VWVortex.com - 02A into a A1, universal FAQ please post links, info and pics that would be necessary for this conv
    Page 1 of 10 12345 ... LastLast
    Results 1 to 25 of 248
    Thread: 02A into a A1, universal FAQ please post links, info and pics that would be necessary for this conv
    1. Member austin neuschafer's Avatar
      Apr 26th, 2002
      knoxville tn
      87 rocco 2l16v w/02a lsd 4.24
      10-10-2003 11:39 PM #1
      PLEASE NOTE there is a link to this post in the trans FAQ get to work everyone, this is a very underrated conversion, these trannys are rock solid when equipped with a AFTERMARKET differential such as quaife and peloquin. 300hp is easy with very strong clutch endurance when compared against the 020 "crumble box" as I have called them before. this conversion is not near as difficult and some have claimed it to be.
      heres one link of mine https://forums.vwvortex.com/zerothread?id=460997 https://forums.vwvortex.com/zerothread?id=749237 https://forums.vwvortex.com/zerothread?id=574174
      Modified by austin neuschafer at 4:41 PM 4-21-2006
      87 rocco 2l16v MS3 02a/j with 4.24 on LSD. 91 rado geting 1.8t, 02 cabrio geting vr6, 04 r32 vf stg 2 sc, and a few other goodies
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. 10-11-2003 07:17 PM #2
      http://www.gironet.nl/home/cillari/gearbox.htm
      Cable clutch:
      VW part no.:
      bracket for mech. clutch operation :
      02A 141 708B (item no. 10)
      boot for mech. clutch operation :
      02A 141 728 (item no. 13)
      clutch cable :
      357 721 335E (item no. 6)
      Note: the part numbers are UK/European, not for the USA/Canada.
      Another option for mechanical actuation of the clutch may come from the 1992
      Eurovan with parts available in the US. (Does anyone know for sure?)
      Mechanical actuator: 02B 141 708A
      boot for actuator: 02A 741 728
      -Dave
      Modified by MrDave at 6:01 PM 10-11-2003
    4. 10-12-2003 09:08 PM #3
      MOUNTS
      Modified pedal box to accept the hydraulics, using parts from a Corrado
      Modified by The Transplanter at 2:09 AM 10-13-2003
      My Rides:
      1986 GTi Engineering Caddy - 1988 VR6 Turbo Caddy - 1990 1.8 GTi Leisure Caddy - 1992 1.8i Caddy Sport - 2001 1.8T Caddy Van - 1978 Ford Escort (1.8T in the making)
      Jun 9th, 2002
      Socal
      75 rabbit, 77 rabbit, 80 caddy, 84 rabbit, 81 caddy trailer
      10-17-2003 02:32 AM #4
      I make some nice mounts for that transmission swap too. Into A1 .
    6. Member thescirocco.com's Avatar
      May 15th, 2002
      Bear, Delaware 19701
      1984 Rabbit GTI
      10-24-2003 08:39 PM #5
      Quote, originally posted by Euro rally »
      Do you have pictures of them?
      Peter call 3O2.605.3003 or [email protected] G mAiL
      Autotech, Peloquin differentials, and Motovicity Quaife dealer
      Jun 9th, 2002
      Socal
      10-27-2003 05:24 AM #6
      yes i'll post some pics
      Modified by Euro rally at 11:04 AM 10-27-2003
      Modified by Euro rally at 11:07 AM 10-27-2003
    8. 10-29-2003 11:16 AM #7
      bump
    9. 11-07-2003 10:16 PM #8
      Well I just did this swap into my A2 and let me tell you I am not convinced it is much tougher. I killed two tird gears in O2As in one month. the only problem I had with O2Os was the diff. Just My 2 cents. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    10. Member thescirocco.com's Avatar
      May 15th, 2002
      1984 Rabbit GTI
      11-07-2003 10:48 PM #9
      Quote, originally posted by DubGray1.8T »
      Really... That's good info, what engine do you have?
      My wagon has an 02A with a Quaife, and when I shift into 3rd, I get a crunch, unless I take my time, which sometimes I forget to do.
      Gary told me 3rd gear on 02A's is like 2nd gear on an 020, the first synchro to go.
      The 02A is tougher than the 020, but the 020 with the stage 3 Peloquin 020 diff. with the 80% shims will reduce the side to side pull that you get with a lot of power.
      I'm deciding between using an 020 VL-6 speed, a 4K, or maybe a 5 or 6 speed 02A.
      I'm leaning towards using a 4K w/Peloquin diff and 80% kit, now, and then maybe the 02A swap later, once I get the 2L16V Motronic swap sorted out..
      If I had an A2, this would be a no brainer, but the A1 needs some customizing.
    11. 11-08-2003 06:13 PM #10
      Well I have an A2 1.8T 20V. T3, 60A/R and a 1992 02A 16V Passat tranny swap.
      obviously my experience with the 02A [swapped anyway] Is very limited so dont take my opinion to gospel. I have heard over and over that it is a tougher tranny. Well as far as my experience goes They have actually been weaker. Every time I tell someone I blew the O2A they tell me I prolly need to shift it easier. I dont agree I enjoyed my car with the 020 much more. although I do like the 02A taller ratio more.
      To be completely honest though I have broken more 020s than 02As but have broken more 02as in a shorter amount of time.
      These were also used trannys one had 80,000 the other had 255,000 but I promise I could break one in less than ten runs. The 22 pound flywheel does not help either.
      I have stripped all the teeth of third gear on the clutch shaft twice. same problem repeated I am assuming it is a weak spot.
      Again this is just my opinion. I may just be having bad luck. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. Member G60ING's Avatar
      Jun 27th, 2000
      Alexandria, VA
      2010 3.6 4-Motion CC, 1990 G60/TDI/R36 Corrado
      11-08-2003 10:40 PM #11
      no 2rd gear problems here. for my experiance here are the problems I've run into with G60 02A trannnys:
      2nd gear syncro grind on a few of them
      1 tranny had a stripped 2nd gear (no teeth at all)
      1 bad 3rd gear syncro
      1 blown diff
      1 chipped reverse tooth but thats about it.
      I've never seen a repeated problem with 3rd gear (syncro or teeth related)
    13. 11-08-2003 10:53 PM #12
      Thanks for the response. I have ripped every tooth off 3rd gear on the clutch shaft side and about 25% of the teeth on the main diff shaft side. It is the initial clutch drop into third from 2nd into 3rd. It is like 1st and 2nd are low enough to burn the tires but 3rd is a ratio that trys but breaks in the process. I has got me baffled. I just got a lightend flywheel and a taller third to try and deal with this.
      Just for the info the clutch grabs hard enough to chirp the tires between 3rd and 4th at around 80 MPH. This plus the rotational weight of the flywheel are what is causing it I think.
    14. 11-11-2003 06:47 AM #13
      I just heard back from my vw dealer contact in the UK. prices below:
      Quote, originally posted by MrDave »
      Cable clutch:
      VW part no.:
      02A 141 708B (item no. 10) $62
      02A 141 728 (item no. 13) $8.50
      clutch cable :
      357 721 335E (item no. 6) $50
      -Dave
    15. Member thescirocco.com's Avatar
      May 15th, 2002
      1984 Rabbit GTI
      11-11-2003 10:49 AM #14
      Sounds great, when are you placing the order?
      I just have to decide if I'm going 020, or 02A.
      I'm leaning towards the 02A swap, since I can get a brand new 02A trans for ~$1200 w/shipping. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    16. 11-11-2003 12:50 PM #15
      Can you use the pedal setup from a G-60 and not even mess with the original pedal from a Mk 1
    17. Member thescirocco.com's Avatar
      May 15th, 2002
      1984 Rabbit GTI
      11-11-2003 01:04 PM #16
      Quote, originally posted by Rabbit350 »
      Not easily...
      Plus I like the idea of having a cable clutch, simple, and easy to replace.
    18. 11-12-2003 06:18 PM #17
      Where did these mounts come from???
      -Raffi
    19. Member
      Jun 30th, 1999
      MoCo, MD
      Jetta TDi, BMW S1000R, Suzuki DRZ400SM, Brodozed Tacoma
      12-01-2003 01:17 PM #18
      Thanks to need_a_VR6 for the part. Here's a pic of the bracket that will allow the conversion from hydraulic to cable.
      DCI
    20. Banned
      May 12th, 2002
      12-01-2003 07:44 PM #19
      Is that the one from the euro van or the other?
    21. 12-02-2003 01:35 AM #20
      What is the round black thing in the top right hand corner of the pic?
      -T99inFL-
      1999 Jetta VR6...GIAC...gone...
      2003 Jetta 1.8T...GIAC...gone...
      2006 Jetta TDI, Package2, Malone Stage 2
      2010 Audi A4 Quattro, Premium Plus
    22. Member
      Sep 6th, 2001
      Baltimore, md
      87 vw golf gti 16v
      12-03-2003 07:07 AM #21
      bump
    23. Member
      Sep 6th, 2001
      Baltimore, md
      87 vw golf gti 16v
      12-05-2003 07:24 AM #22
      bump
    24. 01-07-2004 02:58 PM #23
      Modified by screename at 5:38 PM 1-8-2004
    25. Member Angular's Avatar
      Mar 12th, 2002
      WA state
      2002 Audi S4 Avant
      02-04-2004 09:05 PM #24
      So how do you hook up the speedo cable from a 02A/02J to a Rabbit/Scirocco instrument cluster?
      Anyone with a set of mounts for sale, please contact me ASAP. I'm installing a 02J in my 16VT Scirocco as soon as I get the parts.
      Thanks.
      Bradley
    26. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      02-05-2004 03:08 PM #25
      Brad, early (90-91?) G60's and Passats still had cable driven speedo.
      The bracket that Pat has is Euro-sourced. They're a PAIN to get regardless.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project [email protected] and falling
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
