ShippensburgGTi
6-15-2004
Doylestown, PA
TSI GTI
BASIC TSI INFO/ACRONYMS/FAQ | « » 11:25 AM 9-24-2008 | |
For all the basic questions for new TSI owners..and for newbies: yes, there are 2 types of motors in the newer Audi/VW cars. In a nutshell:What one do you have? POP YOUR HOOD AND READ THE BADGE 1. FSI (found in 2006 and up to 2008 models) DSG and 6spd Manual 2. TSI (found in late 2008.5 and up models) DSG and 6spd Manual The U.S. Spec TSI is NOT the 1.4L Turbo and Supercharged engine that is found in the UK; rather it is second generation, if you will, of the FSI. A 2L 16V direct injection engine - with an IHI Turbo. Official TSI SPEC SHEET from VW (courtesy of Arin Ahnell @ APR Tuning) Engine Code: CCTA OR CBFA Type of Engine: Inline 4-Cylinder TSI Engine Displacement: 121 cu in (1984 cm3) Maximum Power: 200 hp (147 kW) at 5100 - 6000 rpm Maximum Torque: 206 lb ft (280 Nm) at 1700 - 5000 rpm Number of Valves Per Cylinder: 4 Bore: 3.2 in (82.5 mm) Stroke: 3.7 in (92.8 mm) Compression Ratio: 9.6 : 1 Firing Order: 1-3-4-2 Engine Weight: 317 lb (144 kg) Engine Management: Bosch MED 17.5 Fuel Grade: 95/91 RON Exhaust Emission Standard: ULEV (CCTA) - SULEV (CBFA) Some major differences from the FSI to TSI include: - chain driven belt - fuel/engine management - components in the intake system - oil filter and oil dipstick relocated - improved PCV system (proved to be problematic in the FSI) - compression ratio lowered to 9.6:1 - more balanced cam shafts in the center of the block on both sides - down pipe - fuel efficiency (debatable) - better emissions - more 02 sensors on exhaust system | Quote, originally posted by xgtiride » | | ....The fuel system is now run off of a new lobe of its own to reduce wear, which was a problem with some of the earlier 2.0t engines(from the tech's mouth). It is now also run off of the exhaust cam and no longer the intake cam. The tech noted that the injectors must overcome the combustion pressure of the engine to even force fuel directly, causing them to have operation pressures upwards of 1400 psi. Fuel mileage tech: The intake runners have a plate splitting them into two pathways. In the intake manifold exists individual butterfly valve like air flow splitters that direct the airflow into only half of the intake runners while cruising or coasting, thus increasing gas mileage. The airflow is directed into both paths when the engine is under load to increase air flow and power. Other notes: The intake is not part of the engine cover, and the sound pipe can easily be removed..... |
| Quote, originally posted by radgolf » | PZEV and SULEV are basically the same emissions rating, but PZEVs have a 15year/150000mi warranty and zero evaporative emissions. http://localdc.com/pzev.htm |
Every day, there are more and more mods being introduced for the TSI. Revo, APR, GIAC, and Unitronic all have software/flash capability (may vary depending on your ECU box code; as many as ~15 different ones) Intakes have been released by companies (11/08). NA Motorsports has released one by VF Engineering. BSH has their own system (available as stage 1 and stage 2). Neuspeed has a p-flo, APR has released Stage 1 (by Carbonio) and stage 2 is in the works, AWE also has their own custom setup in the making.... Downpipes from FSI applications can be modified to fit TSI cars depending on what engine code you are (CBFA vs CCTA). The mating flanges are slightly different (will require modification) and there is an extra 02 sensor in the stock CBFA setup. (consult your preferred dealer as to what software would clear a downpipe CEL). TSI specific Downpipes are available from various companies; including ones for CBFA. Do a search - i hear it's amazing. Catbacks remain the same from FSI to TSI. There are boost tap kits to make stuff work for our cars that worked on FSI (boost gauges, Forge DV's). Some of the more popular ones are made by BSH, AWE, and 42DD Suspension remains the same. Maybe a few aesthetic parts here and there like an extra rubber mount or bushing. GTI's appear to have alower suspension than stock 2006-2007, but only by a little. Front and Rear sway bars are the same. Popular abbreviations and acronyms associated with VW/AUDI: TSI (Turbo-Stratified Injection) FSI (Fuel-Stratified-Injection) CCTA PZEV CBFA SULEV i will update this as more information becomes available....everyone feel free to post more info to be included...i will add it to the original post and give you credit if you wish, just delete your post after i acknowledge it so this thread doesn't become 234324 pages long.
Modified by ShippensburgGTi at 3:45 PM 5-11-2009
| Quote, originally posted by greyvdub » | Step 1: Calm down about the CEL, embrace it, it adds more color to the instrument cluster
WTT/FS: 18" Smoked Karthoums FS: 2006 Rabbit - My girlfriends car; bone stock
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 1:16 PM 9-24-2008 | |
Here is my somewhat of an attempt to post some relevant information: Official 2.0 TSI Motor Guide FROM VW (Thanks for hosting the file Arin!) Official Specs: http://www.arinahnell.com/other/vw/tech/20tsi.pdf
2009 Carefree Maintenance Program Information: http://www.vw.com/myvw/carefree/en/us/ URL Link to PDF Explanation: http://www.vw.com/downloads/zi...e.zip Link to TSI related TSB: (Thanks again Arin!) http://forums.vwvortex.com/zerothread?id=4333364
EASY WAY TO TELL IF YOUR CAR IS CCTA OR CBFA Pop open your hood and inspect your factory airbox. If the airbox has a 2nd hose coming out of the front of the airbox then your car has the CBFA version of the airbox. The CBFA version also has a 3rd sensor (a 2nd o2 sensor) on the DP that is used for emissions purposes.
The MKV and MKVI Share the SAME TSI motor:
| Quote, originally posted by John Y » | That's not a rumor, the engine in the 2010 GTI in the US is the same TSI motor that has been under the hood of US GTIs since mid-2008 model year. |
| Quote, originally posted by Arin@APR » | Correct US MK5/MK6 2.0 TSI Engine CCTA CBFA CCT and CBF denote the engine's mechanical structure. IE, secondary injection (CBF) vs non secondary injection (CCT). A, the 4th letter, denotes the power output for the calibration, ie both rated in the us for 207ft-lb/200hp. ROW MK6 and A3 2.0 TSI Engines CCZA - A3 CCZB - MK6 CCZ denotes the european mechanical structure. A denotes the 200HP calibration. B denotes the 210HP calibration. |
Oil Change in a TSI Motor:
| Quote, originally posted by VeeRrrSick » | The good news is that you don't need to touch these covers on a TSI for an oil change. I did my first one at the first 1,000 mile mark just to train myself (and to see if there was any metallic content). The drain plug is accessible (points toward the rear), and the process is very painless. 1. Put the warm car up on ramps or jack stands 2. Remove the drain plug (19mm socket) 3. Remove the oil cap to speed draining 4. Once the flow slows significantly, loosen your oil filter slowly until you hear the flow increase again. Let it sit partly unscrewed and drain. (There's a breech pin that'll open if you haven't read about that--it's great.) 5. When the flow slows down significantly, unscrew the filter the remainder of the way by hand and pick the filter straight up. There shouldn't be any mess. 6. Lube and install the new filter. 7. Replace drain plug (no new crush washer is necessary from what I've read... the washer's permanent on the drain plug). 8. Fill 'er up. 5 qts. Start with 4.5, run it to get oil into the filter, and check. Add as needed. Enjoy the relatively painless process! I had a blast... and plan to do changes between dealer maintenance just for the peace of mind... and the relaxation. Modified by VeeRrrSick at 6:18 AM 5-21-2009 |
If you want to mount up a DP that is made for the FSI/ TSI CCTA engine you will have to modify the flange to fit for the CBFA (cut out the 2 parts of the flange that are colored with the charpie):
I am in no way going to update this thread with every single mod that is out on the market but I will pop in here (hopefully) from time to time and post up some available parts:
ECU Flash: APR REVO GIAC Unitronic
Downpipe: AWE (CCTA AND CBFA) 42D - Modular (CCTA AND CBFA) A&L (CCTA AND CBFA) USP (CCTA AND CBFA) Eurojet (CCTA AND CBFA) APR (CCTA AND CBFA)
Catback exhaust: ALL of the available FSI catback exhausts will properly mount up to the TSI engine
Catch Cans: BSH Vent to Atmosphere Race can BSH Recirculation Catch Can
Intercooler: All of the available FSI intercoolers will properly mount up to the TSI engine BSH tested APR tested A3 IC tested:
| Quote, originally posted by ryan mills » | ...The stock hoses work just fine too. You just have to cut the metal ends off, and clamp them down with 2 3/4" hose clamps. I might be imagining things, but my butt dyno notices a pretty large improvement in my 30-110mph runs. The price list is: 9- 6mmX1.0X16mm bolts (HomeDepot) $3.30 2-#36 2 3/4" ideal hose clamps (home Depot, plumbing section) $2.00 About 6 beers (kroger) $8 S3 intercooler (worldimpex.com) $320 +$18 shipping
S3 install thread: http://forums.vwvortex.com/zer...61165Intake: BSH (Stage 1 is the ram air scoop, Stage 2 is the long tube that connects to turbo inlet) Carbonio P-flo Neuspeed VF Motor Mounts: VF
Tranny Mount Insert: NOTE: the 2008.5 TSI mount is the same as the FSI while the 2009 TSI has a different shaped insert than the FSI BSH Dogbone will fit the 2008.5 TSI VF Dogbone will fit the 2008.5 TSI
Neuspeed has a 2009 TSI Insert Black Forest Industries (BFI) has torque arm insert (98a durometer) for 2009 TSI cars Boost tap: NOTE: you CANNOT tap into the vacuum source like the FSI motor you MUST purhchase one of the following pieces to properly tap into a vacuum source for a boost gauge BSH AWE 42
Modified by ViRtUaLheretic at 9:38 AM 12-17-2009
:: APR Fully Loaded TSI ECU :: BSH Race Intake :: BSH VTA Race Can :: BSH Pendulum Mount :: DEFI Blue Racer Gauge :: paitentially waiting for TSI performance parts..... Read this for TSI INFO/FAQ (MODS: sticky this thread plz!)
SimonSays
4-8-2007
Wilmington DE
2009 VW GTI
Re: (ShippensburgGTi) » | « » 7:50 PM 9-24-2008 | |
Alex@A.W.E.
4-9-2008
Willow Grove PA
» | « » 9:07 AM 9-26-2008 | |
Terrific idea Simon. I'll try to gather some info over the next week or so to contribute.
Alex Derderian A.W.E. Tuning Internet Sales
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: (ShippensburgGTi) » | « » 9:59 AM 9-26-2008 | |
These might be good links to incorporate: http://www.mkv-gti.net/wiki/in..._Page http://forums.vwvortex.com/zerothread?id=2374154
Modified by ViRtUaLheretic at 4:07 PM 3-31-2009
snobrdrdan
9-9-2008
White Lake MI
2009 VW GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 10:01 AM 9-26-2008 | |
| Quote, originally posted by ShippensburgGTi » | | Popular abbreviations and acronyms associated with VW/AUDI: TSI (Turbo-Stratified Injection) FSI (Fuel-Stratified-Injection) CCTA PZEV SULEV CBFA |
I know for a fact that I have the TSI.....but what's the difference between the CCTA & the CBFA versions!?!?
2009 UG GTI APR Stage 2+, ATP 3" DP, Carbonio Stage 1 & 2 Intakes, Eibach Sportlines, Sachs Race Dampers, H&R 24mm RSB, Tinted Tail Lights, VF Short Shifter, AutoTech Mount Insert, Neuspeed Intercooler Piping, OEM "D" DV, Euro Shift Knob, Euro Switches, Hoen fogs . . .13.93 @ 101.79
snobrdrdan
9-9-2008
White Lake MI
2009 VW GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 10:51 AM 9-26-2008 | |
How do you exactly figure out which one you have though???I'm in Michigan...so I don't have a emissions strict one
snobrdrdan
9-9-2008
White Lake MI
2009 VW GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ViRtUaLheretic) » | « » 11:25 AM 9-26-2008 | |
PZEV is just a term/label for the "Partial Zero Emissions Vehicle" that they put on the carSo then you either have the CCTA or the CFBA engine code....we just need to figure out which ones go with what type of engine (non PZEV vs. PZEV), lol
snobrdrdan
9-9-2008
White Lake MI
2009 VW GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 11:44 AM 9-26-2008 | |
| Quote, originally posted by ShippensburgGTi » | i think you're right...people may have a PZEV vehicle based on what state they bought the car in...maybe PZEV was just an 08 thing...and the 09's are SULEV (revamped PZEV)? |
We'll just never know....there's like NO info on this car (specifically the motor) at all Last time I checked the VW site they still had the '08 GTI on there & were still showing the FSI motor in it, LOL But yeah....certain states have to have the PZEV cars (like California & some of the northeast states).....so that's why I was wondering if the CCTA/CFBA meant the difference between PZEV & non-PZEV
snobrdrdan
9-9-2008
White Lake MI
2009 VW GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 1:45 PM 9-26-2008 | |
Did it say that on the window sticker?? I'm almost 99.9% positive when I was at the dealer on Tuesday & he pulled my VIN it said CCTA for the motor code (doesn't say anything on the sticker sheet)
So I think the CBFA is the PZEV version & CCTA is the non-PZEV version
NEW2B
11-30-2006
NJ,USA /GREECE
09 GTI /06 2.0T B6
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 8:58 PM 10-18-2008 | |
whats different about the downpipe?
2009 GTI - APR 93 STAGE I - INTAKE -14.0 @ 101MPH 2006 PASSAT-AUTO - 14.3 @96MPH-260HP APR 93 STAGE II - APR TBE - INTAKE - NS PULLEY - NS GAUGE EJ PCV FIX - 18" ACE DIMENSION-TOYO PROXES4 DRIVEGEAR SPRINGS - 35% TINT.
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 6:16 PM 11-7-2008 | |
Alrighty so as Im sure you guys are aware of (those guys that own 2009s that is) the 2009 models come with a "Carefree Maintenance" program. Today I had setup to meet for the Courtesy Vehicle Check, and for some reason I thought that they would change the oil. I guess when I called in and made an appointment I stated that I wanted an oil change or whatever. Anyways, once the "Courtesy Vehicle Check" was done I was handed an $80 bill for doing an oil change Do yourselves a favor and change your own oil before you do your Courtesy Vehicle Check and just have them inspect all the fluids. I wasn't expecting a bill. That's what I get for not looking up something in advance
Ricky Bobby
9-29-2005
Bedminster NJ
08.5 GLI 6MT, 05 SV650S, official mk5 sellout
Re: BASIC TSI INFO/ACRONYMS/FAQ (ViRtUaLheretic) » | « » 12:42 AM 11-8-2008 | |
| Quote, originally posted by ViRtUaLheretic » | Alrighty so as Im sure you guys are aware of (those guys that own 2009s that is) the 2009 models come with a "Carefree Maintenance" program. Today I had setup to meet for the Courtesy Vehicle Check, and for some reason I thought that they would change the oil. I guess when I called in and made an appointment I stated that I wanted an oil change or whatever. Anyways, once the "Courtesy Vehicle Check" was done I was handed an $80 bill for doing an oil change Do yourselves a favor and change your own oil before you do your Courtesy Vehicle Check and just have them inspect all the fluids. I wasn't expecting a bill. That's what I get for not looking up something in advance |
ouch. glad i have an 08
| Quote, originally posted by LETTERMAN52 » | | It's cool. You have a life. You're not on here all the time. For that i loath you copiously. |
Vortex tested, reverse shocker approved.
KampfGTI
3-28-2007
Goldsboro NC
1986 VW GTI 8V, 2009 VW Wolfsburg Jetta 2.0T
» | « » 1:16 PM 11-8-2008 | |
thats because only the 10k, 20k, and 30k services are free, according to my dealer the 5k oil change isn't needed anymore....anybody confirm this?
'09 Wolfsburg Jetta 2.0T M6 Reflex Silver - FK H/Ls with 4300k HID, APR Stage 1, custom Short-ram Intake (Gone)'08 Rabbit 2.5L M5 Reflex Silver - Vision 17"s, BFI TqArm Insert, Custom cat-back exhaust (Gone)'86 GTI 8v CIS-e - Koni reds, round headlights, 6K HIDs, TT 2.25 cat back, G-force Sports
xgtiride
10-22-2003
Dana Point CA
2009 VW Candy White T-Bunny GTI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 1:37 AM 11-9-2008 | |
Thought I would add to this thread as I recently was able to check out an 09 GTI engine being rebuilt at my local VW dealership... As well as I am a new 09 GTI owner .Quick story: This GTI was over-revved to 8900 rpms and some valves and lifters were destroyed. I am assuming the owner accidentally miss shifted. The first thing that the tech, who was a VW enthusiast himself, told me was that the entire valve train and head can be removed assembled to access the engine internals. Thus the advantage of this is that if you were to replace piston rings or need to access the engine internals, you can do so with out disturbing the valve train. He noted that he removed the head cover and the cam shafts were just sitting there, as the bearings are built into the case. The fuel system is now run off of a new lobe of its own to reduce wear, which was a problem with some of the earlier 2.0t engines(from the tech's mouth). It is now also run off of the exhaust cam and no longer the intake cam. The tech noted that the injectors must overcome the combustion pressure of the engine to even force fuel directly, causing them to have operation pressures upwards of 1400 psi. Fuel mileage tech: The intake runners have a plate splitting them into two pathways. In the intake manifold exists individual butterfly valve like air flow splitters that direct the airflow into only half of the intake runners while cruising or coasting, thus increasing gas mileage. The airflow is directed into both paths when the engine is under load to increase air flow and power. Other notes: The intake is not part of the engine cover, and the sound pipe can easily be removed. If anyone has questions, just ask. I probably know the answer, I just can't think of anything else new about the engine at this moment to post.
PAST DUBS...TRADED IN TO CONTINUE THE TRADITION VduB 1.8t Platinum Grey GLI - 195.49 whp - 247.63 wtq on 91 VduB 2.0 T-Red
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: (KampfGTI) » | « » 1:05 PM 11-9-2008 | |
| Quote, originally posted by KampfGTI » | | thats because only the 10k, 20k, and 30k services are free, according to my dealer the 5k oil change isn't needed anymore....anybody confirm this? |
Correct. However I was still kind of leary putting 10k on a brand new motor without an oil change..... I misunderstood what the free 6k maintenance inspection was comprised of and I ended up spendin some extra cash.
2005.5 GLI
10-8-2008
Vancouver WA
2009 GLI
» | « » 9:32 PM 11-12-2008 | |
hmmm they charged you for your 5k oil change on an 09vw, i was just at the dealership yesterday and i asked about the free service on the 09 GLI i bought and he said the oil needs to be changed at the first 5k then 10k after that but didnt say if they would charge me I'll have to check that out. and i talked to a tech and he said they updated and changed the water pathways on the new TSI. thought i would add that little bit of info.
KampfGTI
3-28-2007
Goldsboro NC
» | « » 1:00 AM 11-13-2008 | |
ur salesman probably forgot he was selling an '09, i'd check the fine print in ur manual
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: (2005.5 GLI) » | « » 8:35 AM 11-13-2008 | |
| Quote, originally posted by 2005.5 GLI » | | hmmm they charged you for your 5k oil change on an 09vw, i was just at the dealership yesterday and i asked about the free service on the 09 GLI i bought and he said the oil needs to be changed at the first 5k then 10k after that but didnt say if they would charge me |
Thats what my dealer first told me when he was selling me the car. However he corrected himself and apologized since when I bought the car it had only been on the lot for 3 days and they were still learning about the 09s
radgolf
2-8-2002
Redondo Beach CA
'08 BMP GTI TSI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 6:39 PM 11-17-2008 | |
Modified by radgolf at 3:41 PM 11-17-2008
2008 GTI TSI
radgolf
2-8-2002
Redondo Beach CA
'08 BMP GTI TSI
Re: BASIC TSI INFO/ACRONYMS/FAQ (ShippensburgGTi) » | « » 7:12 PM 11-18-2008 | |
| Quote, originally posted by ShippensburgGTi » | wow...what a warranty...but who is that backed by? the government? vw? the dealer? |
VW, and subsequently all VW dealers, are on the hook for this. The PZEV GTI (Tier 2, Bin 2) is even cleaner than the Prius (Tier 2, Bin 3), which makes me wonder why my tailpipes still have soot?  Tier 2, Bin 10: Least clean… Tier 2, Bin 9-6: Getting cleaner… Tier 2, Bin 5: Average… Tier 2, Bins 4-2: Getting even cleaner… Tier 1, Bin 1: Cleanest, equivalent to CARB’s ZEV standard (see below) http://www.autobytel.com/conte.../1478
2008 GTI TSI
VdubVSHonda
5-4-2008
Boston MA
08 CW GTI
Re: (ShippensburgGTi) » | « » 11:16 PM 12-17-2008 | |
just bought a 2008 TSI GTI this weekend and I'm trying to figure things out on it...... back to top!
FlickR™ | VolkShore | GENGSTOUT
radgolf
2-8-2002
Redondo Beach CA
'08 BMP GTI TSI
Re: (VdubVSHonda) » | « » 8:52 PM 12-18-2008 | |
Congrats! I've had my TSI for 7k miles and no real problems but two:1. When I push unlock on the driver door the thing clicks like 3-5 times sometimes. 2. My brakes squeak when the car is cold for the first minute. Not fully convinced it's the pads, though, and it's completely gone after that 1st min. Not too bad. Is yours a PZEV?
2008 GTI TSI
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: (ShippensburgGTi) » | « » 11:32 AM 1-12-2009 | |
| Quote, originally posted by ShippensburgGTi » | my brakes sqeak the first few times i brake, as well. started after winter came along.
I've noticed that during the winter if it is really cold or if there is any condensation the first few times I break there is some minute brake squeaking. After a few short stops the sound subsides. Should be normal. If you get some upgraded brake pads however there could be some additional noise. EDIT: x2 for sticky!! We should get some of the more major TSI threads sticked to avoid the repetive answers. AKA: z0mg whats chip should i get d00d!
Modified by ViRtUaLheretic at 10:33 AM 1-12-2009
Dream In Euro
6-29-2006
Providence RI
2008 CW GTI
Re: (ViRtUaLheretic) » | « » 5:09 PM 1-21-2009 | |
i noticed the same thing with my new 08 GTI...brakes squeaking on first few stops...figured it was due to the cold/salt all over them.
2008.5 Candy White GTI
[S][A][N][T][O][S]
12-14-2008
hhh HI
Re: (ViRtUaLheretic) » | « » 12:52 AM 2-2-2009 | |
will FSI ecu be compatible with a TSI? I have a 09 gti w/ TSI
ViRtUaLheretic
8-16-2008
St Louis MO
2009 VW BMP GTI
Re: (ShippensburgGTi) » | « » 10:53 PM 2-9-2009 | |
BUMP FOR STICKY
ItalianGLI
11-14-2002
Dallastown PA
2009 CW GTI TSI
Re: (ViRtUaLheretic) » | « » 11:45 PM 3-3-2009 | |
wow, good thing you bumped this. this should be stickied as it helped me since I might be getting an 09 GTI
Learn how you can receive a FREE Apple iPad by just entering your email address....Click Here Now!
LowestDub
11-13-2008
CA
1997 VW MK3 GTI VR6
» | « » 5:31 PM 3-11-2009 | |
bump for sticky
1997 GTI VR6
GTImeister
10-12-2005
Wauwatosa WI
Candy White GTI Candy White Tiguan
» | « » 8:49 AM 3-13-2009 | |
no doubtsticky this bish
bkmintie
3-26-2006
2009 A3 2.0TSI
» | « » 10:58 PM 3-30-2009 | |
Seriously this whole PZEV deal is bloody confusing...I'm guessing a major difference is that PZEV engines have a different ECU, explaining why APR Stage 1 is compatible (yet). Anyone care to elaborate further?
2009 A3 2.0TSI | MT | Ti | APR Stg 1 | Vogtland Coilovers | V1
ShippensburgGTi
6-15-2004
Doylestown, PA
TSI GTI
Re: (bkmintie) » | « » 11:17 PM 3-30-2009 | |
| Quote, originally posted by bkmintie » | | Seriously this whole PZEV deal is bloody confusing... I'm guessing a major difference is that PZEV engines have a different ECU, explaining why APR Stage 1 is compatible (yet). Anyone care to elaborate further? |
google/wiki PZEV. it's not exclusive to VW - it's pretty much a government standard depending where you live (and if your state government is choosing to abide by it) APR software is compatible with both CBFA and CCTA - the incompatibility issues lie in your ECU box code (there's as many as ~8-10?) APR from what i've heard/seen have cracked almost all. i would call APR or talk to (mike/arin) on here and give them your car information. they'll prob send you to an APR location if necessary so they can get a better understanding. it's a matter of a simple upload and download on a laptop connected to your car. i doubt you would even need to do that, though.
bkmintie
3-26-2006
2009 A3 2.0TSI
Re: (ShippensburgGTi) » | « » 12:34 AM 3-31-2009 | |
| Quote, originally posted by ShippensburgGTi » | google/wiki PZEV. it's not exclusive to VW - it's pretty much a government standard depending where you live (and if your state government is choosing to abide by it) APR software is compatible with both CBFA and CCTA - the incompatibility issues lie in your ECU box code (there's as many as ~8-10?) APR from what i've heard/seen have cracked almost all. i would call APR or talk to (mike/arin) on here and give them your car information. they'll prob send you to an APR location if necessary so they can get a better understanding. it's a matter of a simple upload and download on a laptop connected to your car. i doubt you would even need to do that, though. |
Yeah I understand what PZEV is (simply a designation for "grading" a cars emissions into a certain class, PZEV, ULEV, LEV, etc) We tried to do a trial flash today on my 09, no luck as APR doesn't support my ECU yet, but we did send in the code extract from the ECU to APR to take a look at. Arin and Keith have been awesome btw, really awesome customer service they have over there. Xing my fingers that they will be able to support my car sometime soon, the current promo that's going on is an awesome deal.
knavinusa
3-13-2009
Richmond BC
2009 Ibis White 2.0T Quattro
Re: (ShippensburgGTi) » | « » 12:43 AM 3-31-2009 | |
| Quote, originally posted by ShippensburgGTi » | | APR software is compatible with both CBFA and CCTA - the incompatibility issues lie in your ECU box code (there's as many as ~8-10?) APR from what i've heard/seen have cracked almost all. i would call APR or talk to (mike/arin) on here and give them your car information. |
I actually went to see if I could get trial stage 1 software and they told me the code for my car wasn't cracked yet At least they'll be able to crack another one when I bring the car in again.
2009 Audi A3 2.0TQ DSG Ibis White/Black - APR Stage I - BFI Torque Arm Insert - EBC Redstuff - Hartmann HS4 193 whp - 247 wtq - 14.69 @ 95 mph
ShippensburgGTi
6-15-2004
Doylestown, PA
TSI GTI
Re: (bkmintie) » | « » 7:16 AM 3-31-2009 | |
| Quote, originally posted by bkmintie » | Yeah I understand what PZEV is (simply a designation for "grading" a cars emissions into a certain class, PZEV, ULEV, LEV, etc) We tried to do a trial flash today on my 09, no luck as APR doesn't support my ECU yet, but we did send in the code extract from the ECU to APR to take a look at. Arin and Keith have been awesome btw, really awesome customer service they have over there. Xing my fingers that they will be able to support my car sometime soon, the current promo that's going on is an awesome deal. |
sounds like what i had to do initially. and yes, they're awesome people and go the extra mile.
