saaber2
7-15-2008
close by
Bypassing PCV to exhaust DIY (Now updated with vacuum measurements) | « » 8:26 PM 5-12-2009 | |
This is a pcv bypass description using an exhaust "slashcut" system. Crankcase gases are routed to the exhaust instead of into the intake to prevent deposit buildup (such as those seen on on this 2.0 FSI engine with 22k miles and stock pcv system):EDIT: I Have found the best vacuum pull comes from plugging the front PCV port and running the hose out the back of the valve cover, and not using any check valves. This seems to give the best unimpeded flow. So some of the steps below would no longer be applicable under the setup of plugging the front pcv and running out the back of the valve cover. Also, the amount of vacuum has not been measured on a chipped car so it is possible that a chipped car may pull more vacuum.
The gases are evacuated under vacuum created by the exhaust passing by the nipple as shown in this Moroso diagram:
Materials needed: A. Moroso check valve Part No 97800 Update: I am currently running mine without this check valve and it is working great. Testing shows 0-3" Hg vacuum with 5" max for very brief periods. See videos towards the end of this thread. I have not tested the vacuum while the check valve is in place so nothing to compare the "no-check valve" numbers to yet.
B. Moroso exhaust nipple Part No 97810 (you could easily make your own but not worth the trouble for the cost IMO)
C. 7-8 feet of 5/8” high temp heater hose and two hose clamps D. One ¾” freeze plug for intake pcv E. One ¾” freeze plug for pcv line on rear of valve cover F. One 1” freeze plug and one hose clamp to seal off rear pcv line to turbo edit: this plug is not needed, see step 6 under "method" below. The hose clamp is still needed though. Cost: Moroso check valve $20 Moroso nipple $10 Hose $80 Exhaust shop to install nipple $50 Hose clamps and plugs $15 $175 total Method: 1. Weld in nipple into exhaust pipe post-cat and post-sensor, screw on check valve to nipple. Orient nipple at 45 degrees according to instructions located here http://www.moroso.com/catalog/...t.pdf or Click on "instructions 25900" on the bottom of this page http://www.moroso.com/catalog/...13023 I had an exhaust shop do mine. That is not a garden hose, before you ask ha ha, it's a silicon heater hose.
2. Remove engine cover and remove front “accordion” line from pcv to intake 3. Insert ¾” freeze plug into intake and tighten but don’t tighten too much. Or use some other plug method.
4. Remove hose clamp for rear pcv line where rubber hose connects to back of intake manifold and pull hose away from valve cover. Note metal line bends easily making hose removal easier. 5. Plug valve cover outlet at rear pcv line with another ¾” freeze plug or some other plug method. Don’t over tighten
6. Plug metal rear pcv line by inserting 1” freeze plug into the rubber hose and then hold in place with a hose clamp (probably better methods for this but this works fine and is fast). Or use some other plug method. edit: this step is not needed. Simply put rubber hose back onto valve cover outlet and secure with a hose clamp. Install right over the freeze plug, as if the plug wasn't there.
7. Run a heat resistant heater hose from pcv on front of valve cover to the check valve on the exhaust. I ran mine around the engine and down by the exhaust and then back. Pretty easy to do. Very accessible. Secure with metal ties ideally or zip ties so hose doesn’t flop around. Secure both ends with hose clamps.
8. Replace engine cover. Objective: Eliminate source of valve deposits while maintaining a maintenance free, simple system with adequate crankcase evacuation. VW themselves, in the patent for this engine, say that eliminating the PCV would solve the deposit problems but they can’t due to emissions: "Gasoline engines with direct injection of the fuel into the combustion chamber, i.e., not into the intake port, suffer especially from the problem of the formation of carbon deposits on components. ...the successful ignition of the stratified charge depends to a great extent on the correct development of the internal cylinder flow, which ensures reliable transport of the injected fuel to the spark plug to guarantee reliable ignition at the spark plug. However, a coating of carbon deposits in the neck region of the intake valve may interfere so strongly with the tumble flow that ignition failures may occur there as a result. ...Furthermore, the coating of carbon deposits in the neck region of the intake valve causes flow resistance, which can lead to significant performance losses due to insufficient cylinder filling, especially in the upper load and speed range of the internal combustion engine. In addition, the carbon deposits in the neck region of the intake valve may prevent correct valve closing, which leads to compression losses and thus sporadic ignition failures. ...These deposits on the valve stem can result in flow deficits due to undesired swirling and turbulent flow around the globular carbon deposits. This may persistently interfere with the formation of stable tumble flow from cycle to cycle." "A possible solution would be to keep these sources of deposits away, for example, from the intake valve, by completely eliminating exhaust gas recirculation and the introduction of blowby gases into the intake port. However with the combustion behavior of modern reciprocating internal combustion engines, at least external exhaust gas recirculation and the introduction of blowby gases into the intake port are absolutely necessary for reasons of emission control and fuel consumption, so that this approach is not possible. " - Thanks to Rl_RS4 for finding this patent info. Check out his thread listed at bottom of this post for more info. Possible other effects: a. May possibly extend oil life but this is not really expected. i will monitor this anyway Edit: I have done several UOAs and no noticeable benefit to oil life has been observed b. May possibly reduce fuel dilution of oil but this is not expected. i will monitor this Edit: I have done several UOAs and no noticeable benefit to oil life has been observed c. May possibly improve horsepower due to better ring sealing under crankcase vacuum but this is not expected. d. May possibly make car run smoother as deposits to valves and related side effects such as those discussed in the patent are reduced (f.e. injector fouling, incomplete combustion due to restricted air flow). I do expect this system to provide a smoother running and cleaner engine in the long term compared to stock. Edit: Have definitely noticed this. No stumbling starts and very smooth idle for approx. 14k miles and seafoam treatments are no longer needed. e. Increased mpg? Not expected Edit: Have noticed a slight bump, but not a big deal. Method of evaluation: Only good way is to visually inspect valves. I am not going to do that but I am going to monitor the oil condition via TAN and TBN sampling. Benefits/features of this method: 1. Eliminates PCV gases return to intake thereby eliminating largest source of deposits to intake valves, fuel injectors, etc. 2. Routes crankcase gases to exhaust post-cat and post sensor 3. No need to empty a catch can 4. No chance of freezing up, unlike catch can 5. Crankcase gases are removed under vacuum unlike catch can 6. Less chance of pressure drop as could occur with a catch can Cheaper version (downtube): If a person believes that vacuum is not needed to evacuate crankcase gases (such as anyone who wants to run a "race" catch can that vents to the atmosphere), you could eliminate all the expensive parts and just block off front pcv at intake, rear pcv line, and then simply run a hose underneath the car with no catch can. This would cost roughly $10 for the plugs, $15 for hose and clamp? for a total of around $25. the only thing you wouldn’t get is vacuum pull of crankcase gases. One BITOG member did this on his audi RS4 http://www.bobistheoilguy.com/...07413 and really likes it and UOAs look great. He reports no oil spots on driveway etc. from tube. I chose to have vacuum assist. Also, to keep dust, etc. out of the down tube you could add a breather filter on the end of the tube. Some more reading FYI: http://www.honda-tech.com/showthread.php?t=1199935 http://www.honda-tech.com/showthread.php?t=697498 http://www.bobistheoilguy.com/...art=1 http://www.bobistheoilguy.com/...96487 http://www.bobistheoilguy.com/...14263 Of course all the usual caveats apply. This is for a race-only application, do at your own risk, modifying your car may void your warranty, etc.
Modified by saaber2 at 8:02 AM 2-1-2010
dubsker
1-8-2006
Renton WA
a grey turbo car
FV-QR » | « » 8:38 PM 5-12-2009 | |
im guessing that the exhaust gases create a venturi effect and there is a vacuum present at that point?
WILL VAG-COM FOR BEER. WTB YOUR HUFFS
SpecialFX
8-19-2006
Tell City IN
'06 GTI, '82 G60 Rabbit convetible, '85 beater F-250
FV-QR » | « » 8:49 PM 5-12-2009 | |
I haven't made up my mind on what I think of the idea yet, but I give you a big for a very informative post with good technical information!
1983 Stage 3 G60 Rabbit Convertible 2006 Stage 2 GTI 1985 F250 beater
rhouse181
4-13-2008
Houston Tx
2008 MKV GTI
» | « » 9:09 PM 5-12-2009 | |
glad to see you finally received your parts... did you tap into the exhaust pre or post cat?keep us updated on how the car idles and performs under boost. i guess we will never really know how well it works though. its hard to measure the benefits of this type of thing...
saaber2
7-15-2008
close by
Re: (rhouse181) » | « » 9:15 PM 5-12-2009 | |
Yeah, visual inspection is the only way really. But there is no way that crankcase gasses can get to the intake now and they are being pulled out under vacuum. Same effect as race catch can without some of the drawbacks.I would like to test acid buildup in oil of this vacuum assist method vs. just running a tube below the car. Maybe I will disconnect exhaust connection on next oil change to test that (see if TAN level changes). Installation is post-cat. Dubsker, yes the nipple has bernoulli effect from exhaust gases.
Modified by saaber2 at 10:43 AM 6-14-2009
A3_yuppie
6-5-2006
Orange County CA
2006 Audi A3 2.0T (DSG) & 2009 Audi A4 2.0T Quattro Sedan (Tip)
Re: Bypassing PCV and routing to exhaust, description (saaber2) » | « » 11:47 PM 5-12-2009 | |
Which patent are you getting the quoted passages from?
Noob #1: "I want to get a chip. Which is the best?"Oldtimer: "... use the !@#$%&* search ..." Noob #2: "OMG you need to replace your DV and PCV stat!"
saaber2
7-15-2008
close by
Re: Bypassing PCV and routing to exhaust, description (A3_yuppie) » | « » 12:31 AM 5-13-2009 | |
| Quote, originally posted by A3_yuppie » | | Which patent are you getting the quoted passages from? |
http://www.google.com/patents?...A1,M1 This was found by RL_RS4
Rub-ISH
8-7-2006
Vegas NV
Audi 2006 MT6 A3
Re: Bypassing PCV and routing to exhaust, description (saaber2) » | « » 1:32 AM 5-13-2009 | |
Wow that is a very interesting read if you can get through it
| Quote, originally posted by Hunter S. Thompson » | | "You can't cover the American dream in a Phucking VOLKSWAGEN..." |
dubsker
1-8-2006
Renton WA
a grey turbo car
FV-QR » | « » 3:16 AM 5-13-2009 | |
i would say get a bsh stage 1 plate and send everything through the back, that will clean up the hoses.
CoNGLoMeRaTeGTi
4-4-2007
LiL eL SaLVaDoR NY
I DONT LIVE IN THE PAST. CURRENTLY OWN A MKV GTi, SO FAR SO GOOD.
» | « » 6:43 AM 5-13-2009 | |
OP, excellent job.
BUY MY STUFF
b0mb3r
11-9-2006
Bear DE
2006 VW GTI
Re: (CoNGLoMeRaTeGTi) » | « » 8:18 AM 5-13-2009 | |
this is great! what emission implications does this carry? will I no longer be able to pass emissions with this?
~sBig Knob equipped
MFZERO
3-13-2002
Haverhill MA 495 West
2000 Haro Blammo, 1987 4000csq
FV-QR » | « » 9:04 AM 5-13-2009 | |
bravo!
Autobahn Performance REVO Dealer | CHEAP OEM PARTS! | nek.cbs.hbc.csd
saaber2
7-15-2008
close by
Re: (b0mb3r) » | « » 11:05 AM 5-13-2009 | |
| Quote, originally posted by b0mb3r » | | what emission implications does this carry? will I no longer be able to pass emissions with this? |
A safe way to deal with emissions would be to temporarily return it to stock. Remove long heater hose, replace original accordion tube on front pcv, reconnect rear pcv line. This should only take 20-30 min. You can drive with no hose attached to the nipple/check valve in the exhaust. The check valve in the exhaust keeps any noise or exhaust from leaking out (I drove the car this way after exhaust shop installed nipple/valve).
b0mb3r
11-9-2006
Bear DE
2006 VW GTI
Re: (saaber2) » | « » 11:13 AM 5-13-2009 | |
| Quote, originally posted by saaber2 » | A safe way to deal with emissions would be to temporarily return it to stock. Remove long heater hose, replace original accordion tube on front pcv, reconnect rear pcv line. This should only take 20-30 min. You can drive with no hose attached to the nipple/check valve in the exhaust. The check valve in the exhaust keeps any noise or exhaust from leaking out (I drove the car this way after exhaust shop installed nipple/valve). |
I understand that, but is the problem with the emissions is because you are venting exhaust gasses without passing through the cat?
~sBig Knob equipped
Phil@BSH
9-10-2001
Speedshop Az
01 1.8T 3071R, 06 2.0T 3076R, 10 2.0T WIP
Re: (b0mb3r) » | « » 11:18 AM 5-13-2009 | |
Nvm. Good post
Modified by Phil@BSH at 10:20 AM 5-13-2009
BSH Speedshop 602-606-7973 Info@bshspeedshop.com Wholesale Inquiries Welcome
saaber2
7-15-2008
close by
| Quote, originally posted by b0mb3r » | | I understand that, but is the problem with the emissions is because you are venting exhaust gasses without passing through the cat? |
Not if you put it back to stock for the test. But if you are trying to pass emissions as is, yep that would be the problem and would fail visual inspection.
Modified by saaber2 at 4:09 PM 5-13-2009
saaber2
7-15-2008
close by
Re: FV-QR (dubsker) » | « » 11:20 AM 5-13-2009 | |
| Quote, originally posted by dubsker » | | i would say get a bsh stage 1 plate and send everything through the back, that will clean up the hoses. |
Good idea. I like the BSH and FFE caps for the intake etc. also because they look much cleaner than the freeze plugs.
Modified by saaber2 at 8:30 AM 5-13-2009
loudgli
8-3-2005
outside c bus Oh
07 VW GTI, 94 Acura DC2
Re: FV-QR (saaber2) » | « » 1:43 PM 5-13-2009 | |
Is there an advantage to using a catch can with this and just using the drain on the catch can to feed into the exhaust?
07 CW 4dr GTI Underachieving Stage 3
rhouse181
4-13-2008
Houston Tx
2008 MKV GTI
Re: FV-QR (loudgli) » | « » 1:54 PM 5-13-2009 | |
| Quote, originally posted by loudgli » | | Is there an advantage to using a catch can with this and just using the drain on the catch can to feed into the exhaust? |
the venturi effect from the exhaust is not being used as a disposal place for the stuff that would normally be caught in the catch can, even though it does perform that task as an added benefit. running the intake out to the exhaust is what creates that vacuum conditions necessary to remove the blowby vapors under non-boost conditions... with say a BSH catch can, the vacuum effect is created by running the hose from the outlet on the can back into the crankcase... if you opened up the drain plug to the exhaust while having the vaccum line attached to the crankcase, i don't know what results you would get. i would assume the vaccum in the crankcase is greater than the venturi effect off the exhaust, so you might end up sucking exhaust gas into your crankcase.
Modified by rhouse181 at 11:01 AM 5-13-2009
loudgli
8-3-2005
outside c bus Oh
Re: FV-QR (rhouse181) » | « » 2:01 PM 5-13-2009 | |
| Quote, originally posted by rhouse181 » | the venturi effect from the exhaust is not being used as a disposal place for the stuff that would normally be caught in the catch can, even though it does perform that task as an added benefit. running the intake out to the exhaust is what creates that vacuum conditions necessary to remove the blowby vapors under non-boost conditions... with say a BSH catch can, the vacuum effect is created by running the hose from the outlet on the can back into the crankcase... |
Makes sense now. So is one setup more efficient than the other (exluding emissions)? Say the OP setup vs. a ProVent catch can rerouted to the crankcase?
crew219
10-18-2000
ITH NY
Re: FV-QR (dubsker) » | « » 2:38 PM 5-13-2009 | |
Yep, I considered doing this as well, using the single port out the back to connect to a tap in my DP. Only concern would be how much vacuum this method will pull through the PCV tract (easily verifiable via a vacuum gauge). Dave
Forge DV Review APR SII beta logs REVO 93 logs APR 93 logs
saaber2
7-15-2008
close by
Re: (rhouse181) » | « » 5:07 PM 5-13-2009 | |
| Quote, originally posted by rhouse181 » | | keep us updated on how the car idles and performs under boost. |
There is no noticeable change at idle. At WOT it seems to pull harder but I don't put much weight in butt dyno. I used my iphone gtech (dynolicious) which is not scientific of course and the best 0-60 time I could do before was 6.9 sec. All stock car, dsg, not using launch control. Today the best I could do was 6.55 and lots of 6.7's. No other variables such as weight, oil, weather changed so it appears it made a small but noticeable difference in HP (but driver variablility makes this not a very good test of course). The only way to tell for real is to use a real dyno. I just wanted to see if my butt dyno was lying to me. Also I did this mod to tackle the problem of valve deposits not hp. So if there is any gain in hp (and I'm not saying there is a gain, but my impression is that there is a small gain) that is a bonus. I know drag cars and race cars use this method to improve hp. My understanding is that the vacuum helps the rings seal better but I don't know much about that part of it.
Macs S3
10-10-2008
Breganzona TI
2007 8P S3 Audi
» | « » 9:16 AM 5-16-2009 | |
I would like to thank saaber 2 for sharing his experience.I have a couple of questions regarding this solution: A) By routing the oil gasses in the exhaust, wont you risk the carbon buildup in the exhaust? B) I have a BSH catch can but I have not installed it yet, I am thinking of using the BSH plate to route the oil gasses under the car (venting to the atmosphere) since I think that the pressure in the crankcase is enough to blow out the gasses. Will I need to put a one way valve on the hose in order to prevent things to be “sucked back” or there is absolutely no way that a suction can be created in the crankcase? C) What I intend to do is basically to install the BSH catch can system as it is intended by BSH but instead of using the catch can I would route the hose under the car. Obviously I will need to plug one of the two holes in the BSH plate. Will I need to do anything to the back pcv since BSH system does not mention it? Thanks to everyone who will answer this.
saaber2
7-15-2008
close by
Re: (Macs S3) » | « » 8:39 PM 5-16-2009 | |
| Quote, originally posted by Macs S3A » | | By routing the oil gasses in the exhaust, wont you risk the carbon buildup in the exhaust? |
Exhaust already receives tons of carbon, etc. (f.e. look at black exhaust tips). Crankcase gases go through muffler only as it comes in post cat. | Quote, originally posted by Macs S3A » | | B)Will I need to put a one way valve on the hose in order to prevent things to be “sucked back” |
If you use a valve, I would suggest one with a low cracking pressure, not one like the one posted above which needs suction to work. Keep in mind that the key to atmospheric systems, as I understand it, is for the system to "breathe" or vent well. Any impedance to flow such as a check valve or catch can will cause a pressure drop. Some cans or valves would cause higher drops than others and others may be so low as to be almost insignificant I would hazard to guess but i'm no expert. Maybe google "pressure drop" along with "catch cans" or "crankcase evacuation" or "pcv" as I remember some discussion on the pressure drop but I don't have the links. Too much of a pressure drop could cause overpressure in crankcase causing oil to come out dipstick tube etc. | Quote, originally posted by Macs S3A » | | ...or there is absolutely no way that a suction can be created in the crankcase? |
Can't say absolutely no way as it is an open exchange to the air from the crankcase (with no check valve I mean). Check Honda link above for tidbits but no solid discussion on this that I have seen. I know the old road tubes on lazy v8's had air coming and going into crankcase but I don't know with turbo. Has anyone ever measured this?
Macs S3
10-10-2008
Breganzona TI
2007 8P S3 Audi
Re: (saaber2) » | « » 11:29 AM 5-17-2009 | |
Thanks again saber for your answers.I am checking out the thread on Hondas ( http://www.tamparacing.com/for....html ) Do you have any advice regarding the rear pcv given that with the BSH solution it is not mentioned?
b6turbopassat
8-14-2008
Memphis TN
2006 2.0T Passat
» | « » 12:43 PM 5-17-2009 | |
what about where the rear pcv bolted to the turbo is it still bolted there or is that taken off?
Candy White B6 Passat 2.0T-// APR Stage 2 // 6 Spd // Neuspeed P-FLO Intake // Forge DV // BSH PCV Revamp // 3'' Catless Downpipe // 2.5'' Custom Catback // 5% Tint // New South Performance Gauge w/ Pod // 10,000k H.I.D.'s // BSH Dogbone Insert // Neuspeed Race Springs // Micro-CAN 908 (VCDS) // Want: APR Stage 3 Turbo kit IE Rods BSH Dogbone Pendelum Mount BFI Motor/Transmission Mounts
saaber2
7-15-2008
close by
Re: (Macs S3) » | « » 6:20 PM 5-17-2009 | |
| Quote, originally posted by Macs S3 » | | I am checking out the thread on Hondas ( http://www.tamparacing.com/for....html ) Do you have any advice regarding the rear pcv given that with the BSH solution it is not mentioned?
Answer should be on vortex somewhere maybe in these below? Also I wonder if one of the stock inline check valves could be utilized for your check valve? http://forums.vwvortex.com/zerothread?id=4115371 http://forums.vwvortex.com/zerothread?id=4084097 http://forums.vwvortex.com/zerothread?id=4338295 http://forums.vwvortex.com/zerothread?id=3769357
Modified by saaber2 at 3:30 PM 5-17-2009
saaber2
7-15-2008
close by
Re: (b6turbopassat) » | « » 6:21 PM 5-17-2009 | |
| Quote, originally posted by b6turbopassat » | | what about where the rear pcv bolted to the turbo is it still bolted there or is that taken off? |
Is your Q regarding the slashcut/exhaust system? If so, I just left the pipe on as no reason to remove it except for looks.
saaber2
7-15-2008
close by
Re: Bypassing PCV and routing to exhaust, description (saaber2) » | « » 11:32 PM 5-17-2009 | |
Just thought of something. Step 6, plugging the rear pcv line with a 1" freeze plug, is not needed.You could simple reinstall the rubber hose onto the outlet coming from the valve cover (the one where the 3/4" freeze plug is installed). In other words, disconnect the rubber hose at the rear pcv line, plug the outlet at the rear of the valve cover with a 3/4" plug, then reinstall the rubber hose with a hose clamp just as if the 3/4" plug wasn't there. That would look original too, for what that is worth.
Modified by saaber2 at 8:50 PM 5-17-2009
B3sat16v
1-22-2002
KORF, KCPK, KMFV VA
Cessna C172
Re: Bypassing PCV and routing to exhaust, description (saaber2) » | « » 8:38 AM 5-18-2009 | |
VERY NICE! I might have to look into this!
A wooden cahhhh!
saaber2
7-15-2008
close by
Re: Bypassing PCV and routing to exhaust, description (B3sat16v) » | « » 2:36 PM 5-18-2009 | |
If you want to read up on this, the best source is this thread:http://www.honda-tech.com/showthread.php?t=1199935 Skim for "dasher"'s posts in about the first 6 pages. He did an amazing amount of testing different crankcase evacuation methods. There is tons of good info in that thread! After testing all the different methods, he went with the exhaust slashcut method (he actually has two nipples instead of one to create more vacuum).
blackvento36
3-17-2003
Easton pa
06' GLI 6MT Deep Black
Re: Bypassing PCV and routing to exhaust, description (B3sat16v) » | « » 2:38 PM 5-18-2009 | |
What if you were to make a blockoff plate for the front PCV (like the BSH, but no hose fittings), and just connect the tubing to the rear PCV?
The BEST MKV carputer Posting in the MKV forum is like smacking yourself in the face.
B3sat16v
1-22-2002
KORF, KCPK, KMFV VA
Cessna C172
Re: Bypassing PCV and routing to exhaust, description (blackvento36) » | « » 2:48 PM 5-18-2009 | |
| Quote, originally posted by blackvento36 » | | What if you were to make a blockoff plate for the front PCV (like the BSH, but no hose fittings), and just connect the tubing to the rear PCV? |
Yes connect it to the rear PCV.... and block-off the Turbo inlet.
A wooden cahhhh!
blackvento36
3-17-2003
Easton pa
Re: Bypassing PCV and routing to exhaust, description (B3sat16v) » | « » 7:52 AM 5-19-2009 | |
Block off both front valve cover ports, or channel them together like the BSH stage1 kit? Cuz I think connecting the 2 front ports would be the way to go.Edit: Nevermind, I just took a look at that diagram again and it wouldn't make a difference unless you had a way to connect the block crankcase vent to the driver side port like BSH. If you block off the whole PCV, what to you do with the crankcase hose?
Modified by blackvento36 at 7:59 AM 5-19-2009
blackvento36
3-17-2003
Easton pa
Re: Bypassing PCV and routing to exhaust, description (B3sat16v) » | « » 8:40 AM 5-19-2009 | |
