questions . Special thanks to Savwko and Adam@unitronic for their help.
4.5 JETTA GLI PG 04 AUDI A4 Ultrasport 1.8T 02m Clutch DIY
boosted gli
12-29-2005
Boca Raton fl
05 vw jetta gli
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 2:59 PM 7-12-2008 | |
good job on the DIY, finally someone came around to making one.
05 Jetta GLI / GIAC X+ / South Bend Stage 4 / Peloquin LSD / Snow Performance Water-Meth / 3in exhaust / FMIC / B&G RS2 / RSB /and basic bolt on's Molded Lip http://forums.vwvortex.com/zerothread?id=3470947
NOLA_VDubber
5-23-2007
NOLA
2005 Jetta GLI
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 3:02 PM 7-12-2008 | |
GREAT THREAD!!!!Thank you sooo much EDIT: I vote this be added to the FAQ
black and gold super bowl
SAVwKO
3-8-2003
Austintown Ohio
Re: 1.8T 02m Clutch DIY (NOLA_VDubber) » | « » 12:29 AM 7-13-2008 | |
Good job. Couple things to add:Found out to make it easier you can remove both of the axle flanges on the trans and you won't run into clearance issues with the flywheel. It's an allen bolt going thru each flange directly in the center so once those are off the trans can slide literally straight off without hitting the flywheel. Keep in mind though that removing those will open up the trans, literally, and fluid will come out. Better off draining it first out the drain plug.
Redapex
3-8-2004
Birmingham AL
GTi 337
FV-QR » | « » 12:39 AM 7-13-2008 | |
Hmmmm... anyone care to post a DIY on a slave cylinder?
.:337
Chemhalo
5-24-2004
Bartlesville OK
Re: FV-QR (Redapex) » | « » 2:50 AM 7-13-2008 | |
Sorry I didnt get pics of the slave cylinder. Its simple once you get the transmission off. Like I said, its 3 9mm bolts holding it down around the input shaft.
SAVwKO
3-8-2003
Austintown Ohio
Re: FV-QR (Redapex) » | « » 8:39 AM 7-13-2008 | |
| Quote, originally posted by Redapex » | | Hmmmm... anyone care to post a DIY on a slave cylinder? |
For the O2M it's the same procedure as was just posted minus the pressure plate/clutch stuff. You have to drop the trans to get the slave in/out.
J's04BlackPearlGLI
12-4-2006
Canton Mi
2004 Jetta GLI 1.8T
Re: FV-QR (SAVwKO) » | « » 10:16 AM 7-13-2008 | |
Nice write up
Nitro7853
4-26-2006
Lancaster NY
2003, VW GTI 20th anniversary
Re: 1.8T 02m Clutch DIY (SAVwKO) » | « » 11:23 AM 7-13-2008 | |
| Quote, originally posted by SAVwKO » | | Good job. Couple things to add: Found out to make it easier you can remove both of the axle flanges on the trans and you won't run into clearance issues with the flywheel. It's an allen bolt going thru each flange directly in the center so once those are off the trans can slide literally straight off without hitting the flywheel. Keep in mind though that removing those will open up the trans, literally, and fluid will come out. Better off draining it first out the drain plug. |
Can't you just plug it? I did a clutch on a 5spd 2.0 and I'm pretty sure we just left the tranny fluid in there. Although it wouldn't be a badd idea to change the fluid. Anyway this is a great DIY write-up
Current mods Apr 93oct. & race fuel programs., evoms vflow, 3inch downpipe to stock cat-back, forge turbo inlet , dual injection water/meth stage 2 BSH kit comin up dual stage boost controller from The man Sav himself http://HStuning.net
glimark
7-30-2007
847 IL
04.5 Bmp GLI
Re: 1.8T 02m Clutch DIY (Nitro7853) » | « » 10:34 PM 7-13-2008 | |
bradmb
5-2-2006
panama city beach fl
silver dragon
» | « » 11:43 PM 7-13-2008 | |
sweet. when i need to change my clutch ill be checking this out. i have never done one but i think i could manage.
337
pgk2004
11-3-2005
Rolling Meadows IL
2004.5 BMP GLI
Re: (bradmb) » | « » 10:56 AM 7-14-2008 | |
dam, where was this when i was getting raped on my labor for my clutch ?!???!
GIAC X+ program 14c / 42DD 3in DP w/ test pipe into 2.5 Magnaflow Catback exhaust plus Wayne CEL Fix / CAI / APR R1 DV / TIP / SBC Stage 2 clutch / Tyrolsport UGSMIC / Neuspeed Lower Intercooler Pipe ..... Still working on more.....
esoteric vue
10-10-2003
Passaic NJ/ Providence RI
2003 gti with a bunch of valves
Re: (pgk2004) » | « » 12:30 PM 5-30-2009 | |
bump. i hope this is identical to replacing a clutch on an o2m on a vr6? can anyone verify any differences i may run into?
lmaonster
7-20-2007
skullcity wv
20th
Re: (esoteric vue) » | « » 12:48 PM 5-30-2009 | |
http://forums.vwvortex.com/zerothread?id=2703042this should help
i win
Iso1ith
6-11-2007
Worcester MA
2004.5 PG. GLI
Re: (lmaonster) » | « » 12:52 PM 5-30-2009 | |
Fantastic DIY Mods please add this to the FAQ's. Great write up man!
esoteric vue
10-10-2003
Re: (lmaonster) » | « » 5:32 PM 5-30-2009 | |
that' for a 12v vr6 with the 5sp o2j...i havea 24v with the o2m. just wondering what differences there are in removing the trans from the engine??
JAPANDO
2-12-2006
seattle wa
04.5' gli bmp 04.5'gli pg
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 2:02 AM 7-6-2009 | |
ok .... this is a great thread and it helped out massively, untill i went to bolt the axle flange back on the drivers side and what ever the little conicle bolt is bolted to, on the inside of the trans, dropped down now i guess i screwed into taking the trans back out and taking it to a shop and paying fo the thing to get reput back together and putting it back in again crap i shoulda just paid the little extra to let someone else get fried clutch all over them Modified by JAPANDO at 7:42 PM 7-6-2009
turns out the housing to the spider gears inside had been broken for awhile, (there was alot of crud in the bearings) and that was why the gears fell down into the tranny.
Modified by JAPANDO at 11:56 PM 7-28-2009
DUBTHIS
SB_GLI
10-17-2005
Stevens Point WI
2004.5 TR GLI, 1990 White Cabriolet
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 9:10 PM 8-10-2009 | |
thanks for the write up. I'll be using this soon to save myself about $1,500
brandomos
5-6-2008
fourtyminutesfromphilly pa
03' GIT 1.8t, Tornado Red
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 3:25 PM 10-27-2009 | |
Is this also good for a 03 1.8? I just got an estimate and I almost died. They wanted almost 2 grand!!Thanks
dallas04gli
6-25-2007
Dallas Tx
2004.5 VW Jetta GLI
» | « » 5:49 PM 10-27-2009 | |
did this last week, still waiting on my buddy to help me put it back in. a note to all those who are doing this diy. If you dont think that you need to take the driver-side axel out. just do it anyway. it wakes a huge difference, and had i done it in the first place would have saved about an hour. to the op. great diy
2004.5 Plat. Gray Jetta GLI Giac X+; GHL 2.5" dp; 42DD 3" Catback; Koni sport coils; Neuspeed 28mm rsb; Neuspeed 25mm fsb; ABD CAI; ABD Intake Mani; JBL 12" sub; Alpine w205, and 2x1000W amp; Bora R kit http://www.andysautosport.com/volkswagen/
SB_GLI
10-17-2005
Stevens Point WI
Re: (dallas04gli) » | « » 8:05 PM 10-30-2009 | |
Just took mine out today to replace what I think is a bad flywheel. Axle removal made all the difference. had to make a special trip to the hardware store in the middle of taking out the tranny to get a 17mm allen wrench. I was able to sneek the axel out, over the tranny and through the engine bay to remove it, instead of removing the sway bar link and ball joint bolts.My timing hole plug is missing, and it looks like I have a leak from the valve cover or by the camshaft. Oil made it's way into the timing hole (dripped just perfect off a hose and into the hole) and is pretty bad inside the bellhousing. I would bet that's why I am replacing the flywheel in the first place. Edit: My issue was that two of the flywheel bolts were loose. Thanks again for the write up! Much better than looking at the bentley, as it refers to a bunch of special jack stands and tools that we don't have to do this job.
Modified by SB_GLI at 5:46 PM 11-12-2009
locastian
7-25-2007
Albuquerque NM
'00 VR6 GTI[R.I.P]/ 337
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 10:56 PM 11-1-2009 | |
Bookmarked!!!
MK4 stuff for sale: http://forums.vwvortex.com/zerothread?id=4706031
bradmb
5-2-2006
silver dragon
» | « » 12:16 AM 11-2-2009 | |
im glad someone made this, it will come in handy one day. altough, i am very impressed with our oem clutches though. they seem to hold up to alot. nobody i know around my area has had to replace theres unless the have a BT
337
atoson
12-28-2002
Silicon Valley Ca.
00 GTI VR6, 00 NB 2.0, 98 NB 2.0, 84 Scirocco 2045ltr. 80 Dasher Wgn, 72 Bus
Re: (bradmb) » | « » 9:27 AM 11-25-2009 | |
FMWT
Ausgezeichnet access VIRUS C 2010 Fernando Alonso Scuderia Ferrari
j20thgti
1-29-2007
south florida
Imola 20th AE GTI, 00 jetta GLS(sold)
Re: 1.8T 02m Clutch DIY (Chemhalo) » | « » 10:00 AM 11-25-2009 | |
awesome diy
20thGTI & "2.SLOW jetta SOLD" fast mk1 Rare Hare Buildup
