VWVortex.com - Rabbit TDI Part 1: Introduction
    Results 1 to 11 of 11
    Thread: Rabbit TDI Part 1: Introduction
    1. Member CrewCabCaddy's Avatar
      Feb 6th, 2002
      NW Washington State
      1981 CrewCab Pickup w/ chipped 1Z TDI/6 Spd. Tran.
      03-24-2004 02:00 AM #1
      Following in the famous footsteps and generally useful format of MrDave, I will post a series of descriptions of the process I went through to place a TDI into my custom made 1981 crew cab VW pickup.
      I don't have as many pictures as I wanted, because of a computer crash, but IM me if you want to know if I have pictures or want some more specific information on a procedure described in the descriptions to follow.
      The first step was to accept that when my 1.6 liter diesel would not start anymore (298,000 miles and about 300 psi in each cylinder), that it really was dead and needed replacement.
      I wanted a TDI!!!!
      So I started the process by searching forums on VWVortex and Fred's TDI websites and buying a totalled 1996 B4 Passat (front end damage, but no motor damage) containing a 1Z TDI with about 98,000 miles on it. Cost: about $2,000 USD
      Why a '96. Because it was available...and because A3/B4 TDIs (up to early 1999 I believe) have bolt holes in the block that allow the motor mounts from an A1 to bolt on with no modification of the A1 engine bay motor mount positions.
      I strongly recommend buying a whole donor car as I have scavenged many parts from the Passat during the swap.
      I parked both cars side by side on my lower landing and pulled the engine and wiring harness out of the A1 first. I cleaned the engine bay with Castrol Super Clean (works very well), taped off areas I didn't want painted, and sprayed the engine bay with Dynashield sound deadener (a Dynamat product), and then covered the Dynashield with spraypaint. Bentley manual provides tips for A1 engine removal.
      Then I removed the TDI. The Passat front end essentially unbolts and you can pull the motor right out of the front without lifting it much. Much much easier than pulling the A1 motor.
      Removed the TDI engine wiring harness including the drive-by-wire and OBDII. This involved taking apart portions of the Passat dash. Interestingly, to get the dash off (without breaking it) you have to start in the back seat and remove the screws on the back side of the center console first, then the center console, the central dash cover, and so forth until you finally get to the driver's side dash coverings. Not really difficult, just didn't really want to remove all the pieces to get to the wires I needed.
      My advice: take the time to remove all wires without cutting them. You might need them later....!!!!!
      I then sent the A1 and TDI wiring harnesses to David Marshal (www.fastforward.ca). He put them together and made it easy for me to put the TDI/A1 harness into my rabbit. Cost: about $450 USD.
      Important update: Some 96 Passats (like mine) run an auxilliary fuel injection right into the exhaust pipe, and have two (yes 2) exhaust temperature sensors, one on either side of the catalytic converter. The fuel injection "warmed up" the catalytic converter, making it more efficient a lower engine operating temperatures. The ECU from these cars will not work properly without the injector and both temperature sensors in place. I cut these off my Passat harness thinking I would not need them, and now I will be buying a new (used) GQ ECU (028 906 021) that is supposed to be the 96 Passat ECU minus the auxilliary fuel injection controls.
      Subtotal costs (not including beer): $2,450 USD + new ECU
      Coming Soon...
      The Next Step: Mount the TDI
      Search Key Words: A1 Rabbit TDI Engine Swap
      Modified by CrewCabCaddy at 7:18 PM 3-30-2004
      Modified by CrewCabCaddy at 9:42 PM 4-5-2004
      Keep on Keepin' On
    2. Remove Advertisements
      Advertisements
    3. 03-26-2004 10:04 AM #2
      Ok, so now I guess I'm not the only one...
      Does that mean I pioneered a new swap trend?
      And I'd love to see what the crew cab looks like.
      -Dave
    4. 03-27-2004 01:13 PM #3
      how about some pics, i can host them if you need [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Remove Advertisements
      Advertisements
    6. 03-29-2004 12:26 AM #4
      because of MrDave i've started my own tdi (alh) swap with rabbit6 (doing most of the work ) and i know of two more people that are doing the tdi swap because of you... so props to mrdave and anyone else doing this swap.
    7. 03-30-2004 12:10 AM #5
      Oct 2nd, 2001
      Vancouver, B.C. Canada
      1993 Eurovan Westy TDI, 1996 Golf TDI, 1997 Golf Variant Syncro TDI, 2011 Golf TDI, 2014 GSW TDI
      03-30-2004 01:25 PM #6
      Quote, originally posted by Bus pasS »
      I would be one of these two people
      My ALH won't go into my '80 Rabbit GTI however. It'll go into a MK2, most likely a red '91 Jetta that I'm going to check out tonight. But if I like the motor, I may have to get another TDI for the Rabbit haha.
      I will start a new thread on the project soon. I'll enjoy watching your project progress, CrewCabCaddy [IMG]http://*****************.com/smile/emthup.gif[/IMG] Have fun!!
    9. Member CrewCabCaddy's Avatar
      Feb 6th, 2002
      NW Washington State
      04-06-2004 12:44 AM #7
      Note important update in original post.
      It'll save you time, frustration, and money.
      Keep on Keepin' On
    10. Member DesuL's Avatar
      Feb 25th, 2003
      Seattle
      99.5TDI, 92 ABA golf,86 GTi,80 Rabbit truck, 22 model T bucket
      05-08-2004 09:21 PM #8
      Quote, originally posted by CrewCabCaddy »
      Hmm so this means i could swap one into my Mk2 Rocco engine bay really easy...
      What kind of stats does the engine used have? mpg? hp/tq @rpm? Being that your in Seattle as well maybe we will cross paths sometime and ill get a ride in it.
      With gas up around 2.15 a gallon as we speak Im all for a TDI in my unique rocco
    11. Member CrewCabCaddy's Avatar
      Feb 6th, 2002
      NW Washington State
      05-09-2004 10:32 PM #9
      The 1Z TDI is rated at about 90 Horsepower and 150 ft/lbs of torque. You can chip them and add larger fuel injectors to bump HP and torque considerably. I am very happy with the current power. I drove over Snoqualmie from Ellensburg and kept it in fifth gear the whole way. The biggest hills slowed me down to about 60 mph, but I didn't have to downshift.
      From what I have read, mileage in the original A3/B4 cars ranged from 45 to 55 miles per U.S. gallon. Right now I am only getting 35 mpg but I still have a couple of ECU fault codes that I am trying to track down and fix. These could be affecting my mileage. I expect to get the mpg up around 40 with a 3.67 ring and pinion (which is considerable lower than the 3.39 that the orignial Passat had in it.) and the extra weight and squareness of my truck.
      Because of the fuel prices lately, I am considering trading in my Chevy Astro mini van and finding a B4 TDI Passat wagon, just for the mileage.
      I think these engines would fit into your rocco, but you still need to get the ECU and harness figured out...
      Let me know if you go for it. I can probably provide a few ideas...
      Keep on Keepin' On
    12. Member DesuL's Avatar
      Feb 25th, 2003
      Seattle
      05-11-2004 09:10 PM #10
      Whats the cost on something like that and how much gain do you get? Can you do a kerosean injection system like some of the trucks i have seen?
      35mpg is still pretty dang good
    13. Member CrewCabCaddy's Avatar
      Feb 6th, 2002
      NW Washington State
      05-15-2004 11:12 PM #11
      Not sure on the kerosene injection....
      Engine will probably run you around $2,000 usd.
      Modified by CrewCabCaddy at 8:13 PM 5-15-2004
      Keep on Keepin' On
