RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
 CAT Camshaft cracked in half!« »
I was installing a set of Cat 263/264 cams this past weekend and the longer cam cracked in HALF while pushing down on it to adjust the Cam Caps.
Anyone else ever hear of something like this happening with these cams? I'm so pissed off. Also, anyone know the contact info for CAT? I cant find it anywhere and their site is very poor.
Take No Prisoners! Take no $4it! \m/
need_a_VR6
5-19-1999
Oxford PA
1996 Land Rover Discovery
 Re: CAT Camshaft cracked in half! (RattleHead) »« »
Not common, but cams break. You're best bet is to talk to whomever sold you the camset.
Pushing down with what and how on the cam? They're quite brittle and you're not supposed to put any sort of load on them other then radially (holding the cam, torquing, etc). When installing you need to install the caps in the order that will pull it down naturally.
-Paul
'95 GTI VR6 - ALL MOTOR - Powered by Megasquirt
KPTuned : Megasquirt Solutions - Repair - Installation - Tuning
::: The Race Shop : M.J.M.
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
 Re: CAT Camshaft cracked in half! (need_a_VR6) »« »
Quote, originally posted by need_a_VR6 »
correct and I installed the caps in the correct order. If they are brittle then mine must have been extra brittle because I merely pushed down on softly to adjust one of the caps. I believe mine are defective and this pisses me off to no end
need_a_VR6
5-19-1999
Oxford PA
Ever drop them or have them out of the mfg packaging before install. Be glad it didn't break while the motor was running.
That's a Schrick that broke while running, killed the head. As far as anyone could tell it was a small casting flaw.
-Paul
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
no
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
Anyone Know Cat's Contact info? Cant find a number for them on the web.
Eric D
2-16-1999
Tragic Kingdom
Use Catcams UK because Catcams Belgium is useless.
http://www.catcams.co.uk/
Quality Engineered Products - UK Distributors for Catcams
Unit 10, Old Kiln Works
Ditchling Common Ind Est
Hassocks
West Sussex
BN6 8SG
Tel: 01444 243720
Fax: 01444 247906
webenquiry@catcams.co.uk
Manche VWs sind einfach schneller als andere.
The original Dub and Dubber.
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
 Re: CAT Camshaft cracked in half! (Eric D) »« »
Quote, originally posted by Eric D »
Thank you.
BarnDweller
9-23-2006
.... Be glad it didn't break while the motor was running....
Seriously! Consider yourself LUCKY!
The Official 2010 Cycling Goal Thread | Ride a bicycle? Track and compare your millage against fellow VWVortex cyclists!
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
 Re: CAT Camshaft cracked in half! (BarnDweller) »« »
Quote, originally posted by BarnDweller »
I know man. I am not too pissed since it could have been a lot worse.
VRnasty08
6-19-2008
Cambridge MD
2000 VW Jetta VR6
cams are by far the easiest mechanical part in an engine to break.the material they are made of is very brittle.this may seem farfetched but its the truth
blkjettavr6
11-7-2001
Millersville
vr's
When I saw this topic this picture was in my head and I was going to post it for you but obvioulsy you beat me to it
42 Draft Designs
DCI
RattleHead
2-2-2009
Hell \m/ NJ
98 GTI VR6.
 Re: CAT Camshaft cracked in half! (VRnasty08) »« »
Quote, originally posted by VRnasty08 »
regardless of how far fetched, it really sucks and it should not happen.
DubZmk3VR
6-14-2008
somewhereinhere ct
'95 jetta glx
damn that really does suck dude
hustle for what you need not for what you want
VR6 mk3's are the ****
» Return to 2.8l 12v VR6 Engine Forum
