VWVortex.com - Project Build: sc2020
    Page 11 of 28 FirstFirst ... 78910111213141521 ... LastLast
    Results 251 to 275 of 697
    Thread: Project Build: sc2020
    1. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      11-20-2009 02:13 PM #251
      Flywheel and clutch install. I have a template to make the lower trans dust shield, since the Mk4 oil pan bolts to the Trans. I guess if I had a Schrick oil pan, I would weld tabs for the trans.
      VW Lug wrench comes through again for clutch lineup on the 02m, with a couple of wraps of metal tape
    2. Remove Advertisements
      Advertisements
    3. Member sdezego's Avatar
      Apr 23rd, 2004
      11-20-2009 02:27 PM #252
      Final Trans assembly with peloquin and paint.
      Proper Diff Preload shim installed
      Self Etching Primer
      Modified by sdezego at 2:33 PM 11-20-2009
    4. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro, 2014 Audi RS5
      11-20-2009 03:47 PM #253
      Nice work! Good to see you updating your thread.
    5. Remove Advertisements
      Advertisements
    6. Member sdezego's Avatar
      Apr 23rd, 2004
      11-20-2009 04:34 PM #254
      If I didn't mention that your thread helped motivate me to get back on track I would be lying
    7. Member bigtoy302's Avatar
      Apr 26th, 2006
      Eugene, OR
      Mrk4 Gti 1.8t
      11-22-2009 11:51 PM #255
      Hurry up already. I am dying of old age. I want to see this thing done.
    8. Member sdezego's Avatar
      Apr 23rd, 2004
      11-23-2009 11:14 AM #256
      Quote, originally posted by bigtoy302 »
      My daughter doubled in age since I started this project, LOL
      I am working on the axle lengths (remember I am switching to the + suspension).
      There is a lot of ambiguity in this regard, so I took my own measurements and calculations. I may wait until I get my subframe, control arms, etc finished and bolt everything together to measure the distances from the Trans Flanges to the wheel hub inner flanges. Here is a thread I have added info to -> https://forums.vwvortex.com/zerothread?id=3610564, but I will post the specifics here.
      Measurements from Bellhousing Face to CV Flange:
      02a - (NOTE: 3mm CV flange Recess taken into account)
      D/S --------------- P/S
      206.55mm ------ 37.7mm
      Total Diff Width -Flange to Flange = 244.25mm
      02m
      D/S ---------- P/S
      242.24mm ------ 57.8mm
      Total Diff Width -Flange to Flange = 300.04mm
      Total Diff Width Differences and thus net axle length difference = 55.79mm (2.2")
      Based on each Flange Measurements:
      02m D/S Axle = -20.1mm (-.79")
      02m P/S Axle = -35.69mm (-1.41")
      These measurements, I am pretty confident with. The tricky part is measuring the axle lengths in comparison, since the inner CV's can move in and out and throw off measurements as well as the fact that 02m inner CV are Tripods, so a direct comparison is a bit difficult to be precise.
      Here is what I have for axle measurements (Flange to Bearing)
      Stock Corrado Vr (+ suspension):
      27 7/8" - 18 5/8"
      Calculated Lengths using my above calcs based on Vr + axles:
      27" and 17 1/4"
      Nate's Reported Measurements:
      26 13/16" and 16 1/2"
      Blk95VR6 (verifying):
      27 5/16" and 16 3/4"
      Rycou (DSS axles) (just purchased and just measured):
      26 7/8" and 17 5/8"
      So, I am pretty confident that ~27" on the P/S Axle is correct.
      But, you can see the discrepancies on the D/S axle. I can easily see that a measurement can be 1/4" off due to the inner CV position, but this is more.
      FWIW my stock Beetle Turbo S short axle is 17 3/8" which is pretty darn close if not usable as is. P/S is 28 5/8", so it def needs to be shortened.
    9. Member bigtoy302's Avatar
      Apr 26th, 2006
      Eugene, OR
      Mrk4 Gti 1.8t
      11-23-2009 07:11 PM #257
      When I figured my axle lengths I had all the front suspension on and weight on the vehicle. I cut the shafts in half with the cv still on slid both halves of the shafts in and overlapped the cut ends ends. I cut off how ever much hung over and then welded them up. I ended up taking off 1.5" off the long side and .5 off the short side. This was NON + suspension.
    10. Member sdezego's Avatar
      Apr 23rd, 2004
      11-23-2009 10:54 PM #258
      Thanks, that is pretty close to my calcs above (1.41" and .79").
      Regardless whether it is plus or non-plus, the amount the axles must be shortened will be the same. The final lengths (plus or non-plus) will obviously be different.
      Yea, I will probably wait until the last minute to shorten them and measure the actual axle length need (Flange to bearing) with the car's weight on the suspension.
      Lowering the car will definitely change things slightly and I know that being "EXACT" not that critical as there is room for forgiveness with the inner CV.
    11. Member leebro61's Avatar
      Nov 7th, 2001
      11-26-2009 10:14 PM #259
      Looks amazing so far, can't wait to see the last few pieces come together
    12. Member G60ING's Avatar
      Jun 27th, 2000
      Annapolis Area MD
      2010 3.6 4-Motion CC, 1990 G60/TDI/R36 Corrado
      11-27-2009 09:04 AM #260
      Nice Progress [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    13. Member sdezego's Avatar
      Apr 23rd, 2004
      12-07-2009 04:23 PM #261
      Thanks! Motor and Trans are one.
      Started on the wiring too. I acquired a brand new AWP harness with my orig trade/swap and this harness is about 80% of what I need for megasquirt, so I don't have to build from scratch. I felt kind of dirt though cutting off the factory ECu plugs-
      The factory convoluted tubing and connectors are not my favorite, but since I am using a lot of the harness in tact, I am fine with it.
      Here is a sample of one of the plugs that needed to be changed. Since the pin sizes were different for the 2 coolant plugs, I could not just repin to the new housing.
    14. Member Forty-six and 2's Avatar
      Jan 21st, 2007
      Csprings
      '01 TT 225Q '84 Porsche 944
      12-07-2009 06:14 PM #262
      Quote, originally posted by sdezego »
      I need to learn how to do this badly. It's coming along nicely.
      Carbon fiber ME2.2lt Mkl TT coming soon...
      .:46and2:.
    15. Member V-TEC this!!!'s Avatar
      May 4th, 2003
      London, Ont/Krakow, PL
      2002 Jetta TDi, 1990 G60 Corrado
      12-07-2009 06:27 PM #263
      Hey, I modified my shroud to accept my spal fan the same way. Except I didnt weld studs to the shroud, I made 4 spacers and I used nuts and bolts. I cnc'd my shroud and made a press fit for the fan.
      Looking really good, cant wait to see it done.
      GL, Mike
    16. Member deth_core's Avatar
      Jul 12th, 2002
      WA
      1990 Corrado G60
      12-07-2009 09:11 PM #264
      ...that makes her 20 now?
    17. Member sdezego's Avatar
      Apr 23rd, 2004
      12-07-2009 11:39 PM #265
      Quote, originally posted by Forty-six and 2 »
      This was my first 02m and I can say that it is a hundred times easier to work on than the 020 and 02a!
      Quote, originally posted by deth_core »
      it feels like it's been 10 years.. When you are driving your Corrado daily and everything is tip top, it's hard to rush and tear it apart
      Seriously though, if you see all of the custom brkts, fab work etc for the motor alone (I have not really posted those details), you can see why it has been a long time coming. I spent last weekend just prepping and painting all of the brkts, mounts and misc parts.. Good progress the last week though [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      ..she said she would help paint it I let her ride her motorcycle
      Modified by sdezego at 11:42 PM 12-7-2009
    18. Member sdezego's Avatar
      Apr 23rd, 2004
      12-07-2009 11:53 PM #266
      Shiny stuff
    19. Member sdezego's Avatar
      Apr 23rd, 2004
      12-14-2009 11:45 AM #267
      Some pics showing a lot of the custom brackerty I made. Most of which will be completely hidden so I am not sure why I spent so much time prepping and painting (outside of the rear alt mount setup).
      As Always, click for larger pics ->
      Custom front support for custom Mk4 PS brkt to run all on serpentine belt
      Custom Rear mount Mk4 Alt support
      Custom brkt for using G60 Serp tensioner arm in my single belt setup
      Front view of above
      Side view of PS mount
    20. Member sdezego's Avatar
      Apr 23rd, 2004
      12-14-2009 11:50 AM #268
      Also, The crank bolt was never installed yet as I was trying to decide whether to use the 6pt or 12 pt 16v crank bolt. After researching and acquiring both, the 6pt is actually 10.9 grade and the 12 pt is 8.8.
      Anyone who knows the 058 block/crank knows the bolt is always a problem and especially so on the G60, which is the reason for my over obsession. There is a bit more at stake here than on the non-interference 8v.
      Anyway, after searching, I just found what I think may be an ARP solution from a completely different application. Even though my cog is pinned (earlier in this thread), extra insurance is never a bad thing. ...granted a $35 extra insurance
      I will post up the details when the ARP hardware arrives in the next 7-10 days.
    21. Member Forty-six and 2's Avatar
      Jan 21st, 2007
      Csprings
      12-14-2009 01:35 PM #269
      I hope you make the right decision on the crank bolt, since I will be using the same one that you decide on.
      Nice fab work on the brackets. [IMG]http://*****************.com/smile/emthup.gif[/IMG] If you can see it or not, it still needs to be pretty.
      Oh, and where is the excitement in this thread? I have been patiently waiting...sukka
      .:46and2:.
    22. Member sdezego's Avatar
      Apr 23rd, 2004
      12-14-2009 03:06 PM #270
      haha, I knew you were going to post that
    23. Member TheBurninator's Avatar
      Jan 7th, 2009
      Colorado
      Corrado, Mk1, Mk3, CC
      12-14-2009 03:58 PM #271
      Ah the 4 year engine build by Shawn
      So when is this going to make its way INTO a corrado???
      Quote Originally Posted by ein View Post
      * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    24. Member TheBurninator's Avatar
      Jan 7th, 2009
      Colorado
      12-14-2009 04:41 PM #272
      By this time next year, at least Hopefully soon (my soon anyway) ..
      If old age gives me that much patience I don't want to get old
    25. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      12-14-2009 11:38 PM #273
      Looks good Shawn. I appreciate the attention to detail and OCD! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    26. Member sdezego's Avatar
      Apr 23rd, 2004
      01-07-2010 11:34 AM #274
      Thanks!
      Crank Bolt Dilemma solved:
      Full details in a post I made in the 16v Forum (https://forums.vwvortex.com/zerothread?id=4688843, but recap is below.
      We all know the 058 block/crank bolt fails, so In my over-obsession I was searching on the best bolt to use for this motor, since there is a lot at stake.
      You may know that VW used two different bolts over the years on 16v's (possibly 3 if you look in the Bentley, but I will ignore since I have no info on the 3rd other than torque specs). There was a 6pt bolt which was 46mm in length and used a 7mm thick washer, and the later 12 pt bolt which was 39mm and used no washer.
      I bought them both from VW and here are some facts:
      - Thread and pitch are 14mm x 1.5
      - The 6pt is 10.9 grade @ 46mm
      - The 12 pt is 8.8 grade @ 39mm
      - 8vs are 10.9 FYI and shorter of course @ 33mm
      - Diesels and 06a blocks use a larger diameter bolt (16mm and ARP now makes a solution).
      Note: (46mm 6pt bolt - 7mm washer = 39mm 12pt)
      Here are the tq specs:
      Quote, originally posted by 206danebmx »
      This is exactly what the bentley says:
      6 sided bolt with washer---137 lb-ft
      Hex head bolt with washer--111 lb-ft
      12 sided bolt with collar (no washer)--66 lb-ft + 1/2 turn
      So, I started searching high and low for a hardened Stud and aircraft style nut, but was hard at finding what I wanted. I started looking through ARP's catalog to cross reference something and much to my surprise, I found two ARP possibilities.
      1.) Mitsu - 2L (4G63) - 14mx1.5 x 1.525" (38.7mm) - ARP#207-2501
      2.) Ford Duratec (1.8 & 2L) - - 14mx1.5 x 1.735" (44.1mm) - ARP#251-2501
      They both come with a hardened 1/4" (6.35mm) washer which we would not use in either case because it is too large in diam.
      So, I ordered #2 becuase it is longer (much like the PL bolt and I figured I could use some std hardened washer to take up some of the length and still end up with more thread bite in the crank. Note: The 6pt 46mm factory bolt is just about 1-2mm too long w/o using the 7mm washer and just starts to bottom out in the ABA crank as it makes contact, but could vary from crank to crank.
      So, you can see that #2 above looks like it is a pretty darn good match when using the washer (and poss #1 if w/o the washer if the shoulder is large enough).
      I received the bolt and here are the deets.
      Perfect length, perfect thread, but the head was unfortunately too big. Now, this could still be used as is, but you would have no way of getting the harmonic balancer on/off (not too good). So, I went up to the shop and threw it up on the lathe to trim the bolt head down a tad so that it fits through the Balancer hole.
      Looks like it is now a winner. You can either use the thick stock 6 sided 16v washer with it, or get a thinner 14mm one from the hardware store which is what I did. This will actually give more threads to the crank which was no prob for my ABA crank.
      Pics (click for larger image):
      in comparison to the stock PL 6 sided bolts that uses the thick washer
      Head a tad too big
      Shaved a tad down on the lathe
      Did someone say OCD?
    27. Member sdezego's Avatar
      Apr 23rd, 2004
      01-07-2010 11:40 AM #275
      Also, for reference:
      ARP bolts are 200,000 PSI bolts which puts them at a 12.9 hardness and is impossible to find our size bolt in that spec. I wasn't even able to source a 10.9 bolt outside of the factory VW in a few hours of searching.
      Also, if you are the engineering type and care to compare bolt strengths, here you go:
      http://www.boltdepot.com/faste....aspx
      Modified by sdezego at 11:42 AM 1-7-2010
