VWVortex.com - 1986 Golf Diesel TDI Swap
    Results 1 to 8 of 8
    Thread: 1986 Golf Diesel TDI Swap
    1. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      MKII GTI TDI, MKII Jetta TDI, Corrado TDI, 89 Coupe, 89 Golf, 86 Golf, 98 Beetle TDI, 2011 Golf TDI
      05-21-2007 04:20 PM #1
      Here are the vids of it in action after the TDI swap was complete:
      Lifted MKII Golf Diesel TDI Conversion Offroad Videos
      Monday 5-14-07: Clutch Fails
      calls made throughout the week.
      Friday 5-18-07: i met Donald (Goat) @ 6:30 & the descidion was made.
      Saturday - swap is on!!!
      This car is a bone - stock 1986 Golf Diesel that i picked up off craigslist several months ago & swapped passat suspension & a hitch onto.......
      getting the TDI out of a donor mk3 jetta.
      The jetta is getting a 1.6 Diesel from a donor mk2!!!
      here goes!
      And yes..... - that's a 1.6l in an mk3!!!!!
      and you might have noticed the assortment of corrado parts here as well.
      and here are the 2 cars monday morning.
      a 1.9 TDI MK2 Golf
      And A 1998 Jetta 1.6 Diesel
      so, i'm just glad to have fixed the bad clutch issue & maybe a little glad to have doubled the power too
      and it's note totally done yet..... still need to figure out the throttle.
    2. Remove Advertisements
      Advertisements
      Aug 5th, 2003
      87 GTI 1.8T
      05-21-2007 06:51 PM #2
      please resize your pictures, looks like fun
      '87 GTI 1.8t, '98 Dakota 4x4, '88 Shadow VT800C
      '98 Legacy EJ22, '03 20th GTI #2100, '96 Ranger 4x2, '01 TT 180Q, '98 Ranger 4x4, '01 Catera, '90 GLI 16vT, '94 850 Turbo, '90 Golf, '89 Golf, '90 Mustang LX, '91 Jetta, '88 9000S, '86 Jetta, '91 Continental
    4. 09-24-2007 04:55 PM #3
      please more info! you made it loook tooo easy getting the tdi into the mk2, thats what i am planning on doing and would love some pointers
    5. Remove Advertisements
      Advertisements
    6. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      10-17-2007 05:26 PM #4
      I have sone several motor swaps & once you do one it's funny how easy it gets.
      1: try to get a whole donor car... or at least the entire wiring harness & transmission with it if it's a cable shift unit.
      2: use an interior wiring harness from a 1989 or newer mk2 - it will plug in to the mk3 fuse block
      3: get a corrado shift box (drill 4 holes to install it... really easy)
      4: get a corrado pedal assembly... will need to be modded - see
      https://forums.vwvortex.com/zerothread?id=3247319
      or get a passat TDI pedal assembly - should fit from what i have heard - i just couldn't get my hands on one.
      5: don't use a cherry picker - it's a wast of time... just remove the bumper, frille, rad support, rad, & subframe & drop the motor onto a furnature dolly or wheel dolly & then undo the rear mounts & roll that baby away.
      6: if you are insane like me & want lots of ground clearance & a fat intercooler & a mk3 radiator & a good place to mount a skidplate you will want my latest creation:
      https://forums.vwvortex.com/zerothread?id=3365595
      7: & then with some special strut work it can clear 27x8.5r14 tires. i will have to post some pics of this later. - but that's only if you have a desire for 9.5" of ground clearance
    7. 10-22-2007 09:58 AM #5
      you have to post pics of this thing all jacked up!
    8. Member FrankenCar's Avatar
      Dec 1st, 2005
      Dixon, Ca
      10-22-2007 10:30 AM #6
      Here are pics of it all jacked up. on fat mud tires!
      https://forums.vwvortex.com/zerothread?id=3500488
    9. 10-22-2007 12:50 PM #7
      hahahah you are my hero ! that is sooooo sick!
    10. 04-10-2016 12:47 PM #8
      I'm putting a 1.9l tdi engine in my golf 2 1.6l petrol engine got any advise
      Sent from my SM-G930F using Tapatalk
