My Profile | Active Users | Help | Search | Google Search
rs4-380
12-12-2000
Maine
 new owner (2000 avant)« »
Picked up this 160k mile 2000 avant this weekend. It has some things that need attention, but seems to be pretty solid mechanically (and it's loaded to the gills). It will be replacing my "trusty" volvo 240 as a winter/reliable/stock/anyone-can-drive car.
Just did a timing belt, water pump, serpentine belt, oil and filter today. Also cleaned up the headlights (one was pretty bad) and got rid of the orange reflectors in the headlights.
Will be keeping this thread as a record of it's trials and tribulations.
Dave - The Blog
09 S5
00 A6 Avant
87 EJ25 Powered Vanagon Syncro
80 Rabbit 034EFI 16v
rs4-380
12-12-2000
Maine
 Re: new owner (rs4-380) »« »
FYI I am looking for the following:
Passenger side rubber headlight seal (between headlight and body)
Spinning knob for navigation
Navigation CD for the northeast region
Driver and passenger side foglight modules in good shape
Driver side mirror glass
rear cupholder faces (2)
front ash tray face (wood)
front armrest lid (black leather)
rear cargo cover (black)
Modified by rs4-380 at 9:34 PM 10-27-2009
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
pulled the driver side front axle today to do an outer CV bolt. No big surprises, although I did need to go out a buy a 17mm allen head socket. Also found that one of the wheels is bent on the inside. I need to get new tires, so I have to decide what I want to do about it pretty soon, I may just mount the tire and deal with it later.
Dave - The Blog
09 S5
00 A6 Avant
Snowhere
7-26-2007
Buena Vista CO
1990 G60 Corrado, 2001 A6Q Avant
Nice, our avant is a great car and your should treat you well. I got some bent rims fixed at this place in CO. http://specwheelsdenver.com/ I would think you could find a similar service on the east coast.
How tough is it to remove the orange blinkers? I wouldn't mind doing the same thing as it would be a cheap mod to do. I need to get some winter rims right now for the A6, so for today and tomorrow, I will take my truck as it has snow tires on it. I still took the A6 around my block, power sliding in the snow with all seasons on, and she was easy to recover from a slide. Very predictable behaivor even with the wrong tires for the conditions on her. Way better then our Outback was. You should enjoy the avant, not a powerhouse but not terrible by any means.
rs4-380
12-12-2000
Maine
 Re: new owner (Snowhere) »« »
Quote, originally posted by Snowhere »
two ways to do it. One is to pull the lens from the housing. To do this you need to heat the sealant and peel the two apart, some people put the lights in the oven for a bit (on low temp), i prefer to use a big halogen work light and just work my way around the unit heating. Once you get it open the amber reflector just pulls right out.
The other way is to drill a small hole in the top of the lens and use a small pick to dislodge the reflector, then working through the bulb hole, use some sort of snips to gradually break the reflector into small pieces so it falls out the bulb hole.
I actually used one method on one headlight and the other on the other one, the breaking method takes less time, but pulling the lens and just removing it is more straightforward (although somepeople balk at the idea of having to reseal their lights -doesn't bother me).
Anyway, today I pulled the driver side front axle in order to replace a cracked out CV boot. Everything went fine, in fact I was surprised to hear after the fact how many people had trouble with the upper pinch bolt -guess I was lucky on that one).
Also got some new snow tires and had them mounted. Went with dunlop wintersport 3ds. I had them on my old GTI and really like the compromise between snow traction and dry handling (I have found "grippier" tires like blizzak ws-50's too squirmy in the dry). I had them go ahead and mount the bent wheel, Put it on the back and it doesn't seem to be a big deal. Certainly the new tires make a big difference, the old tires were severely out of balance (according to the vibrations) and one had a nail in it.
Driving the car right now and everything seems to be fine. Still have more on my list though-
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
replaced the airbag control module today (mine had the 66535 code that means it's dead). Found a used module with the same exact part number in a junk yard in Tennessee via car-part.com. There were willing to sell the module by itself without the bags for 125 bucks. Used this very good link to get to it and replace it- http://forums.audiworld.com/sh...68977. Airbag light is now off and I am happy. Also took the time to clean all the interior pieces since I had it disassembled -all the crumbs and dust that gets in all the crevices and crannies. Fixed the mounting clips for both the mirror unit and the navigation panel so now they stay put and are flush (as well as the nav buttons now working).
Very happy with the car so far, both the a6 in general as well as the specific one I purchased. It's very comfortable and gets the job done, exactly what I wanted.
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
better picture.
Dave - The Blog
09 S5
00 A6 Avant
Donuts
2-23-2000
Norwalk CT
Quote, originally posted by rs4-380 »
I've gone the oven route on four sets of lights...two for B5s and two for C5s. 8 to 10 minutes at 250 degrees and the lens pops right off. I sat the unit on a piece of hardwood so it didn't come in contact with the metal rack. Same to assemble...place the lens back in position and loosely fastened with a rubber band..heat for 8 to 10 and then remove, compress and put the spring clips back on.
rs4-380
12-12-2000
Maine
 Re: new owner (Donuts) »« »
put in a blitzsafe ipod adapter today. nothing fancy, what I've used in the past. Works as intended.
Also replaced all the vacuum lines at the top of the manifold as the covering on the old ones was crumbling to dust.
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
changed the transmission fluid and filter yesterday. Wasn't that bad for under-the-car work. It only took about 5 liters, I will check it again next week.
Dave - The Blog
09 S5
00 A6 Avant
german-dub
10-20-2009
Berlin B
VW
are you rocking euro headlights ?? looks like that way in the 2nd pic.
rs4-380
12-12-2000
Maine
 Re: new owner (german-dub) »« »
Quote, originally posted by german-dub »
nope, pulled out the orange reflectors
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
I noticed when I changed the oil that there was a leak on the back side of the driver side head that was dripping onto the cat. This created a bunch of smoke after the oil change and you could also smell the burning oil sometimes just after startup.
I bought the whole valve cover gasket set from ecs tuning with the intention of doing everything, but when I got in there and saw it was coming from the cam plug and everything else (including the cam adjuster on the front of the head) looked fine, I ended up just replacing the valve cover gasket and that one cam plug, and didn't even touch the other side.
Everything looks good so far.
Dave - The Blog
09 S5
00 A6 Avant
jasonknezo
5-16-2002
Downingtown PA
Dinan S2 E46 M3, Hyundai Santa Fe
Any tranny issues with the mileage? have been considering a similar winter/all around transport. Cool thread.
I go to Dresden Auto Werks for auto repair, the free ginger ale, dry humor, and cigarette smoke.
rs4-380
12-12-2000
Maine
 Re: new owner (jasonknezo) »« »
Quote, originally posted by jasonknezo »
When I first got the car I thought something may be up, the transmission shifts fine but it seems to lag a little when starting from a stop, that is why I decided to change the fluid and filter. That being said, the old fluid looked fine, there was not excessive **** on the magnets, and the filter and fluid didn't really change anything. I think this may just be the way it drives, it also may be more of a consequence of a hesitant throttle tip-in (which makes you give it more gas, which makes engagement more abrupt).
I'm not terribly worried about it.
Dave - The Blog
09 S5
00 A6 Avant
ironmule
4-11-2008
tfalls wmass mass
A6 battlewagon- corrado g60 project
change out your pcv assembly, its probably clogged (very common) which also goes along with those gasket leak problems. unfortunately its a $70 hose assembly.
RIP Sgt Greg Belanger
rs4-380
12-12-2000
Maine
 Re: new owner (ironmule) »« »
Quote, originally posted by ironmule »
Yup, forgot to mention I checked out the breather hoses and the suction pump a couple weeks ago.
Dave - The Blog
09 S5
00 A6 Avant
zeroboy
9-3-2005
wa
Stuff
Nice car- you mind if I ask how much you paid?...I may be picking up a 99' A6 Avant this weekend. 160k on it, 2 owner car (to replace our 01' FWD Passat Variant). The A6 I'm considering Seems decent, loaded or couse- I have him down to $4500. I don't know..seems fair other than the mileage. But I'm not worried much with the V6.
Any advice on what to look for?
evil
rs4-380
12-12-2000
Maine
 Re: new owner (zeroboy) »« »
Personally I think that is a good deal. I spent a month or two observing market prices (at least up here in the northeast) and while there were cars in the 3000$ range, the needed immediate attention (ie not driveable, CEL's, torn to **** interior, etc). Cars with no problems seemed to be more around 6-7 grand, so something in the 4's that may need some minor stuff is something I would consider a good deal. That being said, I wouldn't expect a trouble free car (initially or in the long run) for that amount. While the engines are pretty bulletproof, these cars do have some minor issues they are known for, but all are pretty well known and straightforward to fix. Only thing I would be concerned about at that mileage is if the transmission was showing signs of issues.
FYI this car had 162k (and came with no service records) when I bought it, that did not deter me.
Dave - The Blog
09 S5
00 A6 Avant
zeroboy
9-3-2005
wa
Stuff
Thats good news. Its looks fine, he says it has a torn CV boot, missing a floor mat, a couple small scratches. Nothing to worry about-- I'll do the T.Belt service this spring if no records of it. Dont really know what I could see to know if the trans was decent on the spot: fluid? slipping? leaks?
just the obvious I guess.
Just curious? Whats the main difference from 99- 01 model?
Modified by zeroboy at 5:58 PM 12-11-2009
evil
rs4-380
12-12-2000
Maine
yup, if the tranny is slipping or crashing into gear.
There are very slight differences between the 99s and the other 2.8s (00 and 01) namely being the radio and corresponding center console design change, and the exclusion of the heated steering wheel after 99. The facelift and 3.0 didn't come until 2002.
Dave - The Blog
09 S5
00 A6 Avant
rs4-380
12-12-2000
Maine
The car came with an incorrect rear wiper, not sure what it is off, and it works fine, but it does not allow the stock cap to be used, which in turn (I imagine) caused the rear washer sprayer to break off. This in turn makes the washer fluid squirt straight out behind the car which wasn't really an issue until they started salting the roads.
I wasn't really sure how the whole thing went together, but I picked up a squirted nozzle at the dealer to see what I could figure out. It looked like the old nozzle had broken off and a good amount was still in the squirter tube. After drilling it out, the new one fit in fine and functions as intended. I am keeping in uninstalled until I can get the correct rear wiper and cap to protect it however.
Dave - The Blog
09 S5
00 A6 Avant
SchickQuattroB5
8-25-2008
Fairport NY
2000 Audi A4 Quattro 1.8T
Nice S5 you have tucked in the garage back there!
2000 Audi A4 1.8T Quattro 5-Speed
rs4-380
12-12-2000
Maine
 Re: new owner (SchickQuattroB5) »« »
Quote, originally posted by SchickQuattroB5 »
thanks
Took the avant down to southern connecticut last weekend, as I was pulling into the garage on the way home I noticed a pretty distinctive groaning/grinding noise. After checking under the hood it was definitely coming from the front of the engine. Monday I got it in the garage and got the whole front end off in order to get the accessory belt off. After doing that it became apparent that the bearings in the tensioner pulley were shot. Guess I should have replaced that when I did the timing belt a month ago, but I haven't seen many tensioner pulleys fail. In fact, i often just pop the seals off of them and regrease them, but I failed to do that this time around, and because it was already eating itself, I decided to replace the whole thing (which by the way they only sell as the whole tensioner assembly).
While in there I also came to a conclusion on my dead oil temperature gauge. I knew it was an issue with the sender, the question was were was the sender. I have heard to different sides of though, one being a basiic pinhead sensor on the block between the crank pulley and the ac compressor, and one being integrated into the level sensor in the oil pan. After a bunch of searching, no pin head sensor (or wiring for one) was found, and those pin head sensors are pretty much bombproof (while the level sensors are NOT) so at next oil change I will be replacing the sensor on the pan in hopes that cures my dead gauge.
Dave - The Blog
09 S5
00 A6 Avant
Jedidiah
1-8-2008
Rochester MI
B7 Audi A4 2.0T, 2006 300C SRT8
+1 for a great thread.
rs4-380
12-12-2000
Maine
 Re: new owner (Jedidiah) »« »
picked up a rear wiper, cap, and spray nozzle off a b5 passat I found at a local junkyard for 10 bucks. The "unfinished" look of no cap and no spray was bothering me. Didn't realize the interchange when until yesterday, granted passats are more prevalent in local yards. Returned the new sprayer (25 bucks) to the dealer. I'm happy, and one more thing off the list.
Dave - The Blog
09 S5
00 A6 Avant
» Return to A6 & S6 (C5)
Forum Jump
