VWVortex.com - My VR6 Swap: PICS
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 97
    Thread: My VR6 Swap: PICS
    1. Member TheMoneyPit's Avatar
      Jun 2nd, 2003
      unSAFE NY
      02-19-2005 11:17 PM #1
      UPDATE: Since I have been getting a constant flow of questions reguarding vr6 swaps into mk3s I'll add some advice and a parts list
      First and foremost, Know what your getting into before you start this swap. If you dont even know how to change your oil thent his prob isnt for you. Though the swap is completly plug and play it takes a little bit of knowledge and a good sense of general mechanics.
      The best advice i can give you is to search on vortex. Pretty much every question you have some else has already asked and some else has answered it. This was my first motor swap and before starting it I really knew very little about doing one, but lets just say i spent alot of time searching through archived links and talking to as many people as possible.
      Parts list: Might not be 100% complete
      vr6 motor
      Vr6 throttle cable
      vr6 tranny (no your 8v tranny wont work)
      vr6 Shifting Linkage
      vr6 wiring harness
      Correct ecu for the motor
      vr6 Clutch master cylinder
      vr6 clutch kit and flywheel
      vr6 Exhaust manifold
      Motor mounts
      Vr6 radiator and fan setup
      vr6 Gauge Cluster
      Some good info:
      I would recommend replacing as many parts as possible while doing the swap. Dont do the swap if you dont have any money. Expect to run into problems. Parts that i would recommend replacing when you do it are parts that are easier to replace while the motor is out. IE: Clutch, Waterpump, Timing chains, Acc pulley, Crank seal, Oil cooler gasket, Crack pipe if its in bad condition, and any other seals/gaskets.
      When i did my swap i replaced the following parts for good measure:
      Motor mounts (black forest Stage II kit)
      Upgraded clutch kit
      Crank seal
      Water pump
      Coil pack
      Spark plugs
      Checked timing chains (found that previous owner replaced them)
      Some other tid bits of information.
      Parts that dont need to be changed if you dont want
      -Axels (if your staying 4 lug)
      -Suspension (2.0 stuff will work but vr6 is stiffer)
      -Pedal Cluster (Same cluster)-Only needs to be changed for mk2 vr swap.
      -Brakes(can remain the same, or upgrade to corrado rotors with vr6 calipers)
      -To hook up the MAF: you need the vr cluster, the maf wiper stalk and the maf wiring harness. the harness hooks up from the stalk to the fusebox
      UPDATED WITH MORE INFO:
      Figured i would through this in here. In regards to the clutch pedal.. You do not need to replace it when doing the swap. The part number (1h1 721 321 a) is the same for both 2.0 and vr6. The pedal was designed to work for both. The clutch cable on an aba motor attaches to the top of the pedal. When doing the swap just remove the clutch cable and install the clutch master cylinder. The operating rod that sticks through the firewall to the inside of the car uses a clip in order to secure into the middle of the pedal.
      The pedal for reference
      The more you replace the better...Vw put alot of these upgraded parts on the vr6's for a reason so if you have the money do it right.
      And heres the pictures
      Enjoy and feel free to comment
      Make a mental note of how clean the floor is in my garage day 1 haha
      Well its all finally comming together.... dash is back together, wiring is done inside the car and the motor is bolted up....
      Then Kevin got tired and took a nap
      Special Thanks to
      Uncle Junk and Oh My Vr6
      Modified by TheMoneyPit at 3:33 AM 2-9-2007
      Current Grocery Getter- 2004 Audi 1.8t Quattro, Stage 3 /Current Family Hauler- 2004 VW Passat 1.8t, 4M, 5-speed
      Previous- 2004 VW .:R32 / Previous- 2000 Audi S4 / Previous- 1995 Jetta gl Vr6
    2. Remove Advertisements
      Advertisements
    3. Banned two point o's Avatar
      Jun 30th, 2004
      02-19-2005 11:24 PM #2
      It's a ton of fun in the freezing cold isn't it.
      Awesome job man. [IMG]http://*****************.com/smile/emthup.gif[/IMG] Wat kind of a time span are we looking at here?
    4. Senior Member jhayesvw's Avatar
      Oct 3rd, 2001
      Tucson, AZ
      12' GTI
      02-19-2005 11:41 PM #3
      im curious as to why you removed your dashboard??
      i didnt remove mine when i swapped.
    5. Remove Advertisements
      Advertisements
    6. Banned
      Jun 25th, 2004
      02-19-2005 11:51 PM #4
      Quote, originally posted by jhayesvw »
      I take em out cause it only takes about 2 seconds and you spend less time curled up uncomfortably in the drivers foot well doing wiring
    7. Senior Member jhayesvw's Avatar
      Oct 3rd, 2001
      Tucson, AZ
      12' GTI
      02-19-2005 11:56 PM #5
      Quote, originally posted by ..Countblah.. »
      no offence derek, but
      youre much bigger than me.
      im guessing its to install the harness for the MFA. but that is a steering column harness isnt it. ?
      i dont have one.
    8. Member TheMoneyPit's Avatar
      Jun 2nd, 2003
      unSAFE NY
      02-19-2005 11:56 PM #6
      Quote, originally posted by two point o »
      well the car was away for the winter so i took my time with it.... about 2 months ...
      bingo nothing worse then laying on your back with the seat bracket sticking into you.
    9. 02-20-2005 12:39 AM #7
      this thing wont ever run !! JK I have faith !! better you than me !
    10. Banned reflexbug's Avatar
      Mar 9th, 2003
      02-20-2005 12:47 AM #8
      looks good [IMG]http://*****************.com/smile/emthup.gif[/IMG] I always take the dash out... otherwise, this could happen to you...
    11. 02-20-2005 11:51 AM #9
    12. 02-20-2005 01:46 PM #10
      that must have been a b**** working with that bad lighting but good stuff anyway [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. Member TheMoneyPit's Avatar
      Jun 2nd, 2003
      unSAFE NY
      02-20-2005 09:37 PM #11
      Quote, originally posted by LowRiderVR »
      My camera just happends to suck at night shots....the lighting was halfway decent... It gets the job done
      thanks for the comments everybody
    14. Senior Member -DOOMED-'s Avatar
      Sep 6th, 2004
      Land of Awesome
      '08 Rabbit
      02-20-2005 09:39 PM #12
      good deal man [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. 02-20-2005 09:43 PM #13
      sweet [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      one of these days i'm going to jump on the wagen
    16. 02-20-2005 09:50 PM #14
      nice... I have the same engine hoist!
      2008 BMW 328 Sports Wagon- 6spd manual - for sale
    17. 02-21-2005 11:12 AM #15
      fun little swap... had to get my pose in there in the night shot v-dub stylez. deadline is march 1st... im sure we have a few more long days ahead of us this week. if your gonna do a swap, do it right like DRC and take your time, it will be worth it in the end.
    18. 02-21-2005 06:50 PM #16
      By any chance is this the wrecked car you got the VR6 motor outta?
      After:
      Before Telephone pole:
      Because if so its my old car....lol....i just noticed the yellow neuspeed spark plug wires and It kinda struck me.
    19. Senior Member VDoubleUVR6's Avatar
      Aug 21st, 2001
      CT
      02-21-2005 07:06 PM #17
      [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      B
    20. 02-21-2005 07:09 PM #18
      Quote, originally posted by euronated »
      yeah it is man....he got it from Ant.
      looking good man....March 1st is around the corner you gonna make that deadline you made for yourself...haha [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. 02-21-2005 08:13 PM #19
      Thanks for the info tom.......nice supercharger by the why.......can't wait to hear that bad mammy jammy [IMG]http://*****************.com/smile/emthup.gif[/IMG] and rims too your car is gonna look ill come summer time
    22. 02-21-2005 08:14 PM #20
      thanks bro....all in due time....i'm poor now but it'll be worth it haha
    23. 02-21-2005 08:15 PM #21
      hell yea man......what are you doing with them montes?
    24. Member TheMoneyPit's Avatar
      Jun 2nd, 2003
      unSAFE NY
      02-21-2005 11:26 PM #22
      Andrew....you did quite a number on the car hahahaha everyone that see's it doesnt know how your still alive. I would at least think that you would be missing a foot . Either way... The motor seems sound and we took it all apart and replaced alot of gaskets and seals. The timing chains looked as if they had been replaced at some point.
      TOM..
      As for march 1st... It will be close.. Im waiting on a new crank pulley... and some other parts. If i had a every parts store i needed close by then you bet your ass it would be done....i hate usps!!!
    25. 02-22-2005 07:36 AM #23
      thats awesome man.......good luck with the motor.......it ran like a champ for the whole 5,000 miles i drove it. [IMG]http://*****************.com/smile/emthup.gif[/IMG] thats gonna be one sick jetta gl........x lol
    26. Member Max_O's Avatar
      Dec 23rd, 2003
      Colorado Springs, CO
      11 GTI/07 GTI - Gone: 09 TReg, 06 Pepper S, 06 Jetta, 97 Jetta, 97 Passat, 89 GTI, 85 GTI, 80 Rabbit
      02-22-2005 07:53 AM #24
      Looks good man [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    27. Member
      Nov 30th, 2002
      Berlin, CT
      02-22-2005 09:32 AM #25
      Connor
      Getlow
