PowerDubs
7-22-2001
NNJ
2004 R32 13.14@105.77 AllMotor
 Mk4 R32 injector specs« »
Bosch 0 280 157 012 injector
Injector type EV 12 E (standard body size)
fuel flow 282,2ccm/min@3bar fuel pressure (note R32 uses 4bar FPR)
spray angles alpha 15 deg.
beta 7 deg.
gamma 10 deg.
delta 270 deg.
impendance 12 Ohms
.:R
PROJECTS- Intake manifold Higher ratio rocker arms Larger cams Ported head Bigger cats Rear TBD
INFO- Injector Specs
PowerDubs
7-22-2001
NNJ
 Re: Mk4 R32 injector specs (PowerDubs) »« »
Here is more info that I forgot to post here-
I asked asked what is the highest it is safe to run these injectors at or is the factory 4bar the limit?
Response-
Josh,
You might increase the fuel pressure up to 6bars without further modifications.
That would lead to an increase of the injector flow rate of 22,5%.
Regards,
Philipp Kurek
Bosch Engineering GmbH
BEG/MSD5
An der Bracke 9
71706 Markgröningen
GERMANY
.:R
» Return to Naturally Aspirated
