VWVortex.com - Here is my complete Crank Fix..
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 130
    Thread: Here is my complete Crank Fix..
    1. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      09-20-2004 03:35 PM #1
      Quick premise: Crank bolt snapped getting up to speed on interstate. Pulley key wasted and crank Key slot partially boogered.
      here is my fix pictorial:
      Parts:
      - New Crank Pulley - VW (049-105-263-C)
      - New Crank Bolt - VW (N-903-208-02)
      - All New Belts
      - Loctite (Stud and Bearing mount)
      - 2 STD Roller Bearings (mid '70-'s Harley Sportster Trans Mainshaft)
      - Brake Cleaner
      Special Tools:
      - Good set of Cobalt Drill bits
      - #5 Easyout (5/16) with 19/32 drill bit (if needed)
      - 1/16, 5/64, 9/64, 5/32 Cobalt drills (if not in set)
      - Flywheel lock (if you have one
      - Torque wrench
      - Center Punch
      - 14mm x 1.5 Thread Tap (if needed)
      Steps:
      1- To make it easy I removed: the timing belt cover, the Serp tensioner, right from wheel, lower timing belt cover and inner fender well.
      2- Using a center Punch I made a mark in the exact center of the broken Crank Bolt. I started with an 1/8 pilot drill bit and worked my way up to 19/32 to extract.
      3- I then took the new crank Pulley on the drill press with a 1/16 drill bit and drilled one hole opposite keyway and all the way through (you can use 2 dowel pins if your crank is really trashed). I drilled the pilot hole so it would be in the center of the crank between the crank bolt hole and the outer edge of the crank (SEE Hind Sight Notes at bottom).
      4- using the 1/16 drill bit and the crank pulley placed on the crank as a template, I drilled the hole in the crank to a depth of 1/2 the length of the dowel pin.
      5- I then used the 5/64 drill bit in the same fashion, drilled all the way through the crank pulley (using it as a template) and then into the crank to the same depth as #4.
      6- using the 9/64 drill I drilled the crank hole out (not using the pulley this time) to same depth as above (1/2 the length of the dowel). Go back and forth a few times to make the hole a tad bigger. You could probably go to the 5/32 drill for the crank only so the pin slides right in, but I wanted a tighter fit.
      7- using the 9/64 drill I drilled the crank pulley hole 1/16" more then 1/2 the depth of the dowel from the Backside out. This will prevent the dowel from backing out and allow and easy way to drive the dowel in to the proper depth in the crank pulley.
      8- Drive dowel pin(s) into crank pulley
      9- Tap crank threads (14mm x 1.5) to clean them up if necessary. I needed to because when the bolt snapped, it slightly screwed up the first 2 threads. The bolt must screw in perfectly by hand to be able to torque properly.
      10- use brake cleaner to clean everything. I then used a small amount of Loctite stud and bearing mount on the crank key slot, than mate surface of the crank pulley and crank and then used regular red (271) on the bolt.
      11- Torqued to proper specs (66 Ft'Lbs + 1/2 Turn) using homemade flywheel lock.
      Hind Sight notes:
      1 - If your crank key slot is really bad you may want to use 2 dowels on either side of the crank (away from the old crank key slot).
      2- If I had to re-do, I would probably have drilled the dowel(s) closer to the outside edge of the crank (further away from the crank bolt). This is because there is less shear force the further out you go from the cranks center point. I was worried about being too close to the end of the crank, but in reality, that's where the stock keyway is...
      This is just me over analyzing things as it will likely never matter anyway..
      Good luck and be patient if you try to do this as well. A broken drill bit in the crank will give you a world of hurt. (light pressures to drill and straight holes)
      Shawn
    2. Remove Advertisements
      VWVortex.com
      Advertisements
    3. 09-20-2004 03:56 PM #2
      thanks, i will be doing the same, but using 2 pins as the crank isnt lookng too good
      i will try and get pics too
    4. 09-20-2004 04:32 PM #3
      OOPS! WHEN i WROTE TC/J that is the shear in the crank pulley itself not the pin, that is alot more complex dynamics prob i think regarding contact forces, and inertial forces. D'Alemberts principal.
      sorry
      Modified by Alpineg60 at 1:37 PM 9-20-2004
      Modified by Alpineg60 at 8:55 AM 9-21-2004
    5. Member marat_g60's Avatar
      Mar 4th, 2003
      Toronto, Scarborough
      94 VRT Corrado
      09-20-2004 08:34 PM #4
      great write up!
      now i can go ahead and fix mine too so it will never happen again
    6. Member sdezego's Avatar
      Apr 23rd, 2004
      09-21-2004 10:49 AM #5
      Quote, originally posted by Alpineg60 »
      Actually the further out from center you go the more shearing force (rotational shear = Tc/J) where T is torque, J the polar moment of inertia, and c is the radius.
      The location of the key being close to the center is probibly the best design, that is where it experiences the least shear.
      I hope you didn't get a good grade in Dynamics or machine Design Your equation is fine and you are on the right track to support what I am saying. What you failed to look at was the Value of J (the polar Moment of inertia). For simplicity, to consider the Key as a hoop at a radial distance r (or c in your equation), the equation for J is:
      Notice that the radius in J is to the 4th power! This is the reason why drive shafts are hollow and have large diameters. The material at a small radius does little to resist shear. If you were correct, everyone would be scurrying to change out their 100mm CVs for 90's If you want to read up check out this link (spec. pages 8 and 9). http://ocw.mit.edu/.../torsion.pdf
      Shawn
    7. Member bulldog2.G's Avatar
      Jul 25th, 2004
      camatortilla
      Cablowrio, 012GLI
      09-21-2004 11:48 AM #6
      "shear" can be thought of even more simply by thinking of, as illustration, a set of "shears" or scissors. It is easier to cut a given material at the beginning of the shears travel, closest to is axis. The further away from axis, the more force necessary to cut the same material. It is leverage dependant.
      Don't challange Mr. Shawn !!!
    8. Member sdezego's Avatar
      Apr 23rd, 2004
      09-21-2004 06:07 PM #7
      OOPS! WHEN i WROTE TC/J ......
      sorry
      No worries (if I was your professor, I would have given you partial credit for thinking in the right context), but you do owe me a for making me think so hard.
      Shawn
    9. Member corradokyd's Avatar
      Jun 4th, 1999
      Baltimore MD
      Corrado
      09-21-2004 10:11 PM #8
      well done. i like seein some sht get done right with busted knuckles...
    10. Member G60 CAB's Avatar
      Oct 25th, 2003
      Denver, CO
      Things with wheels, sometimes upside down
      09-21-2004 10:15 PM #9
      Thats what I did, except I used two dowel pins!
      FJ and Benz project pics on Instagram: G60CAB
      82 500 SEC......Roadhaus
      07 FJ...............Icon CDC w/o sways, 315/70/17s, overland prepped, likes large rocks
      99 M3..............twinscrewed and wallet hungry
    11. Member sdezego's Avatar
      Apr 23rd, 2004
      10-02-2004 05:22 PM #10
      Finally been able to drive her a bit. Man was it a joy. Decided to do the rod bearings while I had the pan off (Pan was damaged from the tow home) and fix a couple of coolant hose issues and such. A new pan was only like $15 from Autotechparts!
      If I could focus for any amount of time, I would be able to build up my ABA
      Shawn
    12. 08-01-2007 03:55 PM #11
      I'm having my supercharger rebuilt by KK at the moment. Dave from KK recommended that it might be a good idea for me to change out the crank bolt.
      When I went to the stealership to get one, they recommended that I also replace the crank pulley as well. Is this really necessary? It's like $150 for one of those suckers.
      -Burt
    13. Member sdezego's Avatar
      Apr 23rd, 2004
      08-01-2007 05:21 PM #12
      That doesn't sound correct.
      It is not a bad idea to change the cog, but if thats what they were quoting you, it's only about $15-20 aftermarket (autotechparts.com). If yours is in perfect shape, there is no real reason to change. The only way to know for sure is to take it off and inspect the keyway.
      Part number listed in first post.
      S
    14. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      08-02-2007 01:21 PM #13
      Interesting! I thought this only happened on TDIs...
      Shame I can't drill straight, otherwise I'd do this too
      Mikki x
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    15. Member sdezego's Avatar
      Apr 23rd, 2004
      08-02-2007 04:24 PM #14
      Quote, originally posted by MikkiJayne »
      Sadly no. It is very common on the G60's. Especially, when the mileage is > 100k miles.
      Too many cycles on the stretch bolt I guess.
    16. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      08-04-2007 12:21 AM #15
      Quote, originally posted by sdezego »
      And its now starting to become common with the 20V's
    17. Member sdezego's Avatar
      Apr 23rd, 2004
      08-04-2007 12:29 AM #16
      You want to know something very peculiar too?
      If you look at the Bentley on an ABA vs a G60 (both use the exact same bolt and cog), you will see that the specs are:
      1.) G60 = 66Ft/lbs + 1/2 turn
      2.) ABA = 66Ft/lbs + 1/4 turn
      Go figure...
      I don't think VW knows/knew wtf
    18. Member jmaddocks's Avatar
      Jan 31st, 2004
      Greater Denver area
      Corrado 16vt, 14 LR4, LX450, 08 GTI, 11 Subaru LGT, 89 Jetta 1.6d HE200, 79 Rabbit, Bigfoot 24SL 4x4
      08-04-2007 01:01 PM #17
      It's almost as if some lowly bolt engineer at VW pulled the specs out of his butt!
    19. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      08-04-2007 05:53 PM #18
      Or manual writer at Bentley Publishers
      The theory with the TDIs is that the rotating mass of the alternator puts a load on the crank during firing cycles at idle (ie crank slows, but the alternator doesn't). The load puts stress on the sprocket and the bolt is the weakest link.
      The fix on the TDI is a one-way clutched alternator pulley which allows the crank to change speed without any inertial load from the alternator (ie the alternator spins freely under its own inertia when the crank slows down).
      This pulley was fitted to 98> TDIs I think, and apparently some VR6s.
      I'm not that surprised that it can happen on the G60, as that has a fair amount of rotating mass too, plus an alternator. Odd that it can happen on the 20V too though?
      Mikki x
    20. Member sdezego's Avatar
      Apr 23rd, 2004
      08-04-2007 06:07 PM #19
      That's is interesting. I have seen the "one way" clutched alternator drive bearings used more and more, but don't think about it in this case.
      Shawn
    21. 11-26-2008 01:57 AM #20
      What a good thread I wiped 2 heads never once thought to check to even see if the key was worn
      My problem was the pully kept getting loose and the timing belt stopped spinning so I thought it just was'nt torqued right
    22. Member swingwing205's Avatar
      Jun 13th, 2001
      Knoxville, TN
      11-29-2008 02:15 PM #21
      Are you saying you think that the bolt @ the crank stretches still more over time, given many cycles? It should be a recommended change out item at certain maintenance intervals then (like for instance, at a timing belt change), esp since this effects other VW engines like the TDI's and 20v's.
      The more I start to think about that, the more I'm thinking it's like "timing out" parts on aircraft (as I'd guess there's no good way to figure out Torque Events on a car, so timing the part out would be the only practical solution...). But, the G60 is a finicky beast, and you do have to kind of look ahead.
      Do you think it's because of the load of the supercharger constantly on the crank then? It couldn't be just the valve drive train load. I've always kind of thought that was possible.
      Modified by swingwing205 at 11:16 AM 11-29-2008
    23. Member sdezego's Avatar
      Apr 23rd, 2004
      11-29-2008 08:12 PM #22
      I personally think it is a little of everything you mention.
      If you look at the failures (and I have inspected quite a few), you can see hoe the fracture of the bolt propagates. Look at the pic above and you can see the fracture which is text book fracture mechanics that originates from too many cycles, stretches, necking, etc..
    24. Member swingwing205's Avatar
      Jun 13th, 2001
      Knoxville, TN
      11-30-2008 12:24 PM #23
      My thoughts too, we're def on the same page.
      The regular 8v's seem immune from this problem, but think about the fact that they have close to nothing to drive, other than the valve drivetrain. The G60's and TDI have all that and both have extra heavy duty appliances to drive, the Supercharger on the G60's and the Injection pump on the TDI's, both of which put some real load on the crank.
      Now, I'm wondering about the 20v's, why they would have so much trouble, as they're doing something very similar to the problem discussed here. Maybe extra heavy valve drivetrain load? I wouldn't think it would be much if any more than the old 16v set up, but I could totally be wrong.
      Well, that settles it. When I do my Timing belt on my G60, I'm changing this crank bolt out as well. Wish me well guys, and hope that this prob isn't already started on my car ( I don't think it is, but...).
    25. Member sdezego's Avatar
      Apr 23rd, 2004
      11-30-2008 05:24 PM #24
      The TDi's and 20v (06a block) uses a larger bolt.
    26. Member sprocket007's Avatar
      Oct 14th, 2002
      Alberta, Canada
      '00 TT,'92PassatG60 Syncro,'90 G60Corrado,'89 Cabriolet,'86 Jetta Coupe,'81 Rabbit,'74&'69Westfalia
      12-01-2008 11:40 AM #25
      When I do the timing belt I change all the engine seals on that side and the crank bolt...you might as well ur there anyway and It really does not take that long.
      Wade
      BSc.N, EMS/FIRE
