VWVortex.com - SMT-6 Additional Injector fueling setup?
    Results 1 to 5 of 5
    Thread: SMT-6 Additional Injector fueling setup?
      Jan 19th, 2002
      Victoria, BC
      '91 B3 16vTurbo Passat
      10-16-2005 12:20 PM #1
      I am going to use Kinetics AIC piece before my throttle body with two 42# injectors. The problem I am running into is the amount of room I have for the fueling setup. Not very much room even after I moved the ECU wiring harness out of the way. I was looking at using the CNC'd injector bosses from SDS, top hat only, because they are quite short. According to SDS's website "The tops are threaded for 1/8 NPT fitting" this size threading sounds a little small for a fuel line.
      Looking for suggestions on how to tie into my existing fuel line? Size and type of recommended fuel line? How to tie onto the injectors themselves?
    2. Remove Advertisements
      Advertisements
    3. 10-16-2005 07:03 PM #2
      the additional injector doesnt need to be right by the throttle body , it can be upto 10 inches away as long as you have a good atomization angle.
    4. Member
      Jan 19th, 2002
      Victoria, BC
      10-16-2005 09:08 PM #3
      On hindsight I might have done as you suggested except this is a really clean install. Any suggestions on how to do the fuel lines to these injectors?
    5. Remove Advertisements
      Advertisements
    6. Banned
      Feb 26th, 2005
      10-16-2005 09:13 PM #4
      I guess I could mill out a TB adaptor plate to add some injectors after the TB.
      Jan 19th, 2002
      Victoria, BC
      10-16-2005 09:51 PM #5
      No, I'm stubborn! I plan on still using the Kinetics piece. What I am really looking for is suggestions on how to hook up fuel lines to the injectors.
