VWVortex.com - ELECTRONIC THROTTLE IN MK2 QUESTION - HAS ANYONE DONE THIS?
    Results 1 to 11 of 11
    Thread: ELECTRONIC THROTTLE IN MK2 QUESTION - HAS ANYONE DONE THIS?
    1. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      MKII GTI TDI, MKII Jetta TDI, Corrado TDI, 89 Coupe, 89 Golf, 86 Golf, 98 Beetle TDI, 2011 Golf TDI
      05-21-2007 01:47 PM #1
      I AM INSTALLING A TDI IN MY MK2 & WOULD LIKE TO KNOW IF ANYONE HAS INSTALLED THE THROTTLE POSITION SENSER IN AN MK2 WITH A CORRADO PEDAL ASSEMBLY. IF SO - HOW DID YOU DO IT?
      THIS CAR WILL BE USING THE ELECTRONIC THROTLE. I JUST HAVN'T HAD THE TIME TO TRY TO FIGURE OUT HOW TO INSTALL IT.
      ANY HELP WOULD BE GREAT.
      THANKS
    2. Remove Advertisements
      Advertisements
    3. 05-21-2007 09:54 PM #2
      mount the DBW pedal in the Corrado pedal assembly, it works, its easy and likely the best solution.
    4. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      05-22-2007 10:38 AM #3
      do you mean like this? i did that last night & it was easy & it did work well.
      hack out pieces of the corrodo pedal assy & weld in mount for throttle. drill hole in pedal & epoxy bolt in to capture cable end.
      and i like these huge pictures! and if someone can't yet appreciate them..... maybe someday thry can afford a monitor big enough to. they are great! and you can see all the detail..... except in the blurry pics..... sorry bout that.
    5. Remove Advertisements
      Advertisements
    6. 05-22-2007 10:51 AM #4
      I was thinking a bit more like this:
      Quote, originally posted by [email protected] »
      Next up, is the corrado g60 pedal cluster with the 1.8t gas pedal fabricated to fit. I needed the g60 pedal cluster for the hydraulic clutch, and I also needed the 1.8t gas pedal for the conversion from drive-by-cable to drive-by-wire. The 1.8t gas pedal wouldn't mount up to the g60 cluster, so we had to cut off the mounting plate from the 1.8t pedal cluster. Then we cut it to fit properly on the g60 cluster and then welded it on.
      Wa la, g60 pedal cluster with the 1.8t gas pedal
      But what you did works too.
    7. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      05-22-2007 11:02 AM #5
      interesting...... that was quite an interesting throttle pedal... mk4? my mk3 unit wasn't nearly that nice to get to fit. juat the sensor & it's cable mounted to a cruddy little bracket that i chopped up to attach to the pedal since the mk3 pedal didn't clear the firewall right. good to see.
    8. 05-22-2007 11:19 AM #6
      yes the one in my is from a Mk4, your Mk3 was DBW
    9. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      05-22-2007 11:26 AM #7
      it sure does. it's a 1998 TDI.... in a 1986 golf! he he this could be fun. & not to sound like an idiot...... but what does DBW stand for?
    10. 05-23-2007 12:40 PM #8
      DBW = Drive By Wire
      It's what all the cars since 2000 have been using. Electric throttle pedal instead of a direct cable link to the throttle body.
    11. Awaiting Email Confirmation
      Sep 3rd, 2003
      05-25-2007 12:11 PM #9
      i did my pedal just like u did on my swap it works great
      nice work
    12. Senior Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '17 R
      12-10-2013 07:05 PM #11
      Anyone have these pics?
      Sent from my SPH-L720 using Tapatalk
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
