VWVortex.com - 2006 Passat Radio Removal Write-Up
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: 2006 Passat Radio Removal Write-Up
    1. 09-13-2005 04:02 PM #1
      Alright well I finally took apart my radio to see what I had to deal with. The new radio's easy to take apart once you know where everything is at. Hope this helps everyone out. Enjoy.
      Stock Radio (No Satellite) Only Single CD, AM, FM ...
      To the left and right of the emergency blinker are two trays. The covers pop off, easy to pop off from bottom. The yellow arrows point to the spots where the cover held in place.
      This is the back of one of the silver tray covers
      Once one or both of the tray covers covers are removed. Take a Flat Screwdriver and pry the molding surrounding the radio. The top of the radio is the easiest to pull off. Work your way down the sides of the radio and the bottom. They whole piece will snap off. The yellow arrows below are where the molding is held in place.
      The radio is then secured by (4) 15 Torx screws. Once the screws are removed the radio slides right out.
      Picture of the wireing harness from behind
      Well that about does it, the radio is very easy to remove and put back together. The wiring is the same as my old VW. So attaching a new radio soudn't be too difficult other than supporting the new radio somehow.
      I hope this helps some people out. Enjoy! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by GTI 1.8T Silverstone at 8:06 PM 9-13-2005
    2. Remove Advertisements
      Advertisements
    3. 09-13-2005 04:54 PM #2
      Quote, originally posted by GTI 1.8T Silverstone »
      You could use this http://enfigpics.com/shopsite_....html or this https://forums.vwvortex.com/zerothread?id=1998437 to support the stereo. I believe they will all fit the Passat....
    4. 09-13-2005 04:56 PM #3
      Nice, do you know of any kit that would fill a hole if I installed a double din sterio. Thanks for the link. Very helpful.
    5. Remove Advertisements
      Advertisements
    6. 09-13-2005 05:00 PM #4
      I don't think they make one yet. From what I've seen people are taking the one from Enfig and cutting the center out to make the DD fit. Here is a link to an install.
      http://www.mk5mods.com/index.php?topic=52.0
    7. 09-13-2005 06:35 PM #5
      That link to mk5 mods is exaclty what I want to do to my car. The same exact unit also. Thanks for the link. Let me know if you find any kits that don't have to be modified. Is the MK5 radio the same as the one in the new passat?
      Modified by GTI 1.8T Silverstone at 10:53 PM 9-13-2005
    8. 09-13-2005 07:49 PM #6
      Cool! Like the first how-to write up on the B6 forum [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    9. 09-13-2005 07:53 PM #7
      It is the same radio and nav unit. Here is a link to the technical details of the stereo. There might be some slight differences but it will have all the info you need on the Factory stereo. Hope this helps.
      https://forums.vwvortex.com/zerothread?id=2111976
      Modified by curraheevw at 4:44 AM 9-14-2005
    10. 09-13-2005 08:44 PM #8
      I wish I'd thought of just taking the front panels off the trays, rather than wrenching them out! Brain power beats brute force again.
    11. 09-14-2005 12:01 AM #9
      How hard do you think it would be to change the veneers on the dash. I would like to order a set of the light maple color they have in europe. do you think the venners are just held in place by double sided tape...
    12. 09-14-2005 12:28 AM #10
      The tray covers pop off along with the emergency blinker cover. The other I am not sure how they are removed. I have not gotten that far. I am sure they are the same thing.
    13. 09-14-2005 01:02 AM #11
      I too would like to replace the dash veneers with light wood. have the Passats been available in Europe long enough for there to be dash replacement parts yet?
    14. 09-18-2005 01:29 PM #12
      Does anyone know if the new Jetta has this same radio. If you do not get any packages.
    15. Member FOXYINAPASSAT's Avatar
      Aug 2nd, 2004
      Santa Barbara
      CC VR6 4MOTION & PASSAT VR6
      09-18-2005 11:57 PM #13
      nice I enjoyed seeing that, i see your in orange county... I am in Irvine.
    16. 09-19-2005 04:35 PM #14
      maybe this for the adapter...
    17. 09-19-2005 04:38 PM #15
      Yeah, I just ordered that, but it is on backorder, I just found out.
    18. 02-27-2006 07:17 PM #16
      Why isn't this in the DIY? The MK5 Forum has a ton of DIY, we have zilch.
    19. 12-02-2006 11:49 AM #17
      The silver tray fronts are easiest/safest to remove if you pry the bottom up a little with a putty knife, and then push up with your hand. If you pull straight forward, you might bend the little clips.
    20. 12-06-2006 01:54 PM #18
      Does anyone have any good stereo recommendations that comes close to fitting in the hole? I'm looking for a stereo with Sirius Satellite radio in it that fits well. I've never done anything like this before, but it seems fairly straightforward.
    21. 12-06-2006 02:19 PM #19
      Were you able to measure how deep the hole behind the radio is? I am trying to plan what I can fit back there
    22. 12-12-2006 12:39 PM #20
      Anyone have any suggestions?
    23. Member MCTB's Avatar
      Dec 30th, 2005
      That's totally inappropriate. It's lewd, lascivious, salacious, outrageous!
      '18 VW Alltrack, '15 Outback Limited
      12-26-2007 09:12 PM #21
      can i put the 6 disc cd/ mp3/ radio out of my jetta into a passat? if so, im going to swap them out in the parking lot if i trade it in...
    24. Member M3Tech's Avatar
      Jan 26th, 2007
      Ft Lauderdale, FL
      2012 M3/2010 CC
      12-27-2007 09:07 AM #22
      Quote, originally posted by morecarsthanbrains »
      Yes... just make sure that you do not turn either car ON while the Passenger Airbag indicator light switch is disconnected while you are swapping radios. This switch is located above the OEM HU in the Jetta and below the OEM HU in the Passat. Otherwise this will trigger the Airbag malfunction indicator ON in the instrument panel.
      If you can do the swap without unplugging those switches -possible but cumbersome- do it... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    25. 12-27-2007 11:49 AM #23
      Metra makes 2 install kits:
      99-9011 : uses a plastic ISO-mount system.
      99-9010 (i think that is the part number): requires to use the metal radio sleeve.
      Also, the 9011 is a grainy textured finish (looks cheesy imo) & the other one is a smooth finish
    26. 10-25-2010 05:46 PM #24
      the pics dont show please fix or where can i find another guide
    27. Member v b chil-n's Avatar
      Nov 6th, 2000
      Florida
      03 Jetta, 06 Passat 3.6, 11 Tiguan SEL
      10-25-2010 11:35 PM #25
      Quote Originally Posted by Passat143 View Post
      lol this post is almost 5yrs old.. check here
