bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
 Cat Cams Chain Clearance Issue« »
On some CAT cams, there is a machining defect that prevents the cam chain from seating fully in the cam gear teeth because the side plate of the cam chain hits the cam. If yours are affected, you may wish to have it fixed. So far the only effect seems to be some noise-many affected sets have been in service for years with no reported issues.
This problem affects all 101 series cast 1.8T cams with adjustable chain sprockets. It DOES NOT affect 101 series 1.8T cast cams with pressed/pinned cam sprockets.
It also affects 100 series billet 1.8T cams.
If you don’t recall which cams you purchased, you will need to remove the valve cover to tell if your cams are affected. If the cams have adjustable chain gears on the back, your cams are affected.
If you believe you own a set of the affected cams please e-mail bobqzzi@cox.net for further instructions.
QED Power.Com
Stock and high performance 1.8T parts.
QED Engine Forum
Turbo VW.Com
carbide01
7-12-2003
Denver CO
EL CAPITAN with haldex!
 Re: Cat Cams Chain Clearance Issue (bobqzzi) »« »
Bob, never heard back from you on those head studs. LMK
ina "engineering"
Quote, originally posted by dubinsincuwereindiapers »
Im sorry Issam... But This is yet another retarded blanket statement; you really need to grow up and get over yourself.. And if you find it impossible to "grow" a bit of maturity.. Maybe you should just climb aboard a commercial jet, light your underwear on fire, and call it a day
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
Up
QED Power.Com
QED Engine Forum
Turbo VW.Com
VRT
12-7-2001
1990 Corrado haldex 2.1/20vT / 2003 jetta 1.8t APR 3
Good to know it won't cause any damage
Rob
Corrado awd 2.1/20V
http://media.corrado-club.ca/members_rides/vrt
2.1 block,Je,Pauter,,cat cams,cat valves springs,TT cam gear,cat retainers,GT35/40R Turbo,RMR intake,70mm TB
ATP manifold,1000cc injectors,Maestro7 ecu,tail wastegate,underdrive pulleys,tial blowoff,ND oil cooler a/w system,RMR fuel rail,Edelbrock fpr,AEBhead
crazyass713
12-27-2006
Westerly RI
2001 VW Golf GLS 1.8T 5-speed - 1998 Audi A4 2.0TQM
 FV-QR »« »
Thanks for this PSA Bob
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
CONTACT ME FOR INSTALL/FABRICATION/ANY PARTS YOU MAY NEED IN NEW ENGLAND
www.DoWerkTuning.com 1.401.525.1264
simon-says
10-20-2007
Brooklyn Oregon
76superrocco, 78rabbit, 80coupe, 80rocco, 84_4KQ, 89vanagon, 97_K2, 03TDI
 Re: FV-QR (crazyass713) »« »
I have 2 pairs that need to come your way then.
http://www.doublejmotorwerks.com
VW,AUDI,TDI. 5541 N.E. 122nd Street Suite 330 Portland,Ore. 503-253-0800
Authorized Premier C2 Software/Hardware- Dealer/Installer.
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
 Re: FV-QR (simon-says) »« »
Quote, originally posted by simon-says »
Please e-mail me
QED Power.Com
QED Engine Forum
Turbo VW.Com
rpm20vjetta
3-8-2009
Fairfield ct
2001 2.0 20v big turbo s364
 Re: FV-QR (bobqzzi) »« »
hey Bob my cams came with problem , i will send to you soon , PETER gonna take out for me tks for now !!! Rafael
2.0 20V S364 http://www.ctsturbo.com http://www.unitronic.ca 538whp at 28psi !! lote more to come
NOLA_VDubber
5-23-2007
NOLA
2005 Jetta GLI
 Re: FV-QR (rpm20vjetta) »« »
black and gold super bowl
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
UP
QED Power.Com
QED Engine Forum
Turbo VW.Com
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
up
QED Power.Com
QED Engine Forum
Turbo VW.Com
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
Dailey Bump
QED Power.Com
QED Engine Forum
Turbo VW.Com
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
up
QED Power.Com
QED Engine Forum
Turbo VW.Com
20aeman
6-7-2006
kiss my ass
when are these going to start being marked for easier installation?
Quote, originally posted by Rukh »
Listen up, buddy, I've had both - I eat plain bagels with cream cheese all the time, and I know people who've brought me onion bagels to try. I've toasted them both. I've even had poppy seed bagels and bagels and lox with capers. I'll pit your onion bagel against my plain bagel with cream cheese any time anywhere, just meet me halfway.
bobqzzi
9-24-2003
Coventry RI
2001 VW Jetta 1.8T
 Re: (20aeman) »« »
Quote, originally posted by 20aeman »
I supply them with marks.
QED Power.Com
QED Engine Forum
Turbo VW.Com
screwball
12-10-2001
Fifty Trim
 FV-QR »« »
FS: Used Full Set of ECS Lightweight Underdrive Pulleys
BoostinBejan
4-12-2009
Cal Poly Pomona CA
Stealth GT3076R'd, Honda F4i CBR600
 Re: FV-QR (screwball) »« »
So for the DIYers, 1mm needs to be turned down, and can do it with the sprockets still on the cams?
Vegeta Gti
2-12-2003
konoha village Hawaii
84 jetta GLi [HGM] BT1.8T, 2008 stolen stereo,06 M3 SMG
 Re: FV-QR (BoostinBejan) »« »
bummp
CARPE DIEM
:HOMEGROWNMOTORSPORTS: STS Performance
• #13 The Dead Rabbits • #13 MKI from birth till death
transient_analysis
1-28-2003
Southern CA
[silverstone]
Quote, originally posted by BoostinBejan »
I had mine turned down to the same diameter as the outside ring. The machine shop did so with the gear still on, and I think that's probably smart (gives you a gauge of where to stop).
.. bum watching at its finest
» Return to 1.8T Engine Forum
