Afazz
2-10-2002
Lower Burrell PA
1994 Jetta, 2008 Rabbit
 4 struts, 17 inches, 2 switches: my built thread« »
I finally got the suspension finished last week, just in time for H2O! I met so many people, everyone was super friendly… too many names to list, but it was nice to meet you all! I got some positive feedback at the show, thanks all for the kind words I wanted to show some of the build pictures with a little explanation of how I did things.
I’ve been working on this for the better part of 2 years, with the metalwork starting back in ~May 2008. I decided to keep it quiet, mainly because there isn’t much worse than a well publicized failure! The whole concept was pretty wild, and the project as a whole was so large I wasn’t sure it would ever be finished. I want to thank the few that knew about it, both for the advice and motivation and for helping keep it low key. I also want to apologize to the people I blew off when they asked about it, I wanted to keep the hype and BS to a minimum and just wait until it was finished to show everything.
Before:
So back in ~November 2007, a month after H2O sporting a fresh respray, I decided it needed to be lower. I had the lowest coils on the market wound to the last thread, so I needed to do something drastic. I took a bunch of measurements, and decided that using Universal Air Aerosports over my Ultra Lows simply wouldn’t be low enough. I looked into Easy Street fabrication kits, called and spoke with them, and decided they would probably lay the car on the frame with a 205-40-16. Then I decided I wanted to lay subframe on 17s.
Keep in mind this was before Bagyard had sold anything stateside; before Mason-Tech had their air kits available; before the Air suspension forum. After narrowing my options and making dozens of phone calls, it came down to two choices; both would be custom designed by myself. One was an airbag setup using a Universal Air Airhouse bag with custom upper and lower plates, and either a shortened Koni strut or a shortened Bilstein Sport. The other was a hydraulic lift coilover I had been thinking about for years, similar to those used in RUF cars, the Bugatti Veyron, some Lamborghinis, and similar to the weight jackers used in circle track racing. Both would be a bit pricey, both would take some time to design and make, but the hydraulic coilover had some distinct advantages. First, it would use a coil spring and shock, which offers predictable and familiar ride and handling characteristics. It would also be placed beside the tire, just like a coilover, allowing me to go super low. The air setup would have to go above the tire, yet below the hood, and even after some careful measurements I wasn’t sure I could lay subframe on a 205/40/17 and still have a bag above the tire. So I decided to go hydraulic. I began design in November 2007.
I fell in love with the Artec PA wheels the first time I saw them in Dubmeister’s PVW ad, so I had a set ordered in January 2008. They came in 5 days after order, and I couldn’t have been happier with the process! The dollar/pound exchange was favorable at the time, so the price wasn’t too bad for a set of 17x8 in 4x100 bolt pattern.
EDIT:
Pages 1-9: build
Page 9: pictures of the finished car
Page 11: 3D models of suspension parts with explaination, more pics
Page 12: more pictures
Alright enough talk, on to the pics! I didn’t have my own camera until Christmas ’08, so I apologize for sparse documentation at the beginning.
Sometime around Feb 2008, I did a test-fit of the new 17s and tires. I pulled the upper shock mounts and bolted everything up to see how much I could tuck before having to cut into the unibody. The answer? Not enough!!! Plasma cutter on order…
Sometime around April or May 2008, I got some of the strut pieces back from the machine shop. More on this later!
May 2008:
I got my Millermatic DVI2 MIG welder and Thermal Dynamics Cutmaster 39 Plasma Cutter.
Moved into my new garage! After 5 months of searching, I found a place to rent about 20 minutes from my house. 400 square feet, no water, the lighting of a dungeon, but the price was right and it was available! Where shall I sign?
Papa Fazz wiring in the 220v welder plug:
Locked the door behind it… no turning back now!
The car in my new laboratory
Modified by Afazz at 7:43 AM 10-23-2009
Afazz
2-10-2002
Lower Burrell PA
 Re: 4 struts, 17 inches, 2 switches: my built thread (Afazz) »« »
First order of business: C-notch the passenger side frame with plenty of clearance. This was a problem even on coils, so I needed to get that out of the way first.
P.S. don’t mind the craptacular welds, I was a but rusty! I ground most of them off later and re-welded the notch.
Then the control arm bottomed out.
I needed balljoint extenders, but didn’t have the cash right then so I fabbed some up for test-fit purposes. I never drove on these, and wouldn’t recommend it
I know everyone is jealous of my welding skills at this point But don’t worry, I eventually learned to make the metal stick together!
Another test fit; not low enough. Metal must move.
Out with the dash!
So I started cutting, a little bit at a time, all while checking clearances. I wanted to make the tubs large enough to lay subframe on an 18” setup, but just barely large enough to avoid getting sloppy and deleting unnecessary metal.
That’s me manning the jack
I threw the fender back on and did another test-fit, and it looked about low enough now. I could then move on to cleaning up the cuts and welding in the new tubs.
I bought some trailer fenders from Ebay to use as wheel tubs:
Then I cleaned up the cuts in the passenger side a little bit
The cabin filter was now in the way… delete it!
Made a big mess of shat in the garage;
Once the passenger side wheel was in place, and the hole cut through the firewall, the recirculation flap of the HVAC control box was hitting the tire. My windows roll down… delete that shiz!
HVAC box, before:
HVAC box, after!
Skip a few steps, thanks to lack of camera, and the passenger side wheel tub is done and in primer. This was mid-July ’08.
The wheel ended up pretty centered in the new tub:
interior view:
This hole got filled later
I also got myself a crappy little lathe on the cheap
Sandlock
8-9-2001
Fresh Prince MD
brilliant.
all day, every day - junglists unite
BBS never let you down.
8100+280=
rat-stylz for the cure
Afazz
2-10-2002
Lower Burrell PA
A while back, the car was involved in a bit of a hit-and-run and the drivers front corner was a bit bent. http://forums.vwvortex.com/zerothread?id=3210397 This little gem was hidden under my shiny bodywork. I knew about it, but I’m a hack. But I decided to fix it
I chopped this section out of a friendly car at the junkyard for $20. I almost lost it, apparently some crackhead cruised by my parents house while it was in the driveway… I had to leave the clip there for 20 minutes to return the pickup truck I borrowed. Luckily my brother and his girlfriend (yes she’s super hot, sorry no pics) were in the swimming pool and yelled at the guy. He dropped my unibody corner and ran away. Lucky!
Welded it in, with the help of my Mitchell body dimensions book from ebay.
Then I busted out the drivers side tub much quicker now that I knew what I was doing. Through the whole process, I didn’t even remove the fuse box and wiring! I had to be super careful, and it worked out pretty well. I am probably going to redo all this sometime this winter, I would like to do the bay properly and the front tub work is no longer up to my standards.
They’re pretty even, but hard to capture in pics. Especially in a Dungeon with a crappy camera and zero photography skills.
Installed real PMW balljoint extenders, since my welded deals weren’t the best
Threw on a fender for a test fit:
August 29, 2008, frame is on the floor with 205/40/17. Huge milestone!
Then I got everything in paint and undercoating. This will probably all be redone since I would like to redo the bay in the future, but the suspension is first priority.
3M brushable seam sealer, 3M undercoating, SEM black for the painted interior sections.
Right by the fuse box. Sketchy
new clip welded in
I just bonded and sealed a plate over the cabin filter, in case I wanted to open it back up in the future I wouldn’t have to cut through welds.
This is the tub intersecting the drivers side raintray. This was difficult to weld, really difficult to seam seal, and difficult to photograph. It looks pretty sloppy here, but it turned out OK in person.
Pile of leftover VW unibody steel:
I fat-fingered the part number for the cone filter and ordered the wrong one. It didn’t rev too good with this little guy on there!
Hey look, a decent weld! Quick get a picture!
Here are the controls for the recirculation flap, including the mystery vacuum reservoir above the drivers side tire. All gone.
I had to plug some vacuum hose barbs when I deleted all that stuff
Got the dash back in on September 8, 2008
That’s all I feel like typing for this evening, more tomorrow night.
moder15
8-11-2009
603
JKSWGN
dammnnn afazz!
Primer Grey All Day.
Seacoast Dub Scene
Wagen Militia.blog
joeslow
9-22-2007
queens, ny
a dusty sparkshow a green machine and a black widow
shut your mouth when you're talking to me
.daily driven.
low'n'slow
FS: mkIII PARTS. lots and lots of parts!
jwill187
4-5-2006
clearwater fl
96 tan sedan
 Re: (Sandlock) »« »
thats low done proper
THEY SAY THE END IS COMIN, IM GONNA WAIT UP FOR IT
DJR once put it, "I think they came from the factory with rust."
Quote, originally posted by X37 »
The other night before my gf went to bed we had sex. While inside of her I whispered in her ear:"In before the lock".
b-VW
2-16-2007
Kenosha WI
98 GTI 2.0
 Re: (jwill187) »« »
you are my god.
PSN: b_vw888
MKX Videos United
Flickr
rlsib16
5-30-2002
saloon. specialized.
ny state of mind
 Re: (jwill187) »« »
you're a madman dude. seriously. stepping up the game big time.
­­¡8380 Labs!
I Adaptec Speedware
pennswoods
8-15-2009
pea aye
1.8, 2.0, 2.8
wow awesome work homey
-Jay Vaughn (no relation to Vince Vaughn)
:: b4 vr6 partout pa ::
Fallsjetta
6-23-2007
The Falls WI
'88 16v with a trunk
 FV-QR »« »
where's that "low done right" thread? this belongs in there
[( )]============GLI[( )]
Lower Standards
Flickr
98DUB
2-21-2003
Lowlife
 FV-QR »« »
damn dude, thats some intense work to truely lay frame. Nice work
WAZZU
The Coupe The Grocery Getter
My Coupe 16v Build
MRosier
9-17-2006
Finksburg MD
1997
 Re: FV-QR (Fallsjetta) »« »
nice seeing you/talking to you on sunday. your work is awesome.
so before you did the hydros you got your car to lay subframe with just the h&r's and 'some' metal work? did you ever notch the frame for the tie rods?
redskinsboy326
10-24-2007
Indianapolis IN
96 2.0
crazy work.
paul wall
3-17-2008
Maryland
brings back some memories dude.
vwjettalikewhoa
9-3-2003
01002 MA
16v/ABA MK3 and a scene MK2
ridiculously awesome.
Quote, originally posted by vwjettalikewhoa »
i thought we were doing pretty good for the MKIII forum
Quote, originally posted by King »
yeah.....no.
4690
10-26-2007
46214
dusty glx & black 2.0
my jaw was on the floor the whole time. i got wind that you had something big planned, but never knew what it was. amazing, and i'm truly jealous i was out of the loop.
amazing dude.
cure : stickers :
flickr of random vortex pictures. CLICK & CONTRIBUTE
Quote, originally posted by Vigo The Carpathian »
Paul, I think you mean chloroform. Unless you wanted to plant a garden with her.
akke41
6-5-2003
412/717/301
ginster dos
 Re: 4 struts, 17 inches, 2 switches: my built thread (vwjettalikewhoa) »« »
one of the coolest/most hardcore things ive seen ever.
8380! New Designs In Stock!
an' den wuttttttttt
WTB: driver's side fender and driver's side door. Color doesn't matter.
Afazz
2-10-2002
Lower Burrell PA
 Re: FV-QR (MRosier) »« »
Quote, originally posted by MRosier »
Nice talking to you too man, I love the new wheels on your ride
The pics of it laying frame up there don't have strut mounts in. I don't believe the H&Rs are capable of laying frame, although I never really tried. The tie rods are installed in that pic, but flipped, and resting on the unibody. I eventually notched them, and built my own struts that go lower than the H&Rs. I will get to that probably tomorrow or so, this is only like the first 5% of the work done haha
4690
10-26-2007
46214
 Re: FV-QR (Afazz) »« »
insane.
edit
looks like you''ll have to get this done again
Modified by 4690 at 1:27 AM 9-29-2009
cure : stickers :
DEV!N
7-21-2007
MD/DC
Mk3, GF's Evo 9
 Re: FV-QR (4690) »« »
Dude once I get a daily, Im gonna try my hand at the independent rear suspension. Not tryna go any lower just want the improved handling, alignment options.
BTW you a genius.
Skate-or-Die Cabin.Krew thenicest
HELLAFAST
Uncalm
6-11-2002
Deutschburg MD
DEad + MkFTL
 Re: 4 struts, 17 inches, 2 switches: my built thread (akke41) »« »
I thought it looked way low this weekend, but I wasn't expecting all this.
Awesome work dude.
PTAC!
CBerger
9-15-2004
Farmington CT
Nice meeting you at getlow house sunday night. Super impressed by the time and work and it paid off, looks great
96 GTI VR6 getlow
Porsche D90's for sale: http://forums.vwvortex.com/zerothread?id=4618086
MasterAres
8-26-2006
Central 73two NJ
your so awesome. so how low would your car be with 15's lol
1995 Sequoia Green automatic jetta 3
1996 Black 5-speed VR6 Jetta
Check out my FS/FT thread:
http://forums.vwvortex.com/zerothread?id=4368750
Complete 1994 GTI Partout, T-Red, Central NJ!!
http://forums.vwvortex.com/zerothread?id=4585411
hyphytrain203
6-8-2003
203/516
bravo man
def looking forward to see more of the process
GAIN 3/4" DROP FROM THESE MODIFIED MKII/MKIII STRUT MOUNTS
4x100 15x6 BBS RS's
.sanya.
8-15-2004
sacramento ca
98 golf vrsc, 98 gti 2.0, 95 jetta vr6, 95 525
you know how i feel about you anthony
.the shop.
openroadtuning
I Adaptec Speedware
reynolds9000
10-16-2003
Huntsville AL
Todays your day baby, whatchagonnado?
andyztoy
1-21-2006
Whitby Ont
1992 jetta aaz 1996 Gti-Sold 1993 Jetta-Sold 04 636 Ninja 03 EX-500 Ninja-Sold
 Re: (.sanya.) »« »
seen the car at H20 chatted with u for a sec,
dig it
Gti - My toy
mk2 td build
04 636
For amazing quality Powdercoating for a fair price contact,
Bright Side Powdercoating ryan@brightsidecoatings.com 905 449 7910
SKIDMRK
9-15-2001
SWASS, WA
03 B6 - 80 Caddy
 Re: »« »
this car and thread make me very happy.
job well done!
epitome - Like McCormick's we're seasoned......
dreamwerks - achtuning - incident catering services - ok's cascade company
rocklizzard91
12-17-2007
Bonney Lake WA
1996 Jetta Trek (16V - MS-II) 1988 Jetta GLI [in pieces] (ABA)
 Re: (.sanya.) »« »
wow!
nice work!
what is control arm rear bushing/bearing? looks nice!
best kanye referance on vortex
Quote, originally posted by Fallsjetta »
you ****in' newb, imma let you finish, but rocklizzard had one of the best sets of wheels of all time!
Quote, originally posted by b-VW »
[oil pan] its kinda like a kidney. its nice to have, but the extra cash for the strip club feels so much better.
Dubsomniac. Vortex keeps me awake at night.
tageddreams
11-3-2008
Rochester Ny
1998 wolfsburg jetta
 Re: (rocklizzard91) »« »
woahhh, i never knew this amount of work went into it, i knew alot had to go in, but never even introduced myself to you, drove the black jetta on white trispokes at h20
you sir are my new inspiration for low, and what im trying to acheive for next summer, just never knew so much cutting was needed, i got notching done on my car as it sits at quarter height with the subframe....
but anyways, loved how you draged the car everytime i saw it move this weekend, like a true trooper!!! the limbo event was crazy as well watching you barrel through with no worrys!
once again very proper
"And after all of this I am amazed, That I am cursed far more than I am praised"
Roc city
TUNA CREW
Dubbin in the ROC
Rocdubs.com
V.R.6.i.c.k
10-31-2004
T.Dot On
2 GTi's, Both VR's
W.O.W....amazing work man!!
Thank you for sharing..please keep the pics and explanations coming!
98 328ic convertible
98 GTi VR6
86 GTi VR6 -- sold
\X/
SLAMATION NATION...wesa
MKIII's KING
5-3-2004
penn
MKIII & Son
I GOT THAT! I GOT THAT! I GOT THAT! oh.
priceless.
club.broke.status - eSTABLISHED.
big bentley
6-6-2001
Frederick MD
 Re: (V.R.6.i.c.k) »« »
nicely done.
crazy insane insane crazy bbs rs's
I've got a Polo that I want to trade you. http://ecodeparts.blogspot.com/
evolveVW
11-11-2000
Weedsport NY
1994 Golf GL 1.8t, 1999 Golf TDI. Formerly 91 Passat Wagon, 81 Rabbit Diesel
 Re: (big bentley) »« »
I wish I had actually checked your car out in detail since it was in my parking lot all weekend, awesome fab work. Way to have the guts to do something like this and pull it off well.
Vinnie/94 Golf GL RS Edition 1.8t Earning its RS pedigree..
99 Golf TDI
www.fastdubs.org-When In Doubt, Puck It!
» Return to Golf III & Jetta III
