VWVortex.com - How to Reset Automatic Transmission
    Page 2 of 2 FirstFirst 12
    Results 26 to 42 of 42
    Thread: How to Reset Automatic Transmission
    1. Member PBWB's Avatar
      Sep 12th, 2004
      NoVA
      97 GTI VR, 98 ABA-T, 13 DE GTI, 13 Touareg TDI Executive Edition
      11-08-2005 01:41 PM #26
      im interested in this too
      -Apple
      Articulated Speed Solutions FTW
      Quote Originally Posted by slcturbo View Post
      I dont care what you or anyone else "thinks" they have done. We're all just racing for fun on here whether you run 9's or 17's.
      Aug 14th, 2001
      Europe
      2016 GOLF 1.4 TSI 125hp 7speed DSG
      11-09-2005 10:45 PM #27
      the best way to play with tranny is to recode transmission with vag-com.look at my thread.
      https://forums.vwvortex.com/zerothread?id=2063606
    4. 12-18-2005 07:00 AM #28
      is there a procedure like this for MK3?
    5. Member sworksguy's Avatar
      Apr 25th, 2002
      NC
      2002 VW 337
      01-02-2006 01:26 PM #29
      I did the "tap twice" step with our '00 VR6 Jetta 4spd, and all I can say is, "THANK YOU!" to those who figured this out!
      The car FINALLY works like I expeted it to, when we got it 5 years ago!
    6. 01-06-2006 05:23 PM #30
      Now, if I put my car into "sport" mode, and want to change it back to "Ecconomy" or "Normal" mode, how would I do that??
      Just asking in case I have to make another 5 hour road trip and don't want to waste gas.
      Thanx all.
    7. 02-14-2006 02:08 AM #31
      I think VW has complicated things. I've seen many cars (OLDER cars too) with the basic, Econo and Power mode (or Normal or Power Mode) switches. Why didn't they just do that??? All this programming with Adaptive tranny etc... what a nightmare. AND they don't tell you about it in the manual. There are times i was to drive slow, it should be just a flick of a button.
    8. 02-18-2006 01:50 AM #32
      95 Golf 2.0 4dr. i've been having this transmission problem which when i accerate to 3000rpm, it jumps to 4000. i tried the method it seems work~ i tried the sport mode, cant' tell if it kicks. going to have the golf checked tomorrow. first VW car. looking forward~
    9. 02-21-2006 08:37 PM #33
      All I can say is THANK YOU SO MUCH! Everyone with a MKIV Auto needs to know about this. Pushing the throttle 2 times didnt do anything, but the 20 seconds did. I didn't know my 2.0 could even go like that! Thank you so much, that has put a massive smile on my face.
    10. 03-08-2006 12:56 AM #34
      I did this procedure on my '03 Tip. I use tip 99% of the time.
      Am I imagining better faster smoother shifts ? (20 sec reset)
    11. 12-13-2011 03:31 PM #35
      I wonder the 20sec would work on my 2000 golf turbo?
      Jan 4th, 2007
      MA
      2004 Jetta GLS 1.8T
      12-15-2011 04:49 PM #36
      i will try this too and see what happens.
      Quote Originally Posted by Petercar View Post
    13. Member VincewagenR32's Avatar
      Nov 6th, 2010
      Turnbull Canyon, Hacienda Heights, CA
      MKIV R32-RS, 05 CTS
      06-27-2013 08:45 PM #37
      just bumping this for knowledge =)
      "A genius is not measured by what he knows, but with what he can figure out with what he already knows."
      Quote Originally Posted by power_mind View Post
      Also, remember that you can throw the whole parts bin at the car, you can even pick and choose, but the best modification is to tighten the loose nut behind the wheel.
      Instagram : Visualblurr
    14. Member CoolAirVw's Avatar
      Mar 8th, 2007
      Kansas City Missouri
      07-01-2013 08:36 AM #38
      Quote Originally Posted by Thaya View Post
      walk out there and try it
      Check out my youtube channel --->https://www.youtube.com/channel/UCpJ..._as=subscriber
      Check out my website -->www.KansasCityTdi.com
    15. 10-23-2014 04:15 AM #39
      Question:
      Does this proceedure also apply to a 1999 passat 1.8t, with tiptronic trans :
      Does the 99 passat have the MK4 trans ?
    16. 11-07-2014 02:51 PM #40
      I just did this on my 05 Jetta TDI which has been shifting odd since I bought from my sister. She never had a problem so hopefully this takes care of the "missed" shifts, slamming into gear, coming out of OD at 76mph, etc. No codes either!! I will find out on the drive home!
    17. Banned
      Jun 27th, 2014
      suffolk longisland ny
      08-05-2015 01:00 PM #41
      good to know
