HiJinx
1-31-2002
Phoenix AZ
96 Jeep XJ and 09 Ducati Monster. Hunting for a Rabbit or Fox.
 Struts and Shocks that fit. . .« »
Ok, just so yall know.
For the front, strut interts that will fit can be found from and for the following models.
VW Fox (any)
Audi 80
Audi 90
Audi 4000
Audi 4000 Quatro
(the same part number for a kyb gr-2 strut shows up for fox, audi 80, 4k, and 4kq)
For the rear,
VW Fox (any)
A2 is pretty close.
so, basically, you can get Bilstien sports for an A2 rear and an Audi 80/4000 for the front and should be good to go.
Modified by HiJinx at 11:58 AM 8-18-2003
ErikLyon
9-15-2002
Victoria B.C.
88 Fox wagon, 88 jetta
 Re: Struts and Shocks that fit. . . (HiJinx)« »
How did you come upon this definitive information?
HiJinx
1-31-2002
Phoenix AZ
 Re: Struts and Shocks that fit. . . (ErikLyon)« »
For the fronts, just start cross referencing part numbers for aftermarket pieces.
for the rears, 1. they look almost identical, 2, people here are using them.
Just some research bro. Have I EVER steered yall wrong?
Evilclown
3-12-2001
Winchester VA
Quote, originally posted by ErikLyon »
4000/80/90/CGT/UrQ/CQ(yes, they're all the same) front struts and A2/Corrado rear shocks are on my car. They're identical to the OEM Fox pieces. The A2 shocks are a little longer at the top, but the threads end at the same point on the body of the shock rod; there's more thread sticking out above the top nut.
'93 Fox Sedan: 9Q, E30 mounts, TT downpipe/cat/catback, TT snub mount, Bilstein/H&R, updated door handles.
More fun on the way...
Tjax
2-19-2003
Wa State
'87 VW Fox coupe
 Re: Struts and Shocks that fit. . . (Evilclown)« »
Cool. Thanks for this info guys. Since you're on the subject, do the A2 rears just bolt on as if they were stock Fox shocks(say that 3 times fast), or is there some modification involved.
....and at the risk of getting flogged one more question:
Can someone please explain a bit clearer what is needed to make the G60 springs work in the rear? There hasn't been a clear explanation of this as of yet as far as I know.
'87 Fox Coupe
2.0L ABA, Port-matched big valve head, Full Techtonics exhaust, TT 268 & adj. cam gear, big bore TB, 16v Brakes w/Carbotech Bobcats, SS braided lines, Quantum booster & 22mm MC, Lowering springs, Bilstein Sports, PSA 5spd trans
HiJinx
1-31-2002
Phoenix AZ
 Re: Struts and Shocks that fit. . . (Tjax)« »
Quote, originally posted by Tjax »
do the A2 rears just bolt on as if they were stock Fox shocks( or is there some modification involved.
Ya, they just bolt on the exactly same way your stock ones do.
a1junkie
4-26-2000
Columbus Ohio
'99 Westy
Someone had posted that if you use A2 springs on the rear, you HAVE to use A2 shox - something about spring diameter - is that true?
Current: '99 Eurovan Westfalia, '85 GTI Lemons Racer
Past: '97 GLX, '83 GTI, '86 GTI, '81 Gas Pickup, '82 Diesel Pickup, '84 Convertible, '83 GTI, '82 Diesel Pickup, '82 ITC Rabbit, '00 Golf TDI, '00 Jetta VR6, '81 SportTruck, '88 Fox Wagon, '87 Cabby, '96 Golf GL, '90 Westfalia, '02 Jetta Wagon GLS...
vwmann1
1-27-2002
 Re: Struts and Shocks that fit. . . (a1junkie)« »
Quote, originally posted by a1junkie »
No, I have A3 springs on the rear of my car right now. They don't fit in the upper perch well but just jam them up there. I have been running this setup for 5 years with no problems.
Douglas Hillmann
VFC Engineering
We Build Champions
HiJinx
1-31-2002
Phoenix AZ
does anyone know what year/type of Audi 80/90 will work?
ErikLyon
9-15-2002
Victoria B.C.
'88 should work
Evilclown
3-12-2001
Winchester VA
Quote, originally posted by HiJinx »
All the same. Audi wasn't big on changing their front suspensions as their platforms progressed. It caused problems as the cars got heavier; the struts and mounts that had been so wonderful on the 2200lb 4000 suddenly didn't work so well on the 3000lb 90. Adding a V6 in the B4 platform didn't help matters, either.
littlesnides
7-20-2002
Wheeling Wv
'91 fox, b4 tdi
 Re: Struts and Shocks that fit. . . (vwmann1)« »
The spring diameter is larger on the A2's, holding the mount in are only 4 small welds which could possibly drilled and removed and then in theory get A2 ones welded in place to fit in the springs----not tried it yet but am planning on it soon
beartots
7-30-2002
mississauga ontario
2K3 Jetta TDI - Straight Stock and getting 1000KM per tank
 Re: Struts and Shocks that fit. . . (HiJinx) »« »
VW Fox (any)
Audi 80
Audi 90
Audi 4000
Audi 4000 Quatro
For the rear,
VW Fox (any)
A2 is pretty close.
I must admit this is some useful info but can you include the model year of the cars above. Also, for "HIGH PERFORMANCE" will I need to replace my springs also or will the above parts fit with the stock Fox springs.
Without any cutting.... which other springs will fit in the FOX???
ŵ€ ģΦΦηǻ ®įĎΣ мЏŤĥĂ ţİŁŁ WĥέέĽδ făĻĻ Ώff
radioh3ad
11-2-2003
vernon NJ
93 wolfsburg fox 2dr red
 Re: Struts and Shocks that fit. . . (beartots) »« »
i hear ya...i too would like to avoid cutting springs
you're the weak, and i am the tyranny of evil men
but im trying, ringo, im trying real hard to be the shepard
93 wolfsburg fox 2 dr tornado red
l2@l]l()h3@d-
noodle32
11-23-2003
Warminster PA
1990 VW Fox Coupe
Or you could always just give Zarrir a holla in Brazil to hook ya up w/ his lowering springs designed for the Fox @ brazilshopping.com
1988 VW Fox Sedan (R.I.P - ended up as a parts car before it was towed away)
1990 VW Fox Coupe
Tjax
2-19-2003
Wa State
'87 VW Fox coupe
 Re: (noodle32) »« »
Quote, originally posted by noodle32 »
I wish somebody would try these with stock type shocks/struts just to curb my curiosity.
'87 Fox Coupe
the brit
6-22-2003
Pottstown PA
Quote, originally posted by beartots »
Audi didn't change their suspension very much over the years, so any year will do if buying struts. As for the springs, they all fit, but they did come in different rates etc due to the loaded V6 being heavier than the budget 4 cyl.
Without cutting which springs will fit ? again, this is in the FAQs, any of the cars lifted above. A2 is again pretty close. A3 is also close.
Replacing your springs for HI-PO ? Yes, they will most likely be old, worn and saggy.. plus they won't lower your ride height at all, so body roll in corners and boating under acceleration will not be addressed by just changing the struts. Best to do both at the same time, although you can definately use old springs with new struts - the opposite, new lowering springs w/ old struts, will quickly give terrible handling / ride though.
Modified by the brit at 4:46 PM 2-11-2004
radioh3ad
11-2-2003
vernon NJ
which would need more modification than the other? audi 80/90, audi4k/coupe etc?
l2@l]l()h3@d-
Evilclown
3-12-2001
Winchester VA
 Re: Struts and Shocks that fit. . . (radioh3ad) »« »
Quote, originally posted by radioh3ad »
As far as struts go, they're all the same. Direct fit for the Fox.
It's in the FAQ.
radioh3ad
11-2-2003
vernon NJ
i thought this was the faq
l2@l]l()h3@d-
rubin_bc
1-22-2004
vancouver bc
88 vw Fox wagon
this should be put in the faq
STOCK 88 red vw fox gl wagon
planning on adding some performance shocks, bu only because the stock ones are going
HiJinx
1-31-2002
Phoenix AZ
Just so the Info is in this thread. . .
What are some good locations to purchase dampeners from?
MeanieMe
7-20-2001
Dallas TX
97 VW Jetta GT 87 PimpWagen Fox
So would the rears be also interchangeable in a Wagon?
Here's the kick tho' I pulled the front strut assembly from a Fox sedan
on the J-yard but when i installed in on my Fox Wagon everything felt loose on the top. The thread on the strut was too high up top so it couldn't get any pressure on the top mount.
I'm desperate right now. I must finish a show worhty fox in 2 weeks so chopping springs w/new struts are what I view in my future.
While I wait for developments in Fox Tunning.
84 Rabbit GTI
87 PimpWagen FOX Wagen
89 PW Cabriolet WE "Topless"
97 PW Jetta GT 2.0t
me
GotEuroCorrado
4-27-2002
hatboro 19040 pa
***** v10 touareg tdi ***** 2007 WCM Ultralite (super 7)
 Re: (Tjax) »« »
if u use a aftermarket lowering spring with a stock shock you are in for a surprise real soon. the stock spring is taller then the lowering spring so the stock shock will be to tall. in other words when u have it on your car you will blow out your stock shocks in less them 5 months because they are getting compressed a LOAD more. if u check with any aftermarket spring manufacturer(neuspeed,eibac,h&r...) they will tell you to go get a set of shocks that were meant for a lowering spring.
FS: BRM TDI MOTOR COMPLETE FROM 2006 JETTA
I INSTALL COILOVERS FOR MK2 MK3 MK4 B3 B4 $225 MK5 B5 $250
When I die, I wanna die like my grandpa, in his sleep. Not like the screaming passengers in his car.
noodle32
11-23-2003
Warminster PA
1990 VW Fox Coupe
I'm getting KYB strut mounts (mechanic said they were so brittle that they just fell apart when the fronts were replaced so I can only imagine how the back is), bellows (just to be sure) and GR-2 shocks (anybody know how these feel performancewise?) put on soon - anything's gotta be better than what I'm feeling in the back right now (I'm pretty sure the one's on there now are the originals) though I guess if GotEuroCorrado is right then I'll be in for a surprise sooner than I thought - I've heard someone mention this to me before - so I guess I'll have to deal with it :/
1990 VW Fox Coupe
Ol' Grey Fox
4-27-2003
Midlothian VA
1989 Fox Wolfsburg
 Re: (GotEuroCorrado) »« »
Quote, originally posted by GotEuroCorrado »
So what about stiffer springs that keep the same ride height? I heard they would do bad things to the shocks as well, but havn't been able to get an explaination of why this is true. Does it just wear out the small section of shock that you use or is something else going on with that?
1989 VW Fox Sport Wolfsburg LE - Stock
1993 VW Fox Coupe - Just an old 8 valve.
"There are two things that no car needs. They are an ashtray and a cupholder." -- Hans-Joachim Stuck
FoxWolf93
7-12-2003
RDU NC
 Re: (Ol' Grey Fox) »« »
In a suspension system (spring + damper), the spring force must match the damping force... If the damping force isn't sufficient (as is the case w/ stiffer springs + OEM dampeners), then the rebound will be too harsh (i.e. the damper can't suffieciently damp the bouncing spring).
RIP '93 Fox Wolfsburg... now just trolling the forum as a former Foxer
>>Get FireFox <<
>>Visit FoxPhiles.com <<
noodle32
11-23-2003
Warminster PA
1990 VW Fox Coupe
 Re: (Tjax) »« »
I already have the lowering springs and stock struts - about to get new shocks put on soon (once I get the money) so I'll letcha know if the 'lowering spring/stock shock/strut' theory is true about them prematuring as early as 4-5 months into their installation by checking about w/ everyone by the end of the summer to see is theres any real change in feeling
1990 VW Fox Coupe
Tjax
2-19-2003
Wa State
'87 VW Fox coupe
 Re: (noodle32) »« »
So how is the ride with that setup?
'87 Fox Coupe
tornadoredcabby
2-13-2002
11757 NY
89 Cabriolet ,96 Jetta
For the benefit of all, I am going to put up my info.
87 Wagon
161-FV535L Weitec Corrado 60/60 springs
075-B360656 Bils Sport GJ2/G60 rear shocks
075-P303006 Bils Sport Audi 90/4K front struts
ZBA 412351 Fox strut bearings
Part #'s from my Rapid parts receipt, Total Before tax $641.65
No shipping as I picked the parts up.
In addition I had to purchase rear "hardware"
Dust sleeve, etc. Don't have part #'s on that, I believe we went with the "kit" for an A2 Jetta.
Driving impression.
Very firm, not very forgiving. At first I wondered did I make the right choice? But dame can it handle, not even fair to compare it to the 16 year old stock garbage that got ripped out. After driving on it for ~6 months, me likey
Would I do it again? probably, maybe would go with coils due to the poor plowing job on my local streets creating a bit of an exhaust issue. It would be nice to raise it up for the winter months.
Rear
Front
Todd
Modified by tornadoredcabby at 4:34 AM 3-25-2004
1989 VW Cabby For Sale
http://forums.vwvortex.com/zerothread?id=3825762
93wolfsburg
2-22-2003
Old Hickory TN
2001 Jetta GLS VR6 1991 Jetta GLI VR6 1988 Jetta Coupe VR6
 Re: Struts and Shocks that fit. . . (tornadoredcabby) »« »
i'd have to agree my weitecs were very firm at first they are still very firm but either i have gotten use to them or they have broken in a little i couldn't tell you but damn bilsteins are NICE
TNEuros
matsit_fox
3-22-2004
Indialantic Florida
95 Passat GLX VR6
so would that set up would work on an 89 wagon? and is it a direct bolt on with no modifing parts?
keeping my Volkswagen a krautmobile not a rice rocket
./\_/\
( o o )
>\_/<
thegreatandpowerful
3-12-2004
Yellow brick road OZ
87 Fox wagon, I don't think much is still original
Just to confirm, AudiNutz over on the DOG and a few other people have had this reasearch out for years.
'Nutz even has went so far as to do technical drawings, with actual dimensioning of the differences.
Just to lay it straight: the info is out there. Like some of these guys know:
1) 16V? Yep, and pics to prove again. Like in the early 90's.
2) Turbo? The company 8VTurbo and DCI Fox can tell you about that.
3) Who else remembers a lady named Heather, who along with 'Nutz, pretty much started this internet Fox forum thingy??
4) And her 15 inch Fox wheels?
How do people come up with this stuff? Too much time, maybe a knowledge of other VW's, stuff like that.
Just wanted to pass that info on.
DCIFOX
1-12-2003
Fox St. Racing
 Re: Struts and Shocks that fit. . . (thegreatandpowerful) »« »
Quote, originally posted by thegreatandpowerful »
They're somewhere on this side of the pond
Oh, to find those on a junkyard Fox
Smilies thrown in just for you LP, because I know how much you like them.
a1junkie
4-26-2000
Columbus Ohio
'99 Westy
To anyone who's put KYB rear shox on their Fox, what did you do about the lower spring mount?
Mine came w/o mounts, and the old ones were spot-welded onto the old housings.
I drilled the welds and sized them down to fit the smaller-diameter KYB GR2 tube (that's Polite for, "I beat the hell out of them with a hammer until they fit"), but I'm not psyched about the prospect of trusting my life to ghetto mounts.
So now I'm surfing around in search of factory A2 mounts. Just thought those doing the upgrade might want to be forewarned.
First  1 2 3 >  Last
» Return to Fox
