l88m22vette
3-1-2006
Chicagoland IL
Let the parts rain down (except the engine block)
 Maestro 7 Tuning: FAQ, DIY, hard data, and advice thread« »
I know there is already a Maestro thread as posted by AL@pagparts.com (Arnold) but that is 15pgs. worth of announcements, information, and armchair racing (not in that order), so I would like to have a dedicated user thread for specific information on self-flashing, tuning, logging, and other Eurodyne/Maestro experiences. Please post up anything that would help other Maestro users with their set-up (*cough* settings/hardware).
I am speaking as the owner of a 2003 BEA 225TT, which means ko4-022/3, VVT, and wideband o2 stock with 72k; I have a turboback, TIP, and Eurodyne Stg.1 flashtune (Tapp file necessary for any of this to work, obviously). All the specific info I included (the graphs/info shots) were from a full-throttle pull after shifting into third gear; it was about 50% humidity and 55°F.
The steps to being tuned:
- Get the Powertap unit and cord out of the box (smaller that I thought, not a bad thing); you must have it plugged in to use either the Maestro or Flash programs; the dongle is actually two pieces, it uses a proprietary printer USB cable to connect the cable to your computer. You have to install the driver file before you install any other software. You will also probably have to do a Windows update, that killed 45 mins. on my end
- You then e-mail Chris, and get your UN/PW
- Sign into Eurodyne to download the necessary software (which includes the Powertap driver). You have to download three programs, as each does a different thing:
1. Maestro 7 – tuning suite, allows adjustment of all tune settings with 3D maps (adjustment through numerical settings, maps non-adjustable as of 10.19.2009)
--- Diagnostics (readiness)
--- Boost
--- Fuel
--- Spark
--- calculator
2. Eurodyne Flash – actual flashing program (first picture below)
--- Read + Write the ECU, get ECU info
--- “Log Data” takes you to a separate data logging screen, displays real-time data on many parameters (second picture below)
--- “Read settings” is sort of deceiving, it actually opens another separate screen which is basically V-tune/Lemmiwinks/Unisettings, though on mine boost isn’t really adjustable, as it is currently at 100% but I only maybe spike at 21psi and taper to 19psi.
3. Log Viewer - allows you to analyze the entire log file; you can zoom to a specific section, print the graph, or save it as an image.
- Once you get the software installed and working, you have to Read ECU with the flash program; I would enable hi-speed since my connection crapped out with it unchecked (probably car dependant). Once you read/save the file, you’ll e-mail this to Chris, and he will send you a tuned file. Barring any problems, you will be able to simply download the file, hook up your computer and flash your ECU. Here is a visual sequence:
Action pic:
Reading the ECU:
(…a few days/emails pass…)
Flashing the ECU:
Time to play!!
I will amend this thread if I or any of you guys give me a simple run-down off the specific features, and what each means and does; I’m a n00b and I know someone else can probably just rattle off a simple explanation for each.
I really like the extra power from my flashtune but I’m excited to dig into my tuning; my only complaints are about the logging window; it is good but not great, although you can save the image I know that future updates are going to come for the software. A few suggestions: I would like the log graph to be available in a separate, full window, I'd like to be able to pick my own line/background colors, labels for most/all the variables in the Log Viewer window would help, and being able to define the values for each axis in the graph (such as psi, *F, CFM, a/f) would kick ass
Maestro guys, please contribute to this thread so we can compile a ton of info to help each other out, and I hope this is informative for anyone thinking about getting the Maestro 7 Here is a picture of a full-throttle 3rd gear run, I can get other info graphed if people want…
Modified by l88m22vette at 6:00 PM 10-21-2009
Audi TT mkI FAQ Coming eventually: project 2.sloTTq www.audifreaks.com
16plus4v
5-3-2006
T.O/ London ON
A4/S366/1.9L/6spd/MaEstro7
 Re: Maestro 7 Tuning: FAQ, DIY, hard data, and advice thread (l88m22vette) »« »
Geez took you long enough
My 2010 Build Thread
INA Engineering
Eurodyne
Auto Select Tuning - GTA's ONLY Eurodyne Dealer
dubinsincuwereindiapers
1-16-2008
Allentown PA P A
2001 jetta 1.8t
 Re: Maestro 7 Tuning: FAQ, DIY, hard data, and advice thread (16plus4v) »« »
Good Job
Quote, originally posted by 20aeman »
That's an effective way of burning money....probably more effective than having a high dollar prostitute (who gets paid by the hour) slowly marinate a bald eagle (seasoned in cocaine of course) over a diamond encrusted bbq that uses 100 dollar bills instead of coal.
VRT
12-7-2001
1990 Corrado haldex 2.1/20vT / 2003 jetta 1.8t APR 3
I recommend a full laptop not a net book. Difficult to see the full screen.
the icons on the maestro screen will open all related windows to make the appropriate changes
Modified by VRT at 11:29 PM 10-19-2009
Modified by VRT at 11:42 AM 10-20-2009
Rob
Corrado awd 2.1/20V
http://media.corrado-club.ca/members_rides/vrt
2.1 block,Je,Pauter,,cat cams,cat valves springs,TT cam gear,cat retainers,GT35/40R Turbo,RMR intake,70mm TB
ATP manifold,1000cc injectors,Maestro7 ecu,tail wastegate,underdrive pulleys,tial blowoff,ND oil cooler a/w system,RMR fuel rail,Edelbrock fpr,AEBhead
halchka99
4-18-2002
Glendale CA
Turbo
 FV-QR »« »
looks nice, i will also be contributing to this thread once mine comes in
Build
-=FS: Powder coated valve covers=-
FS: Big Injector Driver Box
16plus4v
5-3-2006
T.O/ London ON
 Re: FV-QR (halchka99) »« »
Quote, originally posted by halchka99 »
que ? wtf.. no more SM4 ?
INA Engineering
Eurodyne
halchka99
4-18-2002
Glendale CA
Turbo
 FV-QR »« »
i had uni before. just sold that and ordered this
Build
16plus4v
5-3-2006
T.O/ London ON
Oh ya.. brain fart, lol thinking of someone else. Good sell btw
INA Engineering
Eurodyne
Vegeta Gti
2-12-2003
konoha village Hawaii
84 jetta GLi [HGM] BT1.8T, 2008 stolen stereo,06 M3 SMG
 Re: FV-QR (16plus4v) »« »
*** that is delicious
CARPE DIEM
:HOMEGROWNMOTORSPORTS: STS Performance
• #13 The Dead Rabbits • #13 MKI from birth till death
VRT
12-7-2001
 Re: FV-QR (Vegeta Gti) »« »
I found the info on this screen to be interpret differently.
I believe that KEY OFF ENGINE OFF and KEY ON ENGINE OFF would be a better description
I know it caught me a few times when trying to load files
Modified by VRT at 6:08 PM 10-20-2009
Rob
Corrado awd 2.1/20V
McBee
8-11-2006
20v 1.8T
 Re: FV-QR (VRT) »« »
Just what I was looking for
S.A.B.
DIY: Protect Ignition Coil Harness | DIY: Retrofit | DIY: Dual Turns | Design
1-16-2008
Allentown PA P A
2001 jetta 1.8t
 Re: FV-QR (McBee) »« »
Wait a minute.. No access to fuel, timing, boost, and readiness?? That's a bit dissapointing..
VRT
12-7-2001
 Re: FV-QR (dubinsincuwereindiapers) »« »
You obviously can't read
Rob
Corrado awd 2.1/20V
Lou_Y2mK5
4-6-2008
APK FL
2000 Audi A4 Quattro - 2.0L GT30R - 4 Port Water/Meth Injection
Thank you!!!
2000 Audi A4 2.0TQM / 2001.5 Wideband ME7 Conversion / JE 83mm 8.5:1 / ESS Rods / ESS 4340 Billet 98.2mm Crankshaft / AEB Ported Intake side / Pagparts Logger Turbo Manifold / New South Power Intake Gasket / Supertech Valve Springs & Titanium Retainers / Supertech Single Groove Intake & Inconel Exhaust Valves / Autotech Intake Camshaft / GT30R .83ar / DO WAI / Eurodyne 1000cc Maestro7
16plus4v
5-3-2006
T.O/ London ON
Quote, originally posted by dubinsincuwereindiapers »
It's all there.
INA Engineering
Eurodyne
1-16-2008
Allentown PA P A
2001 jetta 1.8t
Quote, originally posted by VRT »
Actually I can... He states that as of 10/19/2009 those maps are non adjustable..
VRT
12-7-2001
I have the program that is not the case
you missunderstand the graph map is not adjustable but the Number map makes all the changes to the graph map
Modified by VRT at 7:26 PM 10-20-2009
Rob
Corrado awd 2.1/20V
Stinky Binky
10-15-2007
Roswell ga
BMP GLI
 FV-QR »« »
I believe you can change the maps, from this picture it appears he his altering the boost duty map, he changes the numerical value which then translates to the visual 3D map. I believe he says the 3D maps are adjustable through changing the numerical data in the table and not through actually grabbing points on the graph and moving them around(I could be wrong thought).
Quote, originally posted by l88m22vette »
1-16-2008
Allentown PA P A
2001 jetta 1.8t
 Re: FV-QR (Stinky Binky) »« »
Ahh.. I stand corrected.. The wording led me to believe otherwise..
Lou_Y2mK5
4-6-2008
APK FL
This thread should be sticky! Revolutionary!
l88m22vette
3-1-2006
Chicagoland IL
 Re: Maestro 7 Tuning: FAQ, DIY, hard data, and advice thread (VRT) »« »
Quote, originally posted by 16plus4v »
yea, I tune in Maestro on my desktop, then transfer files to/from my netbook for flashing and logging. Even if you could see on the netbook screen having an actual workstation is much easier...
Quote, originally posted by Stinky Binky »
There is basic adjustment through "Read Settings" in Flash or with a lot of detail in Maestro
boosted b5
10-31-2004
city state
flintstone edition mk4 gti
if i got forth with anymore mods to my mk4, Maestro 7 is on the "to get" list
'02 GTi L041 - garage mascot
'91 Jetta LZ3L - Re-birth
on the hunt for a LZ6L 00/01 A4 1.8TQ
http://www.pagparts.com
ethorman
6-18-2006
Lawton OK
02 Audi TT 225
Awesome Job, deffinatly STICKY worthy!
2002 Audi TT 225 *Soon to come 450awhp* 2008cc 10:1cr
HOLSET H1E BUILD
dlsolo
9-5-2004
sanford nc
04.5 VW Jetta GLI PG
 FV-QR »« »
Quote, originally posted by ethorman »
x2
She ain't stock!
This is Betsy
uroFixx: Feed The Addiction
Elite Dubs
Issam Abed
All Over
'91 Audi 80 2.0T
 Re: (ethorman) »« »
CAN'T
Great Job Eric,
I will be contributing shortly.
Issam N. Abed
R&D, INA Engineering performance solutions.
INA Engineering.Com
ethorman
6-18-2006
Lawton OK
02 Audi TT 225
 Re: (Issam Abed) »« »
FAQ worthy then?
HOLSET H1E BUILD
16plus4v
5-3-2006
T.O/ London ON
 Re: (ethorman) »« »
FAQ worthy then?
Absolutely.
INA Engineering
Eurodyne
DarkSideGTI
8-11-2001
SL,UT
04 DBP R32T
 Re: (16plus4v) »« »
Make sure you don't accidentally kick the cable while it is writing to the ecu either.
When is this going to be available for other ME7 cars? Like maybe the R32?
//Nick
DBP .:R32T
IntegratedEngineering - Bulletproof your engine.
WTB Golf IV hatch any color will do!
16plus4v
5-3-2006
T.O/ London ON
 Re: (DarkSideGTI) »« »
^^ Very soon.
INA Engineering
Eurodyne
sound-speed-style
10-21-2009
Centralia Wa
Silver 2001.5 Audi A4 1.8TQMS
Got a couple of questions i tried to email their website but im sure they have tons of emails and work thats takes priority so I turn to you guys for help :>
Back ground:
1 my dog (105lb boxer) stepped on my laptop and cracked the screen, still works but i gotta manuever the windows to see stuff lol-myfualt leaving it on the ground in a corner i guess
2 I am planing for going for 450-500awhp later and want to do as many mods now that will get me power or show difference now that i wont have to rebuy later
Question 1
If i get the software now and load it onto my laptop to use on my car... when i get a new laptop can i load it to my new one
question 2
If i get the software and update my car so it is better now, is it free to get another map when i get my exhaust and DV
question 3
how much is it to upgrade the tune/map when i go BAT?
I really appreciate all the help
Silver 2001.5 A4 1.8TQMS
15% Tint, Custom CF Boser Hood, Kamei Grill, CC Mod,
Upcoming: Chip, Exhaust, Intake, DV, Shifting Upgrade Kit, and RS4 Grill.
blackedoutaudi
7-8-2008
fl
01 a4 1.8tQm
 Re: (sound-speed-style) »« »
how much does it cost for this thingy magingy
sound-speed-style
10-21-2009
Centralia Wa
 Re: (blackedoutaudi) »« »
for the Maestro Suite 7 its $915
16plus4v
5-3-2006
T.O/ London ON
Quote, originally posted by sound-speed-style »
Back ground:
Question 1
Yes it's simply a software download off of Eurodyne's website. Chris gives you a log in password for the download
question 2
Yes, you simply flash the file according to your setup.
question 3
The cost for Maestro is a one tme charge. $915 and you won't pay anything to switch files.
INA Engineering
Eurodyne
Wolk's Wagon
9-27-2000
Houston Tx
Any kind of MAF scaling features?
'01 225TT Coupe with 400whp
'08 R32
sound-speed-style
10-21-2009
Centralia Wa
awesome that helps alot means im ordering it friday when i get my check! Its insane that they will just keep sending you free maps as you upgrade... just goes to show how much more CTapp ROCKS over all competitors
First  1 2 3 4 5 6 7 8 9 >  Last
» Return to 1.8T Engine Forum
