California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
To Dakar and Back | « » 3:52 PM 1-12-2009 | |
Some of you may recognize the thread title, a title covering a book of Lawrence Hacking through the Dakar Rally. A Google search will give you plenty of info on what this man has accomplished, but the book expresses it better. This thread will show a journey for a few people, as I'll be covering the progress of his next entry for the 2010 Dakar - where ever they hold it. This will not be a two or three week build blog, as some of us are used to on here seeing the odd engine swap in a VW. I'm sure the truck will be wrenched on to the last minute before leaving the country. Consider this a test of team work, quality manufacturing, build technique , technical insight, reliability, durability and in the end - perseverance. Lawrence has already competed in the Dakar... on a bike. This private entry of his will fall in the T1 Open class for the rally. The best thing about it - The truck is equipped with a VW Turbo Diesel. Here's some pictures on the entry as it sits now. I'll certainly go over all the details of the truck shortly, with more pics of course. It will fill you in on what it is composed of and what regulations the truck follows.
Just a small bit of info of who I am. I've been doing automotive related fabrication/design/car prep for a decent amount of time, roughly 10yrs... Covering quite a few realms of motorsport recently, and daily driven cars from time to time. People know me mostly for turbo manifold fabrication. If some of you have followed some of my other work you will know I don't leave out details. I like to let people feel involved/informed. If you dip into my sig a little bit, it will give you a taste of the work I do. I hope you all enjoy whats to come.
If anyone sees an opportunity for Lawrence to take on some additional support during this journey, by any means, let me know via IM or contact: Lawrence Hacking, offroadrider@aztec-net.com Jay Thornton, california_jay@hotmail.com Please remember the build may not be updated day to day, but will be a great source for info on whats going on surrounding the truck and its progress. A few more pics.
Modified by California Jay at 1:23 PM 1-12-2009
The manifold gods said, "Let there be nice welds." And so there was, and it was good.
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: To Dakar and Back (California Jay) » | « » 3:37 PM 1-13-2009 | |
Today I thought I'd give a rundown of the details of the truck... Added in some more pictures too. Chassis Type: Mason Motorsports Pro-runner, number #006 of 11 to date, is CAD designed and built by Neal and Robert Mason of Mason Motorsports, Escondido, California. It meets SCORE International technical and safety standards and is SCORE tagged (inspected). Roll cage is constructed of 1.75” x .120 wall thickness tubing. Two wheel drive, solid rear axle scaled-down (7/8 scale) Trophy Truck. Wheelbase: 111 inches or 282 cms. Wheel track: 76 inches or 193 cms. Powerplant: 1.9 liter VW / Audi Turbo Diesel engine
Transmission: Toyota R154 5-speed that has been rebuilt and modified with short-throw shift mechanism upgraded thrust washers for strength by Marlin Crawlers, Fresno, California. Some of you may wonder how the trans mounts up to the engine... there are a couple companies that supply hybrid bell housing kits. This one inparticular was from Acme Adapters. Rear differential:Trussed Ford 9 inch with 6:33 gear ratio using 35-spline rear axles, Strange modular third member. this combo is good for 700hp Certainly durable for this application
Brakes: Willwood calipers and 11.5 inch steel rotors that are same for all 4 wheels reducing need to carry unique spares. CNC Master cylinders (for clutch and brakes) and brake bias proportioning valve.
Cooling system: PWR aluminum multi-core radiator with 2 electric cooling fans mounted above and behind the driver’s cockpit out of harms way.  Oil cooler plus Canton Oil filter cooling lines adapter.
Tires:33-inch x 12.50 BF Goodrich Baja TA radials (truck carries the mandatory 2 spares). BFGs are best off-road tires available with numerous Baja 1000 wins. Rear Suspension: 3-link full floating solid rear axle with anti-sway bar supported by FOX 3.0 triple bypass and 2.0 coil-over shocks, 2 per wheel. Maximum Travel: 23 inches or 54 cms but reduced to 18 inches to comply with FIA rules.
Front suspension:Center-mounted fully boxed A-arms supported by FOX 3.0 triple bypass and 2.0 coil-over shocks, 2 per wheel. Maximum travel: 21 inches or 53 cms also reduced to 18 inches. Amount of bump steer throughout full suspension travel stroke: Gross vehicle weight: 2600 pounds or 1176 kilograms. Top speed: 85 miles per hour at 4,500 rpm. Body Type: Fiberglass, 4-piece generic pick-up truck. Fuel Cell: Fuel Safe FIA Approved 32 US gallon or 121 liters. Fuel range at 28 miles per US Gallon: 886 miles
Power steering: Howe hydraulic ram with billet reservoir and filter. Wheels: 15-inch Walker Evans Bead locks to prevent the tires from going flat as a result of lateral impact. Modified by California Jay at 2:26 PM 1-13-2009
Modified by California Jay at 1:58 PM 1-15-2009
Wes@motivemag
motive staff
2-23-1999
Lombard IL
2007 VW Thunder Bunny, 1999 Toyota Camry
Re: To Dakar and Back (California Jay) » | « » 3:42 PM 1-13-2009 | |
Do you have any more pictures of the engine, Jay? That thing looks incredible!
G0to60
6-22-2003
Milwaukie OR
90 Corrado G60 (mustard), 90 Corrado G60 (red organ donor)
Re: To Dakar and Back (California Jay) » | « » 3:44 PM 1-13-2009 | |
definently in to keep an eye on this. i've always wanted to see what it takes to build a Dakar vehicle. to you guys and good luck with the build.
| Quote, originally posted by ashsimmonds » | – it was like walking into a nut-allergy-support-group and licking peanut paste out of the jar and rubbing my nipples |
| Quote, originally posted by -Khaos- » | Seriously, cows "emit" alot of gases compared to cars, yet I don't think any of these smog-test supporters have switched to a vegan diet or made any attempt to place a catalytic converter up a cows rectum. |
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: To Dakar and Back (Wes@motivemag) » | « » 3:54 PM 1-13-2009 | |
Yes there will be plenty.. I've got lots of work to do on the engine.. you will probably get to see some rapid prototyping to aid in evolving some parts. We have stereolithography on site.
Modified by California Jay at 2:19 PM 1-13-2009
Isgro
3-10-2004
Central MA
'63 T2 SC, '05 Triumph T100, '07 Rabbit
Re: To Dakar and Back (California Jay) » | « » 3:57 PM 1-13-2009 | |
Wow, that's very cool. I'll definitely keep an eye on this thread.
MattBDI | c.b.s. - nerding it up since '05 | MID - vinyl, banners and more
Kid Hobo
9-4-2005
09 JSW 6MT 2.0T
FV-QR » | « » 4:03 PM 1-13-2009 | |
No 1.8T?
"We be jammin' now, mon!" Billy said, toasting The Breeze with a slosh of the Coors. The Breeze shook his head balefully. "Keep the can down, watch the road, let me roll the doobie," he said. "Sorry, Breeze," Billy said. "I'm just stoked that we're on the road."
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: FV-QR (Kid Hobo) » | « » 4:08 PM 1-13-2009 | |
A race like this you need to keep it simple and reliable. Fuel needs to last... Mechanical Diesel injection turbo will take care of that.
Kid Hobo
9-4-2005
09 JSW 6MT 2.0T
Re: FV-QR (California Jay) » | « » 4:16 PM 1-13-2009 | |
| Quote, originally posted by California Jay » | | A race like this you need to keep it simple and reliable. Fuel needs to last... Mechanical Diesel injection turbo will take care of that. |
Yeah, but if it had been, you would have had close to 95% of the TCl community follow you down there to help out with anything from impromptu engine swaps to a cup of refreshing ice cold water. The remaining 5% would have been waiting for VTAAAK to kick in yo.
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: FV-QR (Kid Hobo) » | « » 5:46 PM 1-13-2009 | |
LOL I guess you win some and loose some.Here's a quick shot of the steering rack I forgot..It's nice and compact to the center line of the car.... much needed for something with so much suspension travel.
Also a good aerial for some of you.. gives a decent engine shot.
hotweiss
12-4-2005
Calgary AB
2008 Subaru Impreza with Sports Package
Re: FV-QR (California Jay) » | « » 5:56 PM 1-13-2009 | |
 Wow, that truly is a mid-engine car.
Political signatures are not allowed.
G0to60
6-22-2003
Milwaukie OR
Re: FV-QR (California Jay) » | « » 5:57 PM 1-13-2009 | |
so the engine is halfway into the cockpit or am i seeing it wrong? i guess that would help with weight dist.
GTIbyJB
5-9-2006
Mississauga ON
2002 VW GTI
» | « » 6:02 PM 1-13-2009 | |
This thing is awesome, I have the pleasure of working with Jay on a daily basis (More fun then it sounds, he goes a little crazy sometimes, well all the time actually) and to see this in person is amazing. The whole thing is one huge piece of engeneering!
RavinJetta
3-30-2002
2000 Volkswagen Jetta GLX, 1997 Grand Cherokee 4.0, 2004 Acura TSX
» | « » 6:24 PM 1-13-2009 | |
Very cool build
Nourdmrolnmt
5-7-2006
czechoslovakia
Low and Wide w/ some poke and stretch
Re: FV-QR (California Jay) » | « » 6:29 PM 1-13-2009 | |
| Quote, originally posted by California Jay » | LOL I guess you win some and loose some.
no, with the 1.8T you nevar lose
What is a Libertarian? A Republican who owns a bong.
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: FV-QR (G0to60) » | « » 8:00 PM 1-13-2009 | |
| Quote, originally posted by G0to60 » | so the engine is halfway into the cockpit or am i seeing it wrong? i guess that would help with weight dist. |
Your vision is 20/20 It looks a bit farther back in that pic than it really is, the engine and trans area are designed to accomodate a full LS1 drive line if need be.
Eg2Driver
7-9-2007
Montreal Qc
Re: FV-QR (California Jay) » | « » 8:14 PM 1-13-2009 | |
lol at the fram filter......nice truck!!!
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: FV-QR (Eg2Driver) » | « » 10:36 PM 1-13-2009 | |
thanks mate,
Kid Hobo
9-4-2005
09 JSW 6MT 2.0T
FV-QR » | « » 10:41 PM 1-13-2009 | |
1,8ts aside, this is a sweet frakin' ride. Have you put it up on a dyno to see actual output? Did you modify/swap the turbo?
inarisilver78
4-5-2008
South SA Texas
1978 Inari Silver Rabbit Diesel
Re: FV-QR (Kid Hobo) » | « » 10:48 PM 1-13-2009 | |
 It is amazing but change the freakin filter
Mcstiff
1-31-2002
NE Thornton Co
'90 Audi CQ 20V TURBO, '08 Pilot
Wh are your goals for the engine? I thinking about using one in m CJ6
Qu'est-ce qu'on s'amuse!  "Never trust the old shaped quattro's- you just never know what might be under the bonnet" 1990 Coupe Quattro 7aT
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
» | « » 11:05 PM 1-13-2009 | |
Everyone has to understand something... this is work in progress. Some things are installed temporarily to give the representation of something that will be there in the future, it makes it easier to estimate what part has to clear another if there is something new being installed or fabricated... so obviously that filter will not stay. Second to that, when you break in an engine...you don't put the best of filters or oils in first.. its a waste of money.Generally my first stage of break in on a motor like this will be 50km or a documented amount of hours. Then the oil is drained and filter tossed for the next stage of break in. Goals for the engine are still being disscussed... I'd like to see if I can get Garrett on board for the TDI upgrade they offer, its a great torque increase. But tuning it for mechanical injection is another hurdle. We'll see.
tip
8-7-2008
Bellingham
Golf or Tahoe
Re: (California Jay) » | « » 12:04 AM 1-14-2009 | |
| Quote, originally posted by California Jay » | | Second to that, when you break in an engine...you don't put the best of filters or oils in first.. its a waste of money. |
Isn't it funny how people attempt to point out every little thing "wrong" with what you're doing to come across as "intelligent"? Don't listen to the keyboard jockeys in this thread telling you to do this or get rid of that. You and your crew know what you're doing... Props to a guy who's a part of a unique project, I'll be watching this
Kid Hobo
9-4-2005
09 JSW 6MT 2.0T
Re: (tip) » | « » 12:18 AM 1-14-2009 | |
THIS:| Quote, originally posted by tip » | Isn't it funny how people attempt to point out every little thing "wrong" with what you're doing to come across as "intelligent"?  |
Minus this:
| Quote, originally posted by tip » | | Don't listen to the keyboard jockeys in this thread telling you to do this or get rid of that. You and your crew know what you're doing... |
Equals this:
| Quote, originally posted by tip » | Props to a guy who's a part of a unique project, I'll be watching this  |
Modified by Kid Hobo at 9:20 PM 1-13-2009
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: (tip) » | « » 12:48 PM 1-14-2009 | |
thank you!
phryxis
9-18-2008
so cal
» | « » 12:53 PM 1-14-2009 | |
very very cool.the dakar rally is something i've always been interested in.
bulletproof automotive
beatenb3
10-30-2008
Calgary Alberta
B3
» | « » 12:55 PM 1-14-2009 | |
I can't wait to see more. I want to see that thing run.
VW Tuna
1-29-2003
sumner wa
'85 GTi 16v, '08 Rabbit
Re: (beatenb3) » | « » 1:25 PM 1-14-2009 | |
| Quote, originally posted by beatenb3 » | I can't wait to see more. I want to see that thing run.
x2!
I'll try to be NICER if you try to be SMARTER... "Its not a car. Its a Volkswagen." - VAG 1984
Preppy
5-3-2001
Toronto Ontario
2007 MK5 GTI
Re: (VW Tuna) » | « » 1:33 PM 1-14-2009 | |
Out of curiousity, is RWD capable enough for this event? Most of the vehicles (motorbikes aside) are AWD ya?
It's so damn hot, milk was a bad choice.
SteveMcqueen
2-25-2006
This is why I joined TCL. Detailed build threads are great and this is definatly setting the benchmark. Great, clear pictures. Great information. Too bad you couldn't give some more detail on the actual frame build. I love browsing pirate4x4 and seeing the actuall bones of the car form. Either way, thanks, good luck, and keep this thread bumped!
| Quote, originally posted by hrvstofsrrw » | | says the fricking retard driving a Japanese crap brick |
93' 900 Turbo 00' Viggen
climbingcue
2-2-2001
Morristown NJ
2004 Silver R32 13.25@104.76
Re: (California Jay) » | « » 1:36 PM 1-14-2009 | |
Very cool, I will be watching this build
Bill CAT 3 Cam Install's for MKIV R32 Suspension installs for MKIV or MKV IM me
axe
4-29-2005
Moncton, Canada
GE8 Fit
FV-QR » | « » 1:46 PM 1-14-2009 | |
Wow
█♣█ + ███ | FireVortex | Sunlight on chrome, the blur of the landscape... every nerve aware | T'aime, Cocotte
G0to60
6-22-2003
Milwaukie OR
Re: (Preppy) » | « » 1:58 PM 1-14-2009 | |
| Quote, originally posted by Preppy » | | Out of curiousity, is RWD capable enough for this event? Most of the vehicles (motorbikes aside) are AWD ya? |
Robby Gordon has done it the last few years including this year with a RWD truck.
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: (G0to60) » | « » 3:41 PM 1-14-2009 | |
A shot of the dash and configuration for seating, not much room but you cerainly need to sit in there nice and snug. Although, it gives lots of mounting area for the GPS, guages etc etc. This also shows the kick up for the wind screen as the fiberglass body is mounted.
Modified by California Jay at 12:53 PM 1-14-2009
California Jay
8-31-2004
JRP Mississauga ON
99' 1.8t A4,
Re: (California Jay) » | « » 4:53 PM 1-15-2009 | |
Some mounting and decisions on the location of certain items are still being decided, but the power steering reservoir sit quite nicely here... a small circular clamp holds it to the frame nicely. Notice the replaceable filter, nice feature. We still have to figure out the fittings for this item as the suspension travel is so vast, fittings to the drivers side would interfere with suspension components if not placed properly. Manual steering on this is not an option with these big tires.   Some other small brake lines got routed today too. Nothing secure...some lengths of line need to be adjusted also.
Modified by California Jay at 1:56 PM 1-15-2009
