BoostinBejan
4-12-2009
Cal Poly Pomona CA
Stealth GT3076R'd, Honda F4i CBR600
 Project BT stealth mode!« »
Well now that the GLI that I built is finished and out of my garage, I will be starting on my own car. Since lots of my parts went to that car (exhaust mani, IC piping, oil/coolant lines, inlet, etc) I am attempting to get the engine bay to look as stock as possible. I will be building a bottom mount tubular header (sch10 1 1/4) to hide everything. I will run the IC piping under the car, run the stock airbox and stock TIP (not going to anything of course) and some other stuff. Basically I want the engine bay to appear 100% stock, yes I know it's going to be very difficult, especially with my intake mani.
Setup
Turbo: Garrett GT3076R 4" anti-surge inlet, GT V-band turbine housing
Header: Custom tubular bottom mount, sch10 1.25"
Intake Manifold: Custom big port (Inlet Dynamics )
Wastegate: Tial MVS (The new v-banded 38)
BOV: Tial 50mm (version 1)
Intercooler Precision 600hp w/ 2.5" piping all aroundlo
Exhaust: I will build a downpipe/wastegate re-route 3" all the way to the axle, then it will go down to 2.5" to go to a Magnaflow 5x8x24" muffler
Tune: Tapp/Eurodyne 630cc file at 4 bar
Trans: 02J w/ Quaiffe LSD, Spec stage 2+ clutch w/ 12lb flywheel
Head AWP small port heavily ported, stock everything except Supertech inconel exhaust valves.
The pile of new parts is starting!
I am pulling my head off so I can do some ARP bolts, and supertech inconel exhaust valves. The rest of my head will stay how it is, along with stock throttle body.
Will also fully utilize my boost-per-gear setup:
I built the motor last summer, the bottom end will stay how it is.
photoshop PS by loxxrider, so good.
original
I'll update with pics as usual along the way, i'm very excited! This will be a fun build!
Modified by BoostinBejan at 4:14 PM 8-17-2009
NOLA_VDubber
5-23-2007
NOLA
2005 Jetta GLI
 Re: Project BT stealth mode! (BoostinBejan) »« »
gonna be sick, can't wait to see this take shape
black and gold super bowl
l88m22vette
3-1-2006
Chicagoland IL
Let the parts rain down (except the engine block)
Sounds sweet, but why stealth? Keep it clean? Scam unwary ricers?
Audi TT mkI FAQ Coming eventually: project 2.sloTTq www.audifreaks.com
halchka99
4-18-2002
Glendale CA
Turbo
 FV-QR »« »
because of KALIFORNIA
Build
-=FS: Powder coated valve covers=-
FS: Big Injector Driver Box
screwball
12-10-2001
Fifty Trim
 FV-QR »« »
I think it's because of the strict California emissions laws.
I'm dying to wrap my car in semigloss white.
FS: Used Full Set of ECS Lightweight Underdrive Pulleys
halchka99
4-18-2002
Glendale CA
Turbo
 FV-QR »« »
he's gotta smog and get it inspected in california for registration purposes
Build
number1275
3-28-2008
New Roads LA
20th Anniversary #1275
 Re: Project BT stealth mode! (l88m22vette) »« »
Quote, originally posted by l88m22vette »
Pass CA emissions visual?
Boostin, what is the duty cycle like on the 630cc injectors with the 3076?
MI_canuck
12-21-1999
Detroit area, MI
'04 VW Jetta GLS 1.8T 5-spd
sounds like an awesome build!!
the 1st & 2nd gear boost control is pretty cool... with that and the tire choices, i'm assuming your plan is to autocross and/or track the car?
I hope you'll be using your built car's potential for doing more than just going in a straight line
cheers
2004 Jetta GLS 1.8T 5-speed - Eibach ProKit springs & ProDampers - APR Stage 1 - 93 Tune: 215hp/247lb-ft / 100 Tune: 230hp/262lb-ft
l88m22vette
3-1-2006
Chicagoland IL
 Re: FV-QR (screwball) »« »
None of that emissions crap matters, his GTI registered in a different state
BoostinBejan
4-12-2009
Cal Poly Pomona CA
 Re: Project BT stealth mode! (number1275) »« »
Quote, originally posted by number1275 »
at 3 Bar, not good. Which is why I run 4 bar. I was maxing out the 3 bar long ago. According to vag-com's injector duty cycle (Which isn't very accurate) on C16 and high boost (27psi) 630's at 4 bar were getting very very close to getting maxed out.
And yes, I am getting California plates. No more out of state plates, this will be the biggest challenge of the summer/build.
Quote, originally posted by MI_canuck »
cheers
it's just my daily, but there are plenty of good mountain roads around that I have my fun on. Usually track days are out due to school (too busy).
btw I'm from michigan too, it sucks but no emission/smog was nice.
Michigan plates, now gone.
Modified by BoostinBejan at 10:01 AM 7-23-2009
CD155MX
12-18-2007
Pomona CA
1995 Mk3 GTI with a 1.8T
Might respray the car white this fall too, photoshop
[/QUOTE]
OMFT FTMFW!!!!!
1995 MKIII with a 1.8T and Cabrio front
CD155MX GTI Build/Rebuild (mk3.5, 1.8T, BT, 02J content)
lucas13dourado
9-30-2007
Kenmore WA
1 audi and 1 volkswagen
 FV-QR »« »
is it done yet?
Fine Tuning
DUBCACA
Modified by Vmk3W at 11:28 PM 2-22-2008
wolfsburg2617
4-25-2007
the roc NY
01' Jetta Wolfsburg
 Re: FV-QR (lucas13dourado) »« »
son of a...haha
jealous. can't wait to finish school so i can tear my car apart. watching this thread too. gl
i see your problem: you're low on kraut
dubinsincuwereindiapers
1-16-2008
Allentown PA P A
2001 jetta 1.8t
Wow! You don't waste any time do ya?? How you can go to school full time for engineering, work, and do all of these wild builds is beyond me Do you sleep??
Quote, originally posted by 20aeman »
That's an effective way of burning money....probably more effective than having a high dollar prostitute (who gets paid by the hour) slowly marinate a bald eagle (seasoned in cocaine of course) over a diamond encrusted bbq that uses 100 dollar bills instead of coal.
kkkustom
6-5-2007
amsterdam NY
04 Jetta 1.8T
I am going sleeper more than stealth. Shaving the engine bay and getting rid of a ton of crap under the hood. FMIC is black and all stock exterior/wheels too.
The exhasut setup your going to do... how loud will it be do you think? Are you recirculating the wg or dumping it?
What about 830 sw? I am going to run that on my 3076r.
BoostinBejan
4-12-2009
Cal Poly Pomona CA
 Re: (kkkustom) »« »
Quote, originally posted by dubinsincuwereindiapers »
It's summer man! I don't need sleep in the summer. I have about 6 weeks to finish this build and have to drive the car back down to Socal for school, so I have a little while. Only thing is I need the car 100% complete and reliable, and smog-able so I'm all set when I get to school and don't have to worry about the car. I post on vortex at work, that's where I get my fix.
Quote, originally posted by kkkustom »
It should be nice and quiet. Might add another big resonator/muffler in the middle. I already have the 630 file and injectors so there is no point going to the 830's. I don't run C16 very often, and if this setup is more effecient, it should make some good power on pump gas so I won't worry about maxing out the 630s at 4 bar. I will however be using a nice Bosch 044 inline pump along with the stocker.
vdubguy97
9-13-2003
Sunshine State
2003 BMP 20th
Quote, originally posted by BoostinBejan »
I can squeeze 275/40/17 inside the front fenders (Rears fit fine). The 255's aint cutting it.
This is the craziest part of the build. 275's....will you still be able to turn?
Why you are in the head why not springs and retainers?
Speed Kills.Save Your Life.Drive A Honda
HTAGT3076r__Precision__Unitronic__SEM__Shearer Fabrications__Tial__Integrated Engineering__Cat Cams__INA Engineering__Southbend
ncsumecheng
11-1-2005
Greensboro NC
01' Wolfsburg & MKII Jetta
If you really want stealth, figure out how to keep no intercooler visible up front. Having an awic, people think I just have a nice sounding exhaust on a stock Jetta.
Go Unitronic!
FS: my house, my big turbo Jetta, a GLI shell, all together!
http://forums.vwvortex.com/zerothread?id=4614722
BoostinBejan
4-12-2009
Cal Poly Pomona CA
 Re: Project BT stealth mode! (vdubguy97) »« »
Quote, originally posted by vdubguy97 »
What's the point of springs and retainers if I keep stock cams? The cams will limit how high I would rev anyways, it's not like it makes decent power past 7500 with stock cams, not only that but if the majority of my driving is 4-7k, stiffer springs? Why would I want that when the lighter stock springs will work just fine. You gotta remember when you build a head with stiffer springs, it takes more force to compress each one of those springs, robbing power .
vdubguy97
9-13-2003
Sunshine State
2003 BMP 20th
Do it once for future upgrade, thats if cams will be in your future.
BoostinBejan
4-12-2009
Cal Poly Pomona CA
No thank you.
burkechrs1
11-30-2008
Minden NV
2001 VW GTI 1.8t
me = jealous
/thread
2001 GTI 1.8t AWW [[Revo Stage 2, Wavetrac LSD, TT Short Shifter, ABD 25mm FSB, 3" Custom Exhaust, FMIC, Forge 004, Forge MBC, Cone Air Filter, Cranked Wastegate]]
The gremlins are back
1-16-2008
Allentown PA P A
2001 jetta 1.8t
 Re: (BoostinBejan) »« »
I'm logged in on my blackberry 24/7.. I pop in and out of the tex throughout the day.. Either way.. You get a lot done bro.. Props to ya
EF9Si
12-11-2003
Westmont IL
01' Jetta Wolfie BT GT28Rs
 Re: (dubinsincuwereindiapers) »« »
Subscribing to this build now!!!
Unitronic Propelled GT28RS
I love boost
20VT*J4
8-27-2001
I appreciate what you're trying to do, but you might want to consider finding yourself a hookup instead of going through all the trouble of making your car appear stock when standing in front of the engine bay...unless you're going to make the entire car look stock too (from your post, I gather you are not).
Only reason i say this is because when I got my mk4 smogged, the smog guy pulled out a mirror-on-a-stick to inspect every underside portion of my car. He did so based solely on the looks of it (lowered, wheels, etc) cause the engine was actually completely stock at the time. What you plan to do would not have worked with this guy.
Or maybe just find yourself a guy without a mirror-on-a-stick Good luck with whatever you decide to do
BoostinBejan
4-12-2009
Cal Poly Pomona CA
 Re: Project BT stealth mode! (20VT*J4) »« »
Quote, originally posted by 20VT*J4 »
Right, completly understand. I'm doing this more of the po-po then the smog. I can find a shop that can care less, I'm not worried about that as much as I am about getting the hood popped and the cop seeing shiny things.
20VT*J4
8-27-2001
Ah, didn't think of that...carry on in that case! This can def come in handy, CHP made me pop my hood a couple months ago.
Vegeta Gti
2-12-2003
konoha village Hawaii
84 jetta GLi [HGM] BT1.8T, 2008 stolen stereo,06 M3 SMG
very nice..i like
CARPE DIEM
:HOMEGROWNMOTORSPORTS: STS Performance
• #13 The Dead Rabbits • #13 MKI from birth till death
shotofgmplease
5-20-2003
Virginia is for Dubbers
2 BMP AE GTI's & 1.8T B5 Passat
 Re: Project BT stealth mode! (Vegeta Gti) »« »
FS: 3" APR catback exhaust (20th AE/337) http://forums.vwvortex.com/zerothread?id=4700543
M this 1!
5-17-2000
Los Angeles ca
'02 ALMS 225 TT coupe Stg IV Del Rio/GIAC
 Re: Project BT stealth mode! (shotofgmplease) »« »
My TT has no problem passing smogs. i basically put the stock airbox cover (shown) over the EVOMS intake. the blue coupler is now black and the line is below the maf. look up the legalities of an Intake Manifold in our state and you'll be happy.........just needs all the factory nipples.
Fleet Manager at Pacific Audi
Audi TT ALMS stg IV
Nathan Lloyd
323-363-2250
BoostinBejan
4-12-2009
Cal Poly Pomona CA
This is going to be very difficult to build a compact header. Using 1 1/4 helps, but it needs to be 1-2" shorter than this. Ofcourse lowing the turbo flange isn't really an option as the turbo would hit the axle. Basically going to just make a crappy shorter collector that is not as nice of an angle to get everything lower.
Modified by BoostinBejan at 10:42 PM 7-23-2009
jettaman18t
9-13-2005
San Mateo CA
2004 BL GLI 6 SPD
Looks nice so far
3076R .63 A/R, Tapp Tuned, Maestro 7, Inlet Dynamics Intake Mani And Lots more...
2010 Plans- First Things First Get My Car Running Good Again, More Boost, Water-Meth, Cat 3658 Cams, Tubular Exhaust Manifold, And To Fix Lots Of Other Small Things. BoostinBejan
My GLI Build Thread
Haagendaz
5-11-2009
Lake Forest CA
2005 GLI R.I.P. Now 2006 GLI
 Re: Project BT stealth mode! »« »
this is gonna be a beast when its finished
coreyj
8-17-2006
Fastville TN
2003 VW JETTA 1.8T with a lowly 76mm sucking hole
here is a way to get around the mirror on a stick... put a belly pan back on the car. and maybe even extend it farther back on the sub frame to hide the massive turbo and such. then put factory engine covers on and be sneaky.
FS: Revo Stage 3 software 550cc file w/ cluster and key fob $300
Need a rebuilt AEB or small port cylinder head w/valve job and new guides? I can hook you up will ship anywhere.
SG85GTI
6-2-2007
San Bernardino Ca
85 gti, 98 gti
B is nutz, hes like the energizer bunny. once alllllll this is done, he'll prob tear it all up next summer and do something different... and every other weekend where ever he ends up he dgaf!
but I REALLY wanna c that tubular header come out bro that's going to be sweet.
» Return to 1.8T Engine Forum
