VWVortex.com - 2001 jetta mass airflow sensor
    Results 1 to 14 of 14
    Thread: 2001 jetta mass airflow sensor
    1. Semi-n00b
      Jun 25th, 2006
      06-25-2006 09:59 PM #1
      hi all,
      new to the forum, but not to vw's. i usually do basic maint. myself, and am getting bolder as problems arise.
      code p1152 i believe indicates a problem with the mass airflow sensor or possibbly a vacume leak. my question is, can the mass airflow sensor be clean like on toyotas or does it need replaced?
      thanks,
      mark
    2. Remove Advertisements
      Advertisements
    3. Member VAGolfKart's Avatar
      Jun 14th, 2006
      San Diego, CA
      Mk4 Golf 1.8T
      06-25-2006 10:03 PM #2
      There's a section on how to clean it in the 1.8T forum FAQ -
      https://forums.vwvortex.com/zer...36607
      seems pretty easy
      Helicopter Light = back on
    4. Forum Sponsor
      Jan 12th, 2003
      Vancouver, BC
      1.8T Jetta 2001
      06-26-2006 12:18 AM #3
      Your dealership should be replacing this part for you for free.
      They have a special extended warranty on it, rather than a recall.
    5. Remove Advertisements
      Advertisements
    6. Semi-n00b
      Jun 25th, 2006
      06-26-2006 03:15 PM #4
      thanks for the link... this might be a dumb question, but i'll ask any way. would the maf be the same for the 1.8t and the regular 2.0?
    7. Semi-n00b
      Jun 25th, 2006
      06-26-2006 03:16 PM #5
      yeah... about that. i got the car from one of those used car lots. bought it "as is". they don't want to do anything.
      thanks though.
    8. Banned
      Mar 22nd, 2006
      06-26-2006 03:16 PM #6
      Quote, originally posted by metricmetal »
      i think its possible, i've seen people do it but dont quote me on it, i have a MAF from an Audi TT and never had problems
    9. 06-26-2006 03:31 PM #7
      I didn't buy my 2001 jetta from a VW dealer...I was having MAF issues and I just called the local VW dealer and all I had to do was let them do the diagnostic test to prove the MAF was bad. Then they replaced it for free!
    10. Semi-n00b
      Jun 25th, 2006
      06-27-2006 03:40 PM #8
      thanks again everyone. i bought a can of crc today and sprayed the heck out of the maf sensor. now i have to find a place to reset the codes and see how i did.
      thanks again,
      mark
    11. Member jireland's Avatar
      Nov 23rd, 2004
      Maine
      B5 V6 Passat / Mk4 Golf / Mk3 Jetta Woflie / MK2 Jetta Wolfie
      06-27-2006 03:46 PM #9
      from what i've heard you may still want to replace it eventualy.. the MAF are prone to this problem ( early revisions anyway ) same with the coil packs ..
    12. Senior Member mujjuman's Avatar
      Jul 29th, 2004
      New York
      2001 VW Jetta VR6, 2006 VW Jetta 2.5
      06-27-2006 04:01 PM #10
      Quote, originally posted by jireland »
      x2, its def your MAF sensor... just replace it
      mujjuman
    13. Member NashGTI's Avatar
      Mar 7th, 2006
      Nashville, TN
      04 Expedition, 72 Pontiac Catalina, 12 Fusion V6, 72 Yamaha XS-2, 06 Speed Triple
      06-27-2006 04:30 PM #11
      seven years seventy thousand miles extended warranty on 1.8t and 2.0 mass airflow meters, regardless of owner.
      they are the same exact part, down to the part number. also, the TDI MAF is also the same part,......but a different part number and excluded from the recall. kinda like the earlier beetle and passat hazard switches are the same part (except for the cover) as the Jetta/GTI hazard switches, but again are not subject to recall despite going bad just as often.
    14. Member
      Feb 4th, 2005
      Milford
      B7a4 & EVO9
      06-27-2006 04:34 PM #12
      can you clean the MAF using that same technique for the vr6?
    15. Semi-n00b
      Jun 25th, 2006
      06-30-2006 12:20 PM #13
      thanks for the info. the cleaning didn't work so i went to a local dealer and he verified what you said. 7 yr or 70,000 mile extension on this part.
      thanks!!!!!!!!
    16. Banned
      Nov 24th, 2001
      06-30-2006 12:22 PM #14
      thanks!!!!!!!!
      Cleaning does NOT work....it never does. the cost is so low, it's cheaper, and easier to just replace the MAF. $40 is not that much.
