krazyboi
5-19-2004
Northern VA
'06 A3 3.2
DIY, Seat removal instructions | « » 10:51 AM 12-15-2008 | |
As requested...but quick and dirty!Front: 1) If you don’t have a VAG-COM, you should disconnect the Ground connection to your battery to prevent the AirBag error light from staying on. 2) Put seat as far back as possible 3) Remove 2 front bolts using triple square (size to be posted once checked again) 4) Put seat as far front as possible 5) Remove 2 rear seat rail covers. Remove 2 rear bolts using triple square 6) Disconnect connectors on front side of seat 7) Remove seats. Rear: 1) Remove rear seat bench. One side at a time, pull up on the front of the seat, then push the seat bottom towards the rear, unlatching it from the rear hooks. 2) From hatch, remove floor cover, exposing a black plastic cover in between both seats. This cover is pretty hard to remove. You want to try and slide your finger, or some object, under the bottom and pry outwards to the sides gently. If this breaks, you won't die...its just a cover, not a necessity except for looks. 3) Once cover is off, remove the screw and a securing clip. 4) Lift the seat back out of the center mount and pull the back towards the center of the car, removing it from a pin hole. 5) When removing the larger seat backing, there will be a bolt holding the center seat belt down. Remove that. Reinstall everything. Tightening torques: For the center bolt under plastic cap, its 15 Nm. For the seat belt bolts, its 55 Nm. Pics can be taken upon request. Modified by krazyboi at 9:59 AM 4/1/2009
Modified by krazyboi at 10:06 AM 4/1/2009
for sale: HID kit - H7 3000k, s-line shocks
mcowger
11-25-2008
San Francisco CA
2009 A3 quattro 2.0T DSG
Re: DIY, Seat removal instructions (krazyboi) » | « » 11:49 AM 12-15-2008 | |
Great instructions....OK....I have to ask...what on earth is a 'triple square'? Most seat bolts I've seen are Torx or tamper Torx.
yoonskim
6-8-2003
Buffalo NY
08 Audi A3 2.0T Sline & Ti 03 GTI 1.8T
Re: DIY, Seat removal instructions (krazyboi) » | « » 11:58 AM 12-15-2008 | |
ABS error light?? Airbag lights right?
2008 Audi A3 2.0T FSI 6MT - S-Line & Titanium PackageAPR Stage 2+ | APR RSC TBE | APR HPFP | Carbonio Intake | Stasis StreetSport Coilovers | Neuspeed RSB | Forge SSK | ECS Dogbone insert | Euro LED Taillights | AWE Vent Boost Gauge | S3 Shift Knob | Ashtray Delete | Ziza Yellow Fog Lights | ECS Smoked Sidemarkers | JL Audio 13TW5 on custom false floor Yoon
terje_77
12-18-2005
NORCAL CA
2009 Audi TT 2.0T S-Line
Re: DIY, Seat removal instructions (mcowger) » | « » 12:10 PM 12-15-2008 | |
| Quote, originally posted by mcowger » | | Great instructions.... OK....I have to ask...what on earth is a 'triple square'? Most seat bolts I've seen are Torx or tamper Torx. |
It looks like a Torx but with more teeth.
APR | H&R | Milltek
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
Re: DIY, Seat removal instructions (yoonskim) » | « » 12:25 PM 12-15-2008 | |
| Quote, originally posted by yoonskim » | ABS error light?? Airbag lights right? |
Whatcha talkin about? | Quote, originally posted by terje_77 » | It looks like a Torx but with more teeth. |
Correct...there's 12 teeth. Basically 3 squares placed together making up the tool.
irishpride
2-2-2006
south central ky
09 Town and Country, 04 Golf 2.slo, 81Bunny 16vITB'D Monster
Re: DIY, Seat removal instructions (krazyboi) » | « » 12:38 AM 12-16-2008 | |
added
Can't take the HEAT? Be a COP!! Most women want 1 ring on their finger. My woman wants 4 silver rings in the driveway but 3 kids required a Town and Country
angryrican66
4-16-2006
Harrison NY
2007 A3 3.2Q Open Sky,Bose,Technology,Cold Weather, Nav,Roof Rails Ibis White
Re: DIY, Seat removal instructions (krazyboi) » | « » 7:23 AM 12-16-2008 | |
| Quote, originally posted by krazyboi » | | As requested...but quick and dirty! Front: 1) If you don’t have a VAG-COM, you should disconnect the Ground connection to your battery to prevent the AirBag error light from staying on. 2) Put seat as far back as possible 3) Remove 2 front bolts using triple square (size to be posted once checked again) 4) Put seat as far front as possible 5) Remove 2 rear seat rail covers. Remove 2 rear bolts using triple square 6) Disconnect connectors on front side of seat 7) Remove seats. Rear: 1) Remove rear seat bench. One side at a time, pull up on the front of the seat, then push the seat bottom towards the rear, unlatching it from the rear hooks. 2) From hatch, remove floor cover, exposing a black plastic cover in between both seats. This cover is pretty hard to remove. You want to try and slide your finger, or some object, under the bottom and pry outwards to the sides gently. If this breaks, you won't die...its just a cover, not a necessity except for looks. 3) Once cover is off, remove the screw and a securing clip. 4) Lift the seat back out of the center mount and pull the back towards the center of the car, removing it from a pin hole. Reinstall everything. Pics can be taken upon request  Modified by krazyboi at 12:23 PM 12/15/2008
| we should have taken a video to show hot to do it in 15 minutes
/Euro S-Line Spings&Shocks/Haldex GenII/http://i98.photobucket.com/alb...8.jpg http://i98.photobucket.com/alb...s.jpg http://i98.photobucket.com/alb...9.jpg
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
Re: DIY, Seat removal instructions (angryrican66) » | « » 12:58 PM 12-16-2008 | |
| Quote, originally posted by angryrican66 » | we should have taken a video to show hot to do it in 15 minutes |
agreed! perhaps another time
terje_77
12-18-2005
NORCAL CA
Re: DIY, Seat removal instructions (krazyboi) » | « » 1:01 PM 12-16-2008 | |
| Quote, originally posted by krazyboi » | agreed! perhaps another time  |
I'm sure it would hit the top of the charts on youtube!
APR | H&R | Milltek
mcowger
11-25-2008
San Francisco CA
Re: DIY, Seat removal instructions (krazyboi) » | « » 2:03 PM 12-16-2008 | |
Thanks.Dammit, another new tool to buy
terje_77
12-18-2005
NORCAL CA
Re: DIY, Seat removal instructions (mcowger) » | « » 3:37 PM 12-16-2008 | |
| Quote, originally posted by mcowger » | | Thanks. Dammit, another new tool to buy  |
Buy or borrow mine if you're only going to use it one.
APR | H&R | Milltek
live2skate4me
3-31-2007
stony point ny
Re: DIY, Seat removal instructions (terje_77) » | « » 10:12 PM 12-16-2008 | |
Sometimes autozone has triple square sets for cheap, but your best bet is ebay. VIM is the brand i use at my dealer. Inexpensive and reliable. This is the most common sizes you'll need for audi's/Vw's.http://cgi.ebay.com/ebaymotors...Tools
Modified by live2skate4me at 7:13 PM 12/16/2008
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
FV-QR » | « » 8:17 AM 12-17-2008 | |
^^^ that's the same set I purchased, but from another site.Also, I know of a triple square set that also comes w/ the strut spreader we need for our front suspension. Not sure what brand it is, but I know it exists.
skotti
9-27-2005
Alexandria VA
'06 A3 2.0T Brilliant Red, 6MT, Open Sky, and lots of mods!
Re: DIY, Seat removal instructions (krazyboi) » | « » 8:59 AM 4-1-2009 | |
BIG thanks and to krazyboi for his telephone assistance with my seat removal! It was as easy as he said- I'm just paranoid and had to ask him a few questions...
Flying is the most fun you can have with your pants on! (Driving an A3 is second...) Friends don't let friends drive stock
Audi'sRevenge
3-23-2008
Toronto ON
08 A3 2.0T S-Line
Re: DIY, Seat removal instructions (skotti) » | « » 9:33 AM 4-1-2009 | |
Anyone know what the specified torque is on the bolts that retain the seats?I have to remove mine sometime in the coming months to install some tactile transducers, but I'd like to know what the fastener torque is when reinstalling.
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
FV-QR » | « » 10:05 AM 4-1-2009 | |
| Quote, originally posted by Audi'sRevenge » | | Anyone know what the specified torque is on the bolts that retain the seats? I have to remove mine sometime in the coming months to install some tactile transducers, but I'd like to know what the fastener torque is when reinstalling. |
Audi'sRevenge
3-23-2008
Toronto ON
08 A3 2.0T S-Line
Re: FV-QR (krazyboi) » | « » 1:39 PM 4-1-2009 | |
| Quote, originally posted by krazyboi » | For the center bolt under plastic cap, its 15 Nm. For the seat belt bolts, its 55 Nm. |
Thx
skotti
9-27-2005
Alexandria VA
Re: FV-QR (Audi'sRevenge) » | « » 1:41 PM 4-1-2009 | |
FWIW, I was able to remove the black plastic center cap with minimal damage (cracked a little)- best to use fingers and pry, trying from different spots.
skotti
9-27-2005
Alexandria VA
Re: FV-QR (skotti) » | « » 9:01 PM 4-2-2009 | |
Additional information (FWIW): If you are changing your non-powered driver's seat to a powered seat, you will have to run an additional harness for power (3 wires/pins). If there is a harness already installed and taped up somewhere, I couldn't find it
RaleighVW
7-16-2006
Raleigh NC
2007 A3 2.0T
» | « » 9:23 AM 7-9-2009 | |
Anyone remember the size triple square required to remove the front seats?
krazyboi
5-19-2004
Northern VA
'06 A3 3.2
FV-QR » | « » 9:38 AM 7-9-2009 | |
Eh, its been a while, but my guess is 12 or 14. I don't have my car so I can't check.
RaleighVW
7-16-2006
Raleigh NC
2007 A3 2.0T
Re: FV-QR (krazyboi) » | « » 8:31 PM 7-20-2009 | |
10MM was the size
