PowerDubs
7-22-2001
NNJ
2004 R32 13.14@105.77 AllMotor
Increasing my rocker ratio | « » 10:51 PM 2-3-2010 | |
This is about to get interesting. Rocker ratio changes are very popular way to increase performance in many makes of cars when guys hot rod them.. even with VW, but from what I've seen, only air cooled. I can't say that I've ever seen anyone change the rocker ratio on a water cooled car yet. Not that I've looked very hard..
For several months now I have been talking with a couple engineers at Schaeffler about our rocker arms. The reason is that I want more than the 11mm lift that all the aftermarket cams have for the 24v VR6.
Today I was happy to receive the following email- "found one that MIGHT be beneficial to you and it has a slightly higher ratio. There is no guarantee that it will fit or operate successfully without running a full analysis on it. These calculations take weeks, unfortunately my boss wont let me do side jobs like that. Buy a set (or one) and try it out on the bench to see how things line up. Good luck! Let me know how it works"
Sounds like typical engineer disclaimers to me. They have the full specifications of both right in front of them, I'd imagine they would bother telling me about them if they didn't think they were going to work. I'm stoked!
The 'slightly higher' ratio he is talking about is roughly a 14% increase over stock. They should jump the lift on the Schrick cams from 11mm to a hair over 12.5mm. I can't find my old email file from Willy @ Supertech with the specs on the stock valve springs, but if I remember correctly somewhere around 12.5 was the coil bind limit on them. I should have that info again tomorrow when he responds again. Looks like I might need to change them out if this rocker is indeed functional in this application. I also sent an email to the Schrick engineer I converse with to see what his thoughts are just for fun. While these rockers would be a cheap way to gain power on any of the 24v regardless of cams or head, I am especially looking forward to them as my ported head is capable of decent peak CFM over stock. aprox .430 VS .490 with the stock rockers and these new ones..about a 15cfm gain intake side at peak lift. For those of you wanting to know more about changing rocker arm ratios, here is a quick page with a nice graph showing area under the curve. By opening and closing the valves at a faster rate, the engine flows more air for the same number of degrees of valve duration. It is for old American iron, but the concept is the same. http://www.pontiacstreetperfor....html
.:R PROJECTS- Intake manifold Higher ratio rocker arms Larger cams Ported head Bigger cats Rear TBD INFO- Injector Specs
DasTeknoViking
5-25-2008
Palatine IL
04 R32, 87 Golf GL 5 door.
Re: Increasing my rocker ratio (PowerDubs) » | « » 11:23 PM 2-3-2010 | |
Ran Comp Rockers on many V8s I've built...Interesting idea thats overseen by many in the import car game. Do they actually have a rocker arm that could be mounted in our heads ? What kind of price ??
Slampig
6-19-2008
wG, rI
MKlV Golf R
FV-QR » | « » 11:23 PM 2-3-2010 | |
wow, im liking this, excited to hear more info.im also curious on what this would cost also.
.:R32 LOA member#40 VWFiends
r32dub88
12-9-2007
Newton NH
MKIV BMP Golf
Re: Increasing my rocker ratio (PowerDubs) » | « » 11:32 PM 2-3-2010 | |
subscribed! very interested in this, i knew my P&P would come in handy later on. | Quote, originally posted by PowerDubs » | | I can't find my old email file from Willy @ Supertech with the specs on the stock valve springs, but if I remember correctly somewhere around 12.5 was the coil bind limit on them. I should have that info again tomorrow when he responds again. Looks like I might need to change them out if this rocker is indeed functional in this application. |
so even if springs are not required (which they may be) would they be recommended? also what about retainers? i would assume these rockers combined with this set would benefit significantly with a P&P head. correct? Specs: * 13.90mm max lift * Coil bind at 17mm * Rate 12.6lbs/mm
Modified by r32dub88 at 11:33 PM 2-3-2010
GSE - Granite State European R32 Network Euro Addiction| Quote, originally posted by Daemon42 » | | Make sure your friend changes out his blinker fluid and muffler bearings too. |
nkgneto
12-4-2004
Lombard IL
2004 VW R32 T Red/ Auto detailing, IM' me for more info
Re: Increasing my rocker ratio (r32dub88) » | « » 11:49 PM 2-3-2010 | |
Good read, interested in price also.
Become a Fan of "Automobile Day Spa" on Facebook!! "My Auto-Biography"
newcreation
11-23-2003
HBG PA
2004 All Motor R-C2 TUNED
FV-QR » | « » 6:15 AM 2-4-2010 | |
Nice Josh i'll have to did up my old info i had on doing this.If i can find it this was before i moved on my old computer i back everything on my moms computer at the time to save it.Hopefully she has it.I though of the same thing but i was also doing the rest of the head to
-James3.2 N/A people COSWORTH will make us a manifold with enough interest check it here http://forums.vwvortex.com/zer...53413 300BHP CAMMED R
Patryk@DouglasVW
6-29-2009
Summit NJ
2004 R32, 2006 Yamaha R6s, 1984 MB 190D
Re: FV-QR (newcreation) » | « » 6:27 AM 2-4-2010 | |
subscribed
New Jersey's Largest Authorized APR Distributor Douglas Volkswagen 491 Morris Ave. Summit, NJ 07901 parts 908-277-1100, service 908-277-3300
KoolTrix
2-6-2007
Baltimore MD
04 BMP R32
Re: FV-QR (Patryk@DouglasVW) » | « » 7:35 AM 2-4-2010 | |
subscribed
BMP | Cloth | Driver-Mod
billyVR6
5-8-2000
Tastes like plastic
Re: Increasing my rocker ratio (PowerDubs) » | « » 7:43 AM 2-4-2010 | |
| Quote, originally posted by PowerDubs » | | While these rockers would be a cheap way to gain power... |
How cheap? Last I priced out doing similar it was getting pretty expensive. | Quote, originally posted by PowerDubs » | | I also sent an email to the Schrick engineer... |
Schricks N/A cams for the 16v are 12mm/11mm and use stock valvetrain. The R32 and the 16v utilize the same rocker set up, springs, etc. I imagine you would at least be good up to 12mm lift. I was all about this after having my engine fora few months a seeing that cams might be a struggle. There is a gain to be had from this is there, but in stock form it is not as impressive as what you are going to see with you worked head. I plan on keeping the head stock for quite a while so I kept barking up the camshaft tree, found a solution and I am content to see what they do first. Here are HPR's AXW 16v numbers that I put into a chart, you can see that jumping from 11mm stock to 12mm aftermarket is minimal at this point. Headwork will most likely open the spread much more....
Looking forward to what comes from all of this.
*Powered by bolt ons, fueled by ego, and driven by a know it all. k&p performance - the race shop - race-craft fabrication - ishihara johnson
newcreation
11-23-2003
HBG PA
Re: Increasing my rocker ratio (billyVR6) » | « » 8:17 AM 2-4-2010 | |
Josh was thinking if i am in there doing the rockers i never did valve train yet on a 24v.I was thinking of upgrading springs and retainers in the process not sure yet it it woud be worth it with the ration being low enough to still run the factory stuff.Now i am not sure on this particular cylinder head if we can upgrade valve train without removing the head.I know some motors you can pull the cams and then fill the cylinder with air and do the springs and reatiners.It would be nice to beable to do it that way and not have to pull the head.Hopefully someone can chime in here if they done so. Hopefully we can got that route if need be without pulling the head
Euro-tuner
12-16-2005
Rockingham County NH
'00 A4
FV-QR » | « » 8:32 AM 2-4-2010 | |
wow, I'm a 1.8 guys and I'm excited about seeing how this pans out
| Quote, originally posted by r32dub88 » | Specs:* 13.90mm max lift * Coil bind at 17mm * Rate 12.6lbs/mm |
^ those are some "feel good" numbers, with assurance like that in your valvetrain you're not going to have to worry about a damn thing! If Powerdubs is right (considering he always is) that's a great improvement over stock.
GSE - Granite State European  | Quote, originally posted by -Bude- » | | In Germany is no calendar yet arrived. I hope he comes this year. Am very machined. Greetings |
fourthchirpin
11-19-2004
EST.8/1/02
mk3gti
Re: FV-QR (Euro-tuner) » | « » 9:04 AM 2-4-2010 | |
billy you said 16v rockers are the same? I had Jeff's spare rockers in my hand and my R32 rockers side by side and the rockers were clearly different in size with the 16v being shorter then the R32 rockers. I even went further as to find 3.6 rockers and those were the same as R32 rocker arms.
"RACING IMPROVES THE BREED" West Indian Crew "a Fool can make the most simple things complex, It takes a genius to make the most complex things simple."
xbluewaterx
7-20-2006
Arvada CO
MK4 R32 TR Turbo
Re: FV-QR (fourthchirpin) » | « » 9:35 AM 2-4-2010 | |
Very interested in this as well. I always upgrade the rockers on small block chevys I build. Typically with crane rollers 1.6 or 1.7 but I never even thought about doing this with the VWs. I would think that this could be an easy upgrade.
BLUEWATER PERFORMANCE gabe@bwperformance.com Premier C2 Dealer For The Rocky Mountain Region Adjustable Control Arms For MK4 R32 And MK1 TT
need_a_VR6
5-19-1999
Oxford PA
1996 Land Rover Discovery
FV-QR » | « » 10:22 AM 2-4-2010 | |
Bills might be different, it's from a different (euro NA FSI) casting. We did a 'quickie' look at them didn't measure them vs the BDF or R32 ones. Some thoughts... The only way to change the rocker ratio is to change the location of the roller section that hits the cam. My concerns would be with the change in cam phasing if all else is left the same. I had to draw it out below. The numbers are just for reference, they mean nothing compared to actual parts. I just started drawing it out and some of the dimensions might be on the large side so the effect would be exaggerated. Stock type cam, stock rocker:
Increase rocker ratio by moving center pivot toward lifter. This is a ~25% change in designed pivot and ratio. You can see that the lifter would have to pump up slightly to compensate:
Now we take this bad boy to the old full lift cam angle, notice the offset from the new full lift cam angle.
Also, notice that the true rocker ratio at full lift is higher. This is due to the rocker tip needing to 'slide' out to keep valve contact. Some of that can be mitigated with a radius on the end of the rocker arm where it hits the valve, but it was hard to draw  I might redraw it with real numbers if someone could measure a rocker (length, pivot location, lifter ball dia, etc), and get me the approx base circle, tip circle, lift, of the cam, etc. That along with the difference in the new rocker pivot, I can calculate approx differences in how the new rockers will act. *Hint*
Modified by need_a_VR6 at 10:23 AM 2-4-2010
-Paul '95 GTI VR6 - ALL MOTOR - Powered by Megasquirt KPTuned : Megasquirt Solutions - Repair - Installation - Tuning ::: The Race Shop : M.J.M.
Euro-tuner
12-16-2005
'00 A4
FV-QR » | « » 11:14 AM 2-4-2010 | |
| Quote, originally posted by need_a_VR6 » | I might redraw it with real numbers if someone could measure a rocker |
I was wondering what the numbers were measured in, 12mm = 0.47 inches so I wasn't sure. assuming there is no fix yet, would you be able to advance/retard the cams enough to make the "New Lift" angle? Assuming your last numbers are correct, can the cam gears adjust up to 19 degrees? I know there is some adjustment there, maybe even enough to accommodate any angle between teeth?For example, the cam gear could adjust up to 20 degrees and each gear tooth is 20 degrees apart (not real numbers)
Modified by Euro-tuner at 8:17 AM 2-4-2010
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 12:30 PM 2-4-2010 | |
I just made up all the dimensions to illustrate the point, they have NO bearing on reality other then to show the difference in the relationships once you start moving things around. There might be ways to get the cams to be in the right spot. The thing I would worry about at first with having the centerline retarded is exhaust valve lift @ tdc would be higher. This could possibly be compensated with the vvt somewhat, or with different centerline cams.
R32Freddie
3-1-2009
sexytown nj
2004 VWR32
Re: FV-QR (need_a_VR6) » | « » 3:11 PM 2-4-2010 | |
subscribed
lol i dont hate vortex, i just hate how people call others newbies. You wonder why the scene is the way it is. People that have been it in should be helping others with there cars and being mentors not aholes.
PowerDubs
7-22-2001
NNJ
Re: Increasing my rocker ratio (DasTeknoViking) » | « » 4:16 PM 2-4-2010 | |
Ok.. lets start with the basics.#1. Stop asking me what engine the rockers are from. There is no way I am releasing that info yet as these could potentially destroy an engine if they do not fit correctly or smack pistons. I'll tell you 2 things about them though- They are NOT from a VAG product. They are NOT from any engine available in this country (unfortunately). #2. I have no idea what cost is yet. If there are similar to the stockers in cost then that would put them around $300ish for a set. I'm going to guess and say more since they have to be imported and don't appear to be as common as our stockers.
PowerDubs
7-22-2001
NNJ
Re: Increasing my rocker ratio (billyVR6) » | « » 4:36 PM 2-4-2010 | |
| Quote, originally posted by billyVR6 » | | There is a gain to be had from this is there, but in stock form it is not as impressive as what you are going to see with you worked head. |
True the ported head will gain more.. but remember this isn't about peak flow #'s. For those that didn't click the link above to read the article and see the chart..increasing the ratio "the opening and closing rates are much faster, and the area under the overall "curve" is much greater." For the rough guess $300ish these cost.. if they work I would call them a no brainer. CHART-
PowerDubs
7-22-2001
NNJ
Re: FV-QR (need_a_VR6) » | « » 4:39 PM 2-4-2010 | |
| Quote, originally posted by need_a_VR6 » | | I might redraw it with real numbers if someone could .... |
Sent you what I have so far. I think it is enough to be of some use. Happily awaiting pretty pictures.
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 4:44 PM 2-4-2010 | |
I'll work on it tonight, sent you a PM for more details.
killacoupe
6-3-2002
Re: FV-QR (need_a_VR6) » | « » 7:59 PM 2-4-2010 | |
benz 6cyl and v8 rockers are the same style as the r32's....ill take a measurement of them tomorrow
ALL MOTOR 24v 11.786@114.91 271whp 1st ALL MOTOR STREET CAR to go 11's http://www.youtube.com/watch?v...annel
PowerDubs
7-22-2001
NNJ
Re: FV-QR (killacoupe) » | « » 9:26 PM 2-4-2010 | |
There are a ton of cars that have rockers that are the same style. The INA engineer listed something like 15 different variables that make a difference. Seeing as these are the ones he recommends (and INA is the company that makes our stock ones) I don't think you need to look elsewhere at this point. At this point the only source I have found for them is a used parts place in the UK.
I would like to find a source for them new, although I might buy 1 used to test. Heard back from Willy @ Supertech.. yes we will need to change the springs to run this much lift so that drives the cost up a lot, as well as much more involved install. This just went from cheap and somewhat easy to fairly pricey and more involved.
Oh well.. no guts no glory!!
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 10:33 PM 2-4-2010 | |
You'd probably only need to upgrade the springs if you use larger cams. It might be an inexpensive way to more lift/duration with stockers.
billyVR6
5-8-2000
Tastes like plastic
Re: FV-QR (PowerDubs) » | « » 10:46 PM 2-4-2010 | |
Pdubs, this the article that I mentioned, it's a good read at the least... http://www.carcraft.com/techar....html
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 11:16 PM 2-4-2010 | |
Did some more playing around.New drawing of stock with some actual numbers. Started with 11mm peak lift from the Schricks and worked from there..
New 2.3:1 rocker
Two things - the ratio of the old vs new lift doesn't rise as fast as the change in rocker ratio. For this configuration max lift goes from 11mm to 11.65mm. The cam timing error of 2deg with the rocker change seems reasonable. One thing I didn't get right is the dia of the rocker rollers which does influence how much the lifter needs to move when the pivot is moved. Once I find my spare rockers or someone else measures one for me this is about as much as I can do. Even if I'm off on the low side .65mm extra lift and small cam timing error doesn't sound bad as long as it's not crazy money.
PowerDubs
7-22-2001
NNJ
Re: FV-QR (need_a_VR6) » | « » 1:40 AM 2-5-2010 | |
| Quote, originally posted by need_a_VR6 » | | You'd probably only need to upgrade the springs if you use larger cams. It might be an inexpensive way to more lift/duration with stockers. |
Correct. I'm not sure what the stock cams lift is off the top of my head, but Willy said the stock springs bind around 12mm in an email today.
PowerDubs
7-22-2001
NNJ
Re: FV-QR (need_a_VR6) » | « » 1:51 AM 2-5-2010 | |
| Quote, originally posted by need_a_VR6 » | | For this configuration max lift goes from 11mm to 11.65mm. |
Boo.. not enough! I was happy with the 12.5 figure off the top of my head.. even if it meant new springs + retainers the flow increase made the hardware changes worth it. Of course if the true lift really is only 11.65 then the stock springs will still work. I'm going to send those drawings..(and maybe a link to this thread) to the INA engineer. Maybe it will catch his interest enough he can help us with some further input.
HPR
10-31-2004
Antwerpen
audi A3 TDI
» | « » 3:55 AM 2-5-2010 | |
std AXW head tested on Superflow 1020 (bore 84 mm ) @10`` H2O inlet 2 mm 36.0 cfm 3 mm 54.1 4 mm 71.1 5 mm 86.0 6mm 100.2 7mm 113.3 8 mm 125.2 9mm 134.1 10mm 138.4 11mm 140.7 12mm 143.3 13mm 144.7 14 mm 145.6 15 mm 146.5 no valve 143.6 exhaust 2mm 33.6 cfm 3mm 51.3 4mm 66.7 5mm 78.2 6mm 85.5 7mm 89.6 8mm 91.9 9mm 93.5 10mm 94.7 11mm 95.6 12mm 96.5 13mm 97.2 14mm 97.6 15mm 98.1 no valve 104.2 after porting flow will be close to 150 cfm @ 11 mmm on inlet with std valves and exhaust about 115 to 120 cfm @ 11 mm( numbers @10``multiplied x 1.67 ) flow @ 28``H20 should be: inlet /exhaust 2mm 60.12 / 56.11 3mm 90.34 / 85.67 4mm 118.73 /111.39 5mm 143.62 / 130.59 6mm 167.33 / 142.78 7mm 189.21 / 149.63 8mm 209.08 / 153.47 9mm 223.94 / 156.14 10mm 231.13 / 158.15 11mm 234.97 / 159.65 12mm 239.31 / 161.15 13mm 241.65 / 162.32 no valve 239.8 / 174.0 On Catcams Full race profiles ( no pump lobe) who are used now by some engine builders Up to 13.10mm valve lift / 7.80 Cam lift / 314 degr@0.1mm/266degr @1mm /105degr Rocker ratio is 1.68 / 1.69 std rocker ( axw- axx - bhz ) source: Catcams The TFSI cams ( with pump lobe) are ready , but not tested in a car so far All cams are mechanical lifter /non hydro
Modified by HPR at 12:57 AM 2-5-2010
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 8:02 AM 2-5-2010 | |
Info on the parts for the solid conversion!
PowerDubs
7-22-2001
NNJ
Re: FV-QR (need_a_VR6) » | « » 8:29 AM 2-5-2010 | |
Way to take the thread totally off topic guys
lil_kano
4-10-2007
Boynton Beach FL
2004 RS/Cloth R32, 2002 Jetta TDI 5-Spd
FV-QR » | « » 10:03 PM 2-5-2010 | |
in for info.
Trade: BBS RC, FS: Garage Clean Out. Lots Of Parts, WTB: US or EURO R32 Bumper| Quote, originally posted by robocopywriter » | Some say he has a third nipple shaped like the Nurburgring. |
TBT-Syncro
4-28-2001
Vancouver B.C.
1992 MK2 GTI Syncro VRT
Re: Increasing my rocker ratio (PowerDubs) » | « » 12:16 AM 2-6-2010 | |
awesome. its always great to seeing someone trying something new. It seems like too many users dont look to other motors and brands to see how they're able to make power, or improve on power.props.
Project GangGreen VRT Syncro GTI Speedhunters feature on my syncro Some truth about lightweight Batteries
VR6VDub172
4-21-2006
Alexandria VA
2003 GTI, 2001 Wolfsburg
Re: Increasing my rocker ratio (TBT-Syncro) » | « » 12:21 PM 2-6-2010 | |
Subscribed. Question for you guys. I know the 2.8 24v and 3.2 24v have many differences and some similarities in the head. Are the rockers different in the two engines?
Modified by VR6VDub172 at 9:48 AM 2-6-2010
The Elite 24v VR6 Club: Member #268 "Like 6 cylinders of 15 degree sex"| Quote, originally posted by s74n70n » | | waiting for vtec is like waiting for really bad sex....all the anticipation...no boost...then disappointment. |
need_a_VR6
5-19-1999
Oxford PA
FV-QR » | « » 1:47 PM 2-6-2010 | |
Good question. I had a reman 2.8L 24v BDF head that used cast aluminum rockers. The other BDF head and BJS heads I had at the time both uses a stamped steel rocker. I'll try and take pics of the 'reman' ones as they seem to not be the norm. Dimensions between both sets seemed similar enough that I didn't measure anything.
